[fusion-commits] r1500 - in trunk/lib/OpenLayers: Lang
theme/default/img
svn_fusion at osgeo.org
Fri Sep 5 10:40:48 EDT 2008
Author: madair
Date: 2008-09-05 10:40:48 -0400 (Fri, 05 Sep 2008)
New Revision: 1500
Added:
trunk/lib/OpenLayers/Lang/it.js
trunk/lib/OpenLayers/Lang/nb.js
trunk/lib/OpenLayers/Lang/nl.js
trunk/lib/OpenLayers/Lang/pt-BR.js
trunk/lib/OpenLayers/Lang/sv-SE.js
trunk/lib/OpenLayers/Lang/zh-CN.js
trunk/lib/OpenLayers/Lang/zh-TW.js
trunk/lib/OpenLayers/theme/default/img/navigation_history.png
trunk/lib/OpenLayers/theme/default/img/save_features_off.png
trunk/lib/OpenLayers/theme/default/img/save_features_on.png
re #119: interim commit to bring OL to trunk version prior to v2.7 release - add new files too
Added: trunk/lib/OpenLayers/Lang/it.js
--- trunk/lib/OpenLayers/Lang/it.js (rev 0)
+++ trunk/lib/OpenLayers/Lang/it.js 2008-09-05 14:40:48 UTC (rev 1500)
@@ -0,0 +1,120 @@
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
+ * license. See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Lang.js
+ * Namespace: OpenLayers.Lang["it"]
+ * Dictionary for Italian. Keys for entries are used in calls to
+ * <OpenLayers.Lang.translate>. Entry bodies are normal strings or
+ * strings formatted for use with <OpenLayers.String.format> calls.
+OpenLayers.Lang.it = {
+ 'unhandledRequest': "Codice di ritorno della richiesta ${statusText}",
+ 'permalink': "Permalink",
+ 'overlays': "Overlays",
+ 'baseLayer': "Livello base",
+ 'sameProjection':
+ "La mini mappa funziona solamente se ha la stessa proiezione della mappa principale",
+ 'readNotImplemented': "Lettura non implementata.",
+ 'writeNotImplemented': "Scrittura non implementata.",
+ 'noFID': "Impossibile aggiornare un elemento grafico che non abbia il FID.",
+ 'errorLoadingGML': "Errore nel caricamento del file GML ${url}",
+ 'browserNotSupported':
+ "Il tuo browser non supporta il rendering vettoriale. I renderizzatore attualemnte supportati sono:\n${renderers}",
+ 'componentShouldBe': "addFeatures : il componente dovrebbe essere di tipo ${geomType}",
+ // console message
+ 'getFeatureError':
+ "getFeatureFromEvent chiamata su di un livello senza renderizzatore. Ciò significa che " +
+ "il livello è stato cancellato, ma non i gestori associati ad esso.",
+ 'minZoomLevelError':
+ "La proprietà minZoomLevel è da utilizzare solamente " +
+ "con livelli che abbiano FixedZoomLevels. Il fatto che " +
+ "questo livello wfs controlli la proprietà minZoomLevel è " +
+ "un retaggio del passato. Non possiamo comunque rimuoverla " +
+ "senza rompere le vecchie applicazioni che dipendono su di essa." +
+ "Quindi siamo costretti a deprecarla -- minZoomLevel " +
+ "e sarà rimossa dalla vesione 3.0. Si prega di utilizzare i " +
+ "settaggi di risoluzione min/max come descritto qui: " +
+ "http://trac.openlayers.org/wiki/SettingZoomLevels",
