[fusion-commits] r1844 - trunk/layers
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Apr 30 10:31:51 EDT 2009
Author: pagameba
Date: 2009-04-30 10:31:51 -0400 (Thu, 30 Apr 2009)
New Revision: 1844
   trunk/layers/Layers.js
re #252, add empty getMapTip to base class
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js	2009-04-30 14:00:08 UTC (rev 1843)
+++ trunk/layers/Layers.js	2009-04-30 14:31:51 UTC (rev 1844)
@@ -1,585 +1,587 @@
- * Fusion.Layers
- * $Id: MapGuide.js 1590 2008-10-10 14:01:27Z madair $
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
-* Class: Fusion.Layers
-* Implements Layers for Fusion.
-Fusion.Event.MAP_LAYER_TOGGLED = Fusion.Event.lastEventId++;
-Fusion.Event.MAP_LAYER_ORDER_CHANGED = Fusion.Event.lastEventId++;
-Fusion.Event.LAYER_LOADED = Fusion.Event.lastEventId++;
-Fusion.Event.LAYER_LOADING = Fusion.Event.lastEventId++;
-Fusion.Layers = OpenLayers.Class(Fusion.Lib.EventMgr, {
-    bSingleTile: null,
-    bIsBaseLayer: false,     //TODO: set this in AppDef?
-    bDisplayInLegend: true,   //TODO: set this in AppDef?
-    bExpandInLegend: true,   //TODO: set this in AppDef?
-    bMapLoaded: false,
-    bIsMapWidgetLayer: true,  //Set this to false for overview map layers
-    bLayersReversed: false,     //MGOS returns layers top-most layer first
-    sMapResourceId: null,    //pointer to the resource that defines the map (URL, MapFile, MGOS, etc)
-    sImageType: 'png',      //TODO: set this in AppDef?
-    clientAgent: 'Fusion Viewer',
-    noCache: false,
-    _sMapTitle: null,
-    _sMapname: null,
-    initialize: function(map, mapTag, isMapWidgetLayer) {
-        // console.log('Fusion.Layers.initialize');
-        this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
-        this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
-        this.registerEventID(Fusion.Event.MAP_LOADED);
-        this.registerEventID(Fusion.Event.LAYER_LOADED);
-        this.registerEventID(Fusion.Event.LAYER_LOADING);
-        this.registerEventID(Fusion.Event.MAP_LAYER_ORDER_CHANGED);
-        this.mapWidget = map;
-        this.oSelection = null;
-        if (isMapWidgetLayer != null) {
-            this.bIsMapWidgetLayer = isMapWidgetLayer;
-        this.mapTag = mapTag;
-        if (!this.mapTag.layerOptions) {
-          this.mapTag.layerOptions = {};
-        this.ratio = this.mapTag.layerOptions.MapRatio ? this.extension.MapRatio[0] : 1.0;
-        this.bSingleTile = mapTag.singleTile; //this is set in thhe AppDef.Map class
-        this.bIsBaseLayer = mapTag.isBaseLayer;
-        this.sMapResourceId = mapTag.resourceId ? mapTag.resourceId : '';
-        this.mapInfo = mapTag.mapInfo;
-        this.layerType = mapTag.type;
-     * Function: loadScaleRanges
-     * This function should be called after the map has loaded. It
-     * loads the scsle ranges for each layer. I tis for now only
-     * used by the legend widget.
-    loadScaleRanges: function(userFunc) {
-      userFunc();
-    getMapName: function() {
-        return this._sMapname;
-    getMapTitle: function() {
-        return this._sMapTitle;
-     * Function: isMapLoaded
-     * Returns true if the Map has been laoded succesfully form the server
-    isMapLoaded: function() {
-        return this.bMapLoaded;
-    getMaxExtent: function() {
-      var maxExtent = null;
-      if (this.oLayerOL) {
-        maxExtent = this.oLayerOL.maxExtent;
-      return maxExtent;
-    hasSelection: function() {
-      return this.bSelectionOn;
-     * Returns the number of features selected for this map layer
-    getSelectedFeatureCount: function() {
-      var total = 0;
-      return total;
-    getSelectedLayers: function() {
-      var layers = [];
-      return layers;
-    getSelectableLayers: function() {
-      var layers = [];
-      return layers;
-    setSelection: function (selText, zoomTo) {
-     * asynchronously load the current selection.  When the current
-     * selection changes, the selection is not loaded because it
-     * could be a lengthy process.  The user-supplied function will
-     * be called when the selection is available.
