[fusion-commits] r1693 - trunk/lib/OpenLayers
svn_fusion at osgeo.org
Thu Nov 27 16:17:45 EST 2008
Author: madair
Date: 2008-11-27 16:17:45 -0500 (Thu, 27 Nov 2008)
New Revision: 1693
trunk/lib/OpenLayers/OpenLayers.js
re #143: update of OL with extra units (and the Google layer type)
Modified: trunk/lib/OpenLayers/OpenLayers.js
--- trunk/lib/OpenLayers/OpenLayers.js 2008-11-27 15:41:43 UTC (rev 1692)
+++ trunk/lib/OpenLayers/OpenLayers.js 2008-11-27 21:17:45 UTC (rev 1693)
@@ -192,6 +192,7 @@
"OpenLayers/Tween.js",
"Rico/Corner.js",
"Rico/Color.js",
+ "Gears/gears_init.js",
"OpenLayers/Ajax.js",
"OpenLayers/Request.js",
"OpenLayers/Request/XMLHttpRequest.js",
@@ -1336,6 +1337,10 @@
* Constant: INCHES_PER_UNIT
* {Object} Constant inches per unit -- borrowed from MapServer mapscale.c
* derivation of nautical miles from http://en.wikipedia.org/wiki/Nautical_mile
+ * Includes the full set of units supported by CS-MAP (http://trac.osgeo.org/csmap/)
+ * and PROJ.4 (http://trac.osgeo.org/proj/)
+ * The hardcoded table is maintain in a CS-MAP source code module named CSdataU.c
+ * The hardcoded table of PROJ.4 units are in pj_units.c.
OpenLayers.INCHES_PER_UNIT = {
'inches': 1.0,
@@ -1349,8 +1354,84 @@
OpenLayers.INCHES_PER_UNIT["in"]= OpenLayers.INCHES_PER_UNIT.inches;
OpenLayers.INCHES_PER_UNIT["degrees"] = OpenLayers.INCHES_PER_UNIT.dd;
OpenLayers.INCHES_PER_UNIT["nmi"] = 1852 * OpenLayers.INCHES_PER_UNIT.m;
-OpenLayers.INCHES_PER_UNIT["mm"] = OpenLayers.INCHES_PER_UNIT.m / 1000.0;
+//CS-MAP units
+OpenLayers.METERS_PER_INCH = 0.02540005080010160020;
+OpenLayers.INCHES_PER_UNIT["Inch"] = OpenLayers.INCHES_PER_UNIT.inches;
+OpenLayers.INCHES_PER_UNIT["Meter"] = 1.0/OpenLayers.METERS_PER_INCH; //EPSG:9001
+OpenLayers.INCHES_PER_UNIT["Foot"] = 0.30480060960121920243/OpenLayers.METERS_PER_INCH; //EPSG:9003
+OpenLayers.INCHES_PER_UNIT["IFoot"] = 0.30480000000000000000/OpenLayers.METERS_PER_INCH; //EPSG:9002
+OpenLayers.INCHES_PER_UNIT["ClarkeFoot"] = 0.3047972651151/OpenLayers.METERS_PER_INCH; //EPSG:9005
+OpenLayers.INCHES_PER_UNIT["SearsFoot"] = 0.30479947153867624624/OpenLayers.METERS_PER_INCH; //EPSG:9041
+OpenLayers.INCHES_PER_UNIT["GoldCoastFoot"] = 0.30479971018150881758/OpenLayers.METERS_PER_INCH; //EPSG:9094
+OpenLayers.INCHES_PER_UNIT["IInch"] = 0.02540000000000000000/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["MicroInch"] = 0.00002540000000000000/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Mil"] = 0.00000002540000000000/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Centimeter"] = 0.01000000000000000000/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Kilometer"] = 1000.00000000000000000000/OpenLayers.METERS_PER_INCH; //EPSG:9036
+OpenLayers.INCHES_PER_UNIT["Yard"] = 0.91440182880365760731/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["SearsYard"] = 0.914398414616029/OpenLayers.METERS_PER_INCH; //EPSG:9040
+OpenLayers.INCHES_PER_UNIT["IndianYard"] = 0.91439853074444079983/OpenLayers.METERS_PER_INCH; //EPSG:9084
+OpenLayers.INCHES_PER_UNIT["IndianYd37"] = 0.91439523/OpenLayers.METERS_PER_INCH; //EPSG:9085
+OpenLayers.INCHES_PER_UNIT["IndianYd62"] = 0.9143988/OpenLayers.METERS_PER_INCH; //EPSG:9086
+OpenLayers.INCHES_PER_UNIT["IndianYd75"] = 0.9143985/OpenLayers.METERS_PER_INCH; //EPSG:9087
+OpenLayers.INCHES_PER_UNIT["IndianFoot"] = 0.30479951/OpenLayers.METERS_PER_INCH; //EPSG:9080
+OpenLayers.INCHES_PER_UNIT["IndianFt37"] = 0.30479841/OpenLayers.METERS_PER_INCH; //EPSG:9081
+OpenLayers.INCHES_PER_UNIT["IndianFt62"] = 0.3047996/OpenLayers.METERS_PER_INCH; //EPSG:9082
+OpenLayers.INCHES_PER_UNIT["IndianFt75"] = 0.3047995/OpenLayers.METERS_PER_INCH; //EPSG:9083
+OpenLayers.INCHES_PER_UNIT["Mile"] = 1609.34721869443738887477/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["IYard"] = 0.91440000000000000000/OpenLayers.METERS_PER_INCH; //EPSG:9096
+OpenLayers.INCHES_PER_UNIT["IMile"] = 1609.34400000000000000000/OpenLayers.METERS_PER_INCH; //EPSG:9093
+OpenLayers.INCHES_PER_UNIT["NautM"] = 1852.00000000000000000000/OpenLayers.METERS_PER_INCH; //EPSG:9030
+OpenLayers.INCHES_PER_UNIT["Lat-66"] = 110943.316488932731/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Lat-83"] = 110946.25736872234125/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Decimeter"] = 0.10000000000000000000/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Millimeter"] = 0.00100000000000000000/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Dekameter"] = 10.00000000000000000000/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Decameter"] = 10.00000000000000000000/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Hectometer"] = 100.00000000000000000000/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["GermanMeter"] = 1.0000135965/OpenLayers.METERS_PER_INCH; //EPSG:9031
+OpenLayers.INCHES_PER_UNIT["CaGrid"] = 0.999738/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["ClarkeChain"] = 20.1166194976/OpenLayers.METERS_PER_INCH; //EPSG:9038 20.11669506"
+OpenLayers.INCHES_PER_UNIT["GunterChain"] = 20.11684023368047/OpenLayers.METERS_PER_INCH; //EPSG:9033
+OpenLayers.INCHES_PER_UNIT["BenoitChain"] = 20.116782494375872/OpenLayers.METERS_PER_INCH; //EPSG:9062
+OpenLayers.INCHES_PER_UNIT["SearsChain"] = 20.11676512155/OpenLayers.METERS_PER_INCH; //EPSG:9042
+OpenLayers.INCHES_PER_UNIT["ClarkeLink"] = 0.201166194976/OpenLayers.METERS_PER_INCH; //EPSG:9039
+OpenLayers.INCHES_PER_UNIT["GunterLink"] = 0.2011684023368047/OpenLayers.METERS_PER_INCH; //EPSG:9034
+OpenLayers.INCHES_PER_UNIT["BenoitLink"] = 0.20116782494375872/OpenLayers.METERS_PER_INCH; //EPSG:9063
+OpenLayers.INCHES_PER_UNIT["SearsLink"] = 0.2011676512155/OpenLayers.METERS_PER_INCH; //EPSG:9043
+OpenLayers.INCHES_PER_UNIT["Rod"] = 5.02921005842012/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["IntnlChain"] = 20.1168/OpenLayers.METERS_PER_INCH; //EPSG:9097
