[fusion-commits] r1893 - in trunk: . conf db db/revprops
db/revprops/0 db/revs db/revs/0 hooks locks
svn_fusion at osgeo.org
Fri Aug 14 09:42:08 EDT 2009
Author: greigr
Date: 2009-08-14 09:42:08 -0400 (Fri, 14 Aug 2009)
New Revision: 1893
Added:
trunk/README.txt
trunk/conf/
trunk/conf/authz
trunk/conf/passwd
trunk/conf/svnserve.conf
trunk/db/
trunk/db/current
trunk/db/format
trunk/db/fs-type
trunk/db/fsfs.conf
trunk/db/min-unpacked-rev
trunk/db/rep-cache.db
trunk/db/revprops/
trunk/db/revprops/0/
trunk/db/revprops/0/0
trunk/db/revs/
trunk/db/revs/0/
trunk/db/revs/0/0
trunk/db/transactions/
trunk/db/txn-current
trunk/db/txn-current-lock
trunk/db/txn-protorevs/
trunk/db/uuid
trunk/db/write-lock
trunk/format
trunk/hooks/
trunk/hooks/post-commit.tmpl
trunk/hooks/post-lock.tmpl
trunk/hooks/post-revprop-change.tmpl
trunk/hooks/post-unlock.tmpl
trunk/hooks/pre-commit.tmpl
trunk/hooks/pre-lock.tmpl
trunk/hooks/pre-revprop-change.tmpl
trunk/hooks/pre-unlock.tmpl
trunk/hooks/start-commit.tmpl
trunk/locks/
trunk/locks/db-logs.lock
trunk/locks/db.lock
Added: trunk/README.txt
--- trunk/README.txt (rev 0)
+++ trunk/README.txt 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,5 @@
+This is a Subversion repository; use the 'svnadmin' tool to examine
+it. Do not add, delete, or modify files here unless you know how
+to avoid corrupting the repository.
+Visit http://subversion.tigris.org/ for more information.
Added: trunk/conf/authz
--- trunk/conf/authz (rev 0)
+++ trunk/conf/authz 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,32 @@
+### This file is an example authorization file for svnserve.
+### Its format is identical to that of mod_authz_svn authorization
+### files.
+### As shown below each section defines authorizations for the path and
+### (optional) repository specified by the section name.
+### The authorizations follow. An authorization line can refer to:
+### - a single user,
+### - a group of users defined in a special [groups] section,
+### - an alias defined in a special [aliases] section,
+### - all authenticated users, using the '$authenticated' token,
+### - only anonymous users, using the '$anonymous' token,
+### - anyone, using the '*' wildcard.
+### A match can be inverted by prefixing the rule with '~'. Rules can
+### grant read ('r') access, read-write ('rw') access, or no access
+[aliases]
+# joe = /C=XZ/ST=Dessert/L=Snake City/O=Snake Oil, Ltd./OU=Research Institute/CN=Joe Average
+[groups]
+# harry_and_sally = harry,sally
+# harry_sally_and_joe = harry,sally,&joe
+# [/foo/bar]
+# harry = rw
+# &joe = r
+# [repository:/baz/fuz]
+# @harry_and_sally = rw
+# * = r
Added: trunk/conf/passwd
--- trunk/conf/passwd (rev 0)
+++ trunk/conf/passwd 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,8 @@
+### This file is an example password file for svnserve.
+### Its format is similar to that of svnserve.conf. As shown in the
+### example below it contains one section labelled [users].
+### The name and password for each user follow, one account per line.
+[users]
+# harry = harryssecret
+# sally = sallyssecret
Added: trunk/conf/svnserve.conf
--- trunk/conf/svnserve.conf (rev 0)
+++ trunk/conf/svnserve.conf 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,47 @@
+### This file controls the configuration of the svnserve daemon, if you
+### use it to allow access to this repository. (If you only allow
+### access through http: and/or file: URLs, then this file is
+### irrelevant.)
+### Visit http://subversion.tigris.org/ for more information.
+[general]
+### These options control access to the repository for unauthenticated
+### and authenticated users. Valid values are "write", "read",
+### and "none". The sample settings below are the defaults.