-     * @param userFunc {Function} a function to call when the
-     *        selection has loaded
-     * @param layers {string} Optional parameter.  A comma separated
-     *        list of layer names (Roads,Parcels). If it is not
-     *        given, all the layers that have a selection will be used
-     * @param startcount {string} Optional parameter.  A comma separated
-     *        list of a statinh index and the number of features to be retured for
-     *        each layer given in the layers parameter. Index starts at 0
-     *        (eg: 0:4,2:6 : return 4 elements for the first layers starting at index 0 and
-     *         six elements for layer 2 starting at index 6). If it is not
-     *        given, all the elemsnts will be returned.
-    getSelection: function(userFunc, layers, startcount) {
-       Utility function to clear current selection
-    clearSelection: function() {
-       Do a query on the map
-    query: function(options) {
-    processLayerEvents: function(layer, isEnabling) {
-        if (this.mapInfo && this.mapInfo.mapEvents.layerEvents[layer.layerName]) {
-            var layerEvent = this.mapInfo.mapEvents.layerEvents[layer.layerName];
-            var events = isEnabling ? layerEvent.onEnable : layerEvent.onDisable;
-            for (var i=0; i<events.length; i++) {
-                var o = events[i];
-                if (o.type == 'layer') {
-                    var l = this.layerRoot.findLayer(o.name);
-                    if (l) {
-                        if (o.enable) {
-                            l.show(true);
-                        } else {
-                            l.hide(true);
-                } else if (o.type == 'group') {
-                    var g = this.layerRoot.findGroupByAttribute('groupName', o.name);
-                    if (g) {
-                        if (o.enable) {
-                            g.show(true);
-                        } else {
-                            g.hide(true);
-    processGroupEvents: function(group, isEnabling) {
-        if (this.mapInfo && this.mapInfo.mapEvents.groupEvents[group.groupName]) {
-            var groupEvent = this.mapInfo.mapEvents.groupEvents[group.groupName];
-            var events = isEnabling ? groupEvent.onEnable : groupEvent.onDisable;
-                    if (l) {
-                        if (o.enable) {
-                            l.show(true);
-                        } else {
-                            l.hide(true);
-                    if (g) {
-                        if (o.enable) {
-                            g.show(true);
-                        } else {
-                            g.hide(true);
-    refreshLayer: function( layer ) {
-        this.drawMap();
-    setParameter: function(param, value) {
-        if (param == 'SelectionType') {
-            this.selectionType = value;
-    loadStart: function() {
-      if (this.bIsMapWidgetLayer) {
-        this.mapWidget._addWorker();
-    loadEnd: function() {
-        this.mapWidget._removeWorker();
-    getGroupInfoUrl: function(groupName) {
-        if (this.mapInfo) {
-            var groups = this.mapInfo.links.groups;
-            for (var i=0; i<groups.length; i++) {
-                if (groups[i].name == groupName) {
-                    return groups[i].url;
-        return null;
-    getLayerInfoUrl: function(layerName) {
-            var layers = this.mapInfo.links.layers;
-            for (var i=0; i<layers.length; i++) {
-                if (layers[i].name == layerName) {
-                    return layers[i].url;
-        return null;
-* Class: Fusion.Layers.Group
-* Implements the map layer groups
-Fusion.Event.GROUP_PROPERTY_CHANGED = Fusion.Event.lastEventId++;
-Fusion.Layers.Group = OpenLayers.Class(Fusion.Lib.EventMgr, {
