[fusion-commits] r2024 - in trunk: text widgets widgets/Print
svn_fusion at osgeo.org
Mon Dec 21 02:14:16 EST 2009
Author: hubu
Date: 2009-12-21 02:14:10 -0500 (Mon, 21 Dec 2009)
New Revision: 2024
Removed:
trunk/widgets/Print/Print.html
trunk/text/en.json
trunk/widgets/Print.js
This submission fix the ticket #351:Print widget doesn't work with IIS7
Modified: trunk/text/en.json
--- trunk/text/en.json 2009-12-18 21:01:07 UTC (rev 2023)
+++ trunk/text/en.json 2009-12-21 07:14:10 UTC (rev 2024)
@@ -53,5 +53,12 @@
'zoomRect': 'Zoom Rectangle',
'maptipLinkText': 'Click for more information',
+#Print UI
+'PRINTSHOWTITLE':'Show Title?'
+'PRINTOPTIONS' :'Options'
+'PRINTTITLE':'Title'
+'PRINTSHOWLEGEND':'Show Legend?'
+'PRINTSHOWNORTHARROW':'Show North Arrow?'
'end': ''
Deleted: trunk/widgets/Print/Print.html
--- trunk/widgets/Print/Print.html 2009-12-18 21:01:07 UTC (rev 2023)
+++ trunk/widgets/Print/Print.html 2009-12-21 07:14:10 UTC (rev 2024)
@@ -1,13 +0,0 @@
-<div class="PrintDialogForm">
- <fieldset class="PrintDialogOptions">
- <legend>Options</legend>
- <label class="block" for="dialogPrintShowtitle"><input name="dialogPrintShowtitle" id="dialogPrintShowtitle" type="checkbox" value="showtitle" checked>
- Show Title?</label>
- <label class="block" for="dialogPrintTitle">Title</label>
- <input name="dialogPrintTitle" id="dialogPrintTitle" type="text" class="inputText" />
- <label class="block" for="dialogPrintShowlegend"><input name="dialogPrintShowlegend" id="dialogPrintShowlegend" type="checkbox" value="showlegend" checked>
- Show Legend?</label>
- <label class="block" for="dialogPrintShowNorthArrow"><input name="dialogPrintShowNorthArrow" id="dialogPrintShowNorthArrow" type="checkbox" value="shownortharrow" checked>
- Show North Arrow?</label>
- </fieldset>
-</div>
\ No newline at end of file
Modified: trunk/widgets/Print.js
--- trunk/widgets/Print.js 2009-12-18 21:01:07 UTC (rev 2023)
+++ trunk/widgets/Print.js 2009-12-21 07:14:10 UTC (rev 2024)
@@ -82,14 +82,26 @@
var o = {
label: OpenLayers.i18n('printTitle'),
- contentURL : this.dialogContentURL,
- onContentLoaded: OpenLayers.Function.bind(this.contentLoaded, this),
+ content : '<div class="PrintDialogForm">' +
+ '<fieldset class="PrintDialogOptions">' +
+ '<legend>' + OpenLayers.i18n("PRINTOPTIONS") +'</legend>' +
+ '<label class="block" for="dialogPrintShowtitle"><input name="dialogPrintShowtitle" id="dialogPrintShowtitle" type="checkbox" value="showtitle" checked>' +
+ OpenLayers.i18n("PRINTSHOWTITLE") +'</label>' +
+ '<label class="block" for="dialogPrintTitle">' + OpenLayers.i18n("PRINTTITLE") + '</label>' +
+ '<input name="dialogPrintTitle" id="dialogPrintTitle" type="text" class="inputText" />' +
+ '<label class="block" for="dialogPrintShowlegend"><input name="dialogPrintShowlegend" id="dialogPrintShowlegend" type="checkbox" value="showlegend" checked>' +
+ OpenLayers.i18n("PRINTSHOWLEGEND") + '</label>' +
+ '<label class="block" for="dialogPrintShowNorthArrow"><input name="dialogPrintShowNorthArrow" id="dialogPrintShowNorthArrow" type="checkbox" value="shownortharrow" checked>' +
+ OpenLayers.i18n("PRINTSHOWNORTHARROW") + '</label>' +
+ '</fieldset>' +
+ '</div>',
width: 350,
height: 250,
resize: true,
toolbars: [toolbar]
var d = new Jx.Dialog(o);
+ d.addEvent("contentLoaded", this.contentLoaded.bind(this));
toolbar.add(
new Jx.Button({
label: OpenLayers.i18n('printGenerate'),
More information about the fusion-commits
