[fusion-commits] r1566 - in trunk: lib widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Sep 29 14:26:44 EDT 2008
Author: pagameba
Date: 2008-09-29 14:26:44 -0400 (Mon, 29 Sep 2008)
New Revision: 1566
   trunk/lib/fusion.js
   trunk/widgets/ViewOptions.js
Add concept of unit system to Fusion and support setting the right unit system in View Options widget when the map changes unit systems.
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js	2008-09-29 18:11:27 UTC (rev 1565)
+++ trunk/lib/fusion.js	2008-09-29 18:26:44 UTC (rev 1566)
@@ -876,6 +876,31 @@
                     Fusion.UNKNOWN;
+        unitSystem: function(unit) {
+            switch(unit) {
+                case Fusion.INCHES:
+                case Fusion.FEET:
+                case Fusion.YARDS:
+                case Fusion.MILES:
+                case Fusion.NAUTICALMILES:
+                    return 'imperial';
+                case Fusion.MILLIMETERS:
+                case Fusion.CENTIMETERS:
+                case Fusion.METERS:
+                case Fusion.KILOMETERS:
+                    return 'metric';
+                case Fusion.DEGREES:
+                case Fusion.DECIMALDEGREES:
+                case Fusion.DMS:
+                    return 'deg';
+                case Fusion.UNKNOWN:
+                case Fusion.PIXELS:
+                default:
+                    return 'device';
         unitName: function(unit) {
             if (unit >= Fusion.UNKNOWN && unit <= Fusion.PIXELS) {
Modified: trunk/widgets/ViewOptions.js
--- trunk/widgets/ViewOptions.js	2008-09-29 18:11:27 UTC (rev 1565)
+++ trunk/widgets/ViewOptions.js	2008-09-29 18:26:44 UTC (rev 1566)
@@ -37,12 +37,15 @@
         'metric': 'Meters',
         'deg': 'Degrees'
+    menuItems: null,
     initializeWidget: function(widgetTag) {
         var json = widgetTag.extension;
         this.displayUnits = json.DisplayUnits ? json.DisplayUnits[0] : false;
         this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.setMapUnits, this));
+        this.menuItems = {};
     setUiObject: function(uiObj) {
@@ -57,20 +60,20 @@
             buttonSet.add(menuItem);
             this.uiObj.add(menuItem);
+            this.menuItems[key] = menuItem;
-    //action to perform when the button is clicked
-    activate: function(e) {
-        //this.oMenu.show(e);
     setViewOptions: function(units) {
-      this.getMap().setViewOptions(units);
+        this.getMap().setViewOptions(units);
     setMapUnits: function() {
-      var units = this.displayUnits ? this.displayUnits : this.getMap().getUnits();
-      this.setViewOptions(units);
+        var units = this.displayUnits ? this.displayUnits : this.getMap().getUnits();
+        this.setViewOptions(units);
+        var system = Fusion.unitSystem(Fusion.unitFromName(units));
+        if (this.menuItems[system]) {
+            this.menuItems[system].setActive(true);
More information about the fusion-commits mailing list