-    name: null,
-    groups: null,
-    layers: null,
-    oMap: null,
-    initialize: function(o, oMap) {
-        this.uniqueId = o.uniqueId;
-        this.name = o.groupName;
-        this.groups = [];
-        this.layers = [];
-        this.oMap = oMap;
-        this.groupName = o.groupName;
-        this.legendLabel = o.legendLabel;
-        this.parentUniqueId = o.parentUniqueId;
-        this.groupType = o.groupType;
-        this.displayInLegend = o.displayInLegend;
-        this.expandInLegend = o.expandInLegend;
-        this.visible = o.visible;
-        this.initiallyVisible = o.visible;
-        this.actuallyVisible = o.actuallyVisible;
-        this.registerEventID(Fusion.Event.GROUP_PROPERTY_CHANGED);
-    show: function(noDraw) {
-        if (this.visible) {
-            return;
-        this.oMap.showGroup(this, noDraw ? true : false);
-        this.visible = true;
-        if (this.legend && this.legend.checkBox) {
-            this.legend.checkBox.checked = true;
-    hide: function(noDraw) {
-        if (!this.visible) {
-            return;
-        this.oMap.hideGroup(this, noDraw ? true : false);
-        this.visible = false;
-            this.legend.checkBox.checked = false;
-    isVisible: function() {
-        return this.visible;
-    clear: function() {
-        for (var i=0; i<this.groups.length; i++) {
-            this.groups[i].clear();
-        for (var i=0; i<this.layers.length; i++) {
-            this.layers[i].clear();
-        this.groups = [];
-        this.layers = [];
-    set: function(property, value) {
-        this[property] = value;
-        this.triggerEvent(Fusion.Event.GROUP_PROPERTY_CHANGED, this);
-    addGroup: function(group,reverse) {
-        group.parentGroup = this;
-        if (reverse) {
-          this.groups.unshift(group);
-        } else {
-          this.groups.push(group);
-    addLayer: function(layer,reverse) {
-        layer.parentGroup = this;
-        if (reverse) {
-          this.layers.unshift(layer);
-        } else {
-          this.layers.push(layer);
-    findGroup: function(name) {
-        return this.findGroupByAttribute('name', name);
-    findGroupByAttribute: function(attribute, value) {
-        if (this[attribute] == value) {
-            return this;
-            var group = this.groups[i].findGroupByAttribute(attribute, value);
-            if (group) {
-                return group;
-        return null;
-    findLayer: function(name) {
-        return this.findLayerByAttribute('name', name);
-    findLayerByAttribute: function(attribute, value) {
-            if (this.layers[i][attribute] == value) {
-                return this.layers[i];
-            var layer = this.groups[i].findLayerByAttribute(attribute,value);
-            if (layer) {
-                return layer;
-        return null;
-* Class: Fusion.Layers.Layer
-* Implements individual map legend layers
-Fusion.Event.LAYER_PROPERTY_CHANGED = Fusion.Event.lastEventId++;
-Fusion.Layers.Layer = OpenLayers.Class(Fusion.Lib.EventMgr, {
-    name: null,
-    scaleRanges: null,
-    oMap: null,
-        this.oMap = oMap;
-        this.layerName = o.layerName;
-        this.resourceId = o.resourceId;
-        this.selectedFeatureCount = 0;
-        this.layerTypes = [].concat(o.layerTypes);
-        this.statusDefault = o.statusdefault;
-        this.editable = o.editable;
-        this.selectable = o.selectable;
-        //determine the layer type so that the correct icon can be displayed in the legend
-        this.layerType = null;
-        if (this.supportsType(Fusion.Constant.LAYER_RASTER_TYPE)) {   //raster layers
-          this.layerType = Fusion.Constant.LAYER_RASTER_TYPE;
-        } else if (this.supportsType(Fusion.Constant.LAYER_DWF_TYPE)) {  //DWF layers