+OpenLayers.INCHES_PER_UNIT["IntnlLink"] = 0.201168/OpenLayers.METERS_PER_INCH; //EPSG:9098
+OpenLayers.INCHES_PER_UNIT["Perch"] = 5.02921005842012/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Pole"] = 5.02921005842012/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Furlong"] = 201.1684023368046/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Rood"] = 3.778266898/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["CapeFoot"] = 0.3047972615/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Brealey"] = 375.00000000000000000000/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["ModAmFt"] = 0.304812252984505969011938/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["Fathom"] = 1.8288/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["NautM-UK"] = 1853.184/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["50kilometers"] = 50000.0/OpenLayers.METERS_PER_INCH;
+OpenLayers.INCHES_PER_UNIT["150kilometers"] = 150000.0/OpenLayers.METERS_PER_INCH;
+//unit abbreviations supported by PROJ.4
+OpenLayers.INCHES_PER_UNIT["mm"] = OpenLayers.INCHES_PER_UNIT["Meter"] / 1000.0;
+OpenLayers.INCHES_PER_UNIT["cm"] = OpenLayers.INCHES_PER_UNIT["Meter"] / 100.0;
+OpenLayers.INCHES_PER_UNIT["dm"] = OpenLayers.INCHES_PER_UNIT["Meter"] * 100.0;
+OpenLayers.INCHES_PER_UNIT["km"] = OpenLayers.INCHES_PER_UNIT["Meter"] * 1000.0;
+OpenLayers.INCHES_PER_UNIT["kmi"] = OpenLayers.INCHES_PER_UNIT["nmi"]; //International Nautical Mile
+OpenLayers.INCHES_PER_UNIT["fath"] = OpenLayers.INCHES_PER_UNIT["Fathom"]; //International Fathom
+OpenLayers.INCHES_PER_UNIT["ch"] = OpenLayers.INCHES_PER_UNIT["IntnlChain"]; //International Chain
+OpenLayers.INCHES_PER_UNIT["link"] = OpenLayers.INCHES_PER_UNIT["IntnlLink"]; //International Link
+OpenLayers.INCHES_PER_UNIT["us-in"] = OpenLayers.INCHES_PER_UNIT["inches"]; //U.S. Surveyor's Inch
+OpenLayers.INCHES_PER_UNIT["us-ft"] = OpenLayers.INCHES_PER_UNIT["Foot"]; //U.S. Surveyor's Foot
+OpenLayers.INCHES_PER_UNIT["us-yd"] = OpenLayers.INCHES_PER_UNIT["Yard"]; //U.S. Surveyor's Yard
+OpenLayers.INCHES_PER_UNIT["us-ch"] = OpenLayers.INCHES_PER_UNIT["GunterChain"]; //U.S. Surveyor's Chain
+OpenLayers.INCHES_PER_UNIT["us-mi"] = OpenLayers.INCHES_PER_UNIT["Mile"]; //U.S. Surveyor's Statute Mile
+OpenLayers.INCHES_PER_UNIT["ind-yd"] = OpenLayers.INCHES_PER_UNIT["IndianYd37"]; //Indian Yard
+OpenLayers.INCHES_PER_UNIT["ind-ft"] = OpenLayers.INCHES_PER_UNIT["IndianFt37"]; //Indian Foot
+OpenLayers.INCHES_PER_UNIT["ind-ch"] = 20.11669506/OpenLayers.METERS_PER_INCH; //Indian Chain
* Constant: DOTS_PER_INCH
* {Integer} 72 (A sensible default)
@@ -2864,14 +2945,7 @@
* Property: top
* {Number} Maximum vertical coordinate.
- top: null,
- * Property: centerLonLat
- * {<OpenLayers.LonLat>} A cached center location. This should not be
- * accessed directly. Use <getCenterLonLat> instead.
- centerLonLat: null,
+ top: null,
* Constructor: OpenLayers.Bounds
@@ -3048,12 +3122,8 @@
* {<OpenLayers.LonLat>} The center of the bounds in map space.
getCenterLonLat:function() {
- if(!this.centerLonLat) {
- this.centerLonLat = new OpenLayers.LonLat(
- (this.left + this.right) / 2, (this.bottom + this.top) / 2
- return this.centerLonLat;
+ return new OpenLayers.LonLat( (this.left + this.right) / 2,
+ (this.bottom + this.top) / 2);
@@ -3094,7 +3164,7 @@
var bottom = (this.bottom - origy) * ratio + origy;
var right = (this.right - origx) * ratio + origx;
var top = (this.top - origy) * ratio + origy;
return new OpenLayers.Bounds(left, bottom, right, top);
@@ -3130,7 +3200,6 @@
extend:function(object) {
var bounds = null;
if (object) {
- // clear cached center location
switch(object.CLASS_NAME) {
case "OpenLayers.LonLat":
bounds = new OpenLayers.Bounds(object.lon, object.lat,
@@ -3147,7 +3216,6 @@
if (bounds) {
- this.centerLonLat = null;
if ( (this.left == null) || (bounds.left < this.left)) {
this.left = bounds.left;
@@ -3338,8 +3406,6 @@
* {<OpenLayers.Bounds>} Itself, for use in chaining operations.
transform: function(source, dest) {
var ll = OpenLayers.Projection.transform(
{'x': this.left, 'y': this.bottom}, source, dest);
var lr = OpenLayers.Projection.transform(
@@ -4579,23 +4645,7 @@
display: function(display) {
this.imageDiv.style.display = (display) ? "" : "none";
- * APIMethod: isDrawn
- * Returns:
- * {Boolean} Whether or not the icon is drawn.
- isDrawn: function() {
- // nodeType 11 for ie, whose nodes *always* have a parentNode
- // (of type document fragment)
- var isDrawn = (this.imageDiv && this.imageDiv.parentNode &&
- (this.imageDiv.parentNode.nodeType != 11));
- return isDrawn;
CLASS_NAME: "OpenLayers.Icon"
@@ -5996,10 +6046,7 @@
* APIMethod: issue
* Create a new XMLHttpRequest object, open it, set any headers, bind
- * a callback to done state, and send any data. It is recommended that
- * you use one <GET>, <POST>, <PUT>, <DELETE>, <OPTIONS>, or <HEAD>.
- * This method is only documented to provide detail on the configuration
- * options available to all request methods.
+ * a callback to done state, and send any data.
* Parameters:
* config - {Object} Object containing properties for configuring the
@@ -6019,20 +6066,12 @@
* <OpenLayers.ProxyHost>.
* params - {Object} Any key:value pairs to be appended to the
* url as a query string. Assumes url doesn't already include a query
- * string or hash. Typically, this is only appropriate for <GET>
- * requests where the query string will be appended to the url.
- * Parameter values that are arrays will be
+ * string or hash. Parameter values that are arrays will be
* concatenated with a comma (note that this goes against form-encoding)
* as is done with <OpenLayers.Util.getParameterString>.
* headers - {Object} Object with header:value pairs to be set on
* the request.
