[fusion-commits] r1768 - branches/fusion2-mg21/layers/MapGuide/php
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Feb 3 14:31:06 EST 2009
Author: chrisclaydon
Date: 2009-02-03 14:31:06 -0500 (Tue, 03 Feb 2009)
New Revision: 1768
   branches/fusion2-mg21/layers/MapGuide/php/GetSelectionProperties.php
Re #199 - Handle layers with no property mappings set.
Modified: branches/fusion2-mg21/layers/MapGuide/php/GetSelectionProperties.php
--- branches/fusion2-mg21/layers/MapGuide/php/GetSelectionProperties.php	2009-02-03 19:30:17 UTC (rev 1767)
+++ branches/fusion2-mg21/layers/MapGuide/php/GetSelectionProperties.php	2009-02-03 19:31:06 UTC (rev 1768)
@@ -42,10 +42,10 @@
         if($selText != "") {
             $selection->FromXml($selText);
         //now return a data struture which is the same as Query.php
         $featureService = $siteConnection->CreateService(MgServiceType::FeatureService);
         /* Get the map SRS - we use this to convert distances */
         $srsFactory = new MgCoordinateSystemFactory();
         //safely get an SRS ... (in Utilities)
@@ -56,7 +56,7 @@
         $properties = NULL;
         $properties->layers = array();
-        //process
+        //process
         header('Content-type: text/x-json');
         header('X-JSON: true');
         $layers = $selection->GetLayers();
@@ -70,20 +70,22 @@
             /* select the features */
             $queryOptions = new MgFeatureQueryOptions();
             //TODO : seems that property mapping breaks the selection ????
             //could it be that $selection->AddFeatures($layerObj, $featureReader, 0) is
             //the one causing a problem when the properies are limited ?
-            $mappings = $_SESSION['property_mappings'][$oLayer->GetObjectId()];
-            if (0 && count($mappings) > 0) {
-                foreach($mappings as $name => $value) {
-                    $queryOptions->AddFeatureProperty($name);
-                    //echo "$name $value <br>\n";
+            if (isset($_SESSION['property_mappings']) && isset($_SESSION['property_mappings'][$oLayer->GetObjectId()])) {
+                $mappings = $_SESSION['property_mappings'][$oLayer->GetObjectId()];
+                if (0 && count($mappings) > 0) {
+                    foreach($mappings as $name => $value) {
+                        $queryOptions->AddFeatureProperty($name);
+                        //echo "$name $value <br>\n";
+                    $geomName = $oLayer->GetFeatureGeometryName();
+                    $queryOptions->AddFeatureProperty($geomName);
-                $geomName = $oLayer->GetFeatureGeometryName();
-                $queryOptions->AddFeatureProperty($geomName);
             $filter = $selection->GenerateFilter($oLayer, $class);
             $queryOptions->SetFilter($filter);
             $featureReader = $featureService->SelectFeatures($featureResId, $class, $queryOptions);
@@ -92,39 +94,39 @@
             $layerName = $oLayer->GetName();
             array_push($properties->layers, $layerName);
-	    // TODO: Check if computed properties are needed?
+        // TODO: Check if computed properties are needed?
             $bComputedProperties = false;
             $bNeedsTransform = false;
             $srsLayer = NULL;
             if ($bComputedProperties)
-		$spatialContext = $featureService->GetSpatialContexts($featureResId, true);
-		$srsLayerWkt = false;
-		if($spatialContext != null && $spatialContext->ReadNext() != null) {
-		    $srsLayerWkt = $spatialContext->GetCoordinateSystemWkt();
-		    /* skip this layer if the srs is empty */
-		if ($srsLayerWkt == null) {
-		    $srsLayerWkt = $srsDefMap;
-		/* create a coordinate system from the layer's SRS wkt */
-		$srsLayer = $srsFactory->Create($srsLayerWkt);
+        $spatialContext = $featureService->GetSpatialContexts($featureResId, true);
+        $srsLayerWkt = false;
+        if($spatialContext != null && $spatialContext->ReadNext() != null) {
+            $srsLayerWkt = $spatialContext->GetCoordinateSystemWkt();
+            /* skip this layer if the srs is empty */
+        if ($srsLayerWkt == null) {
+            $srsLayerWkt = $srsDefMap;
+        /* create a coordinate system from the layer's SRS wkt */
+        $srsLayer = $srsFactory->Create($srsLayerWkt);
-		// exclude layer if:
-		//  the map is non-arbitrary and the layer is arbitrary or vice-versa
-		//     or
-		//  layer and map are both arbitrary but have different units
-		$bLayerSrsIsArbitrary = ($srsLayer->GetType() == MgCoordinateSystemType::Arbitrary);
-		$bMapSrsIsArbitrary = ($srsMap->GetType() == MgCoordinateSystemType::Arbitrary);
-		if (($bLayerSrsIsArbitrary != $bMapSrsIsArbitrary) ||
-		    ($bLayerSrsIsArbitrary && ($srsLayer->GetUnits() != $srsMap->GetUnits()))) {
-		    $bComputedProperties = false;
-		} else {
-		    $srsTarget = null;
-		    $srsXform = null;
-		    $bNeedsTransform = ($srsLayer->GetUnitScale() != 1.0);
+        // exclude layer if:
+        //  the map is non-arbitrary and the layer is arbitrary or vice-versa
+        //     or
+        //  layer and map are both arbitrary but have different units
+        $bLayerSrsIsArbitrary = ($srsLayer->GetType() == MgCoordinateSystemType::Arbitrary);
+        $bMapSrsIsArbitrary = ($srsMap->GetType() == MgCoordinateSystemType::Arbitrary);
+        if (($bLayerSrsIsArbitrary != $bMapSrsIsArbitrary) ||
+            ($bLayerSrsIsArbitrary && ($srsLayer->GetUnits() != $srsMap->GetUnits()))) {
+            $bComputedProperties = false;
+        } else {
+            $srsTarget = null;
+            $srsXform = null;
+            $bNeedsTransform = ($srsLayer->GetUnitScale() != 1.0);
             $properties = BuildSelectionArray($featureReader, $layerName, $properties,
@@ -132,7 +134,7 @@
                                               $srsLayer, $bNeedsTransform, $oLayer);
             $featureReader->Close();
         $result = NULL;
         $result->hasSelection = false;
         if ($layers && $layers->GetCount() >= 0)
More information about the fusion-commits mailing list
