[fusion-commits] r1621 - trunk
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Oct 30 13:30:18 EDT 2008
Author: madair
Date: 2008-10-30 13:30:18 -0400 (Thu, 30 Oct 2008)
New Revision: 1621
   trunk/build.xml
re #42: also rename config_dist.json to config.json as part of the build process
Modified: trunk/build.xml
--- trunk/build.xml	2008-10-27 19:36:21 UTC (rev 1620)
+++ trunk/build.xml	2008-10-30 17:30:18 UTC (rev 1621)
@@ -113,11 +113,11 @@
     <echo message="Preparing uncompressed build"/>
     <!-- Create build directories as needed -->
     <mkdir dir="${build.home}"/>
+    <copy file="config_dist.json" tofile="${build.home}/config.json"/>
     <!-- Copy static content -->
     <copy todir="${build.home}">
       <fileset dir="${basedir}"
-            includes="config.json
-                      configHeader.json
+            includes="configHeader.json
                       MapGuide/**
                       MapServer/**
                       common/**
More information about the fusion-commits mailing list
