[fusion-commits] r1591 - in branches/fusion-1.1: MapGuide widgets
svn_fusion at osgeo.org
Fri Oct 10 11:24:02 EDT 2008
Author: madair
Date: 2008-10-10 11:24:02 -0400 (Fri, 10 Oct 2008)
New Revision: 1591
branches/fusion-1.1/MapGuide/MapGuide.js
branches/fusion-1.1/widgets/Help.js
branches/fusion-1.1/widgets/TaskPane.js
re #126: remove default params from TaskPane and add to Help widget; other widgets already add the necessary params;
fix error with mapName param for queryLayer
Modified: branches/fusion-1.1/MapGuide/MapGuide.js
--- branches/fusion-1.1/MapGuide/MapGuide.js 2008-10-10 14:01:27 UTC (rev 1590)
+++ branches/fusion-1.1/MapGuide/MapGuide.js 2008-10-10 15:24:02 UTC (rev 1591)
@@ -508,7 +508,7 @@
if ( bSingleTile ) {
params = { //single tile params
session: this.getSessionID(),
- mapname: this._sMapname,
+ mapName: this._sMapname,
clientagent: this.clientAgent
params.showLayers = this.aShowLayers.length > 0 ? this.aShowLayers.toString() : null;
Modified: branches/fusion-1.1/widgets/Help.js
--- branches/fusion-1.1/widgets/Help.js 2008-10-10 14:01:27 UTC (rev 1590)
+++ branches/fusion-1.1/widgets/Help.js 2008-10-10 15:24:02 UTC (rev 1591)
@@ -63,6 +63,19 @@
execute : function() {
var url = this.baseUrl;
+ var map = this.getMap();
+ var params = [];
+ params.push('LOCALE='+Fusion.locale);
+ params.push('SESSION='+map.getSessionID());
+ params.push('MAPNAME='+map.getMapName());
+ if (url.indexOf('?') < 0) {
+ url += '?';
+ } else if (url.slice(-1) != '&') {
+ url += '&';
+ url += params.join('&');
/* check to see if this is going into a task pane */
var taskPaneTarget = Fusion.getWidgetById(this.target);
if ( taskPaneTarget ) {
Modified: branches/fusion-1.1/widgets/TaskPane.js
--- branches/fusion-1.1/widgets/TaskPane.js 2008-10-10 14:01:27 UTC (rev 1590)
+++ branches/fusion-1.1/widgets/TaskPane.js 2008-10-10 15:24:02 UTC (rev 1591)
@@ -153,19 +153,6 @@
this.aExecutedTasks.splice(this.nCurrentTask, this.aExecutedTasks.length - this.nCurrentTask);
- //add in default Fusion parameters to the URL
- var map = this.getMap();
- var params = [];
- params.push('LOCALE='+Fusion.locale);
- params.push('SESSION='+map.getSessionID());
- params.push('MAPNAME='+map.getMapName());
- if (url.indexOf('?') < 0) {
- url += '?';
- } else if (url.slice(-1) != '&') {
- url += '&';
- url += params.join('&');
this.aExecutedTasks.push(url);
++this.nCurrentTask;
this.iframe.src = url;
More information about the fusion-commits
