[fusion-commits] r1829 - trunk
svn_fusion at osgeo.org
Fri Apr 3 15:06:48 EDT 2009
Author: madair
Date: 2009-04-03 15:06:48 -0400 (Fri, 03 Apr 2009)
New Revision: 1829
trunk/config_dist.json
re #242: add missing comma
Modified: trunk/config_dist.json
--- trunk/config_dist.json 2009-04-03 18:38:17 UTC (rev 1828)
+++ trunk/config_dist.json 2009-04-03 19:06:48 UTC (rev 1829)
@@ -20,7 +20,7 @@
leave this empty as it will be automatically calculated. */
"webTierUrl": "",
/* for MapGuide OS version > 2.1 and MGE2010 and higher set this to true*/
- "useAsyncOverlay": true
+ "useAsyncOverlay": true,
/* The tileCacheUrl is the root url to a static mapguide tile cache.
A relative URL will be relative to your application.
The root url will be appended with the 'Sn'
More information about the fusion-commits
