[fusion-commits] r1535 - in trunk/templates/mapguide/standard: . images
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Sep 16 13:51:18 EDT 2008
Author: pagameba
Date: 2008-09-16 13:51:18 -0400 (Tue, 16 Sep 2008)
New Revision: 1535
Added:
   trunk/templates/mapguide/standard/icons.css
   trunk/templates/mapguide/standard/images/icons.png
   trunk/templates/mapguide/standard/ApplicationDefinition.xml
   trunk/templates/mapguide/standard/index.html
add image strip icons to mapguide sample template
Modified: trunk/templates/mapguide/standard/ApplicationDefinition.xml
--- trunk/templates/mapguide/standard/ApplicationDefinition.xml	2008-09-16 17:44:00 UTC (rev 1534)
+++ trunk/templates/mapguide/standard/ApplicationDefinition.xml	2008-09-16 17:51:18 UTC (rev 1535)
@@ -336,8 +336,8 @@
       <Name>menuPan</Name>
       <Type>Pan</Type>
       <StatusItem>Drag the map to view areas out of range.</StatusItem>
-      <ImageUrl>images/icons/pan.png</ImageUrl>
-      <ImageClass/>
+      <ImageUrl>images/icons.png</ImageUrl>
+      <ImageClass>pan</ImageClass>
       <Tooltip>Pan mode</Tooltip>
       <Label>Pan</Label>
       <Disabled/>
@@ -353,8 +353,8 @@
         <Tolerance>5</Tolerance>
         <Factor>2</Factor>
       </Extension>
-      <ImageUrl>images/icons/zoom-in.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>zoom-in</ImageClass>
       <Tooltip>Zoom In</Tooltip>
       <Label>Zoom Rectangle</Label>
       <Disabled/>
@@ -369,8 +369,8 @@
       <Extension xsi:type="CustomContentType">
         <Factor>2</Factor>
       </Extension>
-      <ImageUrl>images/icons/zoom-in-fixed.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>zoom-in-fixed</ImageClass>
       <Label>Zoom In</Label>
       <Disabled/>
@@ -382,8 +382,8 @@
       <Name>menuRefreshMap</Name>
       <Type>RefreshMap</Type>
       <StatusItem>Refreshes the map image.</StatusItem>
-      <ImageUrl>images/icons/view-refresh.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>view-refresh</ImageClass>
       <Tooltip>Refresh map and reload all layers, keeping the current center point and scale.</Tooltip>
       <Label>Refresh Map</Label>
       <Disabled/>
@@ -398,8 +398,8 @@
         <Factor>0.5</Factor>
       </Extension>
-      <ImageUrl>images/icons/zoom-out-fixed.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>zoom-out-fixed</ImageClass>
       <Tooltip>Zoom Out</Tooltip>
       <Label>Zoom Out</Label>
       <Disabled/>
@@ -414,8 +414,8 @@
         <ViewType>extent</ViewType>
       </Extension>
-      <ImageUrl>images/icons/zoom-full.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>zoom-full</ImageClass>
       <Tooltip>Initial Map View</Tooltip>
       <Label>Initial Map View</Label>
       <Disabled/>
@@ -430,8 +430,8 @@
         <Direction>previous</Direction>
       </Extension>
-      <ImageUrl>images/icons/view-back.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>view-back</ImageClass>
       <Tooltip>Previous View</Tooltip>
       <Label>View Previous</Label>
       <Disabled/>
@@ -446,8 +446,8 @@
         <Direction>next</Direction>
       </Extension>
-      <ImageUrl>images/icons/view-forward.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>view-forward</ImageClass>
       <Tooltip>Next View</Tooltip>
       <Label>View Next</Label>
       <Disabled/>
@@ -462,8 +462,8 @@
         <ViewType>center</ViewType>
       </Extension>
-      <ImageClass/>
       <Tooltip>Initial Map Center and Scale</Tooltip>
       <Label>Initial Center and Scale</Label>
       <Disabled/>
@@ -475,8 +475,8 @@
       <Name>menuZoomSelection</Name>
       <Type>ZoomToSelection</Type>
       <StatusItem>Zoom to the extents of the current selection.</StatusItem>
-      <ImageUrl>images/icons/select-zoom.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>select-zoom</ImageClass>
       <Tooltip>Zoom to selection.</Tooltip>
       <Label>Zoom Selection</Label>
       <Disabled/>
@@ -488,8 +488,8 @@
       <Name>menuSelect</Name>
       <Type>Select</Type>
       <StatusItem>Select features by clicking and dragging.</StatusItem>
-      <ImageUrl>images/icons/select-features.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>select-features</ImageClass>
       <Tooltip>Select mode</Tooltip>
       <Label>Select mode</Label>
       <Disabled/>
@@ -501,8 +501,8 @@
       <Name>menuClearSelection</Name>
       <Type>ClearSelection</Type>
