[fusion-commits] r1842 - trunk/layers/Generic
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Apr 29 18:05:45 EDT 2009
Author: pagameba
Date: 2009-04-29 18:05:44 -0400 (Wed, 29 Apr 2009)
New Revision: 1842
   trunk/layers/Generic/Generic.js
re #251, some Google support changes to make it possible to overlay stuff.
Modified: trunk/layers/Generic/Generic.js
--- trunk/layers/Generic/Generic.js	2009-04-29 18:26:31 UTC (rev 1841)
+++ trunk/layers/Generic/Generic.js	2009-04-29 22:05:44 UTC (rev 1842)
@@ -1,187 +1,197 @@
- * Fusion.Layers.Generic
- * $Id: Generic.js 1590 2008-10-10 14:01:27Z madair $
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
-* Class: Fusion.Layers.Generic
-* Implements the map layer for Generic mapping services.
-Fusion.Layers.Generic = OpenLayers.Class(Fusion.Layers, {
-    arch: 'Generic',
-    sActiveLayer: null,
-    selectionType: 'INTERSECTS',
-    bSelectionOn: false,
-    oSelection: null,
-    initialize: function(map, mapTag, isMapWidgetLayer) {
-        // console.log('Generic.initialize');
-        Fusion.Layers.prototype.initialize.apply(this, arguments);
-        this._sMapname = mapTag.layerOptions['name'] ? mapTag.layerOptions['name'] : 'generic layer';
-        this.minScale = mapTag.layerOptions.minScale ? mapTag.layerOptions.minScale : 1;
-        this.maxScale = mapTag.layerOptions.maxScale ? mapTag.layerOptions.maxScale : 'auto';
-        var scaleRange = new Fusion.Layers.ScaleRange({
-            minScale: this.minScale,
-            maxScale: this.maxScale},
-            Fusion.Constant.LAYER_RASTER_TYPE);
-        rootOpts = {
-          layerName: this._sMapname,
-          resourceId: this.sMapResourceId,
-          selectable: false,
-          editable: false,
-          layerTypes: [Fusion.Constant.LAYER_RASTER_TYPE],
-          maxScale: this.maxScale,
-          scaleRanges: [scaleRange],
-          parentGroup: map.layerRoot,
-          displayInLegend: this.bDisplayInLegend,
-          expandInLegend: this.bExpandInLegend,
-          legendLabel: this._sMapname,
-          uniqueId: 'layerRoot',
-          visible: true,
-          actuallyVisible: true
-          //TODO: set other opts for group initialization as required
-        this.layerRoot = new Fusion.Layers.Layer(rootOpts,this);
-        //this.layerRoot = new Fusion.Layers.Group(rootOpts,this);
-        this.loadMap(this.sMapResourceId);
-    loadMap: function(resourceId) {
-        this.bMapLoaded = false;
-        this.triggerEvent(Fusion.Event.LAYER_LOADING);
-        if (this.bIsMapWidgetLayer) {
-          this.mapWidget._addWorker();
-        //remove this layer if it was already created
-        if (this.oLayerOL) {
-            this.oLayerOL.events.unregister("loadstart", this, this.loadStart);
-            this.oLayerOL.events.unregister("loadend", this, this.loadEnd);
-            this.oLayerOL.events.unregister("loadcancel", this, this.loadEnd);
-            this.oLayerOL.destroy();
-        switch (this.layerType) {
-          case 'Google':
-            switch (this.mapTag.layerOptions.type) {   //Google layer types are actual objects
-              case 'G_PHYSICAL_MAP':              //defined by gmap, not a string
-                this.mapTag.layerOptions.type = G_PHYSICAL_MAP;
-                break;
-              case 'G_HYBRID_MAP':
-                this.mapTag.layerOptions.type = G_HYBRID_MAP;
-                break;
-              case 'G_SATELLITE_MAP':
-                this.mapTag.layerOptions.type = G_SATELLITE_MAP;
-                break;
-              case 'G_NORMAL_MAP':
-              default:
-                this.mapTag.layerOptions.type = G_NORMAL_MAP;
-                break;
-            this.mapTag.layerOptions.maxExtent = null;    //maxExtent not allowed on Google layers
-            this.oLayerOL = new OpenLayers.Layer.Google(this.getMapName(), this.mapTag.layerOptions );
-            this.mapWidget.fractionalZoom = false;        //fractionalZoom not permitted with Google layers
-            this.mapWidget.oMapOL.setOptions({fractionalZoom: false});
