[fusion-commits] r1737 - in trunk: layers/MapGuide lib/OpenLayers
svn_fusion at osgeo.org
Fri Jan 16 14:45:30 EST 2009
Author: madair
Date: 2009-01-16 14:45:29 -0500 (Fri, 16 Jan 2009)
New Revision: 1737
trunk/layers/MapGuide/MapGuideViewerApi.js
trunk/lib/OpenLayers/OpenLayers.js
re #200: convert MapGuideViewerApi.js to use OpenLayers.Layer.Vector and DrawFeature controls; includes a patch to OL so that regular polygon handler can be style similar to point,path and polygon handlers
Modified: trunk/layers/MapGuide/MapGuideViewerApi.js
--- trunk/layers/MapGuide/MapGuideViewerApi.js 2009-01-14 15:42:24 UTC (rev 1736)
+++ trunk/layers/MapGuide/MapGuideViewerApi.js 2009-01-16 19:45:29 UTC (rev 1737)
@@ -26,11 +26,14 @@
* This is a simple API layer to mimick the MapGuide ajaxviewer API
-var mapWidgetId = 'Map';
+var mgApiMapWidgetId = 'Map';
+var mgApimgApiActiveWidget = null;
+var mgApiActiveControl = null;
+var mgApiDrawControls;
function Refresh() {
var Fusion = window.top.Fusion;
- var mapWidget = Fusion.getWidgetById(mapWidgetId);
+ var mapWidget = Fusion.getWidgetById(mgApiMapWidgetId);
if (mapWidget && mapWidget.isMapLoaded()) {
mapWidget.redraw();
@@ -38,7 +41,7 @@
function SetSelectionXML(selectionXml) {
mapWidget.setSelection(selectionXml, true);
@@ -46,7 +49,7 @@
function ZoomToView(x, y, scale, refresh) {
var extent = mapWidget.getExtentFromPoint(x, y, scale);
mapWidget.setExtents(extent);
@@ -54,372 +57,26 @@
function DigitizePoint(handler) {
- if (handler) {
- var Fusion = window.top.Fusion;
- var digitizer = new Fusion.Tool.Canvas.Point(mapWidget);
- digitizer.mouseUp = PointHandlers.prototype.mouseUp;
- Object.inheritFrom(digitizer, Fusion.Tool.Canvas.prototype, []);
- digitizer.initializeCanvas();
- var activeWidget = mapWidget.buttonSet.activeButton;
- mapWidget.buttonSet.setActiveButton(null);
- digitizer.handler = function() {
- handler.apply(null, arguments);
- activeWidget.setActive(true);
- digitizer.activateCanvas();
- //add a listener to update the position of the features
- mapWidget.registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED,
- function(){
- digitizer.updatePx();
- digitizer.clearContext();
- digitizer.draw(digitizer.context);
+ mgApiStartDigitizing('point', handler)
function DigitizeLine(handler) {
- if (handler) {
- var digitizer = new Fusion.Tool.Canvas.Line(mapWidget);
- digitizer.mouseDown = LineHandlers.prototype.mouseDown;
- digitizer.mouseMove = LineHandlers.prototype.mouseMove;
- function(){
+ mgApiStartDigitizing('line', handler)
function DigitizeLineString(handler) {
- if (handler) {
- digitizer.mouseDown = MultiPointHandlers.prototype.mouseDown;
- digitizer.mouseMove = MultiPointHandlers.prototype.mouseMove;
- digitizer.dblClick = MultiPointHandlers.prototype.dblClick;
- function(){
+ mgApiStartDigitizing('linestr', handler)
function DigitizeRectangle(handler) {
- if (handler) {
- var digitizer = new Fusion.Tool.Canvas.Polygon(mapWidget);
- digitizer.mouseDown = RectangleHandlers.prototype.mouseDown;
- digitizer.mouseMove = RectangleHandlers.prototype.mouseMove;
- function(){
+ mgApiStartDigitizing('rectangle', handler)
function DigitizePolygon(handler) {
- if (handler) {
- function(){
+ mgApiStartDigitizing('polygon', handler)
-Fusion.Tool.Canvas.prototype.getMap = function() {
- return Fusion.getWidgetById(mapWidgetId);
-Fusion.Tool.Canvas.prototype.deactivateCanvas = function() {
- var map = this.getMap();
- map.deregisterForEvent(Fusion.Event.MAP_RESIZED, this.resizeCanvasFn);
- map.stopObserveEvent('mousemove', this.mouseMoveCB);
- map.stopObserveEvent('mouseup', this.mouseUpCB);