+# anon-access = read
+# auth-access = write
+### The password-db option controls the location of the password
+### database file. Unless you specify a path starting with a /,
+### the file's location is relative to the directory containing
+### this configuration file.
+### If SASL is enabled (see below), this file will NOT be used.
+### Uncomment the line below to use the default password file.
+# password-db = passwd
+### The authz-db option controls the location of the authorization
+### rules for path-based access control. Unless you specify a path
+### starting with a /, the file's location is relative to the the
+### directory containing this file. If you don't specify an
+### authz-db, no path-based access control is done.
+### Uncomment the line below to use the default authorization file.
+# authz-db = authz
+### This option specifies the authentication realm of the repository.
+### If two repositories have the same authentication realm, they should
+### have the same password database, and vice versa. The default realm
+### is repository's uuid.
+# realm = My First Repository
+[sasl]
+### This option specifies whether you want to use the Cyrus SASL
+### library for authentication. Default is false.
+### This section will be ignored if svnserve is not built with Cyrus
+### SASL support; to check, run 'svnserve --version' and look for a line
+### reading 'Cyrus SASL authentication is available.'
+# use-sasl = true
+### These options specify the desired strength of the security layer
+### that you want SASL to provide. 0 means no encryption, 1 means
+### integrity-checking only, values larger than 1 are correlated
+### to the effective key length for encryption (e.g. 128 means 128-bit
+### encryption). The values below are the defaults.
+# min-encryption = 0
+# max-encryption = 256
Added: trunk/db/current
--- trunk/db/current (rev 0)
+++ trunk/db/current 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1 @@
+0
Added: trunk/db/format
--- trunk/db/format (rev 0)
+++ trunk/db/format 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,2 @@
+4
+layout sharded 1000
Added: trunk/db/fs-type
--- trunk/db/fs-type (rev 0)
+++ trunk/db/fs-type 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1 @@
+fsfs
Added: trunk/db/fsfs.conf
--- trunk/db/fsfs.conf (rev 0)
+++ trunk/db/fsfs.conf 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,37 @@
+### This file controls the configuration of the FSFS filesystem.
+[memcached-servers]
+### These options name memcached servers used to cache internal FSFS
+### data. See http://www.danga.com/memcached/ for more information on
+### memcached. To use memcached with FSFS, run one or more memcached
+### servers, and specify each of them as an option like so:
+# first-server = 127.0.0.1:11211
+# remote-memcached = mymemcached.corp.example.com:11212
+### The option name is ignored; the value is of the form HOST:PORT.
+### memcached servers can be shared between multiple repositories;
+### however, if you do this, you *must* ensure that repositories have
+### distinct UUIDs and paths, or else cached data from one repository
+### might be used by another accidentally. Note also that memcached has
+### no authentication for reads or writes, so you must ensure that your
+### memcached servers are only accessible by trusted users.
+[caches]
+### When a cache-related error occurs, normally Subversion ignores it
+### and continues, logging an error if the server is appropriately
+### configured (and ignoring it with file:// access). To make
+### Subversion never ignore cache errors, uncomment this line.
+# fail-stop = true
+[rep-sharing]
+### To conserve space, the filesystem can optionally avoid storing
+### duplicate representations. This comes at a slight cost in performace,
+### as maintaining a database of shared representations can increase
+### commit times. The space savings are dependent upon the size of the
+### repository, the number of objects it contains and the amount of
+### duplication between them, usually a function of the branching and
+### merging process.
+### The following parameter enables rep-sharing in the repository. It can
+### be switched on and off at will, but for best space-saving results
+### should be enabled consistently over the life of the repository.