-           break;
-          default:
-            this.oLayerOL = new OpenLayers.Layer[this.layerType](
-                                  this.getMapName(),
-                                  this.sMapResourceId,
-                                  this.mapTag.layerParams,
-                                  this.mapTag.layerOptions );
-            break;
-        this.oLayerOL.events.register("loadstart", this, this.loadStart);
-        this.oLayerOL.events.register("loadend", this, this.loadEnd);
-        this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
-        //this is to distinguish between a regular map and an overview map
-          this.mapWidget.addMap(this);
-          this.mapWidget._removeWorker();
-        //this.triggerEvent(Fusion.Event.LAYER_LOADED);
-        window.setTimeout(OpenLayers.Function.bind(this.asyncTrigger, this),1);
-    asyncTrigger: function() {
-        this.bMapLoaded = true;
-        this.triggerEvent(Fusion.Event.LAYER_LOADED);
-//TBD: this function not yet converted for OL
-    reloadMap: function() {
-        this.loadMap(this.sResourceId);
-            this.mapWidget.triggerEvent(Fusion.Event.MAP_RELOADED);
-            this.drawMap();
-    drawMap: function() {
-        if (!this.bMapLoaded) {
-            return;
-        this.oLayerOL.mergeNewParams(params);
-    showLayer: function( layer, noDraw ) {
-        this.processLayerEvents(layer, true);
-        if (!noDraw) {
-            this.oLayerOL.setVisibility(true);
-    hideLayer: function( layer, noDraw ) {
-        this.processLayerEvents(layer, false);
-        if (!noDraw) {
-            this.oLayerOL.setVisibility(false);
-    showGroup: function( group, noDraw ) {
-        this.processGroupEvents(group, true);
-    hideGroup: function( group, noDraw ) {
-        this.processGroupEvents(group, false);
-    refreshLayer: function( layer ) {
-        this.drawMap();
-    getLegendImageURL: function(fScale, layer, style) {
-      var url = null; //TODO: provide a generic icon url
-      return url;
+ * Fusion.Layers.Generic
+ * $Id: Generic.js 1590 2008-10-10 14:01:27Z madair $
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+* Class: Fusion.Layers.Generic
+* Implements the map layer for Generic mapping services.
+Fusion.Layers.Generic = OpenLayers.Class(Fusion.Layers, {
+    arch: 'Generic',
+    sActiveLayer: null,
+    selectionType: 'INTERSECTS',
+    bSelectionOn: false,
+    oSelection: null,
+    initialize: function(map, mapTag, isMapWidgetLayer) {
+        // console.log('Generic.initialize');
+        Fusion.Layers.prototype.initialize.apply(this, arguments);
+        this._sMapname = mapTag.layerOptions['name'] ? mapTag.layerOptions['name'] : 'generic layer';
+        this.minScale = mapTag.layerOptions.minScale ? mapTag.layerOptions.minScale : 1;
+        this.maxScale = mapTag.layerOptions.maxScale ? mapTag.layerOptions.maxScale : 'auto';
+        var scaleRange = new Fusion.Layers.ScaleRange({
+            minScale: this.minScale,
+            maxScale: this.maxScale},
+            Fusion.Constant.LAYER_RASTER_TYPE);
+        rootOpts = {
+          layerName: this._sMapname,
+          resourceId: this.sMapResourceId,
+          selectable: false,
+          editable: false,
+          layerTypes: [Fusion.Constant.LAYER_RASTER_TYPE],
+          maxScale: this.maxScale,
+          scaleRanges: [scaleRange],
+          parentGroup: map.layerRoot,
+          displayInLegend: this.bDisplayInLegend,
+          expandInLegend: this.bExpandInLegend,
+          legendLabel: this._sMapname,
+          uniqueId: 'layerRoot',
+          visible: true,
+          actuallyVisible: true
+          //TODO: set other opts for group initialization as required
+        this.layerRoot = new Fusion.Layers.Layer(rootOpts,this);
+        //this.layerRoot = new Fusion.Layers.Group(rootOpts,this);
+        if (isMapWidgetLayer) {
+            this.loadMap(this.sMapResourceId);
+    loadMap: function(resourceId) {
+        this.bMapLoaded = false;
+        this.triggerEvent(Fusion.Event.LAYER_LOADING);
