[fusion-commits] r1548 - trunk/MapServer/php
svn_fusion at osgeo.org
Tue Sep 23 17:40:33 EDT 2008
Author: Assefa
Date: 2008-09-23 17:40:33 -0400 (Tue, 23 Sep 2008)
New Revision: 1548
trunk/MapServer/php/LoadScaleRanges.php
ability to return all legend icons inside one image (#131)
Modified: trunk/MapServer/php/LoadScaleRanges.php
--- trunk/MapServer/php/LoadScaleRanges.php 2008-09-23 19:45:16 UTC (rev 1547)
+++ trunk/MapServer/php/LoadScaleRanges.php 2008-09-23 21:40:33 UTC (rev 1548)
@@ -44,17 +44,87 @@
$scaleObj = NULL;
$scaleObj->layers = array();
+define('ICON_SIZE', 16);
+$nIconWidth = $oMap->legend->keysizex;
+$nIconHeight = $oMap->legend->keysizey;
+if ($nIconWidth <=0)
+ $nIconWidth = ICON_SIZE;
+$nTotalClasses=0;
+$aIcons = array();
+/*special case to force the the legend icons to be drawn using a gd driver
+ This was fixed in ticket http://trac.osgeo.org/mapserver/ticket/2682 which
+ will be available for mapserver version 5.2.1 and 5.4
+ Note that we do not check the outputformat of the map (assuming that we are
+ using GD or AGG renderers)
+$nVersion = ms_GetVersionInt();
+if ($nVersion <= 50200) /*5.2 and before*/
+ $oMap->selectOutputFormat("png24");
for($i=0;$i<$oMap->numlayers;$i++)
if (isset($_SESSION['scale_ranges']) &&
isset($_SESSION['scale_ranges'][$i]))
+ $layer = $oMap->getLayer($i);
$scaleranges = $_SESSION['scale_ranges'][$i];
$layerObj = NULL;
$layerObj->uniqueId = $i;
+ /*generate the legend icons here*/
+ //echo count($scaleranges) . "<br>\n";
+ $nScaleRanges = count($scaleranges);
+ for ($j=0; $j<$nScaleRanges; $j++)
+ $nStyles = count($scaleranges[$j]->styles);
+ for ($k=0; $k<$nStyles; $k++)
+ $nClassIndex = $scaleranges[$j]->styles[$k]->index;
+ $oClass = $layer->getClass($nClassIndex);
+ $oImg = $oClass->createLegendIcon($nIconWidth, $nIconHeight);
+ array_push($aIcons, $oImg);
+ $scaleranges[$j]->styles[$k]->icon_x = ($nTotalClasses*$nIconWidth);
+ $scaleranges[$j]->styles[$k]->icon_y=0;
+ $nTotalClasses++;
$layerObj->scaleRanges = $scaleranges;
array_push($scaleObj->layers, $layerObj);
+ //build and image containing all the icons and return url
+ $nTmpWidth = $oMap->width;
+ $nTmpHeight = $oMap->height;
+ $oMap->set("width", $nTotalClasses*$nIconWidth);
+ $oMap->set("height", $nIconHeight);
+ $oImage = $oMap->prepareImage();
+ $oMap->set("width", $nTmpWidth);
+ $oMap->set("height", $nTmpHeight);
+ for ($i=0; $i<$nTotalClasses;$i++)
+ $oImage->pasteImage($aIcons[$i], -1, $i*$nIconWidth, 0);
+ //set the image path and image dir based on what fusion config file
+ $configObj = $_SESSION['fusionConfig'];
+ if (isset($configObj->mapserver->imagePath) && isset($configObj->mapserver->imageUrl))
+ $oImage->set("imagepath", $configObj->mapserver->imagePath);
+ $oImage->set("imageurl", $configObj->mapserver->imageUrl);
+ $scaleObj->icons_url = $oImage->saveWebImage();
+ $scaleObj->icons_width = $nIconWidth;
+ $scaleObj->icons_height = $nIconHeight;
More information about the fusion-commits
