[fusion-commits] r1583 - trunk/lib/OpenLayers
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Oct 3 09:50:02 EDT 2008
Author: madair
Date: 2008-10-03 09:50:01 -0400 (Fri, 03 Oct 2008)
New Revision: 1583
   trunk/lib/OpenLayers/OpenLayers.js
re #120: patched version of OL which uses asynchronous calls for GETVISIBLEMAPEXTENT and supports the useOverlay flag
Modified: trunk/lib/OpenLayers/OpenLayers.js
--- trunk/lib/OpenLayers/OpenLayers.js	2008-10-03 13:08:06 UTC (rev 1582)
+++ trunk/lib/OpenLayers/OpenLayers.js	2008-10-03 13:50:01 UTC (rev 1583)
@@ -19477,10 +19477,7 @@
      * APIProperty: singleTile
-     * {Boolean} use tile server or request single tile image. Note that using
-     *    singleTile *and* isBaseLayer false is *not recommend*: it uses synchronous
-     *    XMLHttpRequests to load tiles, and this will *lock up users browsers*
-     *    during requests if the server fails to respond.
+     * {Boolean} use tile server or request single tile image.
     singleTile: false,
@@ -19522,11 +19519,12 @@
      * 'session', or 'mapDefinition' and 'locale'.
      * For untiled overlay layers (singleTile=true and isBaseLayer=false),
-     * mapName and session are required parameters for the Layer constructor.
-     * Also NOTE: untiled overlay layers issues a synchronous AJAX request
-     * before the image request can be issued so the users browser may lock
-     * up if the MG Web tier does not respond in a timely fashion.
+     * mapName and session are required parameters for the Layer constructor.
+     * If the useOverlay flag is set to true, the image request will use
+     * GETDYNAMICOVERLAY instead of GETMAPIMAGE and some additonal parameters
+     * will be available as per http://trac.osgeo.org/mapguide/wiki/MapGuideRfc38
      * NOTE: MapGuide OS uses a DPI value and degrees to meters conversion
      * factor that are different than the defaults used in OpenLayers,
      * so these must be adjusted accordingly in your application.
@@ -19650,28 +19648,18 @@
         if (this.singleTile) {
           //set up the call for GETMAPIMAGE or GETDYNAMICMAPOVERLAY
           var params = {};
-          params.setdisplaydpi = OpenLayers.DOTS_PER_INCH;
-          params.setdisplayheight = mapSize.h*this.ratio;
-          params.setdisplaywidth = mapSize.w*this.ratio;
-          params.setviewcenterx = center.lon;
-          params.setviewcentery = center.lat;
-          params.setviewscale = this.map.getScale();
           if (this.useOverlay) {
             // in this case the main image operation is remapped to this
-            this.params.operation = "GETDYNAMICMAPOVERLAYIMAGE";
+            params.operation = "GETDYNAMICMAPOVERLAYIMAGE";
-            //but we first need to call GETVISIBLEMAPEXTENT to set the extent
-            var getVisParams = {};
-            getVisParams = OpenLayers.Util.extend(getVisParams, params);
-            getVisParams.operation = "GETVISIBLEMAPEXTENT";
-            getVisParams.version = "1.0.0";
-            getVisParams.session = this.params.session;
-            getVisParams.mapName = this.params.mapName;
-            getVisParams.format = 'text/xml';
-            url = this.getFullRequestString( getVisParams );
-            OpenLayers.Request.GET({url: url, async: false});
+          } else {
+            params.setdisplaydpi = OpenLayers.DOTS_PER_INCH;
+            params.setdisplayheight = mapSize.h*this.ratio;
+            params.setdisplaywidth = mapSize.w*this.ratio;
+            params.setviewcenterx = center.lon;
+            params.setviewcentery = center.lat;
+            params.setviewscale = this.map.getScale();
           //construct the full URL
@@ -19796,6 +19784,82 @@
+     * Method: moveTo
+     * Override of OpenLayers.Grid.moveTo to call MGOS asynchronously for
+     * overlay layers.
+     * This function is called whenever the map is moved. All the moving
+     * of actual 'tiles' is done by the map, but moveTo's role is to accept
+     * a bounds and make sure the data that that bounds requires is pre-loaded.
+     * Parameters:
+     * bounds - {<OpenLayers.Bounds>}
+     * zoomChanged - {Boolean}
+     * dragging - {Boolean}
+    moveTo:function(bounds, zoomChanged, dragging) {
+        OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this, arguments);
+        bounds = bounds || this.map.getExtent();
+        if (bounds != null) {
+            // if grid is empty or zoom has changed, we *must* re-tile
+            var forceReTile = !this.grid.length || zoomChanged;
+            // total bounds of the tiles
+            var tilesBounds = this.getTilesBounds();
+            if (this.singleTile) {
+                // We want to redraw whenever even the slightest part of the
+                //  current bounds is not contained by our tile.
+                //  (thus, we do not specify partial -- its default is false)
+                if ( forceReTile ||
+                     (!dragging && !tilesBounds.containsBounds(bounds))) {
+                    if (this.useOverlay) {
+                        var center = bounds.getCenterLonLat();
+                        var mapSize = this.map.getCurrentSize();
+                        //first call GETVISIBLEMAPEXTENT to set the extent
+                        //and continue on in the callback asynchronously
+                        var getVisParams = {};
+                        getVisParams.operation = "GETVISIBLEMAPEXTENT";
+                        getVisParams.version = "1.0.0";
+                        getVisParams.setdisplaydpi = OpenLayers.DOTS_PER_INCH;
+                        getVisParams.setdisplayheight = mapSize.h*this.ratio;
+                        getVisParams.setdisplaywidth = mapSize.w*this.ratio;
+                        getVisParams.setviewcenterx = center.lon;
+                        getVisParams.setviewcentery = center.lat;
+                        getVisParams.setviewscale = this.map.getScale();
+                        getVisParams.format = 'text/xml';
+                        url = this.getFullRequestString( getVisParams );
+                        OpenLayers.Request.GET({
+                            url: url,
+                            success: OpenLayers.Function.bind(this.initSingleTile, this, bounds)});
+                    } else {
+                        this.initSingleTile(bounds);
+            } else {
+                // if the bounds have changed such that they are not even
+                //  *partially* contained by our tiles (IE user has
+                //  programmatically panned to the other side of the earth)
+                //  then we want to reTile (thus, partial true).
+                if (forceReTile || !tilesBounds.containsBounds(bounds, true)) {
+                    this.initGriddedTiles(bounds);
+                } else {
+                    //we might have to shift our buffer tiles
+                    this.moveGriddedTiles(bounds);
     CLASS_NAME: "OpenLayers.Layer.MapGuide"
More information about the fusion-commits mailing list
