[fusion-commits] r1739 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Jan 19 13:33:08 EST 2009
Author: madair
Date: 2009-01-19 13:33:07 -0500 (Mon, 19 Jan 2009)
New Revision: 1739
   trunk/widgets/SaveMap.js
closes #193: set format param in upper case and adjust path to php
Modified: trunk/widgets/SaveMap.js
--- trunk/widgets/SaveMap.js	2009-01-16 19:47:30 UTC (rev 1738)
+++ trunk/widgets/SaveMap.js	2009-01-19 18:33:07 UTC (rev 1739)
@@ -178,10 +178,10 @@
         var m = this.getMap().aMaps[0];
         if(navigator.appVersion.match(/\bMSIE\b/)) {
-            var url = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMapFrame." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
+            var url = Fusion.fusionURL + 'layers/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMapFrame." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format.toUpperCase() + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
             w = open(url, "Save", 'menubar=no,height=200,width=300');
         } else {
-            var s = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMap." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
+            var s = Fusion.fusionURL + 'layers/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMap." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format.toUpperCase() + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
             this.iframe.src = s;
More information about the fusion-commits mailing list