+ 'commitSuccess': "Transazione WFS: SUCCESS ${response}",
+ 'commitFailed': "Transazione WFS: FAILED ${response}",
+ 'googleWarning':
+ "Il livello Google non è riuscito a caricare correttamente.<br><br>" +
+ "Per evitare questo messaggio, seleziona un nuovo BaseLayer " +
+ "nel selettore di livelli nell'angolo in alto a destra.<br><br>" +
+ "Più precisamente, ciò accade perchè la libreria Google Maps " +
+ "non è stata inclusa nella pagina, oppure non contiene la " +
+ "corretta API key per il tuo sito.<br><br>" +
+ "Sviluppatori: Per aiuto su come farlo funzionare correttamente, " +
+ "<a href='http://trac.openlayers.org/wiki/Google' " +
+ "target='_blank'>clicca qui</a>",
+ 'getLayerWarning':
+ "Il livello ${layerType} non è riuscito a caricare correttamente.<br><br>" +
+ "Più precisamente, ciò accade perchè la libreria ${layerLib} " +
+ "non è stata inclusa nella pagina.<br><br>" +
+ "<a href='http://trac.openlayers.org/wiki/${layerLib}' " +
+ 'scale': "Scala = 1 : ${scaleDenom}",
+ 'layerAlreadyAdded':
+ "Stai cercando di aggiungere il livello: ${layerName} alla mappa, ma tale livello è già stato aggiunto.",
+ 'reprojectDeprecated':
+ "Stai utilizzando l'opzione 'reproject' sul livello ${layerName}. " +
+ "Questa opzione è deprecata: il suo utilizzo è stato introdotto per" +
+ "supportare il disegno dei dati sopra mappe commerciali, ma tale " +
+ "funzionalità dovrebbe essere ottenuta tramite l'utilizzo della proiezione " +
+ "Spherical Mercator. Per maggiori informazioni consultare qui " +
+ "http://trac.openlayers.org/wiki/SphericalMercator.",
+ 'methodDeprecated':
+ "Questo metodo è stato deprecato e sarà rimosso dalla versione 3.0. " +
+ "Si prega di utilizzare il metodo ${newMethod} in alternativa.",
+ 'boundsAddError': "Devi specificare i valori di x e y alla funzione add.",
+ 'lonlatAddError': "Devi specificare i valori di lon e lat alla funzione add.",
+ 'pixelAddError': "Devi specificare i valori di x e y alla funzione add.",
+ 'unsupportedGeometryType': "Tipo di geometria non supportata: ${geomType}",
+ 'pagePositionFailed':
+ "OpenLayers.Util.pagePosition fallita: l'elemento con id ${elemId} è posizionato in modo errato.",
+ 'end': ''
Added: trunk/lib/OpenLayers/Lang/nb.js
--- trunk/lib/OpenLayers/Lang/nb.js (rev 0)
+++ trunk/lib/OpenLayers/Lang/nb.js 2008-09-05 14:40:48 UTC (rev 1500)
@@ -0,0 +1,121 @@
+ * Namespace: OpenLayers.Lang["nb"]
+ * Dictionary for norwegian bokmål (Norway). Keys for entries are used in calls to
+OpenLayers.Lang["nb"] = {
+ 'unhandledRequest': "Ubehandlet forespørsel returnerte ${statusText}",
+ 'permalink': "Kobling til denne siden",
+ 'overlays': "Kartlag",
+ 'baseLayer': "Bakgrunnskart",
+ 'sameProjection':
+ "Oversiktskartet fungerer bare når det har samme projeksjon som hovedkartet",
+ 'readNotImplemented': "Lesing er ikke implementert.",
+ 'writeNotImplemented': "Skriving er ikke implementert.",