       <StatusItem>Clears the current selection.</StatusItem>
-      <ImageUrl>images/icons/select-clear.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>select-clear</ImageClass>
       <Tooltip/>
       <Label>Clear Selection</Label>
       <Disabled/>
@@ -514,8 +514,8 @@
       <Name>menuSelectRadius</Name>
       <Type>SelectRadius</Type>
       <StatusItem>Click and drag to select all features inside a circle.</StatusItem>
-      <ImageUrl>images/icons/select-radius.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>select-radius</ImageClass>
       <Tooltip>Select Radius</Tooltip>
       <Label>Select Radius</Label>
       <Disabled/>
@@ -527,8 +527,8 @@
       <Name>menuSelectPolygon</Name>
       <Type>SelectPolygon</Type>
       <StatusItem>Create a polygon and select all features that fall within.</StatusItem>
-      <ImageUrl>images/icons/select-polygon.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>select-polygon</ImageClass>
       <Tooltip>Select Polygon</Tooltip>
       <Label>Select Polygon</Label>
       <Disabled/>
@@ -540,8 +540,8 @@
       <Name>menuSelectWithin</Name>
       <Type>SelectWithin</Type>
       <StatusItem>Select all features that fall within the currently selected area.</StatusItem>
-      <ImageUrl>images/icons/select-within.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>select-within</ImageClass>
       <Tooltip>Select Within</Tooltip>
       <Label>Select Within</Label>
       <Disabled/>
@@ -553,8 +553,8 @@
       <Name>menuBuffer</Name>
       <Type>BufferPanel</Type>
       <StatusItem>Create buffers around the selected features</StatusItem>
-      <ImageUrl>images/icons/buffer.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>buffer</ImageClass>
       <Tooltip>Buffer</Tooltip>
       <Label>Buffer</Label>
       <Disabled/>
@@ -569,8 +569,8 @@
         <DisplayUnits>degrees</DisplayUnits>
       </Extension>
-      <ImageUrl>images/icons/view-options.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>view-options</ImageClass>
       <Tooltip/>
       <Label>View Options</Label>
       <Disabled/>
@@ -582,8 +582,8 @@
       <Name>menuHelp</Name>
       <Type>Help</Type>
       <StatusItem/>
-      <ImageUrl>images/icons/help.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>help</ImageClass>
       <Tooltip/>
       <Label>Help</Label>
       <Disabled/>
@@ -617,8 +617,8 @@
         <Units>meters</Units>
         <Target>TaskPane</Target>
       </Extension>
-      <ImageUrl>images/icons/measure.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>measure</ImageClass>
       <Label>Measure</Label>
       <Disabled/>
@@ -636,8 +636,8 @@
       <Name>toolbarBuffer</Name>
-      <ImageClass/>
       <Extension>
@@ -652,8 +652,8 @@
       <Name>toolbarRefreshMap</Name>
-      <ImageClass/>
       <Disabled/>
@@ -674,8 +674,8 @@
       </Extension>
-      <ImageClass/>
       <Tooltip>Measure</Tooltip>
       <Disabled/>
@@ -690,8 +690,8 @@
         <DisplayUnits>meters</DisplayUnits>
       </Extension>
-      <ImageClass/>
       <Tooltip/>
       <Disabled/>
@@ -703,8 +703,8 @@
       <Name>toolbarHelp</Name>
       <Type>Help</Type>
       <StatusItem/>
-      <ImageClass/>
       <Tooltip/>
       <Label></Label>
       <Disabled/>
@@ -729,8 +729,8 @@
       <Name>toolbarClearSelection</Name>
-      <ImageClass/>
       <Tooltip/>
       <Label></Label>
       <Disabled/>
@@ -742,8 +742,8 @@
       <Name>toolbarSelectRadius</Name>
-      <ImageClass/>
       <Label></Label>
       <Disabled/>
@@ -755,8 +755,8 @@
       <Name>toolbarSelectPolygon</Name>
-      <ImageClass/>
       <Label></Label>
       <Disabled/>
@@ -779,8 +779,8 @@
       </Extension>
-      <ImageClass/>
       <Label/>
       <Disabled/>
@@ -795,8 +795,8 @@
       </Extension>
-      <ImageClass/>
       <Label/>
       <Disabled/>
@@ -811,8 +811,8 @@
       </Extension>
-      <ImageClass/>
       <Label/>
       <Disabled/>
@@ -824,8 +824,8 @@
       <Name>toolbarSecondaryZoomSelection</Name>
-      <ImageClass/>
       <Label/>
       <Disabled/>
@@ -957,8 +957,8 @@
         <Factor>2</Factor>
       </Extension>
-      <ImageClass/>
       <Tooltip>Zoom in to a rectangular region.</Tooltip>
       <Label/>
       <Disabled/>
@@ -973,8 +973,8 @@
         <Factor>4</Factor>
       </Extension>
-      <ImageClass/>
       <Tooltip>Zoom in by a fixed factor.</Tooltip>
       <Label/>
       <Disabled/>