-          this.layerType = Fusion.Constant.LAYER_DWF_TYPE;
-        this.parentGroup = o.parentGroup;
-        this.minScale = o.minScale;
-        this.maxScale = o.maxScale;
-        if (this.maxScale == 'infinity') {
-          this.maxScale = 1000000000000;
-        this.scaleRanges = [];
-        if (o.scaleRanges)
-          for (var i=0; i<o.scaleRanges.length; i++) {
-            var scaleRange = new Fusion.Layers.ScaleRange(o.scaleRanges[i],
-        this.layerType);
-            this.scaleRanges.push(scaleRange);
-        this.registerEventID(Fusion.Event.LAYER_PROPERTY_CHANGED);
-    supportsType: function(type) {
-        for (var i=0; i<this.layerTypes.length; i++) {
-            if (this.layerTypes[i] == type) {
-                return true;
-        return false;
-    getScaleRange: function(fScale) {
-        for (var i=0; i<this.scaleRanges.length; i++) {
-            if (this.scaleRanges[i].contains(fScale)) {
-                return this.scaleRanges[i];
-        return null;
-            return;
-        this.set('visible', true);
-        this.oMap.showLayer(this, noDraw ? true : false);
-            return;
-        this.set('visible',false);
-        this.oMap.hideLayer(this, noDraw ? true : false);
-    clear: function() {},
-        this.triggerEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, this);
-* Class: Fusion.Layers.ScaleRange
-* Implements a scale range object
-Fusion.Layers.ScaleRange = OpenLayers.Class({
-    styles: null,
-    initialize: function(o, layerType) {
-        if (this.maxScale == 'infinity' || this.maxScale == 'auto') {
-          this.maxScale = Infinity;
-        this.styles = [];
-        if (!o.styles) {
-          var styleItem = new Fusion.Layers.StyleItem({legendLabel:'DWF'}, layerType);
-          this.styles.push(styleItem);
-          return;
-        var staticIcon = o.styles.length>1 ? false : layerType;
-        for (var i=0; i<o.styles.length; i++) {
-            var styleItem = new Fusion.Layers.StyleItem(o.styles[i], staticIcon);
-    contains: function(fScale) {
-        var testScale = Math.round(fScale);
-        return testScale >= this.minScale && testScale <= this.maxScale;
-* Class: Fusion.Layers.StyleItem
-* Implements the legend style items to get a legend icon from the server
-Fusion.Layers.StyleItem = OpenLayers.Class({
-    initialize: function(o, staticIcon) {
-        this.filter = o.filter;
-        this.geometryType = o.geometryType;
-        if (this.geometryType == '') {
-            this.geometryType = -1;
-        this.categoryIndex = o.categoryIndex;
-        if (this.categoryindex == '') {
-            this.categoryindex = -1;
-        this.index = o.index; //TODO: merge this with categoryIndex?
-        this.staticIcon = staticIcon;
+ * Fusion.Layers
+ * $Id: MapGuide.js 1590 2008-10-10 14:01:27Z madair $
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+* Class: Fusion.Layers
+* Implements Layers for Fusion.
+Fusion.Event.MAP_LAYER_TOGGLED = Fusion.Event.lastEventId++;
+Fusion.Event.MAP_LAYER_ORDER_CHANGED = Fusion.Event.lastEventId++;
+Fusion.Event.LAYER_LOADED = Fusion.Event.lastEventId++;
+Fusion.Event.LAYER_LOADING = Fusion.Event.lastEventId++;
+Fusion.Layers = OpenLayers.Class(Fusion.Lib.EventMgr, {
+    bSingleTile: null,
+    bIsBaseLayer: false,     //TODO: set this in AppDef?
+    bDisplayInLegend: true,   //TODO: set this in AppDef?
+    bExpandInLegend: true,   //TODO: set this in AppDef?
+    bMapLoaded: false,
+    bIsMapWidgetLayer: true,  //Set this to false for overview map layers
+    bLayersReversed: false,     //MGOS returns layers top-most layer first
+    sMapResourceId: null,    //pointer to the resource that defines the map (URL, MapFile, MGOS, etc)
+    sImageType: 'png',      //TODO: set this in AppDef?
