[fusion-commits] r1762 - trunk/widgets
svn_fusion at osgeo.org
Mon Feb 2 15:09:19 EST 2009
Author: pdeschamps
Date: 2009-02-02 15:09:19 -0500 (Mon, 02 Feb 2009)
New Revision: 1762
trunk/widgets/Maptip.js
initial rework of widget to normalize it to be arch independant
Modified: trunk/widgets/Maptip.js
--- trunk/widgets/Maptip.js 2009-02-02 19:19:46 UTC (rev 1761)
+++ trunk/widgets/Maptip.js 2009-02-02 20:09:19 UTC (rev 1762)
@@ -57,6 +57,8 @@
bOverTip: false,
sWinFeatures: 'menubar=no,location=no,resizable=no,status=no',
offset: new OpenLayers.Pixel(2,20),
+ szTip: '',
+ szHref:'',
initializeWidget: function(widgetTag) {
var json = widgetTag.extension;
@@ -67,14 +69,11 @@
this.delay = json.Delay ? parseInt(json.Delay[0]) : 350;
this.nTolerance = json.Tolerance ? parseInt(json.Tolerance[0]) : 2;
+ this.layer = json.Layer;
+ this.customURL = json.CustomURL;
+ this.textField = json.TextField;
- this.aLayers = [];
- if (json.Layer) {
- for (var i=0; i<json.Layer.length; i++) {
- this.aLayers.push(json.Layer[i]);
//prepare the container div for the maptips
Fusion.addWidgetStyleSheet(widgetTag.location + 'Maptip/Maptip.css');
if (this.domObj) {
@@ -103,6 +102,9 @@
this.getMap().observeEvent('mousedown', OpenLayers.Function.bind(this.mouseDown, this));
this.getMap().observeEvent('mouseup', OpenLayers.Function.bind(this.mouseUp, this));
this.getMap().observeEvent('mouseout', OpenLayers.Function.bind(this.mouseOut, this));
+ this.eventListener = false;
+ this.getMap().aMaps[0].registerForEvent(Fusion.Event.MAP_MAPTIP_REQ_FINISHED,OpenLayers.Function.bind(this._display,this));
@@ -118,6 +120,10 @@
mouseMove: function(e) {
+ if(!this.eventListener){
+ this.eventListener = true;
//console.log('map tip mouseMove');
if (this.bOverTip || this.mouseIsDown) {
return;
@@ -126,15 +132,24 @@
var map = this.getMap();
this.mapSize = map.getSize();
this.mapOffset = map._oDomObj.offsets;
var p = map.getEventPosition(e);
this.oCurrentPosition = p;
this.oMapTipPosition = p;
if (this.oCurrentPosition) {
window.clearTimeout(this.nTimer);
this.nTimer = null;
- this.nTimer = window.setTimeout(OpenLayers.Function.bind(this.showMaptip, this), this.delay);
+ this.options = {};
+ this.options.e = e;
+ this.options.nTolerance = this.nTolerance;
+ this.options.textField = this.textField
+ this.options.layer = this.layer
+ this.options.customURL = this.customURL
+ this.nTimer = window.setTimeout(OpenLayers.Function.bind(this.showMaptip, this,this.options,e), this.delay);
//Event.stop(e);
@@ -147,119 +162,80 @@
this.mouseIsDown = false;
- showMaptip: function(r) {
- //console.log('showMaptip');
- var map = this.getMap();
- if (map == null) {
- return;
- var oBroker = Fusion.oBroker;
- var x = this.oCurrentPosition.x;
- var y = this.oCurrentPosition.y;
- var min = map.pixToGeo(x-this.nTolerance, y-this.nTolerance);
- var max = map.pixToGeo(x+this.nTolerance, y+this.nTolerance);
- //this can fail if no map is loaded
- if (!min) {
- return;
- var sGeometry = 'POLYGON(('+ min.x + ' ' + min.y + ', ' + min.x + ' ' + max.y + ', ' + max.x + ' ' + max.y + ', ' + max.x + ' ' + min.y + ', ' + min.x + ' ' + min.y + '))';
- //var sGeometry = 'POINT('+ min.x + ' ' + min.y + ')';
- var maxFeatures = 1;
- var persist = 0;
- var selection = 'INTERSECTS';
- // only select visible layers with maptips defined (1+4)
- var layerAttributeFilter = 5;
- var maps = this.getMap().getAllMaps();
- //TODO: possibly make the layer names configurable?
