[fusion-commits] r1541 - in trunk/MapGuide: . php
svn_fusion at osgeo.org
Mon Sep 22 14:48:25 EDT 2008
Author: Assefa
Date: 2008-09-22 14:48:25 -0400 (Mon, 22 Sep 2008)
New Revision: 1541
trunk/MapGuide/MapGuide.js
trunk/MapGuide/php/LoadMap.php
Initial cleaup of LoadMap.php (remove unnecessary elements, optimize get layer types) #129
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js 2008-09-18 12:23:49 UTC (rev 1540)
+++ trunk/MapGuide/MapGuide.js 2008-09-22 18:48:25 UTC (rev 1541)
@@ -466,6 +466,7 @@
hideGroups : this.aHideGroups.length > 0 ? this.aHideGroups.toString() : null,
refreshLayers : this.aRefreshLayers.length > 0 ? this.aRefreshLayers.toString() : null
this.aShowLayers = [];
this.aHideLayers = [];
this.aShowGroups = [];
@@ -473,6 +474,7 @@
this.aRefreshLayers = [];
this.oLayerOL.mergeNewParams(params);
if (this.queryLayer) this.queryLayer.redraw(true);
@@ -1094,16 +1096,17 @@
this.layerName = o.layerName;
this.uniqueId = o.uniqueId;
this.resourceId = o.resourceId;
- this.legendLabel = o.legendLabel;
this.selectable = o.selectable;
this.selectedFeatureCount = 0;
this.layerTypes = [].concat(o.layerTypes);
- this.displayInLegend = o.displayInLegend;
- this.expandInLegend = o.expandInLegend;
this.visible = o.visible;
this.actuallyVisible = o.actuallyVisible;
this.editable = o.editable;
+ this.legendLabel = o.legendLabel;
+ this.displayInLegend = o.displayInLegend;
+ this.expandInLegend = o.expandInLegend;
//determine the layer type so that the correct icon can be displayed in the legend
this.layerType = null;
if (this.supportsType(Fusion.Constant.LAYER_RASTER_TYPE)) { //raster layers
@@ -1113,15 +1116,20 @@
this.parentGroup = o.parentGroup;
+ this.minScale = o.minScale;
+ this.maxScale = o.maxScale;
+ if (this.maxScale == 'infinity') {
+ this.maxScale = Infinity;
this.scaleRanges = [];
- this.minScale = 1.0e10;
- this.maxScale = 0;
- for (var i=0; i<o.scaleRanges.length; i++) {
- var scaleRange = new Fusion.Maps.MapGuide.ScaleRange(o.scaleRanges[i],
- this.layerType);
- this.scaleRanges.push(scaleRange);
- this.minScale = Math.min(this.minScale, scaleRange.minScale);
- this.maxScale = Math.max(this.maxScale, scaleRange.maxScale);
+ if (o.scaleRanges)
+ for (var i=0; i<o.scaleRanges.length; i++) {
+ var scaleRange = new Fusion.Maps.MapGuide.ScaleRange(o.scaleRanges[i],
+ this.layerType);
+ this.scaleRanges.push(scaleRange);
Modified: trunk/MapGuide/php/LoadMap.php
--- trunk/MapGuide/php/LoadMap.php 2008-09-18 12:23:49 UTC (rev 1540)
+++ trunk/MapGuide/php/LoadMap.php 2008-09-22 18:48:25 UTC (rev 1541)
@@ -28,9 +28,12 @@
* Purpose: get map initial information
+include(dirname(__FILE__).'/../../common/php/Utilities.php');
include('Common.php');
include('Utilities.php');
+$mapObj = NULL;
try
$mappingService = $siteConnection->CreateService(MgServiceType::MappingService);
@@ -40,13 +43,10 @@
if (isset($_REQUEST['mapid']))
$mapid = $_REQUEST['mapid'];
- //echo $mapid;
$resourceID = new MgResourceIdentifier($mapid);
$map = new MgMap();
$mapTitle = $resourceID->GetName();
- //echo "<br> maname $mapName <br>";
$map->Create($resourceService, $resourceID, $mapTitle);
$mapName = uniqid($mapTitle);
@@ -66,8 +66,6 @@
$mapid = $map->GetMapDefinition()->ToString();
- //$sessionId = $map->GetSessionId();
- //$mapName = $map->GetName() ;
$extents = $map->GetMapExtent();
@$oMin = $extents->GetLowerLeftCoordinate();
@$oMax = $extents->GetUpperRightCoordinate();
@@ -87,65 +85,94 @@
