[fusion-commits] r1731 - in branches/fusion-1.1: MapGuide widgets
svn_fusion at osgeo.org
Thu Jan 8 13:33:01 EST 2009
Author: madair
Date: 2009-01-08 13:33:01 -0500 (Thu, 08 Jan 2009)
New Revision: 1731
branches/fusion-1.1/MapGuide/MapGuide.js
branches/fusion-1.1/widgets/LinkToView.js
re #34: adding support for show/hide layers/groups
Modified: branches/fusion-1.1/MapGuide/MapGuide.js
--- branches/fusion-1.1/MapGuide/MapGuide.js 2009-01-07 19:46:05 UTC (rev 1730)
+++ branches/fusion-1.1/MapGuide/MapGuide.js 2009-01-08 18:33:01 UTC (rev 1731)
@@ -150,7 +150,20 @@
mapSessionCreated: function() {
if (this.sMapResourceId != '') {
- this.loadMap(this.sMapResourceId);
+ var options = {};
+ if (this.bIsMapWidgetLayer) {
+ var showlayers = Fusion.getQueryParam('showlayers');
+ var hidelayers = Fusion.getQueryParam('hidelayers');
+ var showgroups = Fusion.getQueryParam('showgroups');
+ var hidegroups = Fusion.getQueryParam('hidegroups');
+ var options = {
+ showlayers: showlayers == '' ? [] : showlayers.split(','),
+ hidelayers: hidelayers == '' ? [] : hidelayers.split(','),
+ showgroups: showgroups == '' ? [] : showgroups.split(','),
+ hidegroups: hidegroups == '' ? [] : hidegroups.split(',')
+ this.loadMap(this.sMapResourceId, options);
window.setInterval(OpenLayers.Function.bind(this.pingServer, this), this.keepAliveInterval * 1000);
@@ -1058,18 +1071,37 @@
getLinkParams: function() {
var queryParams = {};
queryParams.theme = this.sMapResourceId;
- if (this.aShowLayers.length > 0) {
- queryParams.showlayers = this.aShowLayers.toString();
+ //determine which layers have been toggled
+ var showLayers = [];
+ var hideLayers = [];
+ for (var i=0; i<this.aLayers.length; ++i) {
+ var layer = this.aLayers[i];
+ if (layer.visible && !layer.initiallyVisible) { //layer was turned on
+ showLayers.push(layer.name);
+ if (!layer.visible && layer.initiallyVisible) { //layer was turned off
+ hideLayers.push(layer.name);
- if (this.aHideLayers.length > 0) {
- queryParams.hidelayers = this.aHideLayers.toString();
+ queryParams.showlayers = showLayers.join(',');
+ queryParams.hidelayers = hideLayers.join(',');
+ //determine which groups have been toggled
+ var showGroups = [];
+ var hideGroups = [];
+ for (var i=0; i<this.layerRoot.groups.length; ++i) {
+ var group = this.layerRoot.groups[i];
+ if (group.visible && !group.initiallyVisible) { //layer was turned on
+ showGroups.push(group.name);
+ if (!group.visible && group.initiallyVisible) { //layer was turned off
+ hideGroups.push(group.name);
- if (this.aShowGroups.length > 0) {
- queryParams.showgroups = this.aShowGroups.toString();
- if (this.aHideGroups.length > 0) {
- queryParams.hidegroups = this.aHideGroups.toString();
+ queryParams.showgroups = showGroups.join(',');
+ queryParams.hidegroups = hideGroups.join(',');
return queryParams;
@@ -1092,6 +1124,7 @@
this.groupType = o.groupType;
this.displayInLegend = o.displayInLegend;
this.expandInLegend = o.expandInLegend;
+ this.initiallyVisible = o.visible;
this.visible = o.visible;
this.actuallyVisible = o.actuallyVisible;
@@ -1148,6 +1181,7 @@
this.editable = o.editable;
Modified: branches/fusion-1.1/widgets/LinkToView.js
--- branches/fusion-1.1/widgets/LinkToView.js 2009-01-07 19:46:05 UTC (rev 1730)
+++ branches/fusion-1.1/widgets/LinkToView.js 2009-01-08 18:33:01 UTC (rev 1731)
@@ -51,7 +51,11 @@
param == 'spatialfilter' ||
param == 'variant' ||
param == 'theme' ||
- param == 'selectlayer') {
+ param == 'selectlayer' ||
+ param == 'showlayers' ||
+ param == 'hidelayers' ||
+ param == 'showgroups' ||
+ param == 'hidegroups' ) {
continue;
this.baseUrl += join + param + '=' + queryParams[param];
More information about the fusion-commits
