[fusion-commits] r1698 - trunk/layers
svn_fusion at osgeo.org
Fri Nov 28 15:13:40 EST 2008
Author: pdeschamps
Date: 2008-11-28 15:13:40 -0500 (Fri, 28 Nov 2008)
New Revision: 1698
trunk/layers/Layers.js
removed logic to convert a string "true"/"false" comparison into a
boolean.
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js 2008-11-28 20:12:48 UTC (rev 1697)
+++ trunk/layers/Layers.js 2008-11-28 20:13:40 UTC (rev 1698)
@@ -311,10 +311,10 @@
this.legendLabel = o.legendLabel;
this.parentUniqueId = o.parentUniqueId;
this.groupType = o.groupType;
- this.displayInLegend = o.displayInLegend=="true"?true:false;
- this.expandInLegend = o.expandInLegend=="true"?true:false;
- this.visible = o.visible=="true"?true:false;
- this.actuallyVisible = o.actuallyVisible=="true"?true:false;
+ this.displayInLegend = o.displayInLegend;
+ this.expandInLegend = o.expandInLegend;
+ this.visible = o.visible;
+ this.actuallyVisible = o.actuallyVisible;
this.registerEventID(Fusion.Event.GROUP_PROPERTY_CHANGED);
@@ -437,28 +437,13 @@
this.selectedFeatureCount = 0;
this.layerTypes = [].concat(o.layerTypes);
+ this.editable = o.editable;
+ this.selectable = o.selectable;
- /* In mapserver - flags are boolean's where as in MapGuide they need to be converted from strings.
- http://trac.osgeo.org/fusion/ticket/186
- if(typeof(o.displayInLegend)=="boolean"){
- this.displayInLegend = o.displayInLegend;
- this.expandInLegend = o.expandInLegend;
- this.actuallyVisible = o.actuallyVisible;
- this.editable = o.editable;
- this.visible = o.visible;
- this.selectable = o.selectable;
- else
- this.editable = o.editable=="true"?true:false;
- this.selectable = o.selectable=="true"?true:false;
//determine the layer type so that the correct icon can be displayed in the legend
this.layerType = null;
More information about the fusion-commits