- header('Content-type: text/x-json');
- header('X-JSON: true');
- echo "{";
- echo "sessionId:'$sessionID',";
- echo "mapId:'$mapid',";
- echo "metersPerUnit:$metersPerUnit,";
- //echo "mapTitle:'".addslashes(htmlentities($mapTitle))."',";
- //echo "mapName:'".addslashes(htmlentities($mapName))."',";
- echo "mapTitle:'".addslashes($mapTitle)."',";
- echo "mapName:'".addslashes($mapName)."',";
- echo "extent:[";
- echo $oMin->GetX().",";
- echo $oMin->GetY().",";
- echo $oMax->GetX().",";
- echo $oMax->GetY()."],";
+ //header('Content-type: text/x-json');
+ //header('X-JSON: true');
+ $mapObj->sessionId = $sessionID;
+ $mapObj->mapId = $mapid;
+ $mapObj->metersPerUnit = $metersPerUnit;
+ $mapObj->mapTitle=addslashes($mapTitle);
+ $mapObj->mapName=addslashes($mapName);
+ $mapObj->extent = array($oMin->GetX(), $oMin->GetY(), $oMax->GetX(), $oMax->GetY());
$layers=$map->GetLayers();
- echo "layers:[";
- $layerSep = '';
+ //layers
+ $mapObj->layers = array();
for($i=0;$i<$layers->GetCount();$i++)
+ //only output layers that are part of the 'Normal Group' and
+ //not the base map group used for tile maps. (Where is the test for that Y.A.???)
$layer=$layers->GetItem($i);
+ $layerDefinition = $layer->GetLayerDefinition();
+ $layerObj = NULL;
+ $mappings = GetLayerPropertyMappings($resourceService, $layer);
+ $_SESSION['property_mappings'][$layer->GetObjectId()] = $mappings;
- //only output layers that are part of the 'Normal Group' and
- //not the base map group used for tile maps.
- echo $layerSep.'{';
- OutputLayerInfo($layer, $resourceService, $featureService);
- echo '}';
- $layerSep = ',';
+ $layerObj->uniqueId = $layer->GetObjectId();
+ $layerObj->layerName = addslashes($layer->GetName());
+ //$aLayerTypes = GetLayerTypes($featureService, $layer);
+ $aLayerTypes = GetLayerTypesFromResourceContent($layer);
+ $layerObj->layerTypes = $aLayerTypes;
+ $layerObj->resourceId = $layerDefinition->ToString();
+ $layerObj->parentGroup = $layer->GetGroup() ? $layer->GetGroup()->GetObjectId() : '';
+ $layerObj->selectable = BooleanToString($layer->GetSelectable());
+ $layerObj->visible = BooleanToString($layer->GetVisible());
+ $layerObj->actuallyVisible = BooleanToString($layer->isVisible());
+ $layerObj->editable = IsLayerEditable($resourceService, $layer) ? 'true' : 'false';
+ $layerObj->legendLabel = addslashes($layer->GetLegendLabel());
+ $layerObj->displayInLegend = BooleanToString($layer->GetDisplayInLegend());
+ $layerObj->expandInLegend = BooleanToString($layer->GetExpandInLegend());
+ $oScaleRanges = buildScaleRanges($layer);
+ $layerObj->scaleRanges = $oScaleRanges;
+ /*get the min/max scale for the layer*/
+ $nCount = count($oScaleRanges);
+ $layerObj->minScale = $oScaleRanges[0]->minScale;
+ $layerObj->maxScale = $oScaleRanges[0]->maxScale;
+ for ($j=1; $j<$nCount; $j++)
+ $layerObj->minScale = min($layerObj->minScale, $oScaleRanges[$j]->minScale);
+ $layerObj->maxScale = max($layerObj->maxScale, $oScaleRanges[$j]->maxScale);
+ array_push($mapObj->layers, $layerObj);
- echo "],";
//Get layer groups as xml
$groups = $map->GetLayerGroups();
- echo "groups:[";
- $groupSep = '';
+ $mapObj->groups = array();
for($i=0;$i<$groups->GetCount();$i++)
$group=$groups->GetItem($i);
- echo $groupSep.'{';
- OutputGroupInfo($group);
- echo '}';
- $groupSep = ',';
+ array_push($mapObj->groups, OutputGroupInfo($group));
- echo"],";
- //FiniteDisplayScales for tiled maps
- echo "FiniteDisplayScales:[";