+ 'noFID': "Kan ikke oppdatere feature (objekt) som ikke har FID.",
+ 'errorLoadingGML': "Feil under lasting av GML-fil ${url}",
+ "Din nettleser støtter ikke vektortegning. Følgende tegnemetoder støttes:\n${renderers}",
+ 'componentShouldBe': "addFeatures : komponenten må være en ${geomType}",
+ "getFeatureFromEvent kjørt mot lag uten tegnemetode. Dette betyr som regel at du " +
+ "fjernet et lag uten å fjerne alle handlere tilknyttet laget.",
+ "Egenskapen minZoomLevel er kun tenkt for bruk på lag " +
+ "basert på FixedZoomLevels. At dette wfs-laget sjekker " +
+ "minZoomLevel er en fortidslevning. Det kan dog ikke " +
+ "tas bort uten å risikere at OL-baserte applikasjoner " +
+ "slutter å virke, så det er merket som foreldet: " +
+ "minZoomLevel i sjekken nedenfor vil fjernes i 3.0. " +
+ "Vennligst bruk innstillingene for min/maks oppløsning " +
+ "som er beskrevet her: "+
+ 'commitSuccess': "WFS-transaksjon: SUKSESS ${response}",
+ 'commitFailed': "WFS-transaksjon: FEILET ${response}",
+ 'googleWarning':
+ "Google-laget kunne ikke lastes.<br><br>" +
+ "Bytt til et annet bakgrunnslag i lagvelgeren i " +
+ "øvre høyre hjørne for å slippe denne meldingen.<br><br>" +
+ "Sannsynligvis forårsakes feilen av at Google Maps-biblioteket " +
+ "ikke er riktig inkludert på nettsiden, eller at det ikke er " +
+ "angitt riktig API-nøkkel for nettstedet.<br><br>" +
+ "Utviklere: For hjelp til å få dette til å virke se "+
+ "target='_blank'>her</a>.",
+ "${layerType}-laget kunne ikke lastes.<br><br>" +
+ "Sannsynligvis forårsakes feilen av at " +
+ "${layerLib}-biblioteket ikke var riktig inkludert " +
+ "på nettsiden.<br><br>" +
+ "Utviklere: For hjelp til å få dette til å virke se " +
+ 'scale': "<strong>Skala</strong> 1 : ${scaleDenom}",
+ "Du forsøkte å legge til laget ${layerName} på kartet, men det er allerede lagt til",
+ "Du bruker innstillingen 'reproject' på laget ${layerName}. " +
+ "Denne innstillingen er foreldet, den var ment for å støtte " +
+ "visning av kartdata over kommersielle bakgrunnskart, men det " +
+ "bør nå gjøres med støtten for Spherical Mercator. Mer informasjon " +
+ "finnes på " +
+ "Denne metoden er markert som foreldet og vil bli fjernet i 3.0. " +
+ "Bruk ${newMethod} i stedet.",
+ 'boundsAddError': "Du må gi både x- og y-verdier til funksjonen add.",
+ 'lonlatAddError': "Du må gi både lon- og lat-verdier til funksjonen add.",
+ 'pixelAddError': "Du må gi både x- og y-verdier til funksjonen add.",
+ 'unsupportedGeometryType': "Ustøttet geometritype: ${geomType}",
+ "OpenLayers.Util.pagePosition feilet: elementet med id ${elemId} kan være feilplassert.",
+ 'end': ''
Added: trunk/lib/OpenLayers/Lang/nl.js
--- trunk/lib/OpenLayers/Lang/nl.js (rev 0)
+++ trunk/lib/OpenLayers/Lang/nl.js 2008-09-05 14:40:48 UTC (rev 1500)
@@ -0,0 +1,68 @@
+ * @requires OpenLayers/Lang/en.js
