[fusion-commits] r1799 - trunk/layers/MapServer/php
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Feb 20 14:15:33 EST 2009
Author: pdeschamps
Date: 2009-02-20 14:15:33 -0500 (Fri, 20 Feb 2009)
New Revision: 1799
   trunk/layers/MapServer/php/Maptip.php
Trapped possible bug with an invalid layername specified.
Modified: trunk/layers/MapServer/php/Maptip.php
--- trunk/layers/MapServer/php/Maptip.php	2009-02-20 19:03:59 UTC (rev 1798)
+++ trunk/layers/MapServer/php/Maptip.php	2009-02-20 19:15:33 UTC (rev 1799)
@@ -84,49 +84,44 @@
     foreach($aLayer as $key=>$layer){
         $oLayer = @$oMap->GetLayerByName($layer);
-        if(!is_object($oLayer)){
-            echo  "{'maptips':'','url':'','label':'','error':' The layer [".$layer."] was not found'}";
-            die();
+        // make sure the layer exists in the map.
+        if(is_object($oLayer)){
+            $oLayer->set('tolerance', 0);
-        $oLayer->set('tolerance', 0);
+            if ($oLayer->type ==  MS_LAYER_RASTER || $oLayer->type == MS_LAYER_QUERY ||
+                    $oLayer->type ==  MS_LAYER_CIRCLE ||  $oLayer->type == MS_LAYER_CHART) {
+                    die("{'error':'maptips are only valid for vector layers'}");
-        if ($oLayer->type ==  MS_LAYER_RASTER || $oLayer->type == MS_LAYER_QUERY ||
-                $oLayer->type ==  MS_LAYER_CIRCLE ||  $oLayer->type == MS_LAYER_CHART) {
-                die("{'error':'maptips are only valid for vector layers'}");
+            if (@$oLayer->queryByShape($oSpatialFilter) == MS_SUCCESS) {
-        if (@$oLayer->queryByShape($oSpatialFilter) == MS_SUCCESS) {
+                $oRes = $oLayer->getResult(0);
+                $oLayer->open();
-            $oRes = $oLayer->getResult(0);
-            $oLayer->open();
+                $oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
-            $oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
+                $szMapTipText .= $oLayer->name." : ".$oShape->values[$aMapTipTextField[$key]].$szBreak;
-            $szMapTipText .= $oLayer->name." : ".$oShape->values[$aMapTipTextField[$key]].$szBreak;
+                $szLabels = $aLabel[$key];
-            $szLabels = $aLabel[$key];
+                $szMapTip  = $oShape->values[$aMapTipTextField[$key]];
+                $szURL = buildCustonUrl($oShape->values,$aMapTipURL[$key]);
-            $szMapTip  = $oShape->values[$aMapTipTextField[$key]];
-            $szURL = buildCustonUrl($oShape->values,$aMapTipURL[$key]);
+                $szMapTip = $szMapTip != "undefined" ? $szMapTip : "";
+                $szURL = $szURL != "undefined" ? $szURL : "";
+                $szLabels = $szLabels != "undefined" ? $szLabels : "";
-            $szMapTip = $szMapTip != "undefined" ? $szMapTip : "";
-            $szURL = $szURL != "undefined" ? $szURL : "";
-            $szLabels = $szLabels != "undefined" ? $szLabels : "";
+                array_push($aMapTips, $szMapTip);
+                array_push($aURL, $szURL);
+                array_push($aTipLabel,$szLabels);
-            array_push($aMapTips, $szMapTip);
-            array_push($aURL, $szURL);
-            array_push($aTipLabel,$szLabels);
-            $oLayer->close();
+                $oLayer->close();
-echo "{'maptips':".var2json($aMapTips).",'url':".var2json($aURL).",'label':".var2json($aTipLabel)."}";
+    echo "{'maptips':".var2json($aMapTips).",'url':".var2json($aURL).",'label':".var2json($aTipLabel)."}";
 else
More information about the fusion-commits mailing list
