[fusion-commits] r1748 - trunk/layers/MapGuide
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Jan 26 11:24:06 EST 2009
Author: madair
Date: 2009-01-26 11:24:06 -0500 (Mon, 26 Jan 2009)
New Revision: 1748
   trunk/layers/MapGuide/MapGuide.js
closes #201: patch applied to trunk
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js	2009-01-23 21:47:43 UTC (rev 1747)
+++ trunk/layers/MapGuide/MapGuide.js	2009-01-26 16:24:06 UTC (rev 1748)
@@ -51,6 +51,8 @@
         var newTheme = Fusion.getQueryParam('theme');
         if (newTheme != '') {
           this.sMapResourceId = newTheme;
+          //clear the query param after it has been used once
+          Fusion.queryParams['theme'] = null;
         this.registerEventID(Fusion.Event.MAP_SESSION_CREATED);
@@ -138,9 +140,13 @@
           var options = {};
           if (this.bIsMapWidgetLayer) {
             var showlayers = Fusion.getQueryParam('showlayers');
+            Fusion.queryParams['showlayers'] = null;
             var hidelayers = Fusion.getQueryParam('hidelayers');
+            Fusion.queryParams['hidelayers'] = null;
             var showgroups = Fusion.getQueryParam('showgroups');
+            Fusion.queryParams['showgroups'] = null;
             var hidegroups = Fusion.getQueryParam('hidegroups');
+            Fusion.queryParams['hidegroups'] = null;
             var options = {
               showlayers: showlayers == '' ? [] : showlayers.split(','),
               hidelayers: hidelayers == '' ? [] : hidelayers.split(','),
More information about the fusion-commits mailing list
