[fusion-commits] r1573 - in trunk: . lib
svn_fusion at osgeo.org
Mon Sep 29 21:17:07 EDT 2008
Author: pagameba
Date: 2008-09-29 21:17:07 -0400 (Mon, 29 Sep 2008)
New Revision: 1573
trunk/build.xml
trunk/lib/fusion.js
update build to replace fusion lib name after concatenation, update error message related to finding fusion to include the script name it is looking for.
Modified: trunk/build.xml
--- trunk/build.xml 2008-09-30 00:51:45 UTC (rev 1572)
+++ trunk/build.xml 2008-09-30 01:17:07 UTC (rev 1573)
@@ -208,8 +208,7 @@
<!-- Fusion looks for it's own script name to set paths for other widgets
so replace the value to look for with the sfName used to create the file-->
- <replace file="${build.home}/lib/fusion.js" token="lib/fusion" value="lib/${sfName}"/>
<!-- merge everything into a single file -->
<concat destfile="${buildOutput}.js" outputencoding="UTF-8">
<filelist dir="${build.home}/lib"
@@ -231,6 +230,9 @@
<fileset dir="${build.home}/text" includes="**/*.json"/>
<filelist dir="${build.home}" files="configHeader.json config.json"/>
</concat>
+ <replace file="${buildOutput}.js" token="lib/fusion" value="lib/${sfName}"/>
</target>
<!-- =================== concat all support files (no appdef supplied) ================================== -->
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js 2008-09-30 00:51:45 UTC (rev 1572)
+++ trunk/lib/fusion.js 2008-09-30 01:17:07 UTC (rev 1573)
@@ -1062,7 +1062,7 @@
if (!this.fusionURL) {
- alert('failed to determine fusionURL. Initialization aborted');
+ alert('failed to determine fusionURL using script name '+Fusion._scriptName+'. Initialization aborted');
return;
return Fusion.fusionURL;
More information about the fusion-commits
