[fusion-commits] r2022 - trunk/widgets/widgetinfo
svn_fusion at osgeo.org
Fri Dec 18 01:15:24 EST 2009
Author: christinebao
Date: 2009-12-18 01:15:23 -0500 (Fri, 18 Dec 2009)
New Revision: 2022
trunk/widgets/widgetinfo/featureinfo.xml
trunk/widgets/widgetinfo/query.xml
trunk/widgets/widgetinfo/redline.xml
trunk/widgets/widgetinfo/theme.xml
Fix ticket https://trac.osgeo.org/mapguide/ticket/1211
The icon of FeatureInfo, Theme, Query and Redline should be replaced
Modified: trunk/widgets/widgetinfo/featureinfo.xml
--- trunk/widgets/widgetinfo/featureinfo.xml 2009-12-17 15:12:33 UTC (rev 2021)
+++ trunk/widgets/widgetinfo/featureinfo.xml 2009-12-18 06:15:23 UTC (rev 2022)
@@ -6,7 +6,7 @@
<Label>Feature Info</Label>
<Tooltip>Click to display selected feature info</Tooltip>
<ImageUrl>images/icons.png</ImageUrl>
- <ImageClass>invoke-url</ImageClass>
+ <ImageClass>featureinfo</ImageClass>
<StandardUi>true</StandardUi>
<ContainableBy>Any</ContainableBy>
<Parameter>
Modified: trunk/widgets/widgetinfo/query.xml
--- trunk/widgets/widgetinfo/query.xml 2009-12-17 15:12:33 UTC (rev 2021)
+++ trunk/widgets/widgetinfo/query.xml 2009-12-18 06:15:23 UTC (rev 2022)
@@ -6,7 +6,7 @@
<Label>Query</Label>
<Tooltip>Click to execute a custom query</Tooltip>
+ <ImageClass>query</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/redline.xml
--- trunk/widgets/widgetinfo/redline.xml 2009-12-17 15:12:33 UTC (rev 2021)
+++ trunk/widgets/widgetinfo/redline.xml 2009-12-18 06:15:23 UTC (rev 2022)
@@ -6,7 +6,7 @@
<Label>Redline</Label>
<Tooltip>Click to draw redline features</Tooltip>
+ <ImageClass>redline</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/theme.xml
--- trunk/widgets/widgetinfo/theme.xml 2009-12-17 15:12:33 UTC (rev 2021)
+++ trunk/widgets/widgetinfo/theme.xml 2009-12-18 06:15:23 UTC (rev 2022)
@@ -6,7 +6,7 @@
<Label>Theme</Label>
<Tooltip>Click to create a themed layer</Tooltip>
+ <ImageClass>theme</ImageClass>
<Parameter>
More information about the fusion-commits