+    clientAgent: 'Fusion Viewer',
+    noCache: false,
+    _sMapTitle: null,
+    _sMapname: null,
+    initialize: function(map, mapTag, isMapWidgetLayer) {
+        // console.log('Fusion.Layers.initialize');
+        this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
+        this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
+        this.registerEventID(Fusion.Event.MAP_LOADED);
+        this.registerEventID(Fusion.Event.LAYER_LOADED);
+        this.registerEventID(Fusion.Event.LAYER_LOADING);
+        this.registerEventID(Fusion.Event.MAP_LAYER_ORDER_CHANGED);
+        this.mapWidget = map;
+        this.oSelection = null;
+        if (isMapWidgetLayer != null) {
+            this.bIsMapWidgetLayer = isMapWidgetLayer;
+        this.mapTag = mapTag;
+        if (!this.mapTag.layerOptions) {
+          this.mapTag.layerOptions = {};
+        this.ratio = this.mapTag.layerOptions.MapRatio ? this.extension.MapRatio[0] : 1.0;
+        this.bSingleTile = mapTag.singleTile; //this is set in thhe AppDef.Map class
+        this.bIsBaseLayer = mapTag.isBaseLayer;
+        this.sMapResourceId = mapTag.resourceId ? mapTag.resourceId : '';
+        this.mapInfo = mapTag.mapInfo;
+        this.layerType = mapTag.type;
+     * Function: loadScaleRanges
+     * This function should be called after the map has loaded. It
+     * loads the scsle ranges for each layer. I tis for now only
+     * used by the legend widget.
+    loadScaleRanges: function(userFunc) {
+      userFunc();
+    getMapName: function() {
+        return this._sMapname;
+    getMapTitle: function() {
+        return this._sMapTitle;
+     * Function: isMapLoaded
+     * Returns true if the Map has been laoded succesfully form the server
+    isMapLoaded: function() {
+        return this.bMapLoaded;
+    getMaxExtent: function() {
+      var maxExtent = null;
+      if (this.oLayerOL) {
+        maxExtent = this.oLayerOL.maxExtent;
+      return maxExtent;
+    hasSelection: function() {
+      return this.bSelectionOn;
+     * Returns the number of features selected for this map layer
+    getSelectedFeatureCount: function() {
+      var total = 0;
+      return total;
+    getSelectedLayers: function() {
+      var layers = [];
+      return layers;
+    getSelectableLayers: function() {
+      var layers = [];
+      return layers;
+    setSelection: function (selText, zoomTo) {
+     * asynchronously load the current selection.  When the current
+     * selection changes, the selection is not loaded because it
+     * could be a lengthy process.  The user-supplied function will
+     * be called when the selection is available.
+     * @param userFunc {Function} a function to call when the
+     *        selection has loaded
+     * @param layers {string} Optional parameter.  A comma separated
+     *        list of layer names (Roads,Parcels). If it is not
+     *        given, all the layers that have a selection will be used
+     * @param startcount {string} Optional parameter.  A comma separated
+     *        list of a statinh index and the number of features to be retured for
+     *        each layer given in the layers parameter. Index starts at 0
+     *        (eg: 0:4,2:6 : return 4 elements for the first layers starting at index 0 and
+     *         six elements for layer 2 starting at index 6). If it is not
+     *        given, all the elemsnts will be returned.
+    getSelection: function(userFunc, layers, startcount) {
+       Utility function to clear current selection
+    clearSelection: function() {
+       Do a query on the map
+    query: function(options) {
+    processLayerEvents: function(layer, isEnabling) {
+        if (this.mapInfo && this.mapInfo.mapEvents.layerEvents[layer.layerName]) {
+            var layerEvent = this.mapInfo.mapEvents.layerEvents[layer.layerName];
+            var events = isEnabling ? layerEvent.onEnable : layerEvent.onDisable;
+            for (var i=0; i<events.length; i++) {
+                var o = events[i];
+                if (o.type == 'layer') {
+                    var l = this.layerRoot.findLayer(o.name);
+                    if (l) {
+                        if (o.enable) {
+                            l.show(true);
+                        } else {
+                            l.hide(true);
+                } else if (o.type == 'group') {