+ * Namespace: OpenLayers.Lang["nl"]
+ * Dictionary for Dutch. Keys for entries are used in calls to
+OpenLayers.Lang.nl = OpenLayers.Util.applyDefaults({
+ 'unhandledRequest': "Niet afgehandeld request met als terugmelding ${statusText}",
+ 'baseLayer': "Achtergrondkaart",
+ 'sameProjection':
+ "De overzichtskaart werkt alleen als de projectie gelijk is aan de projectie van de hoofdkaart",
+ 'readNotImplemented': "Lezen niet geïmplementeerd.",
+ 'writeNotImplemented': "Schrijven niet geïmplementeerd.",
+ 'noFID': "Een feature welke geen FID heeft kan niet bijgewerkt worden.",
+ 'errorLoadingGML': "Fout bij het laden van GML bestand ${url}",
+ "Uw browser ondersteunt het weergeven van vector niet. Momenteel ondersteunde weergave engines:\n${renderers}",
+ 'componentShouldBe': "addFeatures : component zou van het type ${geomType} moeten zijn",
+ 'commitSuccess': "WFS-transactie: SUCCESVOL ${response}",
+ 'commitFailed': "WFS-transactie: MISLUKT ${response}",
+ 'googleWarning':
+ "De Google-Layer kon niet correct geladen worden.<br><br>" +
+ "Om deze melding niet meer te krijgen, moet u een andere " +
+ "achtergrondkaart kiezen in de LayerSwitcher in de rechterbovenhoek.<br><br>" +
+ "Dit is waarschijnlijk omdat de ${layerLib} bilbiotheek " +
+ "niet correct ingevoegd is.<br><br>" +
+ "Ontwikkelaars: om dit werkend te krijgen, " +
+ "target='_blank'>klik hier</a>",
+ "De ${layerType} Layer kon niet goed geladen worden.<br><br>" +
+ 'scale': "Schaal = 1 : ${scaleDenom}",
+ 'end': ''
+}, OpenLayers.Lang["en"]);
Added: trunk/lib/OpenLayers/Lang/pt-BR.js
--- trunk/lib/OpenLayers/Lang/pt-BR.js (rev 0)
+++ trunk/lib/OpenLayers/Lang/pt-BR.js 2008-09-05 14:40:48 UTC (rev 1500)
@@ -0,0 +1,122 @@
+ * Namespace: OpenLayers.Lang["pt-BR"]
+ * Dictionary for Brazilian Portuguese. Keys for entries are used in calls to
+OpenLayers.Lang["pt-BR"] = {
+ 'unhandledRequest': "A requisição retornou um erro não tratado: ${statusText}",
+ 'permalink': "Link para essa página",
+ 'overlays': "Camadas de Sobreposição",
+ 'baseLayer': "Camada Base",
+ 'sameProjection':
+ "O mapa de referência só funciona quando ele está na mesma projeção do mapa principal",
+ 'readNotImplemented': "Leitura não implementada.",
+ 'writeNotImplemented': "Escrita não implementada.",
+ 'noFID': "Não é possÃvel atualizar uma feição que não tenha um FID.",
+ 'errorLoadingGML': "Erro ao carregar o arquivo GML ${url}",
+ "Seu navegador não suporta renderização de vetores. Os renderizadores suportados atualmente são:\n${renderers}",
+ 'componentShouldBe': "addFeatures: o componente deve ser do tipo ${geomType}",
+ "getFeatureFromEvent foi executado mas nenhum renderizador foi encontrado. " +
+ "Isso pode indicar que você destruiu uma camana, mas não o handler associado a ela.",
+ "A propriedade minZoomLevel é de uso restrito das camadas "+