+ $mapObj->FiniteDisplayScales = array();
+ //FiniteDisplayScales for tiled maps
for ($i=0; $i<$map->GetFiniteDisplayScaleCount(); $i++)
- if ($i>0)
- echo ",";
- echo $map->GetFiniteDisplayScaleAt($i);
+ array_push($mapObj->FiniteDisplayScales, $map->GetFiniteDisplayScaleAt($i));
- echo"]";
- echo "}";
+ echo var2json($mapObj);
catch (MgException $e)
@@ -153,10 +180,67 @@
echo $e->GetDetails() . "\n";
echo $e->GetStackTrace() . "\n";
exit;
-function buildScaleRanges($layer) {
+/* GetLayerTypesFromResourceContent */
+/* Replacement for GetLayerTypes function. */
+/* Extract the layer types based on the styling available. */
+/* GetLayerTypes was costly in time when dealing in DB. */
+function GetLayerTypesFromResourceContent($layer)
+ $aLayerTypes = array();
global $resourceService;
+ try
+ $dataSourceId = new MgResourceIdentifier($layer->GetFeatureSourceId());
+ if($dataSourceId->GetResourceType() == MgResourceType::DrawingSource)
+ array_push($aLayerTypes, '5');// DWF
+ else
+ $resID = $layer->GetLayerDefinition();
+ $layerContent = $resourceService->GetResourceContent($resID);
+ $xmldoc = DOMDocument::loadXML(ByteReaderToString($layerContent));
+ $gridlayers = $xmldoc->getElementsByTagName('GridLayerDefinition');
+ if ($gridlayers->length > 0)
+ array_push($aLayerTypes, '4');// raster
+ $scaleRanges = $xmldoc->getElementsByTagName('VectorScaleRange');
+ $typeStyles = array("PointTypeStyle", "LineTypeStyle", "AreaTypeStyle", "CompositeTypeStyle");
+ for($sc = 0; $sc < $scaleRanges->length; $sc++)
+ $scaleRange = $scaleRanges->item($sc);
+ for($ts=0, $count = count($typeStyles); $ts < $count; $ts++)
+ $typeStyle = $scaleRange->getElementsByTagName($typeStyles[$ts]);
+ if ($typeStyle->length > 0)
+ array_push($aLayerTypes, $ts);
+ catch (MgException $e)
+ echo "ERROR: " . $e->GetMessage() . "\n";
+ echo $e->GetDetails() . "\n";
+ echo $e->GetStackTrace() . "\n";
+ $aLayerTypes = array_unique($aLayerTypes);
+ return $aLayerTypes;
+function buildScaleRanges($layer)
+ $aScaleRanges = array();
+ global $resourceService;
@@ -177,39 +261,38 @@
$ruleNames = array("PointRule", "LineRule", "AreaRule", "CompositeRule");
- $output = 'scaleRanges: [';
- $scaleSep = '';
+ $scaleRangeObj = NULL;
+ $scaleRangeObj->styles = array();
$minElt = $scaleRange->getElementsByTagName('MinScale');
$maxElt = $scaleRange->getElementsByTagName('MaxScale');
$minScale = "0";
- $maxScale = "'infinity'"; // as MDF's VectorScaleRange::MAX_MAP_SCALE
+ $maxScale = 'infinity'; // as MDF's VectorScaleRange::MAX_MAP_SCALE
if($minElt->length > 0)
$minScale = $minElt->item(0)->nodeValue;
if($maxElt->length > 0)
$maxScale = $maxElt->item(0)->nodeValue;
- $output .= $scaleSep."{";
- $output .= "minScale:".$minScale.",";
- $output .= "maxScale:".$maxScale;
+ $scaleRangeObj->minScale = $minScale;
+ $scaleRangeObj->maxScale = $maxScale;
if($type != 0) {
- $output .= "}";
- $scaleSep = ',';
+ array_push($aScaleRanges, $scaleRangeObj);
break;
- $output .= ',styles:[';
$styleIndex = 0;
- $styleSep = '';
$catIndex = 0;
for($st = 0; $st < $typeStyle->length; $st++) {
+ $styleObj = NULL;
// We will check if this typestyle is going to be shown in the legend
$showInLegend = $typeStyle->item($st)->getElementsByTagName("ShowInLegend");
if($showInLegend->length > 0)
@@ -224,21 +307,18 @@
$labelText = $label->length==1? $label->item(0)->nodeValue: "";
$filterText = $filter->length==1? $filter->item(0)->nodeValue: "";
- $output .= $styleSep."{";