@@ -989,8 +989,8 @@
       </Extension>
-      <ImageClass/>
       <Tooltip>Zoom Out by a fixed factor</Tooltip>
       <Label/>
       <Disabled/>
@@ -1002,8 +1002,8 @@
       <Name>Select</Name>
       <Type>Select</Type>
-      <ImageClass/>
       <Label/>
       <Disabled/>
@@ -1047,8 +1047,8 @@
         <ShowNorthArrow>true</ShowNorthArrow>
         <ImageBaseUrl>images/</ImageBaseUrl>
       </Extension>
-      <ImageUrl>images/icons/file-print.png</ImageUrl>
-      <ImageClass/>
+      <ImageClass>file-print</ImageClass>
       <Tooltip>Get printable page.</Tooltip>
       <Label></Label>
       <Disabled/>
@@ -1060,8 +1060,8 @@
       <Name>Pan</Name>
       <Type>Pan</Type>
-      <ImageClass/>
       <Label/>
       <Disabled/>
Added: trunk/templates/mapguide/standard/icons.css
--- trunk/templates/mapguide/standard/icons.css	                        (rev 0)
+++ trunk/templates/mapguide/standard/icons.css	2008-09-16 17:51:18 UTC (rev 1535)
@@ -0,0 +1,44 @@
+img.buffer { background-position: 0px 0px; }
+img.edit-copy { background-position: -16px 0px; }
+img.edit-cut { background-position: -32px 0px; }
+img.edit-duplicate { background-position: -48px 0px; }
+img.edit-paste { background-position: -64px 0px; }
+img.edit-redo { background-position: -80px 0px; }
+img.edit-undo { background-position: -96px 0px; }
+img.file-open { background-position: -112px 0px; }
+img.file-print { background-position: -128px 0px; }
+img.file-save { background-position: -144px 0px; }
+img.help { background-position: -160px 0px; }
+img.legend-layer { background-position: -176px 0px; }
+img.legend-map { background-position: -192px 0px; }
+img.legend-raster { background-position: -208px 0px; }
+img.legend-theme { background-position: -224px 0px; }
+img.measure { background-position: -240px 0px; }
+img.move-down { background-position: -256px 0px; }
+img.move-up { background-position: -272px 0px; }
+img.navigator { background-position: -288px 0px; }
+img.pan-east { background-position: -304px 0px; }
+img.pan-north { background-position: -320px 0px; }
+img.pan-south { background-position: -336px 0px; }
+img.pan { background-position: -352px 0px; }
+img.search { background-position: -368px 0px; }
+img.select-attribute { background-position: -384px 0px; }
+img.select-centre { background-position: -400px 0px; }
+img.select-clear { background-position: -416px 0px; }
+img.select-features { background-position: -432px 0px; }
+img.select-polygon { background-position: -448px 0px; }
+img.select-query { background-position: -464px 0px; }
+img.select-radius { background-position: -480px 0px; }
+img.select-rectangle { background-position: -496px 0px; }
+img.select-zoom { background-position: -512px 0px; }
+img.select { background-position: -528px 0px; }
+img.view-back { background-position: -544px 0px; }
+img.view-forward { background-position: -560px 0px; }
+img.view-refresh { background-position: -576px 0px; }
+img.warning { background-position: -592px 0px; }
+img.west { background-position: -608px 0px; }
+img.zoom-full { background-position: -624px 0px; }
+img.zoom-in-fixed { background-position: -640px 0px; }
+img.zoom-in { background-position: -656px 0px; }
+img.zoom-out-fixed { background-position: -672px 0px; }
+img.zoom-out { background-position: -688px 0px; }
Added: trunk/templates/mapguide/standard/images/icons.png
(Binary files differ)
Property changes on: trunk/templates/mapguide/standard/images/icons.png
___________________________________________________________________
   + application/octet-stream
Modified: trunk/templates/mapguide/standard/index.html
--- trunk/templates/mapguide/standard/index.html	2008-09-16 17:44:00 UTC (rev 1534)
+++ trunk/templates/mapguide/standard/index.html	2008-09-16 17:51:18 UTC (rev 1535)
@@ -5,10 +5,10 @@
 <title>Sample Fusion Application</title>
 <!-- change the source of the following tag to point to your fusion installation -->
 <script type="text/javascript" src="../../../lib/fusion.js"></script>
+<link rel="stylesheet" href="../../../jx/jxskin_delicious.css" type="text/css" media="screen" charset="utf-8">
+<link rel="stylesheet" href="icons.css" type="text/css" media="screen" charset="utf-8">
 <style type="text/css">
-    @import url(../../../jx/lib/jxskin_delicious.css);
     #Statusbar .spanCursorPosition,
     #Statusbar .inputEditableScale,
     #Statusbar .spanViewSize,
More information about the fusion-commits mailing list
