[fusion-commits] r1774 - trunk/widgets
svn_fusion at osgeo.org
Wed Feb 4 14:22:20 EST 2009
Author: madair
Date: 2009-02-04 14:22:20 -0500 (Wed, 04 Feb 2009)
New Revision: 1774
trunk/widgets/Legend.js
closes #192: change to just call folder expand/collapse without re-arranging nodes in the expandAll/collapseAll operation
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js 2009-02-04 15:24:29 UTC (rev 1773)
+++ trunk/widgets/Legend.js 2009-02-04 19:22:20 UTC (rev 1774)
@@ -224,7 +224,7 @@
bIncludeVisToggle: true,
- initialize : function(legend, widgetTag) {
+ initialize: function(legend, widgetTag) {
Fusion.Widget.Legend.LegendRenderer.prototype.initialize.apply(this, [legend]);
var json = widgetTag.extension;
@@ -246,19 +246,23 @@
this.showRootFolder = (json.ShowRootFolder && json.ShowRootFolder[0] == 'true') ? true:false;
//do show the map folder by default
this.showMapFolder = (json.ShowMapFolder && json.ShowMapFolder[0] == 'false') ? false:true;
- if (this.showRootFolder) {
- var opt = {
- label: OpenLayers.i18n('defaultMapTitle'),
- open: true,
- draw: this.renderFolder,
- 'class':'fusionLegendFolder'
- this.oRoot = new Jx.TreeFolder(opt);
- this.oRoot.contextMenu = this.getContextMenu(this.oRoot);
- this.oTree.append(this.oRoot);
- } else {
- this.oRoot = this.oTree;
+ var opt = {
+ label: OpenLayers.i18n('defaultMapTitle'),
+ open: true,
+ draw: this.renderFolder,
+ 'class':'fusionLegendFolder'
+ this.oRoot = new Jx.TreeFolder(opt);
+ this.oRoot.contextMenu = this.getContextMenu(this.oRoot);
+ this.oTree.append(this.oRoot);
+ //if root folder is to be hidden, just shift the tree so that it is not
+ //visible so that there is always a top level folder for expand/collapse
+ if (!this.showRootFolder) {
+ this.oRoot.domObj.parentNode.style.top = "-16px";
+ this.oRoot.domObj.parentNode.style.left = "-12px";
this.extentsChangedWatcher = this.update.bind(this);
@@ -305,11 +309,27 @@
expandAll: function(folder) {
- this.recurseTree('expand', this.oRoot);
+ for (var i=0; i<this.oTree.nodes.length; i++) {
+ var item = this.oTree.nodes[i];
+ if (item instanceof Jx.TreeFolder) {
+ this.recurseTree('expand', item);
+ if (this.showRootFolder) {
+ this.oRoot.expand();
collapseAll: function(folder) {
- this.recurseTree('collapse', this.oRoot);
+ this.recurseTree('collapse', item);
+ this.oRoot.collapse();
collapseBranch: function(folder) {
@@ -332,16 +352,6 @@
this.recurseTree(op, item);
item[op]();
- if (item.domObj) {
- var p = $(item.domObj).getPrevious();
- if (p) {
- item.domObj.dispose();
- $(item.domObj).inject(p, 'before');
- } else {
- p = $(item.domObj).getParent();
- $(item.domObj).inject(p, 'top');
@@ -653,7 +663,8 @@
var item = new Jx.TreeItem(opt);
- item.contextMenu = this.getContextMenu(item); if (bCheckBox) {
+ item.contextMenu = this.getContextMenu(item);
+ if (bCheckBox) {
//item.domObj.insertBefore(layer.legend.checkBox, item.domObj.childNodes[1]);
/* only need to add layer info if it has a check box too */
var layerInfo = layer.oMap.getLayerInfoUrl(layer.layerName);
More information about the fusion-commits