- $output .= "legendLabel:'".addslashes(trim($labelText))."',";
- $output .= "filter:'".addslashes(trim($filterText))."',";
- $output .= "geometryType:".($ts+1).",";
- $output .= "categoryIndex:".($catIndex++);
- $output .= '}';
- $styleSep = ',';
+ $styleObj->legendLabel = addslashes(trim($labelText));
+ $styleObj->filter = addslashes(trim($filterText));
+ $styleObj->geometryType = ($ts+1);
+ $styleObj->categoryIndex = $catIndex++;
+ array_push($scaleRangeObj->styles, $styleObj);
- $output .= ']}';
- $scaleSep = ',';
- $output .= ']';
- return $output;
+ return $aScaleRanges;
@@ -255,63 +335,22 @@
function OutputGroupInfo($group)
- echo "groupName:'".addslashes($group->GetName())."',";
- echo "legendLabel:'".addslashes($group->GetLegendLabel())."',";
- echo "uniqueId:'".$group->GetObjectId()."',";
- echo "displayInLegend:".BooleanToString($group->GetDisplayInLegend()).",";
- echo "expandInLegend:".BooleanToString($group->GetExpandInLegend()).",";
- echo "layerGroupType:'".$group->GetLayerGroupType()."',";
+ $groupObj = NULL;
+ $groupObj->groupName = addslashes($group->GetName());
+ $groupObj->legendLabel = addslashes($group->GetLegendLabel());
+ $groupObj->uniqueId = $group->GetObjectId();
+ $groupObj->displayInLegend = BooleanToString($group->GetDisplayInLegend());
+ $groupObj->expandInLegend = BooleanToString($group->GetExpandInLegend());
$parent = $group->GetGroup();
- echo "parentUniqueId:";
- echo $parent != null ? "'".$parent->GetObjectId()."'," : "null,";
- echo "visible:".BooleanToString($group->GetVisible()).",";
- echo "actuallyVisible:".BooleanToString($group->isVisible());
+ $groupObj->parentUniqueId = $parent != null ? $parent->GetObjectId() : '';
+ $groupObj->visible = BooleanToString($group->GetVisible());
+ $groupObj->actuallyVisible = BooleanToString($group->isVisible());
+ return $groupObj;
-function OutputLayerInfo($layer, $resourceService, $featureService)
- $mappings = GetLayerPropertyMappings($resourceService, $layer);
- if (!isset($_SESSION['property_mappings'])) {
- $_SESSION['property_mappings'] = array();
- $_SESSION['property_mappings'][$layer->GetObjectId()] = $mappings;
- $layerDefinition = $layer->GetLayerDefinition();
- $aLayerTypes = GetLayerTypes($featureService, $layer);
- //echo '<pre>'; print_r($aLayerTypes); echo '</pre>'; exit;
- echo "propertyMappings:{";
- $sep = '';
- foreach($mappings as $name => $value) {
- echo $sep."'$name':'$value'";
- $sep = ',';
- echo "},";
- echo "uniqueId:'".$layer->GetObjectId()."',";
- echo "layerName:'".addslashes($layer->GetName())."',";
- echo 'layerTypes:[';
- $sep = '';
- for ( $j=0; $j < count($aLayerTypes); $j++ )
- echo $sep . $aLayerTypes[$j];
- $sep = ',';
- echo '],';
- echo "displayInLegend:".BooleanToString($layer->GetDisplayInLegend()).",";
- echo "expandInLegend:".BooleanToString($layer->GetExpandInLegend()).",";
- echo "resourceId:'".$layerDefinition->ToString()."',";
- echo "parentGroup:";
- echo $layer->GetGroup() ? "'".$layer->GetGroup()->GetObjectId()."'," : 'null,';
- echo "legendLabel:'".addslashes($layer->GetLegendLabel())."',";
- echo "selectable:".BooleanToString($layer->GetSelectable()).",";
- echo "visible:".BooleanToString($layer->GetVisible()).",";
- echo "actuallyVisible:".BooleanToString($layer->isVisible()).",";
- if (IsLayerEditable($resourceService, $layer)) {
- echo "editable:true,";
- } else {
- echo "editable:false,";
- echo buildScaleRanges($layer);
More information about the fusion-commits
