[fusion-commits] r1688 - trunk/layers/MapServer/php
svn_fusion at osgeo.org
Wed Nov 26 16:19:30 EST 2008
Author: pdeschamps
Date: 2008-11-26 16:19:30 -0500 (Wed, 26 Nov 2008)
New Revision: 1688
trunk/layers/MapServer/php/LoadMap.php
added relative pathing for appdef, First if specified loadmap will use a relative path from config.json's mapserver.mapFileRoot, If it does not exist
it will then look for the map relative from the fusion install directory root. if that does not exist either it uses an absolute path. closes bug#67
Modified: trunk/layers/MapServer/php/LoadMap.php
--- trunk/layers/MapServer/php/LoadMap.php 2008-11-26 21:03:44 UTC (rev 1687)
+++ trunk/layers/MapServer/php/LoadMap.php 2008-11-26 21:19:30 UTC (rev 1688)
@@ -41,8 +41,6 @@
/* could potentially make this optional */
$moveToSession = true;
TODO make it possible to specify only a relative path
in the WebLayout and have this code know where to
@@ -51,14 +49,40 @@
/* only do something if a mapfile was requested */
if (isset($_REQUEST['mapfile'])) {
- $oMap = ms_newMapObj($_REQUEST['mapfile']);
+ /* look for mapFileRoot specified in config.json and test to see if the map path in appdef is realitive to it.*/
+ $configObj = $_SESSION['fusionConfig'];
+ $szFusionRoot = dirname(__FILE__).'/../../../'; // TODO : not a very elegant way of doing this
+ $szDblSeparator = DIRECTORY_SEPARATOR.DIRECTORY_SEPARATOR;
+ $szMapFromFusionRoot = str_replace($szDblSeparator,DIRECTORY_SEPARATOR,$szFusionRoot.DIRECTORY_SEPARATOR.$_REQUEST['mapfile']);
+ $szMapFileRoot = str_replace($szDblSeparator,DIRECTORY_SEPARATOR,$configObj->mapserver->mapFileRoot.DIRECTORY_SEPARATOR.$_REQUEST['mapfile']);
+ if( file_exists($szMapFileRoot) ) {
+ /* use the realitive path specified in config.json */
+ $szMapFile = $szMapFileRoot;
+ else
+ if( file_exists($szMapFromFusionRoot) ) {
+ /* use the realitive path from fusion install root */
+ $szMapFile = $szMapFromFusionRoot;
+ else
+ /* use absolute path from appdef */
+ $szMapFile = $_REQUEST['mapfile'];
+ $oMap = ms_newMapObj($szMapFile);
/* optionally move the mapfile to the session */
if ($moveToSession) {
//path to map file in the session is used by the client
$mapId = getSessionSavePath().($oMap->name).".map";
//modify various paths if necessary
- $pathToMap = dirname($_REQUEST['mapfile']);
+ $pathToMap = dirname($szMapFile);
$cwd = getcwd();
chdir($pathToMap);
$shapePath = $oMap->shapepath;
More information about the fusion-commits