- * data - {String | Document} Optional data to send with the request.
- * Typically, this is only used with <POST> and <PUT> requests.
- * Make sure to provide the appropriate "Content-Type" header for your
- * data. For <POST> and <PUT> requests, the content type defaults to
- * "application-xml". If your data is a different content type, or
- * if you are using a different HTTP method, set the "Content-Type"
- * header to match your data type.
+ * data - {Object} Any data to send with the request.
* callback - {Function} Function to call when request is done.
* To determine if the request failed, check request.status (200
* indicates success).
@@ -8989,7 +9028,7 @@
- * APIFunction: loadURL
+ * Function: loadURL
* Background load a document. For more flexibility in using XMLHttpRequest,
* see the <OpenLayers.Request> methods.
@@ -12270,17 +12309,6 @@
- * Returns:
- * {Boolean} Whether or not the marker is drawn.
- var isDrawn = (this.icon && this.icon.isDrawn());
- return isDrawn;
* Method: onScreen
* Returns:
@@ -14177,7 +14205,7 @@
if (this.checkModifiers(evt) &&
this.control.handleRightClicks &&
OpenLayers.Event.isRightClick(evt)) {
- propagate = this.rightclick(evt);
+ propogate = this.rightclick(evt);
return propagate;
@@ -16909,6 +16937,745 @@
CLASS_NAME: "OpenLayers.Handler.Box"
+ OpenLayers/Layer/EventPane.js
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
+ * license. See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Layer.js
+ * @requires OpenLayers/Util.js
+ * Class: OpenLayers.Layer.EventPane
+ * Base class for 3rd party layers. Create a new event pane layer with the
+ * <OpenLayers.Layer.EventPane> constructor.
+ * Inherits from:
+ * - <OpenLayers.Layer>
+OpenLayers.Layer.EventPane = OpenLayers.Class(OpenLayers.Layer, {
+ * APIProperty: smoothDragPan
+ * {Boolean} smoothDragPan determines whether non-public/internal API
+ * methods are used for better performance while dragging EventPane
+ * layers. When not in sphericalMercator mode, the smoother dragging
+ * doesn't actually move north/south directly with the number of
+ * pixels moved, resulting in a slight offset when you drag your mouse
+ * north south with this option on. If this visual disparity bothers
+ * you, you should turn this option off, or use spherical mercator.
+ * Default is on.
+ smoothDragPan: true,
+ * Property: isBaseLayer
+ * {Boolean} EventPaned layers are always base layers, by necessity.
+ isBaseLayer: true,
+ * APIProperty: isFixed
+ * {Boolean} EventPaned layers are fixed by default.
+ isFixed: true,
+ * Property: pane
+ * {DOMElement} A reference to the element that controls the events.
+ pane: null,
+ * Property: mapObject
+ * {Object} This is the object which will be used to load the 3rd party library
+ * in the case of the google layer, this will be of type GMap,
+ * in the case of the ve layer, this will be of type VEMap
+ mapObject: null,
+ * Constructor: OpenLayers.Layer.EventPane
+ * Create a new event pane layer
+ * Parameters:
+ * name - {String}
+ * options - {Object} Hashtable of extra options to tag onto the layer
+ initialize: function(name, options) {
+ OpenLayers.Layer.prototype.initialize.apply(this, arguments);
+ if (this.pane == null) {
+ this.pane = OpenLayers.Util.createDiv(this.div.id + "_EventPane");
+ * APIMethod: destroy
+ * Deconstruct this layer.
+ destroy: function() {
+ this.mapObject = null;
+ OpenLayers.Layer.prototype.destroy.apply(this, arguments);
+ * Method: setMap
+ * Set the map property for the layer. This is done through an accessor
+ * so that subclasses can override this and take special action once
+ * they have their map variable set.
+ * Parameters:
+ * map - {<OpenLayers.Map>}
+ setMap: function(map) {
+ OpenLayers.Layer.prototype.setMap.apply(this, arguments);
+ this.pane.style.zIndex = parseInt(this.div.style.zIndex) + 1;
+ this.pane.style.display = this.div.style.display;
+ this.pane.style.width="100%";
+ this.pane.style.height="100%";
+ if (OpenLayers.Util.getBrowserName() == "msie") {
+ this.pane.style.background =
+ "url(" + OpenLayers.Util.getImagesLocation() + "blank.gif)";
+ if (this.isFixed) {
+ this.map.viewPortDiv.appendChild(this.pane);
+ } else {
+ this.map.layerContainerDiv.appendChild(this.pane);
+ // once our layer has been added to the map, we can load it
+ this.loadMapObject();
+ // if map didn't load, display warning
+ if (this.mapObject == null) {
+ this.loadWarningMessage();
+ * APIMethod: removeMap
+ * On being removed from the map, we'll like to remove the invisible 'pane'
+ * div that we added to it on creation.
+ * Parameters:
+ removeMap: function(map) {
+ if (this.pane && this.pane.parentNode) {
+ this.pane.parentNode.removeChild(this.pane);
+ this.pane = null;
+ OpenLayers.Layer.prototype.removeMap.apply(this, arguments);
+ * Method: loadWarningMessage
+ * If we can't load the map lib, then display an error message to the
+ * user and tell them where to go for help.
+ * This function sets up the layout for the warning message. Each 3rd
+ * party layer must implement its own getWarningHTML() function to
+ * provide the actual warning message.
+ loadWarningMessage:function() {
+ this.div.style.backgroundColor = "darkblue";
+ var viewSize = this.map.getSize();
+ var msgW = Math.min(viewSize.w, 300);
+ var msgH = Math.min(viewSize.h, 200);
+ var size = new OpenLayers.Size(msgW, msgH);
+ var centerPx = new OpenLayers.Pixel(viewSize.w/2, viewSize.h/2);
+ var topLeft = centerPx.add(-size.w/2, -size.h/2);
+ var div = OpenLayers.Util.createDiv(this.name + "_warning",
+ topLeft,
+ size,
+ null,
+ null,
+ null,
+ "auto");
+ div.style.padding = "7px";
+ div.style.backgroundColor = "yellow";
+ div.innerHTML = this.getWarningHTML();
+ this.div.appendChild(div);
+ * Method: getWarningHTML
+ * To be implemented by subclasses.
+ * Returns:
+ * {String} String with information on why layer is broken, how to get
+ * it working.
+ getWarningHTML:function() {
+ //should be implemented by subclasses
+ return "";
+ * Method: display
+ * Set the display on the pane
+ * Parameters:
+ * display - {Boolean}
+ display: function(display) {
+ OpenLayers.Layer.prototype.display.apply(this, arguments);
+ * Method: setZIndex
+ * Set the z-index order for the pane.
+ * Parameters:
+ * zIndex - {int}
+ setZIndex: function (zIndex) {
+ OpenLayers.Layer.prototype.setZIndex.apply(this, arguments);
+ * Method: moveTo
+ * Handle calls to move the layer.