+ "descendentes de FixedZoomLevels. A verificação dessa propriedade " +
+ "pelas camadas wfs é um resÃduo do passado. Não podemos, entretanto " +
+ "não é possÃvel removê-la sem possÃvelmente quebrar o funcionamento " +
+ "de aplicações OL que possuem depência com ela. Portanto estamos " +
+ "tornando seu uso obsoleto -- a verificação desse atributo será " +
+ "removida na versão 3.0. Ao invés, use as opções de resolução " +
+ "min/max como descrito em: " +
+ 'commitSuccess': "Transação WFS : SUCESSO ${response}",
+ 'commitFailed': "Transação WFS : ERRO ${response}",
+ 'googleWarning':
+ "Não foi possÃvel carregar a camada Google corretamente.<br><br>" +
+ "Para se livrar dessa mensagem, selecione uma nova Camada Base, " +
+ "na ferramenta de alternação de camadas localização do canto " +
+ "superior direito.<br><br>" +
+ "Muito provavelmente, isso foi causado porque o script da " +
+ "biblioteca do Google Maps não foi incluÃdo, ou porque ele não " +
+ "contém a chave correta da API para o seu site.<br><br>" +
+ "Desenvolvedores: Para obter ajuda em solucionar esse problema " +
+ "target='_blank'>cliquem aqui</a>",
+ "Não foi possÃvel carregar a camada ${layerType} corretamente.<br><br>" +
+ "biblioteca ${layerLib} não foi incluÃdo corretamente.<br><br>" +
+ 'scale': "Escala = 1 : ${scaleDenom}",
+ "Você tentou adicionar a camada: ${layerName} ao mapa, mas ela já foi adicionada",
+ "Você está usando a opção 'reproject' na camada ${layerName}. " +
+ "Essa opção está obsoleta: seu uso foi projetado para suportar " +
+ "a visualização de dados sobre bases de mapas comerciais, " +
+ "entretanto essa funcionalidade deve agora ser alcançada usando " +
+ "o suporte à projeção Mercator. Mais informação está disponÃvel em: " +
+ "Esse método está obsoleto e será removido na versão 3.0. " +
+ "Ao invés, por favor use ${newMethod}.",
+ 'boundsAddError': "Você deve informar ambos os valores x e y para a função add.",
+ 'lonlatAddError': "Você deve informar ambos os valores lon e lat para a função add.",
+ 'pixelAddError': "Você deve informar ambos os valores x e y para a função add.",
+ 'unsupportedGeometryType': "Tipo geométrico não suportado: ${geomType}.",
+ "OpenLayers.Util.pagePosition falhou: o elemento de id ${elemId} deve estar fora do lugar.",
+ 'end': ''
Added: trunk/lib/OpenLayers/Lang/sv-SE.js
--- trunk/lib/OpenLayers/Lang/sv-SE.js (rev 0)
+++ trunk/lib/OpenLayers/Lang/sv-SE.js 2008-09-05 14:40:48 UTC (rev 1500)
@@ -0,0 +1,121 @@
+ * Namespace: OpenLayers.Lang["sv-SE"]
+ * Dictionary for swedish (Sweden). Keys for entries are used in calls to
+OpenLayers.Lang["sv-SE"] = {
+ 'unhandledRequest': "Ej hanterad fråga retur ${statusText}",
+ 'permalink': "Permalänk",
+ 'overlays': "Kartlager",
+ 'baseLayer': "Bakgrundskarta",
+ 'sameProjection':
+ "Översiktskartan fungerar endast när den har samma projektion som huvudkartan",