+# enable-rep-sharing = false
Added: trunk/db/min-unpacked-rev
--- trunk/db/min-unpacked-rev (rev 0)
+++ trunk/db/min-unpacked-rev 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1 @@
+0
Added: trunk/db/rep-cache.db
(Binary files differ)
Property changes on: trunk/db/rep-cache.db
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/db/revprops/0/0
--- trunk/db/revprops/0/0 (rev 0)
+++ trunk/db/revprops/0/0 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,5 @@
+K 8
+svn:date
+V 27
+2009-08-12T18:44:01.484375Z
+END
Added: trunk/db/revs/0/0
--- trunk/db/revs/0/0 (rev 0)
+++ trunk/db/revs/0/0 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,11 @@
+PLAIN
+END
+ENDREP
+id: 0.0.r0/17
+type: dir
+count: 0
+text: 0 0 4 4 2d2977d1c96f487abe4a1e202dd03b4e
+cpath: /
+17 107
Added: trunk/db/txn-current
--- trunk/db/txn-current (rev 0)
+++ trunk/db/txn-current 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1 @@
+0
Added: trunk/db/uuid
--- trunk/db/uuid (rev 0)
+++ trunk/db/uuid 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1 @@
+6da37b3a-b7f0-264f-8d44-7608c4e1d449
Added: trunk/format
--- trunk/format (rev 0)
+++ trunk/format 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1 @@
+5
Added: trunk/hooks/post-commit.tmpl
--- trunk/hooks/post-commit.tmpl (rev 0)
+++ trunk/hooks/post-commit.tmpl 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,50 @@
+#!/bin/sh
+# POST-COMMIT HOOK
+# The post-commit hook is invoked after a commit. Subversion runs
+# this hook by invoking a program (script, executable, binary, etc.)
+# named 'post-commit' (for which this file is a template) with the
+# following ordered arguments:
+# [1] REPOS-PATH (the path to this repository)
+# [2] REV (the number of the revision just committed)
+# The default working directory for the invocation is undefined, so
+# the program should set one explicitly if it cares.
+# Because the commit has already completed and cannot be undone,
+# the exit code of the hook program is ignored. The hook program
+# can use the 'svnlook' utility to help it examine the
+# newly-committed tree.
+# On a Unix system, the normal procedure is to have 'post-commit'
+# invoke other programs to do the real work, though it may do the
+# work itself too.
+# Note that 'post-commit' must be executable by the user(s) who will
+# invoke it (typically the user httpd runs as), and that user must
+# have filesystem-level permission to access the repository.
+# On a Windows system, you should name the hook program
+# 'post-commit.bat' or 'post-commit.exe',
+# but the basic idea is the same.
+# The hook program typically does not inherit the environment of
+# its parent process. For example, a common problem is for the
+# PATH environment variable to not be set to its usual value, so
+# that subprograms fail to launch unless invoked via absolute path.
+# If you're having unexpected problems with a hook program, the
+# culprit may be unusual (or missing) environment variables.
+# Here is an example hook script, for a Unix /bin/sh interpreter.
+# For more examples and pre-written hooks, see those in
+# the Subversion repository at
+# http://svn.collab.net/repos/svn/trunk/tools/hook-scripts/ and
+# http://svn.collab.net/repos/svn/trunk/contrib/hook-scripts/
+REPOS="$1"
+REV="$2"
+mailer.py commit "$REPOS" "$REV" /path/to/mailer.conf
Added: trunk/hooks/post-lock.tmpl
--- trunk/hooks/post-lock.tmpl (rev 0)
+++ trunk/hooks/post-lock.tmpl 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,44 @@
+#!/bin/sh
+# POST-LOCK HOOK
+# The post-lock hook is run after a path is locked. Subversion runs
+# named 'post-lock' (for which this file is a template) with the
+# [2] USER (the user who created the lock)
+# The paths that were just locked are passed to the hook via STDIN (as
+# of Subversion 1.2, only one path is passed per invocation, but the
+# plan is to pass all locked paths at once, so the hook program
+# should be written accordingly).
+# Because the lock has already been created and cannot be undone,
+# newly-created lock.
+# On a Unix system, the normal procedure is to have 'post-lock'
+# work itself too.
+# Note that 'post-lock' must be executable by the user(s) who will
+# 'post-lock.bat' or 'post-lock.exe',
+# Here is an example hook script, for a Unix /bin/sh interpreter:
+REPOS="$1"
+USER="$2"
+# Send email to interested parties, let them know a lock was created:
+mailer.py lock "$REPOS" "$USER" /path/to/mailer.conf
Added: trunk/hooks/post-revprop-change.tmpl
--- trunk/hooks/post-revprop-change.tmpl (rev 0)
+++ trunk/hooks/post-revprop-change.tmpl 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,56 @@
+#!/bin/sh
+# POST-REVPROP-CHANGE HOOK
+# The post-revprop-change hook is invoked after a revision property
+# has been added, modified or deleted. Subversion runs this hook by
+# invoking a program (script, executable, binary, etc.) named
+# 'post-revprop-change' (for which this file is a template), with the
+# [2] REV (the revision that was tweaked)
+# [3] USER (the username of the person tweaking the property)
+# [4] PROPNAME (the property that was changed)
+# [5] ACTION (the property was 'A'dded, 'M'odified, or 'D'eleted)
+# [STDIN] PROPVAL ** the old property value is passed via STDIN.
