Author: pagameba
Date: 2008-09-29 20:46:10 -0400 (Mon, 29 Sep 2008)
New Revision: 1571
trunk/MapGuide/php/LoadMap.php
trunk/MapGuide/php/LoadScaleRanges.php
assign null to scaleObj so that a new one is made for every scale range, otherwise every entry is a clone of the last one.
Modified: trunk/MapGuide/php/LoadMap.php
--- trunk/MapGuide/php/LoadMap.php 2008-09-30 00:33:30 UTC (rev 1570)
+++ trunk/MapGuide/php/LoadMap.php 2008-09-30 00:46:10 UTC (rev 1571)
@@ -171,9 +171,7 @@
array_push($mapObj->FiniteDisplayScales, $map->GetFiniteDisplayScaleAt($i));
echo var2json($mapObj);
catch (MgException $e)
@@ -308,6 +306,7 @@
$labelText = $label->length==1? $label->item(0)->nodeValue: "";
$filterText = $filter->length==1? $filter->item(0)->nodeValue: "";
+ $styleObj = NULL;
$styleObj->legendLabel = addslashes(trim($labelText));
$styleObj->filter = addslashes(trim($filterText));
$styleObj->geometryType = ($ts+1);
Modified: trunk/MapGuide/php/LoadScaleRanges.php
--- trunk/MapGuide/php/LoadScaleRanges.php 2008-09-30 00:33:30 UTC (rev 1570)
+++ trunk/MapGuide/php/LoadScaleRanges.php 2008-09-30 00:46:10 UTC (rev 1571)
@@ -57,8 +57,7 @@
-header('Content-type: text/x-json');
-header('X-JSON: true');
+header('Content-type: application/json');
echo var2json($scaleObj);
exit;