+ 'readNotImplemented': "Läsning ej implementerad.",
+ 'writeNotImplemented': "Skrivning ej implementerad.",
+ 'noFID': "Kan ej uppdatera feature (objekt) för vilket FID saknas.",
+ 'errorLoadingGML': "Fel i laddning av GML-fil ${url}",
+ "Din webbläsare stöder inte vektorvisning. För närvarande stöds följande visning:\n${renderers}",
+ 'componentShouldBe': "addFeatures : komponenten skall vara en ${geomType}",
+ "getFeatureFromEvent anropad för lager utan utritning. Detta betyder oftast att man " +
+ "raderat ett lager, men inte en hanterare som är knuten till lagret.",
+ "Egenskapen minZoomLevel är endast avsedd att användas " +
+ "med lager med FixedZoomLevels. Att detta WFS-lager " +
+ "kontrollerar minZoomLevel är en relik från äldre versioner. " +
+ "Vi kan dock inte ta bort det utan att riskera att " +
+ "OL-baserade tillämpningar som använder detta slutar " +
+ "fungera. Därför är det satt som deprecated, minZoomLevel " +
+ "kommer att tas bort i version 3.0. Använd i stället " +
+ "inställning av min/max resolution som beskrivs här: " +
+ 'commitSuccess': "WFS-transaktion: LYCKADES ${response}",
+ 'commitFailed': "WFS-transaktion: MISSLYCKADES ${response}",
+ 'googleWarning':
+ "Google-lagret kunde inte laddas korrekt.<br><br>" +
+ "För att slippa detta meddelande, välj en annan bakgrundskarta " +
+ "i lagerväljaren i övre högra hörnet.<br><br>" +
+ "Sannolikt beror felet på att Google Maps-biblioteket " +
+ "inte är inkluderat på webbsidan eller på att sidan " +
+ "inte anger korrekt API-nyckel för webbplatsen.<br><br>" +
+ "Utvecklare: hjälp för att åtgärda detta, " +
+ "target='_blank'>klicka här</a>.",
+ "${layerType}-lagret kunde inte laddas korrekt.<br><br>" +
+ "Sannolikt beror felet på att ${layerLib}-biblioteket " +
+ "inte är inkluderat på webbsidan.<br><br>" +
+ "Du försökte lägga till lagret: ${layerName} på kartan, men det har lagts till tidigare",
+ "Du använder inställningen 'reproject' på lagret ${layerName}. " +
+ "Denna inställning markerad som deprecated: den var avsedd " +
+ "att användas för att stödja visning av kartdata på kommersiella " +
+ "bakgrundskartor, men nu bör man i stället " +
+ "använda Spherical Mercator-stöd för den funktionaliteten. " +
+ "Mer information finns " +
+ "på http://trac.openlayers.org/wiki/SphericalMercator.",
+ "Denna metod är markerad som deprecated och kommer att tas bort i 3.0. " +
+ "Använd ${newMethod} i stället.",
+ 'boundsAddError': "Du måste skicka både x- och y-värde till funktionen add.",
+ 'lonlatAddError': "Du måste skicka både lon- och lat-värde till funktionen add.",
+ 'pixelAddError': "Du måste skicka både x- och y-värde till funktionen add.",
+ 'unsupportedGeometryType': "Stöd saknas för geometritypen: ${geomType}",
+ "OpenLayers.Util.pagePosition misslyckades: elementet med id ${elemId} kan placeras fel.",
+ 'end': ''
Added: trunk/lib/OpenLayers/Lang/zh-CN.js