+ * Parameters:
+ * bounds - {<OpenLayers.Bounds>}
+ * zoomChanged - {Boolean}
+ * dragging - {Boolean}
+ moveTo:function(bounds, zoomChanged, dragging) {
+ OpenLayers.Layer.prototype.moveTo.apply(this, arguments);
+ if (this.mapObject != null) {
+ var newCenter = this.map.getCenter();
+ var newZoom = this.map.getZoom();
+ if (newCenter != null) {
+ var moOldCenter = this.getMapObjectCenter();
+ var oldCenter = this.getOLLonLatFromMapObjectLonLat(moOldCenter);
+ var moOldZoom = this.getMapObjectZoom();
+ var oldZoom= this.getOLZoomFromMapObjectZoom(moOldZoom);
+ if ( !(newCenter.equals(oldCenter)) ||
+ !(newZoom == oldZoom) ) {
+ if (dragging && this.dragPanMapObject &&
+ this.smoothDragPan) {
+ var oldPx = this.map.getViewPortPxFromLonLat(oldCenter);
+ var newPx = this.map.getViewPortPxFromLonLat(newCenter);
+ this.dragPanMapObject(newPx.x-oldPx.x, oldPx.y-newPx.y);
+ } else {
+ var center = this.getMapObjectLonLatFromOLLonLat(newCenter);
+ var zoom = this.getMapObjectZoomFromOLZoom(newZoom);
+ this.setMapObjectCenter(center, zoom, dragging);
+ /* Baselayer Functions */
+ * Method: getLonLatFromViewPortPx
+ * Get a map location from a pixel location
+ * Parameters:
+ * viewPortPx - {<OpenLayers.Pixel>}
+ * Returns:
+ * {<OpenLayers.LonLat>} An OpenLayers.LonLat which is the passed-in view
+ * port OpenLayers.Pixel, translated into lon/lat by map lib
+ * If the map lib is not loaded or not centered, returns null
+ getLonLatFromViewPortPx: function (viewPortPx) {
+ var lonlat = null;
+ if ( (this.mapObject != null) &&
+ (this.getMapObjectCenter() != null) ) {
+ var moPixel = this.getMapObjectPixelFromOLPixel(viewPortPx);
+ var moLonLat = this.getMapObjectLonLatFromMapObjectPixel(moPixel);
+ lonlat = this.getOLLonLatFromMapObjectLonLat(moLonLat);
+ return lonlat;
+ * Method: getViewPortPxFromLonLat
+ * Get a pixel location from a map location
+ * Parameters:
+ * lonlat - {<OpenLayers.LonLat>}
+ * Returns:
+ * {<OpenLayers.Pixel>} An OpenLayers.Pixel which is the passed-in
+ * OpenLayers.LonLat, translated into view port pixels by map lib
+ * If map lib is not loaded or not centered, returns null
+ getViewPortPxFromLonLat: function (lonlat) {
+ var viewPortPx = null;
+ var moLonLat = this.getMapObjectLonLatFromOLLonLat(lonlat);
+ var moPixel = this.getMapObjectPixelFromMapObjectLonLat(moLonLat);
+ viewPortPx = this.getOLPixelFromMapObjectPixel(moPixel);
+ return viewPortPx;
+ /* Translation Functions */
+ /* The following functions translate Map Object and */
+ /* OL formats for Pixel, LonLat */
+ // TRANSLATION: MapObject LatLng <-> OpenLayers.LonLat
+ * Method: getOLLonLatFromMapObjectLonLat
+ * Get an OL style map location from a 3rd party style map location
+ * Parameters
+ * moLonLat - {Object}
+ * Returns:
+ * {<OpenLayers.LonLat>} An OpenLayers.LonLat, translated from the passed in
+ * MapObject LonLat
+ * Returns null if null value is passed in
+ getOLLonLatFromMapObjectLonLat: function(moLonLat) {
+ var olLonLat = null;
+ if (moLonLat != null) {
+ var lon = this.getLongitudeFromMapObjectLonLat(moLonLat);
+ var lat = this.getLatitudeFromMapObjectLonLat(moLonLat);
+ olLonLat = new OpenLayers.LonLat(lon, lat);
+ return olLonLat;
+ * Method: getMapObjectLonLatFromOLLonLat
+ * Get a 3rd party map location from an OL map location.
+ * Parameters:
+ * olLonLat - {<OpenLayers.LonLat>}
+ * Returns:
+ * {Object} A MapObject LonLat, translated from the passed in
+ getMapObjectLonLatFromOLLonLat: function(olLonLat) {
+ var moLatLng = null;
+ if (olLonLat != null) {
+ moLatLng = this.getMapObjectLonLatFromLonLat(olLonLat.lon,
+ olLonLat.lat);
+ return moLatLng;
+ // TRANSLATION: MapObject Pixel <-> OpenLayers.Pixel
+ * Method: getOLPixelFromMapObjectPixel
+ * Get an OL pixel location from a 3rd party pixel location.
+ * Parameters:
+ * moPixel - {Object}
+ * Returns:
+ * {<OpenLayers.Pixel>} An OpenLayers.Pixel, translated from the passed in
+ * MapObject Pixel
+ getOLPixelFromMapObjectPixel: function(moPixel) {
+ var olPixel = null;
+ if (moPixel != null) {
+ var x = this.getXFromMapObjectPixel(moPixel);
+ var y = this.getYFromMapObjectPixel(moPixel);
+ olPixel = new OpenLayers.Pixel(x, y);
+ return olPixel;
+ * Method: getMapObjectPixelFromOLPixel
+ * Get a 3rd party pixel location from an OL pixel location
+ * Parameters:
+ * olPixel - {<OpenLayers.Pixel>}
+ * Returns:
+ * {Object} A MapObject Pixel, translated from the passed in
+ * OpenLayers.Pixel
+ getMapObjectPixelFromOLPixel: function(olPixel) {
+ var moPixel = null;
+ if (olPixel != null) {
+ moPixel = this.getMapObjectPixelFromXY(olPixel.x, olPixel.y);
+ return moPixel;
+ CLASS_NAME: "OpenLayers.Layer.EventPane"
+ OpenLayers/Layer/FixedZoomLevels.js
+ * Class: OpenLayers.Layer.FixedZoomLevels
+ * Some Layers will already have established zoom levels (like google
+ * or ve). Instead of trying to determine them and populate a resolutions[]
+ * Array with those values, we will hijack the resolution functionality
+ * here.
+ * When you subclass FixedZoomLevels:
+ * The initResolutions() call gets nullified, meaning no resolutions[] array
+ * is set up. Which would be a big problem getResolution() in Layer, since
+ * it merely takes map.zoom and indexes into resolutions[]... but....
+ * The getResolution() call is also overridden. Instead of using the
+ * resolutions[] array, we simply calculate the current resolution based
+ * on the current extent and the current map size. But how will we be able
+ * to calculate the current extent without knowing the resolution...?
+ * The getExtent() function is also overridden. Instead of calculating extent
+ * based on the center point and the current resolution, we instead
+ * calculate the extent by getting the lonlats at the top-left and
+ * bottom-right by using the getLonLatFromViewPortPx() translation function,
+ * taken from the pixel locations (0,0) and the size of the map. But how
+ * will we be able to do lonlat-px translation without resolution....?
+ * The getZoomForResolution() method is overridden. Instead of indexing into
+ * the resolutions[] array, we call OpenLayers.Layer.getExent(), passing in
+ * the desired resolution. With this extent, we then call getZoomForExtent()
+ * Whenever you implement a layer using OpenLayers.Layer.FixedZoomLevels,
+ * it is your responsibility to provide the following three functions:
+ * - getLonLatFromViewPortPx
+ * - getViewPortPxFromLonLat
+ * - getZoomForExtent
+ * ...those three functions should generally be provided by any reasonable
+ * API that you might be working from.
