[fusion-commits] r2026 - trunk/widgets/SelectWithin
svn_fusion at osgeo.org
Mon Dec 21 03:33:24 EST 2009
Author: liuar
Date: 2009-12-21 03:33:20 -0500 (Mon, 21 Dec 2009)
New Revision: 2026
trunk/widgets/SelectWithin/SelectWithin.php
Fixed ticket http://trac.osgeo.org/fusion/ticket/337
Fusion: Select Within doesn't work.
Comments from Buddy who fixed a similar defect in MapGuide:
In this patch, I check the type for each feature. And create a multipolygon if there are only polygon. If there are unsupported types, continue and go to the next one. For mixed supported types, create a multi-geometry.
BTW, the MG Server, the render service doesn't support QueryFeatures?? for the multi-geometry. So If we create a multi-polygoemetry, QueryFeatures??. will return null, and everything in the map will be cleared.
We need address another defect for this issue.
Modified: trunk/widgets/SelectWithin/SelectWithin.php
--- trunk/widgets/SelectWithin/SelectWithin.php 2009-12-21 08:04:46 UTC (rev 2025)
+++ trunk/widgets/SelectWithin/SelectWithin.php 2009-12-21 08:33:20 UTC (rev 2026)
@@ -148,7 +148,7 @@
$geomColl = new MgGeometryCollection();
$agfRW = new MgAgfReaderWriter();
- $polyOnly = true;
+ $simplyPolygonOnly = true;
for($i = 0; $i < $selLayers->GetCount(); $i++)
@@ -162,23 +162,18 @@
$classDef = $features->GetClassDefinition();
$geomPropName = $classDef->GetDefaultGeometryPropertyName();
- $j = 0;
- $isPoly = true;
while($features->ReadNext())
$geomReader = $features->GetGeometry($geomPropName);
$geom = $agfRW->Read($geomReader);
- if($j ++ == 0)
+ $type = $geom->GetGeometryType();
+ if($type == MgGeometryType::MultiPolygon || $type == MgGeometryType::CurvePolygon || $type == MgGeometryType::MultiCurvePolygon)
- $type = $geom->GetGeometryType();
- if($type == MgGeometryType::MultiPolygon || $type == MgGeometryType::CurvePolygon || $type == MgGeometryType::MultiCurvePolygon)
- $isPoly = false;
- $polyOnly = false;
- else if($type != MgGeometryType::Polygon)
- break;
+ $simplyPolygonOnly = false;
+ else if($type != MgGeometryType::Polygon)
+ continue;
$geomColl->Add($geom);
$features->Close();
@@ -188,7 +183,7 @@
return null;
$gf = new MgGeometryFactory();
- if($polyOnly)
+ if($simplyPolygonOnly)
$polyColl = new MgPolygonCollection();
for($i = 0; $i < $geomColl->GetCount(); $i++)
More information about the fusion-commits