--- trunk/lib/OpenLayers/Lang/zh-CN.js (rev 0)
+++ trunk/lib/OpenLayers/Lang/zh-CN.js 2008-09-05 14:40:48 UTC (rev 1500)
@@ -0,0 +1,120 @@
+ * Namespace: OpenLayers.Lang["zh-CN"]
+ * Dictionary for Simplified Chinese. Keys for entries are used in calls to
+OpenLayers.Lang["zh-CN"] = {
+ 'unhandledRequest': "æªå¤çç请æ±ï¼è¿åå¼ä¸º ${statusText}",
+ 'permalink': "æ°¸ä¹
龿¥",
+ 'overlays': "å å å±",
+ 'baseLayer': "åºç¡å¾å±",
+ 'sameProjection':
+ "é¹°ç¼å°å¾åªæå¨å主å°å¾ä½¿ç¨ç¸åçæå½±çæ¶åæè½æ£å¸¸å
±å·¥ä½",
+ 'readNotImplemented': "读ååè½æ²¡æå®ç°ã",
+ 'writeNotImplemented': "åå
¥åè½æ²¡æå®ç°ã",
+ 'noFID': "æ æ³æ´æ°featureï¼ç¼ºå°FIDã",
+ 'errorLoadingGML': "å è½½GMLæä»¶ ${url} åºç°é误ã",
+ "ä½ ä½¿ç¨çæµè§å¨ä¸æ¯æç¢é渲æãå½åæ¯æçæ¸²ææ¹å¼å
æ¬ï¼\n${renderers}",
+ 'componentShouldBe': "addFeatures : ç»ä»¶ç±»ååºè¯¥æ¯ ${geomType}",
+ "getFeatureFromEventæ¹æ³å¨ä¸ä¸ªæ²¡ææ¸²æå¨çå¾å±ä¸è¢«è°ç¨ã è¿é常æå³çæ¨" +
+ "鿝äºä¸ä¸ªå¾å±ï¼ä½å¹¶æªéæ¯å
¶å
³èçhandlerã",
+ "minZoomLevel屿§ä»
éåç¨äº" +
+ "使ç¨äºåºå®ç¼©æ¾çº§å«çå¾å±ãè¿ä¸ª " +
+ "wfs å¾å±æ£æ¥ minZoomLevel æ¯è¿å»éç䏿¥çã" +
+ "ç¶èï¼æä»¬ä¸è½ç§»é¤å®ï¼" +
+ "èç ´åä¾èµäºå®çåºäºOLçåºç¨ç¨åºã" +
+ "å æ¤ï¼æä»¬åºé¤äºå® -- minZoomLevel " +
+ "å°ä¼å¨3.0ä¸è¢«ç§»é¤ã请æ¹ç¨ " +
+ "min/max resolution 设置ï¼åèï¼" +
+ 'commitSuccess': "WFS Transaction: æåã ${response}",
+ 'commitFailed': "WFS Transaction: 失败ã ${response}",
+ 'googleWarning':
+ "Googleå¾å±ä¸è½æ£ç¡®å è½½ã<br><br>" +
+ "è¦æ¶é¤è¿ä¸ªä¿¡æ¯ï¼è¯·å¨å³ä¸è§ç" +
+ "å¾å±æ§å¶é¢æ¿ä¸éæ©å
¶ä»çåºç¡å¾å±ã<br><br>" +
+ "è¿ç§æ
åµå¾å¯è½æ¯æ²¡ææ£ç¡®çå
å«Googleå°å¾èæ¬åºï¼" +
+ "æè
æ¯æ²¡æå
å«å¨ä½ çç«ç¹ä¸" +
+ "使ç¨çæ£ç¡®çGoogle Maps APIå¯åã<br><br>" +
+ "å¼åè
ï¼è·å使å
¶æ£ç¡®å·¥ä½ç帮å©ä¿¡æ¯ï¼" +
+ "target='_blank'>ç¹å»è¿é</a>",
+ "${layerType} å¾å±ä¸è½æ£ç¡®å è½½ã<br><br>" +
+ "è¿ç§æ
å«" +
+ "${layerLib} èæ¬åºã<br><br>" +
+ "å¼åè
ï¼è·å使å
+ 'scale': "æ¯ä¾å°º = 1 : ${scaleDenom}",
+ "ä½ å°è¯æ·»å å¾å±ï¼ ${layerName} å°å°å¾ä¸ï¼ä½æ¯å®ä¹å就已ç»è¢«æ·»å ã",
+ "ä½ æ£å¨ä½¿ç¨ ${layerName} å¾å±ä¸ç'reproject'é项ã" +
+ "è¿ä¸ªé项已ç»ä¸å使ç¨ï¼" +
+ "宿¯è¢«è®¾è®¡ç¨æ¥æ¯ææ¾ç¤ºåä¸çå°å¾æ°æ®ï¼" +
+ "ä¸è¿ç°å¨è¯¥åè½å¯ä»¥éè¿ä½¿ç¨Spherical Mercatoræ¥å®ç°ã" +
+ "æ´å¤ä¿¡æ¯å¯ä»¥åé
+ "è¯¥æ¹æ³å·²ç»ä¸åè¢«æ¯æï¼å¹¶ä¸å°å¨3.0ä¸è¢«ç§»é¤ã" +
+ "è¯·ä½¿ç¨ ${newMethod} æ¹æ³æ¥æ¿ä»£ã",
+ 'boundsAddError': "æ¨å¿
é¡»ä¼ é x å y ä¸¤ä¸ªåæ°å¼å° add æ¹æ³ã",
+ 'lonlatAddError': "æ¨å¿
é¡»ä¼ é lon å lat ä¸¤ä¸ªåæ°å¼å° add æ¹æ³ã",
+ 'pixelAddError': "æ¨å¿
é¡»ä¼ é x and y ä¸¤ä¸ªåæ°å¼å° add æ¹æ³ã",
+ 'unsupportedGeometryType': "䏿¯æçå ä½ä½ç±»åï¼ ${geomType}",
+ "OpenLayers.Util.pagePosition 失败ï¼id 为 ${elemId} çå
ç´ å¯è½è¢«éç½®ã",
+ 'end': ''
Added: trunk/lib/OpenLayers/Lang/zh-TW.js
--- trunk/lib/OpenLayers/Lang/zh-TW.js (rev 0)
+++ trunk/lib/OpenLayers/Lang/zh-TW.js 2008-09-05 14:40:48 UTC (rev 1500)
@@ -0,0 +1,121 @@
+ * Namespace: OpenLayers.Lang["zh-TW"]
+ * Dictionary for Traditional Chinese. (Used Mainly in Taiwan)