+# Because the propchange has already completed and cannot be undone,
+# new property value.
+# On a Unix system, the normal procedure is to have 'post-revprop-change'
+# work itself too.
+# Note that 'post-revprop-change' must be executable by the user(s) who will
+# 'post-revprop-change.bat' or 'post-revprop-change.exe',
+REPOS="$1"
+REV="$2"
+USER="$3"
+PROPNAME="$4"
+ACTION="$5"
+mailer.py propchange2 "$REPOS" "$REV" "$USER" "$PROPNAME" "$ACTION" /path/to/mailer.conf
Added: trunk/hooks/post-unlock.tmpl
--- trunk/hooks/post-unlock.tmpl (rev 0)
+++ trunk/hooks/post-unlock.tmpl 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,42 @@
+#!/bin/sh
+# POST-UNLOCK HOOK
+# The post-unlock hook runs after a path is unlocked. Subversion runs
+# named 'post-unlock' (for which this file is a template) with the
+# [2] USER (the user who destroyed the lock)
+# The paths that were just unlocked are passed to the hook via STDIN
+# (as of Subversion 1.2, only one path is passed per invocation, but
+# the plan is to pass all unlocked paths at once, so the hook program
+# Because the lock has already been destroyed and cannot be undone,
+# On a Unix system, the normal procedure is to have 'post-unlock'
+# work itself too.
+# Note that 'post-unlock' must be executable by the user(s) who will
+# 'post-unlock.bat' or 'post-unlock.exe',
+REPOS="$1"
+USER="$2"
+# Send email to interested parties, let them know a lock was removed:
+mailer.py unlock "$REPOS" "$USER" /path/to/mailer.conf
Added: trunk/hooks/pre-commit.tmpl
--- trunk/hooks/pre-commit.tmpl (rev 0)
+++ trunk/hooks/pre-commit.tmpl 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,81 @@
+#!/bin/sh
+# PRE-COMMIT HOOK
+# The pre-commit hook is invoked before a Subversion txn is
+# committed. Subversion runs this hook by invoking a program
+# (script, executable, binary, etc.) named 'pre-commit' (for which
+# this file is a template), with the following ordered arguments:
+# [2] TXN-NAME (the name of the txn about to be committed)
+# [STDIN] LOCK-TOKENS ** the lock tokens are passed via STDIN.
+# If STDIN contains the line "LOCK-TOKENS:\n" (the "\n" denotes a
+# single newline), the lines following it are the lock tokens for
+# this commit. The end of the list is marked by a line containing
+# only a newline character.
+# Each lock token line consists of a URI-escaped path, followed
+# by the separator character '|', followed by the lock token string,
+# followed by a newline.
+# If the hook program exits with success, the txn is committed; but
+# if it exits with failure (non-zero), the txn is aborted, no commit
+# takes place, and STDERR is returned to the client. The hook
+# program can use the 'svnlook' utility to help it examine the txn.
+# On a Unix system, the normal procedure is to have 'pre-commit'
+# work itself too.
+# *** NOTE: THE HOOK PROGRAM MUST NOT MODIFY THE TXN, EXCEPT ***
+# *** FOR REVISION PROPERTIES (like svn:log or svn:author). ***
+# This is why we recommend using the read-only 'svnlook' utility.
+# In the future, Subversion may enforce the rule that pre-commit
+# hooks should not modify the versioned data in txns, or else come
+# up with a mechanism to make it safe to do so (by informing the
+# committing client of the changes). However, right now neither
+# mechanism is implemented, so hook writers just have to be careful.
+# Note that 'pre-commit' must be executable by the user(s) who will
+# 'pre-commit.bat' or 'pre-commit.exe',
+REPOS="$1"
+TXN="$2"
+# Make sure that the log message contains some text.