- map.stopObserveEvent('mousedown', this.mouseDownCB);
- map.stopObserveEvent('dblclick', this.dblClickCB);
-PointHandlers = Class.create();
-PointHandlers.prototype = {
- mouseUp: function(e) {
- var p = this.getMap().getEventPosition(e);
- var point = this.getMap().pixToGeo(p.x, p.y);
- this.setPoint(point.x, point.y);
- this.clearContext();
- this.draw(this.context);
- this.isDigitizing = false;
- this.deactivateCanvas();
- this.handler(new Point(point.x, point.y));
-LineHandlers = Class.create();
-LineHandlers.prototype = {
- mouseDown: function(e) {
- if (OpenLayers.Event.isLeftClick(e)) {
- if (!this.isDigitizing) {
- this.segments = [];
- var from = new Fusion.Tool.Canvas.Node(point.x,point.y, this.getMap());
- var to = new Fusion.Tool.Canvas.Node(point.x,point.y, this.getMap());
- var seg = new Fusion.Tool.Canvas.Segment(from,to);
- seg.setEditing(true);
- this.addSegment(seg);
- this.isDigitizing = true;
- } else {
- var seg = this.lastSegment();
- seg.setEditing(false);
- //seg = this.extendLine();
- this.clean();
- var ls = new LineString();
- var nodes = this.getNodes();
- for (var i=0; i<nodes.length; ++i) {
- var node = nodes[i];
- ls.AddPoint(new Point(node.x, node.y));
- this.handler(ls);
- mouseMove: function(e) {
- //console.log('SelectRadius.mouseMove');
- return;
- seg.to.setPx(p.x,p.y);
- seg.to.updateGeo();
-RectangleHandlers = Class.create();
-RectangleHandlers.prototype = {
- this.seg1 = new Fusion.Tool.Canvas.Segment(from,to);
- this.addSegment(this.seg1);
- from = new Fusion.Tool.Canvas.Node(point.x,point.y, this.getMap());
- to = new Fusion.Tool.Canvas.Node(point.x,point.y, this.getMap());
- this.seg2 = new Fusion.Tool.Canvas.Segment(from,to);
- this.addSegment(this.seg2);
- this.seg3 = new Fusion.Tool.Canvas.Segment(from,to);
- this.addSegment(this.seg3);
- this.seg4 = new Fusion.Tool.Canvas.Segment(from,to);
- this.addSegment(this.seg4);
- } else {
- this.clean();
- var p1 = new Point(this.seg1.from.x,this.seg1.from.y);
- var p2 = new Point(this.seg3.from.x,this.seg3.from.y);
- var rect = new Rectangle(p1, p2);
- this.handler(rect);
- return;
- this.seg1.to.setPx(p.x, this.seg1.from.py);
- this.seg1.to.updateGeo();
- this.seg2.from.setPx(p.x, this.seg1.from.py);
- this.seg2.from.updateGeo();
- this.seg2.to.setPx(p.x, p.y);
- this.seg2.to.updateGeo();
- this.seg3.from.setPx(p.x, p.y);
- this.seg3.from.updateGeo();
- this.seg3.to.setPx(this.seg1.from.px, p.y);
- this.seg3.to.updateGeo();
- this.seg4.from.setPx(this.seg1.from.px, p.y);
- this.seg4.from.updateGeo();
-MultiPointHandlers = Class.create();
-MultiPointHandlers.prototype = {
- } else {
- seg = this.extendLine();
- return;
- dblClick: function(e) {
- //console.log('Digitizer.dblClick');
- return;
- this.event = e;
- seg.to.set(point.x,point.y);
- this.clean();
- this.handler(ls);
+//Theses are the Geometry classes used in the MapGuide Viewer API
function Point(x, y) {
this.X = x;
this.Y = y;
@@ -469,3 +126,164 @@
this.LineStringInfo();
+//The following methods are private and not intended for use by applications
+function mgApiStartDigitizing(type, handler) {
+ if (handler) {
+ var Fusion = window.top.Fusion;
+ mgApiActiveWidget = mapWidget.oActiveWidget;
+ if (mgApiActiveWidget) {
+ mapWidget.deactivateWidget(mgApiActiveWidget);
+ var control = mgApiDrawControls[type];
+ control.userHandler = handler;
+ mgApiActiveControl = control;
+ control.activate();
+function mgApiCallHandler(evt) {
+ var geom = evt.feature.geometry;
+ var apiGeom = null;
+ switch (geom.CLASS_NAME) {
+ case 'OpenLayers.Geometry.Point':
+ apiGeom = new Point(geom.x, geom.y);
+ break;
+ case 'OpenLayers.Geometry.LineString':
