[fusion-commits] r1681 - trunk/lib
svn_fusion at osgeo.org
Mon Nov 24 15:53:59 EST 2008
Author: madair
Date: 2008-11-24 15:53:58 -0500 (Mon, 24 Nov 2008)
New Revision: 1681
trunk/lib/ApplicationDefinition.js
trunk/lib/fusion.js
closes #155: also break execution thread if session parameter is supplied
Modified: trunk/lib/ApplicationDefinition.js
--- trunk/lib/ApplicationDefinition.js 2008-11-20 20:25:23 UTC (rev 1680)
+++ trunk/lib/ApplicationDefinition.js 2008-11-24 20:53:58 UTC (rev 1681)
@@ -123,10 +123,14 @@
OpenLayers.Function.bind(this.getAppDefCB, this));
} else {
+ //these need to be called via setTimeout so that the execution thread
+ //is broken in IE and so that the ApplicationDefinition constructor
+ //will return a valid object to Fusion in loadConfig before the loadState
+ //gets incremented.
if (!this.sessionId) {
- window.setTimeout(OpenLayers.Function.bind(this.delayedDispatch,this),50);
+ window.setTimeout(OpenLayers.Function.bind(this.delayedDispatch,this),5);
} else {
- this.getAppDef();
+ window.setTimeout(OpenLayers.Function.bind(this.getAppDef,this),5);
return true;
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js 2008-11-20 20:25:23 UTC (rev 1680)
+++ trunk/lib/fusion.js 2008-11-24 20:53:58 UTC (rev 1681)
@@ -320,8 +320,13 @@
break;
case this.LOAD_COMPLETE:
//console.log('load complete');
- this.applicationDefinition.create();
- this.triggerEvent(Fusion.Event.FUSION_INITIALIZED);
+ if (this.applicationDefinition) {
+ this.applicationDefinition.create();
+ this.triggerEvent(Fusion.Event.FUSION_INITIALIZED);
+ } else {
+ Fusion.reportError(new Fusion.Error(Fusion.Error.FATAL,
+ 'failed to create AppDef object'));
break;
@@ -338,7 +343,7 @@
//with the compressed version, all scripts are already laoded so just
//increment the load state
if (this.aScripts.length == 0) {
- this.setLoadState(this.loadState+1);
+ this.setLoadState(this.LOAD_COMPLETE);
return;
@@ -426,7 +431,7 @@
if (this.aScripts.length > 0) {
this.loadQueuedScripts();
} else {
More information about the fusion-commits
