[fusion-commits] r1513 - sandbox/jx2/lib
svn_fusion at osgeo.org
Wed Sep 10 08:15:02 EDT 2008
Author: pagameba
Date: 2008-09-10 08:15:02 -0400 (Wed, 10 Sep 2008)
New Revision: 1513
sandbox/jx2/lib/Widget.js
add shared active state amongst widgets of the same type so if you choose a tool in a menu, the corresponding tool in the toolbar also shows as active.
Modified: sandbox/jx2/lib/Widget.js
--- sandbox/jx2/lib/Widget.js 2008-09-10 11:46:10 UTC (rev 1512)
+++ sandbox/jx2/lib/Widget.js 2008-09-10 12:15:02 UTC (rev 1513)
@@ -45,10 +45,6 @@
group: null,
domObj: null,
uiClass: null,
- initializeWidget: function() {},
- activate: function() {},
- deactivate: function() {},
- setUiObject: function(uiObj) { this.uiObj = uiObj; },
* initialize the widget
@@ -59,6 +55,9 @@
this.name = widgetTag.name;
this.widgetTag = widgetTag;
this.registerEventID(Fusion.Event.WIDGET_STATE_CHANGED);
+ if (!Fusion.Widget.uiInstances[this.type]) {
+ Fusion.Widget.uiInstances[this.type] = [];
var group = widgetTag.extension.Group ? widgetTag.extension.Group[0] : '';
if (group != '') {
@@ -78,6 +77,40 @@
this.initializeWidget(widgetTag);
+ initializeWidget: function() {},
+ activate: function() { },
+ deactivate: function() { },
+ setUiObject: function(uiObj) {
+ Fusion.Widget.uiInstances[this.type].push(uiObj);
+ if (Fusion.Widget.uiInstances[this.type][0].options.isActive) {
+ uiObj.options.isActive = true;
+ uiObj.domA.addClass('jx' + uiObj.options.type + 'Active');
+ uiObj.addEvents({
+ 'up': (function() {
+ var instances = Fusion.Widget.uiInstances[this.type];
+ for (var i=0; i<instances.length; i++) {
+ var instance = instances[i];
+ instance.options.isActive = false;
+ instance.domA.removeClass('jx' + instance.options.type + 'Active');
+ }).bind(this),
+ 'down': (function() {
+ instance.options.isActive = true;
+ instance.domA.addClass('jx' + instance.options.type + 'Active');
+ }).bind(this)
+ this.uiObj = uiObj;
* set the map object that this widget is associated with
* @param oMap {Object} the map
@@ -185,3 +218,5 @@
this.paramRegister.push(param);
+Fusion.Widget.uiInstances = {};
More information about the fusion-commits
