[fusion-commits] r1578 - in trunk: MapGuide lib
svn_fusion at osgeo.org
Wed Oct 1 10:46:05 EDT 2008
Author: madair
Date: 2008-10-01 10:46:05 -0400 (Wed, 01 Oct 2008)
New Revision: 1578
trunk/MapGuide/MapGuide.js
trunk/lib/Map.js
closes #113: fix for regression, explicitly set MaxScale in AppDef MapWidget extension to set limit for zooming out; applied to trunk
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js 2008-10-01 14:45:17 UTC (rev 1577)
+++ trunk/MapGuide/MapGuide.js 2008-10-01 14:46:05 UTC (rev 1578)
@@ -535,7 +535,7 @@
var layerOptions = {
units: this.units,
isBaseLayer: bIsBaseLayer,
- maxExtent: this.mapWidget.maxExtent ? this.mapWidget.maxExtent : this._oMaxExtent,
+ maxExtent: this._oMaxExtent,
maxResolution: 'auto',
useOverlay: this.selectionAsOverlay,
ratio: this.ratio
@@ -551,7 +551,9 @@
if (this.maxScale != Infinity) {
layerOptions.minScale = this.maxScale; //OL interpretation of min/max scale is reversed from Fusion
} else {
- layerOptions.minScale = Fusion.REALLY_SMALL_SCALE;
+ if (this.mapWidget.minScale) {
+ layerOptions.minScale = this.mapWidget.maxScale;
+ }// otherwise minscale is set automatically by OL
//only set both max and min scale when not using scales array
if (!this.mapWidget.oMapOL.scales && !this.scales) {
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js 2008-10-01 14:45:17 UTC (rev 1577)
+++ trunk/lib/Map.js 2008-10-01 14:46:05 UTC (rev 1578)
@@ -68,6 +68,7 @@
layerRoot: null,
singleTile: true,
fractionalZoom: true, //TODO: set this in AppDef?
+ maxScale: null, //set this to a large number in AppDef to zoom out beyond maxExtent, e.g. 1 billion
* construct a new view Fusion.Widget.Map class.
@@ -97,6 +98,12 @@
this.fractionalZoom = false;
+ //Set a MaxScale in MapWIdget extension to allow zoom out to that scale
+ //otherwise, MaxScale is calculated automatically
+ if (widgetTag.extension.MaxScale) {
+ this.maxScale = parseInt(widgetTag.extension.MaxExtent[0]);
var maxExtent = null;
if (widgetTag.extension.MaxExtent) {
maxExtent = OpenLayers.Bounds.fromString(widgetTag.extension.MaxExtent[0]);
More information about the fusion-commits