+OpenLayers.Layer.FixedZoomLevels = OpenLayers.Class({
+ /* The following functions must all be implemented */
+ /* by all base layers */
+ * Constructor: OpenLayers.Layer.FixedZoomLevels
+ * Create a new fixed zoom levels layer.
+ initialize: function() {
+ //this class is only just to add the following functions...
+ // nothing to actually do here... but it is probably a good
+ // idea to have layers that use these functions call this
+ // inititalize() anyways, in case at some point we decide we
+ // do want to put some functionality or state in here.
+ * Method: initResolutions
+ * Populate the resolutions array
+ initResolutions: function() {
+ var props = new Array('minZoomLevel', 'maxZoomLevel', 'numZoomLevels');
+ for(var i=0, len=props.length; i<len; i++) {
+ var property = props[i];
+ this[property] = (this.options[property] != null)
+ ? this.options[property]
+ : this.map[property];
+ if ( (this.minZoomLevel == null) ||
+ (this.minZoomLevel < this.MIN_ZOOM_LEVEL) ){
+ this.minZoomLevel = this.MIN_ZOOM_LEVEL;
+ // At this point, we know what the minimum desired zoom level is, and
+ // we must calculate the total number of zoom levels.
+ // Because we allow for the setting of either the 'numZoomLevels'
+ // or the 'maxZoomLevel' properties... on either the layer or the
+ // map, we have to define some rules to see which we take into
+ // account first in this calculation.
+ // The following is the precedence list for these properties:
+ // (1) numZoomLevels set on layer
+ // (2) maxZoomLevel set on layer
+ // (3) numZoomLevels set on map
+ // (4) maxZoomLevel set on map*
+ // (5) none of the above*
+ // *Note that options (4) and (5) are only possible if the user
+ // _explicitly_ sets the 'numZoomLevels' property on the map to
+ // null, since it is set by default to 16.
+ // Note to future: In 3.0, I think we should remove the default
+ // value of 16 for map.numZoomLevels. Rather, I think that value
+ // should be set as a default on the Layer.WMS class. If someone
+ // creates a 3rd party layer and does not specify any 'minZoomLevel',
+ // 'maxZoomLevel', or 'numZoomLevels', and has not explicitly
+ // specified any of those on the map object either.. then I think
+ // it is fair to say that s/he wants all the zoom levels available.
+ // By making map.numZoomLevels *null* by default, that will be the
+ // case. As it is, I don't feel comfortable changing that right now
+ // as it would be a glaring API change and actually would probably
+ // break many peoples' codes.
+ //the number of zoom levels we'd like to have.
+ var desiredZoomLevels;
+ //this is the maximum number of zoom levels the layer will allow,
+ // given the specified starting minimum zoom level.
+ var limitZoomLevels = this.MAX_ZOOM_LEVEL - this.minZoomLevel + 1;
+ if ( ((this.options.numZoomLevels == null) &&
+ (this.options.maxZoomLevel != null)) // (2)
+ ((this.numZoomLevels == null) &&
+ (this.maxZoomLevel != null)) // (4)
+ //calculate based on specified maxZoomLevel (on layer or map)
+ desiredZoomLevels = this.maxZoomLevel - this.minZoomLevel + 1;
+ } else {
+ //calculate based on specified numZoomLevels (on layer or map)
+ // this covers cases (1) and (3)
+ desiredZoomLevels = this.numZoomLevels;
+ if (desiredZoomLevels != null) {
+ //Now that we know what we would *like* the number of zoom levels
+ // to be, based on layer or map options, we have to make sure that
+ // it does not conflict with the actual limit, as specified by
+ // the constants on the layer itself (and calculated into the
+ // 'limitZoomLevels' variable).
+ this.numZoomLevels = Math.min(desiredZoomLevels, limitZoomLevels);
+ } else {
+ // case (5) -- neither 'numZoomLevels' not 'maxZoomLevel' was
+ // set on either the layer or the map. So we just use the
+ // maximum limit as calculated by the layer's constants.
+ this.numZoomLevels = limitZoomLevels;
+ //now that the 'numZoomLevels' is appropriately, safely set,
+ // we go back and re-calculate the 'maxZoomLevel'.
+ this.maxZoomLevel = this.minZoomLevel + this.numZoomLevels - 1;
+ if (this.RESOLUTIONS != null) {
+ var resolutionsIndex = 0;
+ this.resolutions = [];
+ for(var i= this.minZoomLevel; i <= this.maxZoomLevel; i++) {
+ this.resolutions[resolutionsIndex++] = this.RESOLUTIONS[i];
+ this.maxResolution = this.resolutions[0];
+ this.minResolution = this.resolutions[this.resolutions.length - 1];
+ * APIMethod: getResolution
+ * Get the current map resolution
+ * Returns:
+ * {Float} Map units per Pixel
+ getResolution: function() {
+ if (this.resolutions != null) {
+ return OpenLayers.Layer.prototype.getResolution.apply(this, arguments);
+ } else {
+ var resolution = null;
+ var extent = this.getExtent();
+ if ((viewSize != null) && (extent != null)) {
+ resolution = Math.max( extent.getWidth() / viewSize.w,
+ extent.getHeight() / viewSize.h );
+ return resolution;
+ * APIMethod: getExtent
+ * Calculates using px-> lonlat translation functions on tl and br
+ * corners of viewport
+ * Returns:
+ * {<OpenLayers.Bounds>} A Bounds object which represents the lon/lat
+ * bounds of the current viewPort.
+ getExtent: function () {
+ var extent = null;
+ var size = this.map.getSize();
+ var tlPx = new OpenLayers.Pixel(0,0);
+ var tlLL = this.getLonLatFromViewPortPx(tlPx);
+ var brPx = new OpenLayers.Pixel(size.w, size.h);
+ var brLL = this.getLonLatFromViewPortPx(brPx);
+ if ((tlLL != null) && (brLL != null)) {
+ extent = new OpenLayers.Bounds(tlLL.lon,
+ brLL.lat,
+ brLL.lon,
+ tlLL.lat);
+ return extent;
+ * Method: getZoomForResolution
+ * Get the zoom level for a given resolution
+ * Parameters:
+ * resolution - {Float}
+ * Returns:
+ * {Integer} A suitable zoom level for the specified resolution.
+ * If no baselayer is set, returns null.
