[fusion-commits] r2020 - in trunk: layers/Generic lib/OpenLayers
svn_fusion at osgeo.org
Tue Dec 15 15:05:13 EST 2009
Author: madair
Date: 2009-12-15 15:05:12 -0500 (Tue, 15 Dec 2009)
New Revision: 2020
trunk/layers/Generic/Generic.js
trunk/lib/OpenLayers/OpenLayers.js
closes #304: patch OpenLayers to include option to turn animation off for VE layers (this will be in OL2.9 from OL issue #2286)
Modified: trunk/layers/Generic/Generic.js
--- trunk/layers/Generic/Generic.js 2009-12-14 15:01:16 UTC (rev 2019)
+++ trunk/layers/Generic/Generic.js 2009-12-15 20:05:12 UTC (rev 2020)
@@ -118,7 +118,8 @@
break;
break;
- case 'VirtualEarth':
+ case 'VirtualEarth':
+ this.mapTag.layerOptions.animationEnabled = false;
switch (this.mapTag.layerOptions.type) { //VE layer types are enumerated values
case 'Aerial': //defined in VEMapStyle from the VE api
case 'a':
@@ -242,6 +243,10 @@
getLegendImageURL: function(fScale, layer, style,defaultIcon) {
//var url = null; //TODO: provide a generic icon url
return defaultIcon;
+ getSessionID: function() {
+ return '';
Modified: trunk/lib/OpenLayers/OpenLayers.js
--- trunk/lib/OpenLayers/OpenLayers.js 2009-12-14 15:01:16 UTC (rev 2019)
+++ trunk/lib/OpenLayers/OpenLayers.js 2009-12-15 20:05:12 UTC (rev 2020)
@@ -1,95 +1,95 @@
- OpenLayers.js -- OpenLayers Map Viewer Library
- Copyright 2005-2008 MetaCarta, Inc., released under the Clear BSD license.
- Please see http://svn.openlayers.org/trunk/openlayers/license.txt
- for the full text of the license.
- Includes compressed code under the following licenses:
- (For uncompressed versions of the code used please see the
- OpenLayers SVN repository: <http://openlayers.org/>)
-/* Contains portions of Prototype.js:
- * Prototype JavaScript framework, version 1.4.0
- * (c) 2005 Sam Stephenson <sam at conio.net>
- * Prototype is freely distributable under the terms of an MIT-style license.
- * For details, see the Prototype web site: http://prototype.conio.net/
-* Contains portions of Rico <http://openrico.org/>
-* Copyright 2005 Sabre Airline Solutions
-* Licensed under the Apache License, Version 2.0 (the "License"); you
-* may not use this file except in compliance with the License. You
-* may obtain a copy of the License at
-* http://www.apache.org/licenses/LICENSE-2.0
-* Unless required by applicable law or agreed to in writing, software
-* distributed under the License is distributed on an "AS IS" BASIS,
-* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
-* implied. See the License for the specific language governing
-* permissions and limitations under the License.
- * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
- * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Contains portions of Gears <http://code.google.com/apis/gears/>
- * Copyright 2007, Google Inc.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- * this list of conditions and the following disclaimer in the documentation
- * and/or other materials provided with the distribution.
- * 3. Neither the name of Google Inc. nor the names of its contributors may be
- * used to endorse or promote products derived from this software without
- * specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
- * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
- * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
- * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
- * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
- * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
- * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * Sets up google.gears.*, which is *the only* supported way to access Gears.
- * Circumvent this file at your own risk!
- * In the future, Gears may automatically define google.gears.* without this
- * file. Gears may use these objects to transparently fix bugs and compatibility
- * issues. Applications that use the code below will continue to work seamlessly
- * when that happens.
+ OpenLayers.js -- OpenLayers Map Viewer Library
+ Copyright 2005-2008 MetaCarta, Inc., released under the Clear BSD license.
+ Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+ for the full text of the license.
+ Includes compressed code under the following licenses:
+ (For uncompressed versions of the code used please see the
+ OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ * (c) 2005 Sam Stephenson <sam at conio.net>
+ * Prototype is freely distributable under the terms of an MIT-style license.
+ * For details, see the Prototype web site: http://prototype.conio.net/
+* Contains portions of Rico <http://openrico.org/>
+* Copyright 2005 Sabre Airline Solutions
+* Licensed under the Apache License, Version 2.0 (the "License"); you
+* may not use this file except in compliance with the License. You
+* may obtain a copy of the License at
+* http://www.apache.org/licenses/LICENSE-2.0
+* Unless required by applicable law or agreed to in writing, software
+* distributed under the License is distributed on an "AS IS" BASIS,
+* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+* implied. See the License for the specific language governing
+* permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * 3. Neither the name of Google Inc. nor the names of its contributors may be
+ * used to endorse or promote products derived from this software without
+ * specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
OpenLayers/SingleFile.js
@@ -27384,6 +27384,14 @@
sphericalMercator: false,
+ * APIProperty: animationEnabled
+ * {Boolean} If set to true, the transition between zoom levels will be
+ * animated. Set to false to match the zooming experience of other
+ * layer types. Default is true.
+ animationEnabled: true,
* Constructor: OpenLayers.Layer.VirtualEarth
@@ -27429,6 +27437,9 @@
} catch (e) { }
this.mapObject.HideDashboard();
+ if(typeof this.mapObject.SetAnimationEnabled == "function") {
+ this.mapObject.SetAnimationEnabled(this.animationEnabled);
//can we do smooth panning? this is an unpublished method, so we need
More information about the fusion-commits