+SVNLOOK=/usr/local/bin/svnlook
+$SVNLOOK log -t "$TXN" "$REPOS" | \
+ grep "[a-zA-Z0-9]" > /dev/null || exit 1
+# Check that the author of this commit has the rights to perform
+# the commit on the files and directories being modified.
+commit-access-control.pl "$REPOS" "$TXN" commit-access-control.cfg || exit 1
+# All checks passed, so allow the commit.
+exit 0
Added: trunk/hooks/pre-lock.tmpl
--- trunk/hooks/pre-lock.tmpl (rev 0)
+++ trunk/hooks/pre-lock.tmpl 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,71 @@
+#!/bin/sh
+# PRE-LOCK HOOK
+# The pre-lock hook is invoked before an exclusive lock is
+# created. Subversion runs this hook by invoking a program
+# (script, executable, binary, etc.) named 'pre-lock' (for which
+# [2] PATH (the path in the repository about to be locked)
+# [3] USER (the user creating the lock)
+# [4] COMMENT (the comment of the lock)
+# [5] STEAL-LOCK (1 if the user is trying to steal the lock, else 0)
+# If the hook program outputs anything on stdout, the output string will
+# be used as the lock token for this lock operation. If you choose to use
+# this feature, you must guarantee the tokens generated are unique across
+# the repository each time.
+# If the hook program exits with success, the lock is created; but
+# if it exits with failure (non-zero), the lock action is aborted
+# and STDERR is returned to the client.
+# On a Unix system, the normal procedure is to have 'pre-lock'
+# work itself too.
+# Note that 'pre-lock' must be executable by the user(s) who will
+# 'pre-lock.bat' or 'pre-lock.exe',
+REPOS="$1"
+PATH="$2"
+USER="$3"
+# If a lock exists and is owned by a different person, don't allow it
+# to be stolen (e.g., with 'svn lock --force ...').
+# (Maybe this script could send email to the lock owner?)
+GREP=/bin/grep
+SED=/bin/sed
+LOCK_OWNER=`$SVNLOOK lock "$REPOS" "$PATH" | \
+ $GREP '^Owner: ' | $SED 's/Owner: //'`
+# If we get no result from svnlook, there's no lock, allow the lock to
+# happen:
+if [ "$LOCK_OWNER" = "" ]; then
+ exit 0
+fi
+# If the person locking matches the lock's owner, allow the lock to
+# happen:
+if [ "$LOCK_OWNER" = "$USER" ]; then
+ exit 0
+fi
+# Otherwise, we've got an owner mismatch, so return failure:
+echo "Error: $PATH already locked by ${LOCK_OWNER}." 1>&2
+exit 1
Added: trunk/hooks/pre-revprop-change.tmpl
--- trunk/hooks/pre-revprop-change.tmpl (rev 0)
+++ trunk/hooks/pre-revprop-change.tmpl 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,66 @@
+#!/bin/sh
+# PRE-REVPROP-CHANGE HOOK
+# The pre-revprop-change hook is invoked before a revision property
+# is added, modified or deleted. Subversion runs this hook by invoking
+# a program (script, executable, binary, etc.) named 'pre-revprop-change'
+# (for which this file is a template), with the following ordered
+# arguments:
+# [2] REVISION (the revision being tweaked)
+# [4] PROPNAME (the property being set on the revision)
+# [5] ACTION (the property is being 'A'dded, 'M'odified, or 'D'eleted)
+# [STDIN] PROPVAL ** the new property value is passed via STDIN.
+# If the hook program exits with success, the propchange happens; but
+# if it exits with failure (non-zero), the propchange doesn't happen.
+# The hook program can use the 'svnlook' utility to examine the
+# existing value of the revision property.
+# WARNING: unlike other hooks, this hook MUST exist for revision
+# properties to be changed. If the hook does not exist, Subversion
+# will behave as if the hook were present, but failed. The reason
+# for this is that revision properties are UNVERSIONED, meaning that
+# a successful propchange is destructive; the old value is gone
+# forever. We recommend the hook back up the old value somewhere.
+# On a Unix system, the normal procedure is to have 'pre-revprop-change'
+# work itself too.