+ getZoomForResolution: function(resolution) {
+ return OpenLayers.Layer.prototype.getZoomForResolution.apply(this, arguments);
+ } else {
+ var extent = OpenLayers.Layer.prototype.getExtent.apply(this, []);
+ return this.getZoomForExtent(extent);
+ /* The following functions translate GMaps and OL */
+ /* formats for Pixel, LonLat, Bounds, and Zoom */
+ // TRANSLATION: MapObject Zoom <-> OpenLayers Zoom
+ * Method: getOLZoomFromMapObjectZoom
+ * Get the OL zoom index from the map object zoom level
+ * Parameters:
+ * moZoom - {Integer}
+ * Returns:
+ * {Integer} An OpenLayers Zoom level, translated from the passed in zoom
+ getOLZoomFromMapObjectZoom: function(moZoom) {
+ var zoom = null;
+ if (moZoom != null) {
+ zoom = moZoom - this.minZoomLevel;
+ return zoom;
+ * Method: getMapObjectZoomFromOLZoom
+ * Get the map object zoom level from the OL zoom level
+ * Parameters:
+ * olZoom - {Integer}
+ * Returns:
+ * {Integer} A MapObject level, translated from the passed in olZoom
+ getMapObjectZoomFromOLZoom: function(olZoom) {
+ var zoom = null;
+ if (olZoom != null) {
+ zoom = olZoom + this.minZoomLevel;
+ return zoom;
+ CLASS_NAME: "FixedZoomLevels.js"
OpenLayers/Layer/HTTPRequest.js
@@ -17283,6 +18050,7 @@
if ((marker.icon != null) && (marker.icon.imageDiv != null) &&
(marker.icon.imageDiv.parentNode == this.div) ) {
this.div.removeChild(marker.icon.imageDiv);
+ marker.drawn = false;
@@ -17313,11 +18081,10 @@
if (px == null) {
marker.display(false);
} else {
- if (!marker.isDrawn()) {
- var markerImg = marker.draw(px);
+ var markerImg = marker.draw(px);
+ if (!marker.drawn) {
this.div.appendChild(markerImg);
- } else if(marker.icon) {
- marker.icon.moveTo(px);
+ marker.drawn = true;
@@ -17346,6 +18113,169 @@
CLASS_NAME: "OpenLayers.Layer.Markers"
+ OpenLayers/Layer/SphericalMercator.js
+ * @requires OpenLayers/Projection.js
+ * Class: OpenLayers.Layer.SphericalMercator
+ * A mixin for layers that wraps up the pieces neccesary to have a coordinate
+ * conversion for working with commercial APIs which use a spherical
+ * mercator projection. Using this layer as a base layer, additional
+ * layers can be used as overlays if they are in the same projection.
+ * A layer is given properties of this object by setting the sphericalMercator
+ * property to true.
+ * More projection information:
+ * - http://spatialreference.org/ref/user/google-projection/
+ * Proj4 Text:
+ * +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
+ * +k=1.0 +units=m +nadgrids=@null +no_defs
+ * WKT:
+ * 900913=PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84",
+ * DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]],
+ * PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295],
+ * AXIS["Longitude", EAST], AXIS["Latitude", NORTH]],
+ * PROJECTION["Mercator_1SP_Google"],
+ * PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0],
+ * PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0],
+ * PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST],
+ * AXIS["y", NORTH], AUTHORITY["EPSG","900913"]]
+OpenLayers.Layer.SphericalMercator = {
+ * Method: getExtent
+ * Get the map's extent.
+ * Returns:
+ * {<OpenLayers.Bounds>} The map extent.
+ getExtent: function() {
+ if (this.sphericalMercator) {
+ extent = this.map.calculateBounds();
+ } else {
+ extent = OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);
+ return extent;
+ * Method: initMercatorParameters
+ * Set up the mercator parameters on the layer: resolutions,
+ * projection, units.
+ initMercatorParameters: function() {
+ // set up properties for Mercator - assume EPSG:900913
+ this.RESOLUTIONS = [];
+ var maxResolution = 156543.0339;
+ for(var zoom=0; zoom<=this.MAX_ZOOM_LEVEL; ++zoom) {
+ this.RESOLUTIONS[zoom] = maxResolution / Math.pow(2, zoom);
+ this.units = "m";
+ this.projection = "EPSG:900913";
+ * APIMethod: forwardMercator
+ * Given a lon,lat in EPSG:4326, return a point in Spherical Mercator.
+ * Parameters:
+ * lon - {float}
+ * lat - {float}
+ * Returns:
+ * {<OpenLayers.LonLat>} The coordinates transformed to Mercator.
+ forwardMercator: function(lon, lat) {
+ var x = lon * 20037508.34 / 180;
+ var y = Math.log(Math.tan((90 + lat) * Math.PI / 360)) / (Math.PI / 180);
+ y = y * 20037508.34 / 180;
+ return new OpenLayers.LonLat(x, y);
+ * APIMethod: inverseMercator
+ * Given a x,y in Spherical Mercator, return a point in EPSG:4326.
+ * Parameters:
+ * x - {float} A map x in Spherical Mercator.
+ * y - {float} A map y in Spherical Mercator.
+ * Returns:
+ * {<OpenLayers.LonLat>} The coordinates transformed to EPSG:4326.
+ inverseMercator: function(x, y) {
+ var lon = (x / 20037508.34) * 180;
+ var lat = (y / 20037508.34) * 180;
+ lat = 180/Math.PI * (2 * Math.atan(Math.exp(lat * Math.PI / 180)) - Math.PI / 2);
+ return new OpenLayers.LonLat(lon, lat);
+ * Method: projectForward
+ * Given an object with x and y properties in EPSG:4326, modify the x,y
+ * properties on the object to be the Spherical Mercator projected
+ * coordinates.
+ * Parameters:
+ * point - {Object} An object with x and y properties.
+ * Returns:
+ * {Object} The point, with the x and y properties transformed to spherical
+ * mercator.
+ projectForward: function(point) {
+ var lonlat = OpenLayers.Layer.SphericalMercator.forwardMercator(point.x, point.y);
+ point.x = lonlat.lon;
+ point.y = lonlat.lat;
+ return point;
+ * Method: projectInverse
+ * Given an object with x and y properties in Spherical Mercator, modify
+ * the x,y properties on the object to be the unprojected coordinates.
+ * Parameters:
+ * Returns:
+ * {Object} The point, with the x and y properties transformed from
+ * spherical mercator to unprojected coordinates..
+ projectInverse: function(point) {
+ var lonlat = OpenLayers.Layer.SphericalMercator.inverseMercator(point.x, point.y);
+ return point;
+ * Note: Two transforms declared
+ * Transforms from EPSG:4326 to EPSG:900913 and from EPSG:900913 to EPSG:4326
+ * are set by this class.
+OpenLayers.Projection.addTransform("EPSG:4326", "EPSG:900913",
+ OpenLayers.Layer.SphericalMercator.projectForward);
+OpenLayers.Projection.addTransform("EPSG:900913", "EPSG:4326",
+ OpenLayers.Layer.SphericalMercator.projectInverse);
OpenLayers/Control/DrawFeature.js
@@ -17876,6 +18806,555 @@
CLASS_NAME: "OpenLayers.Format.WKT"
+ OpenLayers/Layer/Google.js
+ * @requires OpenLayers/Layer/SphericalMercator.js
+ * @requires OpenLayers/Layer/EventPane.js
+ * @requires OpenLayers/Layer/FixedZoomLevels.js
+ * Class: OpenLayers.Layer.Google
+ * Inherits from:
+ * - <OpenLayers.Layer.SphericalMercator>
+ * - <OpenLayers.Layer.EventPane>
+ * - <OpenLayers.Layer.FixedZoomLevels>
+OpenLayers.Layer.Google = OpenLayers.Class(
+ OpenLayers.Layer.EventPane,
+ OpenLayers.Layer.FixedZoomLevels, {
+ * Constant: MIN_ZOOM_LEVEL
+ * {Integer} 0
+ MIN_ZOOM_LEVEL: 0,
+ * Constant: MAX_ZOOM_LEVEL
+ * {Integer} 19
+ MAX_ZOOM_LEVEL: 19,
+ * Constant: RESOLUTIONS
+ * {Array(Float)} Hardcode these resolutions so that they are more closely
+ * tied with the standard wms projection
+ RESOLUTIONS: [
+ 1.40625,
+ 0.703125,
+ 0.3515625,
+ 0.17578125,
+ 0.087890625,
+ 0.0439453125,
+ 0.02197265625,
+ 0.010986328125,
+ 0.0054931640625,
+ 0.00274658203125,
+ 0.001373291015625,
+ 0.0006866455078125,
+ 0.00034332275390625,
+ 0.000171661376953125,
+ 0.0000858306884765625,
+ 0.00004291534423828125,
+ 0.00002145767211914062,
+ 0.00001072883605957031,
+ 0.00000536441802978515,
+ 0.00000268220901489257
+ * APIProperty: type
+ * {GMapType}
+ type: null,
+ * APIProperty: sphericalMercator
+ * {Boolean} Should the map act as a mercator-projected map? This will
+ * cause all interactions with the map to be in the actual map
+ * projection, which allows support for vector drawing, overlaying
+ * other maps, etc.
