[fusion-commits] r1546 - in branches/fusion-1.1: lib widgets
widgets/widgetinfo
svn_fusion at osgeo.org
Tue Sep 23 15:34:14 EDT 2008
Author: madair
Date: 2008-09-23 15:34:14 -0400 (Tue, 23 Sep 2008)
New Revision: 1546
branches/fusion-1.1/lib/Map.js
branches/fusion-1.1/widgets/InitialMapView.js
branches/fusion-1.1/widgets/widgetinfo/initialmapview.xml
closes #130
Modified: branches/fusion-1.1/lib/Map.js
--- branches/fusion-1.1/lib/Map.js 2008-09-23 17:01:44 UTC (rev 1545)
+++ branches/fusion-1.1/lib/Map.js 2008-09-23 19:34:14 UTC (rev 1546)
@@ -567,6 +567,7 @@
center.lon + w_deg,
center.lat + h_deg);
+ this.initialExtents = initialExtents;
return initialExtents;
Modified: branches/fusion-1.1/widgets/InitialMapView.js
--- branches/fusion-1.1/widgets/InitialMapView.js 2008-09-23 17:01:44 UTC (rev 1545)
+++ branches/fusion-1.1/widgets/InitialMapView.js 2008-09-23 19:34:14 UTC (rev 1546)
@@ -32,8 +32,14 @@
Fusion.Widget.InitialMapView = OpenLayers.Class(Fusion.Widget, Fusion.Tool.ButtonBase, {
+ viewType: 'initial',
initialize : function(widgetTag) {
//console.log('InitialMapView.initialize');
+ var json = widgetTag.extension;
+ if (json.ViewType && (json.ViewType[0] == 'full')) {
+ this.viewType = 'full';
Fusion.Widget.prototype.initialize.apply(this, [widgetTag, false]);
Fusion.Tool.ButtonBase.prototype.initialize.apply(this, []);
@@ -41,6 +47,11 @@
execute: function() {
//console.log('InitialMapView.activateTool');
- this.getMap().fullExtents();
+ if (this.viewType == 'full') {
+ this.getMap().fullExtents();
+ } else {
+ var mapWidget = this.getMap();
+ mapWidget.setExtents(mapWidget.initialExtents);
Modified: branches/fusion-1.1/widgets/widgetinfo/initialmapview.xml
--- branches/fusion-1.1/widgets/widgetinfo/initialmapview.xml 2008-09-23 17:01:44 UTC (rev 1545)
+++ branches/fusion-1.1/widgets/widgetinfo/initialmapview.xml 2008-09-23 19:34:14 UTC (rev 1546)
@@ -10,4 +10,20 @@
<ImageClass></ImageClass>
<StandardUi>true</StandardUi>
<ContainableBy>Any</ContainableBy>
+ <Parameter>
+ <Name>ViewType</Name>
+ <Description>option to zoom to full map extents or just the initial extent</Description>
+ <Type>String</Type>
+ <Label>ViewType</Label>
+ <AllowedValue>
+ <Name>full</Name>
+ <Label>full extent</Label>
+ </AllowedValue>
+ <AllowedValue>
+ <Name>initial</Name>
+ <Label>initial map extent</Label>
+ </AllowedValue>
+ <DefaultValue>initial</DefaultValue>
+ <IsMandatory>false</IsMandatory>
+ </Parameter>
</WidgetInfo>
More information about the fusion-commits