+                    var g = this.layerRoot.findGroupByAttribute('groupName', o.name);
+                    if (g) {
+                        if (o.enable) {
+                            g.show(true);
+                        } else {
+                            g.hide(true);
+    processGroupEvents: function(group, isEnabling) {
+        if (this.mapInfo && this.mapInfo.mapEvents.groupEvents[group.groupName]) {
+            var groupEvent = this.mapInfo.mapEvents.groupEvents[group.groupName];
+            var events = isEnabling ? groupEvent.onEnable : groupEvent.onDisable;
+                    if (l) {
+                        if (o.enable) {
+                            l.show(true);
+                        } else {
+                            l.hide(true);
+                    if (g) {
+                        if (o.enable) {
+                            g.show(true);
+                        } else {
+                            g.hide(true);
+    refreshLayer: function( layer ) {
+        this.drawMap();
+    setParameter: function(param, value) {
+        if (param == 'SelectionType') {
+            this.selectionType = value;
+    loadStart: function() {
+      if (this.bIsMapWidgetLayer) {
+        this.mapWidget._addWorker();
+    loadEnd: function() {
+        this.mapWidget._removeWorker();
+    getGroupInfoUrl: function(groupName) {
+        if (this.mapInfo) {
+            var groups = this.mapInfo.links.groups;
+            for (var i=0; i<groups.length; i++) {
+                if (groups[i].name == groupName) {
+                    return groups[i].url;
+        return null;
+    getLayerInfoUrl: function(layerName) {
+            var layers = this.mapInfo.links.layers;
+            for (var i=0; i<layers.length; i++) {
+                if (layers[i].name == layerName) {
+                    return layers[i].url;
+        return null;
+    getMapTip: function(mapTipWidget) {}
+* Class: Fusion.Layers.Group
+* Implements the map layer groups
+Fusion.Event.GROUP_PROPERTY_CHANGED = Fusion.Event.lastEventId++;
+Fusion.Layers.Group = OpenLayers.Class(Fusion.Lib.EventMgr, {
+    name: null,
+    groups: null,
+    layers: null,
+    oMap: null,
+    initialize: function(o, oMap) {
+        this.uniqueId = o.uniqueId;
+        this.name = o.groupName;
+        this.groups = [];
+        this.layers = [];
+        this.oMap = oMap;
+        this.groupName = o.groupName;
+        this.legendLabel = o.legendLabel;
+        this.parentUniqueId = o.parentUniqueId;
+        this.groupType = o.groupType;
+        this.displayInLegend = o.displayInLegend;
+        this.expandInLegend = o.expandInLegend;
+        this.visible = o.visible;
+        this.initiallyVisible = o.visible;
+        this.actuallyVisible = o.actuallyVisible;
+        this.registerEventID(Fusion.Event.GROUP_PROPERTY_CHANGED);
+    show: function(noDraw) {
+        if (this.visible) {
+            return;
+        this.oMap.showGroup(this, noDraw ? true : false);
+        this.visible = true;
+        if (this.legend && this.legend.checkBox) {
+            this.legend.checkBox.checked = true;
+    hide: function(noDraw) {
+        if (!this.visible) {
+            return;
+        this.oMap.hideGroup(this, noDraw ? true : false);
+        this.visible = false;
+            this.legend.checkBox.checked = false;
+    isVisible: function() {
+        return this.visible;
+    clear: function() {
+        for (var i=0; i<this.groups.length; i++) {
+            this.groups[i].clear();
+        for (var i=0; i<this.layers.length; i++) {
+            this.layers[i].clear();
+        this.groups = [];
+        this.layers = [];
+    set: function(property, value) {
+        this[property] = value;
+        this.triggerEvent(Fusion.Event.GROUP_PROPERTY_CHANGED, this);
+    addGroup: function(group,reverse) {
+        group.parentGroup = this;
+        if (reverse) {
+          this.groups.unshift(group);
+        } else {
+          this.groups.push(group);
+    addLayer: function(layer,reverse) {
+        layer.parentGroup = this;
+        if (reverse) {
+          this.layers.unshift(layer);
+        } else {
+          this.layers.push(layer);
+    findGroup: function(name) {
+        return this.findGroupByAttribute('name', name);
+    findGroupByAttribute: function(attribute, value) {
+        if (this[attribute] == value) {