- var layerNames = this.aLayers.toString();
- var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(maps[0].getSessionID(),
- maps[0]._sMapname,
- sGeometry,
- maxFeatures, persist, selection, layerNames,
- layerAttributeFilter);
- oBroker.dispatchRequest(r,
- OpenLayers.Function.bind(Fusion.xml2json, this,
- OpenLayers.Function.bind(this.requestCB, this)));
+ showMaptip: function(oOptions) {
+ //console.log("MAPTIP: showMaptip");
+ this.getMap().aMaps[0].getMapTip(this,oOptions);
- requestCB: function(xhr) {
- var o;
- eval("o="+xhr.responseText);
- this._display(o);
- if (this.nHideTimer) {
- window.clearTimeout(this.nHideTimer);
- this.nHideTimer = null;
- _display: function(tooltip) {
- if (this.mouseIsDown) {
+ _display: function(eventID,oMapTip) {
+ //console.log("MAPTIP: _display");
+ if (typeof(oMapTip) == "undefined" || oMapTip.t == '') {
return;
- //console.log('maptip _display');
- this.domObj.innerHTML = ' ';
+ if(this.domObj.style.visibility != 'visible' || oMapTip.t != this.szTip ){
+ this.domObj.innerHTML = null;
var contentDiv = document.createElement('div');
contentDiv.className = 'maptipContent';
this.domObj.appendChild(contentDiv);
var empty = true;
this.bIsVisible = true;
- var t = tooltip['FeatureInformation']['Tooltip'];
+ var t = oMapTip.t;
+ this.szTip = t;
+ this.szHref = h;
if (t) {
- contentDiv.innerHTML = t[0].replace(/\n/g, "<br>");
- empty = false;
+ contentDiv.innerHTML = t.replace(/\n/g, "<br>");
+ empty = false;
- var h = tooltip['FeatureInformation']['Hyperlink'];
+ var h =oMapTip.h;
if (h) {
- var a, linkURL;
- var linkDiv = document.createElement('div');
- if (h[0].indexOf('href=') > 0) { //MGOS allows complete anchor tags as the hyperlink
- linkDiv.innerHTML = h[0];
+ var a, linkURL;
+ var linkDiv = document.createElement('div');
+ if (h.indexOf('href=') > 0) { //MGOS allows complete anchor tags as the hyperlink
+ linkDiv.innerHTML = h;
a = linkDiv.firstChild;
linkURL = a.href;
- } else {
+ } else {
a = document.createElement('a');
- a.innerHTML = h[0];
- linkURL = h[0];
+ a.innerHTML = h;
+ linkURL = h;
linkDiv.appendChild(a);
- a.href = 'javascript:void(0)';
- var openLink = OpenLayers.Function.bind(this.openLink, this, linkURL);
- a.onclick = OpenLayers.Function.bindAsEventListener(openLink, this);
- contentDiv.appendChild(linkDiv);
- empty = false;
+ a.href = 'javascript:void(0)';
+ var openLink = OpenLayers.Function.bind(this.openLink, this, linkURL);
+ a.onclick = OpenLayers.Function.bindAsEventListener(openLink, this);
+ contentDiv.appendChild(linkDiv);
+ empty = false;
if (!empty) {
var size = $(this.domObj).getBorderBoxSize();
this.oMapTipPosition = this.oMapTipPosition.add(this.mapOffset[0], this.mapOffset[1]);
if (this.oCurrentPosition.x < this.mapSize.w/2) {
- this.domObj.style.left = (this.oMapTipPosition.x + this.offset.x) + 'px';
+ this.domObj.style.left = (this.oMapTipPosition.x + this.offset.x) + 'px';
} else {
- this.domObj.style.left = (this.oMapTipPosition.x - (size.width+this.offset.x)) + 'px';
+ this.domObj.style.left = (this.oMapTipPosition.x - (size.width+this.offset.x)) + 'px';
if (this.oCurrentPosition.y < this.mapSize.h/2) {
- this.domObj.style.top = (this.oMapTipPosition.y + this.offset.y) + 'px';
+ this.domObj.style.top = (this.oMapTipPosition.y + this.offset.y) + 'px';
} else {
- this.domObj.style.top = (this.oMapTipPosition.y - (size.height+this.offset.y)) + 'px';
+ this.domObj.style.top = (this.oMapTipPosition.y - (size.height+this.offset.y)) + 'px';
this.domObj.style.visibility = 'hidden';
this.domObj.style.display = 'block';
if (!window.opera) {
contentDiv.appendChild(this.iframe);
var size = $(this.domObj).getContentBoxSize();
this.iframe.style.width = size.width + "px";
this.iframe.style.height = size.height + "px";
this.domObj.style.visibility = 'visible';
+ //this.hideTimer = window.setTimeout(OpenLayers.Function.bind(this._hide, this),10000);
} else {
this.hideMaptip();
hideMaptip: function() {
@@ -272,6 +248,7 @@
//console.log('maptip _hide');
this.hideTimer = null;
this.domObj.style.display = 'none';
+ this.domObj.style.visibility = '';
//this.oMapTipPosition = null;
More information about the fusion-commits