+# Note that 'pre-revprop-change' must be executable by the user(s) who will
+# 'pre-revprop-change.bat' or 'pre-revprop-change.exe',
+REPOS="$1"
+REV="$2"
+USER="$3"
+PROPNAME="$4"
+ACTION="$5"
+if [ "$ACTION" = "M" -a "$PROPNAME" = "svn:log" ]; then exit 0; fi
+echo "Changing revision properties other than svn:log is prohibited" >&2
+exit 1
Added: trunk/hooks/pre-unlock.tmpl
--- trunk/hooks/pre-unlock.tmpl (rev 0)
+++ trunk/hooks/pre-unlock.tmpl 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,63 @@
+#!/bin/sh
+# PRE-UNLOCK HOOK
+# The pre-unlock hook is invoked before an exclusive lock is
+# destroyed. Subversion runs this hook by invoking a program
+# (script, executable, binary, etc.) named 'pre-unlock' (for which
+# [2] PATH (the path in the repository about to be unlocked)
+# [3] USER (the user destroying the lock)
+# [4] TOKEN (the lock token to be destroyed)
+# [5] BREAK-UNLOCK (1 if the user is breaking the lock, else 0)
+# If the hook program exits with success, the lock is destroyed; but
+# if it exits with failure (non-zero), the unlock action is aborted
+# On a Unix system, the normal procedure is to have 'pre-unlock'
+# work itself too.
+# Note that 'pre-unlock' must be executable by the user(s) who will
+# 'pre-unlock.bat' or 'pre-unlock.exe',
+REPOS="$1"
+PATH="$2"
+USER="$3"
+# If a lock is owned by a different person, don't allow it be broken.
+GREP=/bin/grep
+SED=/bin/sed
+# If we get no result from svnlook, there's no lock, return success:
+ exit 0
+fi
+# If the person unlocking matches the lock's owner, return success:
+ exit 0
+fi
+echo "Error: $PATH locked by ${LOCK_OWNER}." 1>&2
+exit 1
Added: trunk/hooks/start-commit.tmpl
--- trunk/hooks/start-commit.tmpl (rev 0)
+++ trunk/hooks/start-commit.tmpl 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,65 @@
+#!/bin/sh
+# START-COMMIT HOOK
+# The start-commit hook is invoked before a Subversion txn is created
+# in the process of doing a commit. Subversion runs this hook
+# by invoking a program (script, executable, binary, etc.) named
+# 'start-commit' (for which this file is a template)
+# with the following ordered arguments:
+# [2] USER (the authenticated user attempting to commit)
+# [3] CAPABILITIES (a colon-separated list of capabilities reported
+# by the client; see note below)
+# Note: The CAPABILITIES parameter is new in Subversion 1.5, and 1.5
+# clients will typically report at least the "mergeinfo" capability.
+# If there are other capabilities, then the list is colon-separated,
+# e.g.: "mergeinfo:some-other-capability" (the order is undefined).
+# The list is self-reported by the client. Therefore, you should not
+# make security assumptions based on the capabilities list, nor should
+# you assume that clients reliably report every capability they have.
+# The working directory for this hook program's invocation is undefined,
+# so the program should set one explicitly if it cares.
+# If the hook program exits with success, the commit continues; but
+# if it exits with failure (non-zero), the commit is stopped before
+# a Subversion txn is created, and STDERR is returned to the client.
+# On a Unix system, the normal procedure is to have 'start-commit'
+# work itself too.
+# Note that 'start-commit' must be executable by the user(s) who will
+# 'start-commit.bat' or 'start-commit.exe',
+REPOS="$1"
+USER="$2"
+commit-allower.pl --repository "$REPOS" --user "$USER" || exit 1
+special-auth-check.py --user "$USER" --auth-level 3 || exit 1
+exit 0
Added: trunk/locks/db-logs.lock
--- trunk/locks/db-logs.lock (rev 0)
+++ trunk/locks/db-logs.lock 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,3 @@
+This file is not used by Subversion 1.3.x or later.
+However, its existence is required for compatibility with
+Subversion 1.2.x or earlier.
Added: trunk/locks/db.lock
--- trunk/locks/db.lock (rev 0)
+++ trunk/locks/db.lock 2009-08-14 13:42:08 UTC (rev 1893)
@@ -0,0 +1,3 @@
More information about the fusion-commits