+ sphericalMercator: false,
+ * Property: dragObject
+ * {GDraggableObject} Since 2.93, Google has exposed the ability to get
+ * the maps GDraggableObject. We can now use this for smooth panning
+ dragObject: null,
+ * Constructor: OpenLayers.Layer.Google
+ * Parameters:
+ * name - {String} A name for the layer.
+ * options - {Object} An optional object whose properties will be set
+ * on the layer.
+ OpenLayers.Layer.EventPane.prototype.initialize.apply(this, arguments);
+ OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,
+ arguments);
+ this.addContainerPxFunction();
+ OpenLayers.Util.extend(this, OpenLayers.Layer.SphericalMercator);
+ this.initMercatorParameters();
+ * Method: loadMapObject
+ * Load the GMap and register appropriate event listeners. If we can't
+ * load GMap2, then display a warning message.
+ loadMapObject:function() {
+ //has gmaps library has been loaded?
+ try {
+ // create GMap, hide nav controls
+ this.mapObject = new GMap2( this.div );
+ //since v 2.93 getDragObject is now available.
+ if(typeof this.mapObject.getDragObject == "function") {
+ this.dragObject = this.mapObject.getDragObject();
+ } else {
+ this.dragPanMapObject = null;
+ // move the ToS and branding stuff up to the pane
+ // thanks a *mil* Erik for thinking of this
+ var poweredBy = this.div.lastChild;
+ this.div.removeChild(poweredBy);
+ this.pane.appendChild(poweredBy);
+ poweredBy.className = "olLayerGooglePoweredBy gmnoprint";
+ poweredBy.style.left = "";
+ poweredBy.style.bottom = "";
+ var termsOfUse = this.div.lastChild;
+ this.div.removeChild(termsOfUse);
+ this.pane.appendChild(termsOfUse);
+ termsOfUse.className = "olLayerGoogleCopyright";
+ termsOfUse.style.right = "";
+ termsOfUse.style.bottom = "";
+ } catch (e) {
+ OpenLayers.Console.error(e);
+ * APIMethod: setMap
+ * Overridden from EventPane because if a map type has been specified,
+ * we need to attach a listener for the first moveend -- this is how
+ * we will know that the map has been centered. Only once the map has
+ * been centered is it safe to change the gmap object's map type.
+ * Parameters:
+ OpenLayers.Layer.EventPane.prototype.setMap.apply(this, arguments);
+ if (this.type != null) {
+ this.map.events.register("moveend", this, this.setMapType);
+ * Method: setMapType
+ * The map has been centered, and a map type was specified, so we
+ * set the map type on the gmap object, then unregister the listener
+ * so that we dont keep doing this every time the map moves.
+ setMapType: function() {
+ if (this.mapObject.getCenter() != null) {
+ // Support for custom map types.
+ if (OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),
+ this.type) == -1) {
+ this.mapObject.addMapType(this.type);
+ this.mapObject.setMapType(this.type);
+ this.map.events.unregister("moveend", this, this.setMapType);
+ * APIMethod: onMapResize
+ * Parameters:
+ * evt - {Event}
+ onMapResize: function() {
+ if(this.visibility) {
+ this.mapObject.checkResize();
+ } else {
+ this.windowResized = true;
+ * Method: display
+ * Hide or show the layer
+ * Parameters:
+ OpenLayers.Layer.EventPane.prototype.display.apply(this, arguments);
+ if(this.div.style.display == "block" && this.windowResized) {
+ this.windowResized = false;
+ * APIMethod: getZoomForExtent
+ * Parameters:
+ * Returns:
+ * {Integer} Corresponding zoom level for a specified Bounds.
+ * If mapObject is not loaded or not centered, returns null
+ getZoomForExtent: function (bounds) {
+ var zoom = null;
+ var moBounds = this.getMapObjectBoundsFromOLBounds(bounds);
+ var moZoom = this.getMapObjectZoomFromMapObjectBounds(moBounds);
+ //make sure zoom is within bounds
+ var moZoom = Math.min(Math.max(moZoom, this.minZoomLevel),
+ this.maxZoomLevel);
+ zoom = this.getOLZoomFromMapObjectZoom(moZoom);
+ return zoom;
+ // TRANSLATION: MapObject Bounds <-> OpenLayers.Bounds
+ * APIMethod: getOLBoundsFromMapObjectBounds
+ * Parameters:
+ * moBounds - {Object}
+ * Returns:
+ * {<OpenLayers.Bounds>} An <OpenLayers.Bounds>, translated from the
+ * passed-in MapObject Bounds.
+ * Returns null if null value is passed in.
+ getOLBoundsFromMapObjectBounds: function(moBounds) {
+ var olBounds = null;
+ if (moBounds != null) {
+ var sw = moBounds.getSouthWest();
+ var ne = moBounds.getNorthEast();
+ sw = this.forwardMercator(sw.lng(), sw.lat());
+ ne = this.forwardMercator(ne.lng(), ne.lat());
+ } else {
+ sw = new OpenLayers.LonLat(sw.lng(), sw.lat());
+ ne = new OpenLayers.LonLat(ne.lng(), ne.lat());
+ olBounds = new OpenLayers.Bounds(sw.lon,
+ sw.lat,
+ ne.lon,
+ ne.lat );
+ return olBounds;
+ * APIMethod: getMapObjectBoundsFromOLBounds
+ * Parameters:
+ * olBounds - {<OpenLayers.Bounds>}
+ * Returns:
+ * {Object} A MapObject Bounds, translated from olBounds
+ getMapObjectBoundsFromOLBounds: function(olBounds) {
+ var moBounds = null;
+ if (olBounds != null) {
+ var sw = this.sphericalMercator ?
+ this.inverseMercator(olBounds.bottom, olBounds.left) :
+ new OpenLayers.LonLat(olBounds.bottom, olBounds.left);
+ var ne = this.sphericalMercator ?
+ this.inverseMercator(olBounds.top, olBounds.right) :
+ new OpenLayers.LonLat(olBounds.top, olBounds.right);
+ moBounds = new GLatLngBounds(new GLatLng(sw.lat, sw.lon),
+ new GLatLng(ne.lat, ne.lon));
+ return moBounds;
+ * Method: addContainerPxFunction
+ * Hack-on function because GMAPS does not give it to us
+ * Parameters:
+ * gLatLng - {GLatLng}
+ * Returns:
+ * {GPoint} A GPoint specifying gLatLng translated into "Container" coords
+ addContainerPxFunction: function() {
+ if ( (typeof GMap2 != "undefined") &&
+ !GMap2.prototype.fromLatLngToContainerPixel) {
+ GMap2.prototype.fromLatLngToContainerPixel = function(gLatLng) {
+ // first we translate into "DivPixel"
+ var gPoint = this.fromLatLngToDivPixel(gLatLng);
+ // locate the sliding "Div" div
+ var div = this.getContainer().firstChild.firstChild;
+ // adjust by the offset of "Div" and voila!