+            return this;
+            var group = this.groups[i].findGroupByAttribute(attribute, value);
+            if (group) {
+                return group;
+        return null;
+    findLayer: function(name) {
+        return this.findLayerByAttribute('name', name);
+    findLayerByAttribute: function(attribute, value) {
+            if (this.layers[i][attribute] == value) {
+                return this.layers[i];
+            var layer = this.groups[i].findLayerByAttribute(attribute,value);
+            if (layer) {
+                return layer;
+        return null;
+* Class: Fusion.Layers.Layer
+* Implements individual map legend layers
+Fusion.Event.LAYER_PROPERTY_CHANGED = Fusion.Event.lastEventId++;
+Fusion.Layers.Layer = OpenLayers.Class(Fusion.Lib.EventMgr, {
+    name: null,
+    scaleRanges: null,
+    oMap: null,
+        this.oMap = oMap;
+        this.layerName = o.layerName;
+        this.resourceId = o.resourceId;
+        this.selectedFeatureCount = 0;
+        this.layerTypes = [].concat(o.layerTypes);
+        this.statusDefault = o.statusdefault;
+        this.editable = o.editable;
+        this.selectable = o.selectable;
+        //determine the layer type so that the correct icon can be displayed in the legend
+        this.layerType = null;
+        if (this.supportsType(Fusion.Constant.LAYER_RASTER_TYPE)) {   //raster layers
+          this.layerType = Fusion.Constant.LAYER_RASTER_TYPE;
+        } else if (this.supportsType(Fusion.Constant.LAYER_DWF_TYPE)) {  //DWF layers
+          this.layerType = Fusion.Constant.LAYER_DWF_TYPE;
+        this.parentGroup = o.parentGroup;
+        this.minScale = o.minScale;
+        this.maxScale = o.maxScale;
+        if (this.maxScale == 'infinity') {
+          this.maxScale = 1000000000000;
+        this.scaleRanges = [];
+        if (o.scaleRanges)
+          for (var i=0; i<o.scaleRanges.length; i++) {
+            var scaleRange = new Fusion.Layers.ScaleRange(o.scaleRanges[i],
+        this.layerType);
+            this.scaleRanges.push(scaleRange);
+        this.registerEventID(Fusion.Event.LAYER_PROPERTY_CHANGED);
+    supportsType: function(type) {
+        for (var i=0; i<this.layerTypes.length; i++) {
+            if (this.layerTypes[i] == type) {
+                return true;
+        return false;
+    getScaleRange: function(fScale) {
+        for (var i=0; i<this.scaleRanges.length; i++) {
+            if (this.scaleRanges[i].contains(fScale)) {
+                return this.scaleRanges[i];
+        return null;
+            return;
+        this.set('visible', true);
+        this.oMap.showLayer(this, noDraw ? true : false);
+            return;
+        this.set('visible',false);
+        this.oMap.hideLayer(this, noDraw ? true : false);
+    clear: function() {},
+        this.triggerEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, this);
+* Class: Fusion.Layers.ScaleRange
+* Implements a scale range object
+Fusion.Layers.ScaleRange = OpenLayers.Class({
+    styles: null,
+    initialize: function(o, layerType) {
+        if (this.maxScale == 'infinity' || this.maxScale == 'auto') {
+          this.maxScale = Infinity;
+        this.styles = [];
+        if (!o.styles) {
+          var styleItem = new Fusion.Layers.StyleItem({legendLabel:'DWF'}, layerType);
+          this.styles.push(styleItem);
+          return;
+        var staticIcon = o.styles.length>1 ? false : layerType;
+        for (var i=0; i<o.styles.length; i++) {
+            var styleItem = new Fusion.Layers.StyleItem(o.styles[i], staticIcon);
+    contains: function(fScale) {
+        var testScale = Math.round(fScale);
+        return testScale >= this.minScale && testScale <= this.maxScale;
+* Class: Fusion.Layers.StyleItem
+* Implements the legend style items to get a legend icon from the server
+Fusion.Layers.StyleItem = OpenLayers.Class({
+    initialize: function(o, staticIcon) {
+        this.filter = o.filter;
+        this.geometryType = o.geometryType;
+        if (this.geometryType == '') {
+            this.geometryType = -1;
+        this.categoryIndex = o.categoryIndex;
+        if (this.categoryindex == '') {
+            this.categoryindex = -1;
+        this.index = o.index; //TODO: merge this with categoryIndex?
+        this.staticIcon = staticIcon;
More information about the fusion-commits mailing list