+ * Keys for entries are used in calls to
+OpenLayers.Lang["zh-TW"] = {
+ 'unhandledRequest': "æªèççè«æ±ï¼å³åå¼çº ${statusText}ã",
é£çµ",
+ 'overlays': "é¡å¤å層",
+ 'baseLayer': "åºç¤å層",
+ 'sameProjection':
+ "å°å縮覽(OverviewMap)åªè½å¨è·ä¸»å°åç¸åæå½±æèµ·ä½ç¨ã",
+ 'readNotImplemented': "æ²æå¯¦ä½è®åçåè½ã",
+ 'writeNotImplemented': "æ²æå¯¦ä½å¯«å
¥çåè½ã",
+ 'noFID': "å çºæ²æ FID æä»¥ç¡æ³æ´æ° featureã",
+ 'errorLoadingGML': "è®åGMLæªæ¡ ${url} é¯èª¤ã",
+ "æ¨ççè¦½å¨æªæ¯æ´å鿏²æ. ç®åæ¯æ´çæ¸²ææ¹å¼æ¯:\n${renderers}",
+ 'componentShouldBe': "addFeatures : å
ä»¶æè©²çº ${geomType}",
+ "getFeatureFromEvent å¨ä¸åæ²æè¢«æ¸²æçå層裡被å¼å«ãéé常æå³èæ¨ " +
+ "æ§æ¯äºä¸åå層ï¼ä½ä¸¦æªæ§æ¯ç¸éçhandlerã",
+ "minZoomLevel 屬æ§å
é©åç¨å¨ " +
+ "FixedZoomLevels-descendent é¡åçå層. éå" +
+ "wfs layer ç minZoomLevel æ¯é廿éºçä¸ä¾çï¼" +
+ "ç¶èæåä¸è½ç§»é¤å®èä¸è®å®å°" +
+ "éå»çç¨å¼ç¸å®¹æ§çµ¦ç ´å£æã" +
+ "å æ¤æåå°æè¿´é¿ä½¿ç¨å® -- minZoomLevel " +
+ "æå¨3.0被移é¤ï¼è«æ¹" +
+ "ç¨å¨ééæè¿°ç min/max resolution è¨å®: " +
+ 'commitSuccess': "WFS Transaction: æå ${response}",
+ 'commitFailed': "WFS Transaction: 失æ ${response}",
+ 'googleWarning':
+ "The Google Layer åå±¤ç¡æ³è¢«æ£ç¢ºçè¼å
¥ã<br><br>" +
+ "è¦è¿´é¿éåè¨æ¯, è«å¨å³ä¸è§çå層æ¹è®å¨è£¡ï¼" +
+ "é¸ä¸åæ°çåºç¤å層ã<br><br>" +
+ "徿å¯è½æ¯å çº Google Maps çå½å¼åº«" +
+ "è
³æ¬æ²æè¢«æ£ç¢ºçç½®å
¥ï¼ææ²æå
å« " +
+ "æ¨ç¶²ç«ä¸æ£ç¢ºç API key <br><br>" +
+ "éç¼è
: è¦å¹«å©éåè¡çºæ£ç¢ºå®æï¼" +
+ "target='_blank'>è«æé裡</a>",
+ "${layerType} åå±¤ç¡æ³è¢«æ£ç¢ºçè¼å
¥ã<br><br>" +
+ "徿å¯è½æ¯å çº ${layerLib} çå½å¼åº«" +
+ "è
³æ¬æ²æè¢«æ£ç¢ºçç½®å
¥ã<br><br>" +
+ "éç¼è
+ 'scale': "Scale = 1 : ${scaleDenom}",
+ "ä½ è©¦èæ°å¢å層: ${layerName} å°å°åä¸ï¼ä½å層ä¹å就已ç¶è¢«æ°å¢äºã",
+ "ä½ æ£ä½¿ç¨ 'reproject' éåé¸é
+ "å¨ ${layerName} 層ãéåé¸é
å·²ç¶ä¸å使ç¨:" +
+ "å®ç使ç¨åæ¬æ¯è¨è¨ç¨ä¾æ¯æ´å¨åæ¥å°åä¸ç§åºè³æï¼" +
+ "ä½éååè½å·²ç¶è¢«" +
+ "Spherical Mercatoræåä»£ãæ´å¤çè³è¨å¯ä»¥å¨ " +
+ "http://trac.openlayers.org/wiki/SphericalMercator æ¾å°ã",
+ "éåæ¹æ³å·²ç¶ä¸å使ç¨ä¸å¨3.0å°æè¢«ç§»é¤ï¼" +
+ "è«ä½¿ç¨ ${newMethod} ä¾ä»£æ¿ã",
é å³å
¥ x è· y å
©è
çå¼é² add 彿¸ã",
é å³å
¥ lon è· lat å
©è
çå¼é² add 彿¸ã",
é å³å
¥ x è· y å
©è
çå¼é² add 彿¸ã",
+ 'unsupportedGeometryType': "æªæ¯æ´çå¹¾ä½åå¥: ${geomType}ã",
+ "OpenLayers.Util.pagePosition 失æ: id ${elemId} ç element å¯è½è¢«é¯ç½®ã",
+ 'end': ''
Added: trunk/lib/OpenLayers/theme/default/img/navigation_history.png
(Binary files differ)
Property changes on: trunk/lib/OpenLayers/theme/default/img/navigation_history.png
___________________________________________________________________
+ application/octet-stream
Added: trunk/lib/OpenLayers/theme/default/img/save_features_off.png
Property changes on: trunk/lib/OpenLayers/theme/default/img/save_features_off.png
Added: trunk/lib/OpenLayers/theme/default/img/save_features_on.png
Property changes on: trunk/lib/OpenLayers/theme/default/img/save_features_on.png
More information about the fusion-commits