+        if (this.bIsMapWidgetLayer) {
+          this.mapWidget._addWorker();
+        //remove this layer if it was already created
+        if (this.oLayerOL) {
+            this.oLayerOL.events.unregister("loadstart", this, this.loadStart);
+            this.oLayerOL.events.unregister("loadend", this, this.loadEnd);
+            this.oLayerOL.events.unregister("loadcancel", this, this.loadEnd);
+            this.oLayerOL.destroy();
+        switch (this.layerType) {
+          case 'Google':
+            switch (this.mapTag.layerOptions.type) {   //Google layer types are actual objects
+              case 'G_PHYSICAL_MAP':              //defined by gmap, not a string
+                this.mapTag.layerOptions.type = G_PHYSICAL_MAP;
+                break;
+              case 'G_HYBRID_MAP':
+                this.mapTag.layerOptions.type = G_HYBRID_MAP;
+                break;
+              case 'G_SATELLITE_MAP':
+                this.mapTag.layerOptions.type = G_SATELLITE_MAP;
+                break;
+              case 'G_NORMAL_MAP':
+              default:
+                this.mapTag.layerOptions.type = G_NORMAL_MAP;
+                break;
+            if (!this.mapTag.layerOptions.maxExtent) {
+                this.mapTag.layerOptions.maxExtent = new OpenLayers.Bounds(-20037508.3427892, -20037508.3427892, 20037508.3427892, 20037508.3427892);
+            if (typeof this.mapTag.layerOptions.sphericalMercator == 'undefined') {
+                this.mapTag.layerOptions.sphericalMercator = true;
+            if (typeof this.mapTag.layerOptions.numZoomLevels == 'undefined') {
+                this.mapTag.layerOptions.numZoomLevels = 20;
+            this.oLayerOL = new OpenLayers.Layer.Google(this.getMapName(), this.mapTag.layerOptions );
+            this.mapWidget.fractionalZoom = false;        //fractionalZoom not permitted with Google layers
+            this.mapWidget.oMapOL.setOptions({fractionalZoom: false});
+           break;
+          default:
+            this.oLayerOL = new OpenLayers.Layer[this.layerType](
+                                  this.getMapName(),
+                                  this.sMapResourceId,
+                                  this.mapTag.layerParams,
+                                  this.mapTag.layerOptions );
+            break;
+        this.oLayerOL.events.register("loadstart", this, this.loadStart);
+        this.oLayerOL.events.register("loadend", this, this.loadEnd);
+        this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
+        //this is to distinguish between a regular map and an overview map
+          this.mapWidget.addMap(this);
+          this.mapWidget._removeWorker();
+        //this.triggerEvent(Fusion.Event.LAYER_LOADED);
+        window.setTimeout(OpenLayers.Function.bind(this.asyncTrigger, this),1);
+    asyncTrigger: function() {
+        this.bMapLoaded = true;
+        this.triggerEvent(Fusion.Event.LAYER_LOADED);
+//TBD: this function not yet converted for OL
+    reloadMap: function() {
+        this.loadMap(this.sResourceId);
+            this.mapWidget.triggerEvent(Fusion.Event.MAP_RELOADED);
+            this.drawMap();
+    drawMap: function() {
+        if (!this.bMapLoaded) {
+            return;
+        this.oLayerOL.mergeNewParams(params);
+    showLayer: function( layer, noDraw ) {
+        this.processLayerEvents(layer, true);
+        if (!noDraw) {
+            this.oLayerOL.setVisibility(true);
+    hideLayer: function( layer, noDraw ) {
+        this.processLayerEvents(layer, false);
+        if (!noDraw) {
+            this.oLayerOL.setVisibility(false);
+    showGroup: function( group, noDraw ) {
+        this.processGroupEvents(group, true);
+    hideGroup: function( group, noDraw ) {
+        this.processGroupEvents(group, false);
+    refreshLayer: function( layer ) {
+        this.drawMap();
+    getLegendImageURL: function(fScale, layer, style) {
+      var url = null; //TODO: provide a generic icon url
+      return url;
More information about the fusion-commits mailing list