+ gPoint.x += div.offsetLeft;
+ gPoint.y += div.offsetTop;
+ return gPoint;
+ * APIMethod: getWarningHTML
+ * Returns:
+ * it working.
+ return OpenLayers.i18n("googleWarning");
+ * MapObject Interface Controls *
+ // Get&Set Center, Zoom
+ * APIMethod: setMapObjectCenter
+ * Set the mapObject to the specified center and zoom
+ * Parameters:
+ * center - {Object} MapObject LonLat format
+ * zoom - {int} MapObject zoom format
+ setMapObjectCenter: function(center, zoom) {
+ this.mapObject.setCenter(center, zoom);
+ * APIMethod: dragPanMapObject
+ * Parameters:
+ * dX - {Integer}
+ * dY - {Integer}
+ dragPanMapObject: function(dX, dY) {
+ this.dragObject.moveBy(new GSize(-dX, dY));
+ * APIMethod: getMapObjectCenter
+ * Returns:
+ * {Object} The mapObject's current center in Map Object format
+ getMapObjectCenter: function() {
+ return this.mapObject.getCenter();
+ * APIMethod: getMapObjectZoom
+ * Returns:
+ * {Integer} The mapObject's current zoom, in Map Object format
+ getMapObjectZoom: function() {
+ return this.mapObject.getZoom();
+ // LonLat - Pixel Translation
+ * APIMethod: getMapObjectLonLatFromMapObjectPixel
+ * Parameters:
+ * moPixel - {Object} MapObject Pixel format
+ * Returns:
+ * {Object} MapObject LonLat translated from MapObject Pixel
+ getMapObjectLonLatFromMapObjectPixel: function(moPixel) {
+ return this.mapObject.fromContainerPixelToLatLng(moPixel);
+ * APIMethod: getMapObjectPixelFromMapObjectLonLat
+ * Parameters:
+ * moLonLat - {Object} MapObject LonLat format
+ * Returns:
+ * {Object} MapObject Pixel transtlated from MapObject LonLat
+ getMapObjectPixelFromMapObjectLonLat: function(moLonLat) {
+ return this.mapObject.fromLatLngToContainerPixel(moLonLat);
+ // Bounds
+ * APIMethod: getMapObjectZoomFromMapObjectBounds
+ * Parameters:
+ * moBounds - {Object} MapObject Bounds format
+ * Returns:
+ * {Object} MapObject Zoom for specified MapObject Bounds
+ getMapObjectZoomFromMapObjectBounds: function(moBounds) {
+ return this.mapObject.getBoundsZoomLevel(moBounds);
+ * MapObject Primitives *
+ // LonLat
+ * APIMethod: getLongitudeFromMapObjectLonLat
+ * Parameters:
+ * Returns:
+ * {Float} Longitude of the given MapObject LonLat
+ getLongitudeFromMapObjectLonLat: function(moLonLat) {
+ return this.sphericalMercator ?
+ this.forwardMercator(moLonLat.lng(), moLonLat.lat()).lon :
+ moLonLat.lng();
+ * APIMethod: getLatitudeFromMapObjectLonLat
+ * Parameters:
+ * Returns:
+ * {Float} Latitude of the given MapObject LonLat
+ getLatitudeFromMapObjectLonLat: function(moLonLat) {
+ var lat = this.sphericalMercator ?
+ this.forwardMercator(moLonLat.lng(), moLonLat.lat()).lat :
+ moLonLat.lat();
+ return lat;
+ * APIMethod: getMapObjectLonLatFromLonLat
+ * Parameters:
+ * lon - {Float}
+ * lat - {Float}
+ * Returns:
+ * {Object} MapObject LonLat built from lon and lat params
+ getMapObjectLonLatFromLonLat: function(lon, lat) {
+ var gLatLng;
+ if(this.sphericalMercator) {
+ var lonlat = this.inverseMercator(lon, lat);
+ gLatLng = new GLatLng(lonlat.lat, lonlat.lon);
+ } else {
+ gLatLng = new GLatLng(lat, lon);
+ return gLatLng;
+ // Pixel
+ * APIMethod: getXFromMapObjectPixel
+ * Parameters:
+ * Returns:
+ * {Integer} X value of the MapObject Pixel
+ getXFromMapObjectPixel: function(moPixel) {
+ return moPixel.x;
+ * APIMethod: getYFromMapObjectPixel
+ * Parameters:
+ * Returns:
+ * {Integer} Y value of the MapObject Pixel
+ getYFromMapObjectPixel: function(moPixel) {
+ return moPixel.y;
+ * APIMethod: getMapObjectPixelFromXY
+ * Parameters:
+ * x - {Integer}
+ * y - {Integer}
+ * Returns:
+ * {Object} MapObject Pixel from x and y parameters
+ getMapObjectPixelFromXY: function(x, y) {
+ return new GPoint(x, y);
+ CLASS_NAME: "OpenLayers.Layer.Google"
OpenLayers/Layer/Grid.js
@@ -18296,12 +19775,12 @@
tileoffsetlon += tilelon;
tileoffsetx += this.tileSize.w;
} while ((tileoffsetlon <= bounds.right + tilelon * this.buffer)
- || colidx < minCols);
+ || colidx < minCols)
tileoffsetlat -= tilelat;
tileoffsety += this.tileSize.h;
} while((tileoffsetlat >= bounds.bottom - tilelat * this.buffer)
- || rowidx < minRows);
+ || rowidx < minRows)
//shave off exceess rows and colums
this.removeExcessTiles(rowidx, colidx);
@@ -19039,17 +20518,6 @@
* {Boolean} Whether or not to handle right clicks. Default is false.
handleRightClicks: false,
- * APIProperty: zoomBoxKeyMask
- * {Integer} <OpenLayers.Handler> key code of the key, which has to be
- * pressed, while drawing the zoom box with the mouse on the screen.
- * You should probably set handleRightClicks to true if you use this
- * with MOD_CTRL, to disable the context menu for machines which use
- * CTRL-Click as a right click.
- * Default: <OpenLayers.Handler.MOD_SHIFT
- zoomBoxKeyMask: OpenLayers.Handler.MOD_SHIFT,
* Constructor: OpenLayers.Control.Navigation
@@ -19133,7 +20601,7 @@
OpenLayers.Util.extend({map: this.map}, this.dragPanOptions)
this.zoomBox = new OpenLayers.Control.ZoomBox(
- {map: this.map, keyMask: this.zoomBoxKeyMask});
+ {map: this.map, keyMask: OpenLayers.Handler.MOD_SHIFT});
this.dragPan.draw();
this.zoomBox.draw();
this.handlers.wheel = new OpenLayers.Handler.MouseWheel(
@@ -21529,7 +22997,9 @@
this.preFeatureInsert(feature);
- this.drawFeature(feature);
+ if (this.drawn) {
+ this.drawFeature(feature);
if (notify) {
this.events.triggerEvent("featureadded", {
@@ -21648,12 +23118,6 @@
* style - {Object} Symbolizer hash or {String} renderIntent
drawFeature: function(feature, style) {
- // don't try to draw the feature with the renderer if the layer is not
- // drawn itself
- if (!this.drawn) {
- return
if (typeof style != "object") {
var renderIntent = typeof style == "string" ?
style : feature.renderIntent;
More information about the fusion-commits
