[fusion-commits] r2001 - in trunk: docs templates/mapguide/standard
templates/mapserver/standard widgets/widgetinfo
svn_fusion at osgeo.org
Wed Dec 2 00:34:17 EST 2009
Author: liuar
Date: 2009-12-02 00:34:16 -0500 (Wed, 02 Dec 2009)
New Revision: 2001
trunk/docs/ApplicationDefinition.xml
trunk/templates/mapguide/standard/ApplicationDefinition.xml
trunk/templates/mapserver/standard/ApplicationDefinition.xml
trunk/widgets/widgetinfo/measure.xml
Fixed ticket http://trac.osgeo.org/fusion/ticket/339
Measure: Tooltip for measure need to be updated.
Modified: trunk/docs/ApplicationDefinition.xml
--- trunk/docs/ApplicationDefinition.xml 2009-12-01 11:03:15 UTC (rev 2000)
+++ trunk/docs/ApplicationDefinition.xml 2009-12-02 05:34:16 UTC (rev 2001)
@@ -480,7 +480,7 @@
<Widget xsi:type="UiWidgetType">
<Name>Measure</Name>
<Type>Measure</Type>
- <Description>Measure distances on the map.</Description>
+ <Description>Measure distances and areas on the map.</Description>
<Extension xsi:type="CustomContentType">
<Type>both</Type>
<RulerTooltipContainer>RulerResult</RulerTooltipContainer>
@@ -497,7 +497,7 @@
<Name>menuMeasure</Name>
<Type>both</Type>
Modified: trunk/templates/mapguide/standard/ApplicationDefinition.xml
--- trunk/templates/mapguide/standard/ApplicationDefinition.xml 2009-12-01 11:03:15 UTC (rev 2000)
+++ trunk/templates/mapguide/standard/ApplicationDefinition.xml 2009-12-02 05:34:16 UTC (rev 2001)
@@ -692,7 +692,7 @@
- <StatusText>Measure distances on the map.</StatusText>
+ <StatusText>Measure distances and areas on the map.</StatusText>
<Type>both</Type>
<MeasureTooltipContainer>MeasureResult</MeasureTooltipContainer>
@@ -749,7 +749,7 @@
<Name>toolbarMeasure</Name>
<Type>both</Type>
Modified: trunk/templates/mapserver/standard/ApplicationDefinition.xml
--- trunk/templates/mapserver/standard/ApplicationDefinition.xml 2009-12-01 11:03:15 UTC (rev 2000)
+++ trunk/templates/mapserver/standard/ApplicationDefinition.xml 2009-12-02 05:34:16 UTC (rev 2001)
@@ -674,7 +674,7 @@
<Type>distance</Type>
@@ -749,7 +749,7 @@
<Type>both</Type>
Modified: trunk/widgets/widgetinfo/measure.xml
--- trunk/widgets/widgetinfo/measure.xml 2009-12-01 11:03:15 UTC (rev 2000)
+++ trunk/widgets/widgetinfo/measure.xml 2009-12-02 05:34:16 UTC (rev 2001)
@@ -4,7 +4,7 @@
<Description>A widget that allows measurements to be made on the map</Description>
<Location></Location>
<Label>Measure</Label>
- <Tooltip>Measure distances on the map</Tooltip>
+ <Tooltip>Measure distances and areas on the map</Tooltip>
<StatusText></StatusText>
<ImageUrl>images/icons.png</ImageUrl>
<ImageClass>measure</ImageClass>
More information about the fusion-commits