+ apiGeom = new LineString();
+ var nodes = geom.components;
+ for (var i=0; i<nodes.length; ++i) {
+ var node = nodes[i];
+ apiGeom.AddPoint(new Point(node.x, node.y));
+ break;
+ case 'OpenLayers.Geometry.Polygon':
+ var nodes = geom.components[0].components;
+ break;
+ this.userHandler(apiGeom);
+ //deactivate the control in a separate thread so that the chain of event
+ //handlers has a chance to finish before the deactivation occurs
+ window.setTimeout(mgApiDeactivate, 100);
+ return false;
+function mgApiDeactivate() {
+ mgApiActiveControl.deactivate();
+ mgApiActiveControl = null;
+ mapWidget.activateWidget(mgApiActiveWidget);
+ mgApiActiveWidget = null;
+// set the Stylemap for the MGAPI
+var mgApiStyle = new OpenLayers.Style({
+ pointRadius: 4,
+ graphicName: "square",
+ fillColor: "white",
+ fillOpacity: 0.4,
+ strokeWidth: 2,
+ strokeOpacity: 1,
+ strokeColor: "#666666"
+var mgApiStyleMap = new OpenLayers.StyleMap(mgApiStyle);
+window.top.Fusion.registerForEvent(window.top.Fusion.Event.FUSION_INITIALIZED, mgApiInit);
+//set up of digitizing tools once everything is initialized
+function mgApiInit() {
+ var map = window.top.Fusion.getWidgetById(mgApiMapWidgetId).oMapOL;
+ var digiLayer = new OpenLayers.Layer.Vector("Digitizing Layer", {styleMap: mgApiStyleMap});
+ map.addLayers([digiLayer]);
+ mgApiDrawControls = {
+ point: new OpenLayers.Control.DrawFeature(digiLayer,
+ OpenLayers.Handler.Point, {
+ handlerOptions: {
+ layerOptions: {
+ styleMap: mgApiStyleMap
+ line: new OpenLayers.Control.DrawFeature(digiLayer,
+ OpenLayers.Handler.Path, {
+ handlerOptions: {
+ freehandToggle: null,
+ freehand: false,
+ persist: true,
+ style: "default", // this forces default render intent
+ layerOptions: {
+ callbacks: {
+ 'point': mgApiCheckLine
+ linestr: new OpenLayers.Control.DrawFeature(digiLayer,
+ handlerOptions: {
+ freehand: false,
+ persist: true,
+ layerOptions: {
+ rectangle: new OpenLayers.Control.DrawFeature(digiLayer,
+ OpenLayers.Handler.RegularPolygon, {
+ handlerOptions: {
+ persist: true,
+ sides: 4,
+ irregular: true,
+ layerOptions: {
+ polygon: new OpenLayers.Control.DrawFeature(digiLayer,
+ OpenLayers.Handler.Polygon, {
+ handlerOptions: {
+ freehand: false,
+ persist: true,
+ layerOptions: {
+ for(var key in mgApiDrawControls) {
+ mgApiDrawControls[key].events.register('featureadded', null, mgApiCallHandler);
+ map.addControl(mgApiDrawControls[key]);
+//this callback method for the 'line' control to limit the number of points
+//in the linestring to 2 - there is an extra point in the feature that gets
+//removed when the feature is finalized
+function mgApiCheckLine(point, geom) {
+ if (geom.components.length == 3) {
+ this.handler.dblclick();
+ //this.handler.finalize();
Modified: trunk/lib/OpenLayers/OpenLayers.js
--- trunk/lib/OpenLayers/OpenLayers.js 2009-01-14 15:42:24 UTC (rev 1736)
+++ trunk/lib/OpenLayers/OpenLayers.js 2009-01-16 19:45:29 UTC (rev 1737)
@@ -20805,14 +20805,14 @@
var activated = false;
if(OpenLayers.Handler.prototype.activate.apply(this, arguments)) {
// create temporary vector layer for rendering geometry sketch
- var options = {
+ var options = OpenLayers.Util.extend({
displayInLayerSwitcher: false,
// indicate that the temp vector layer will never be out of range
// without this, resolution properties must be specified at the
// map-level for this temporary layer to init its resolutions
// correctly
calculateInRange: function() { return true; }
+ }, this.layerOptions);
this.layer = new OpenLayers.Layer.Vector(this.CLASS_NAME, options);
this.map.addLayer(this.layer);
activated = true;
More information about the fusion-commits
