[fusion-commits] r1751 - branches/fusion2-mg21/widgets/widgetinfo
svn_fusion at osgeo.org
Wed Jan 28 11:17:55 EST 2009
Author: chrisclaydon
Date: 2009-01-28 11:17:55 -0500 (Wed, 28 Jan 2009)
New Revision: 1751
branches/fusion2-mg21/widgets/widgetinfo/extenthistory.xml
branches/fusion2-mg21/widgets/widgetinfo/invokescript.xml
branches/fusion2-mg21/widgets/widgetinfo/invokeurl.xml
branches/fusion2-mg21/widgets/widgetinfo/panonclick.xml
branches/fusion2-mg21/widgets/widgetinfo/zoomonclick.xml
re #203 - Remove default icon, tooltip, label settings from multipurpose widgets
Modified: branches/fusion2-mg21/widgets/widgetinfo/extenthistory.xml
--- branches/fusion2-mg21/widgets/widgetinfo/extenthistory.xml 2009-01-27 18:08:15 UTC (rev 1750)
+++ branches/fusion2-mg21/widgets/widgetinfo/extenthistory.xml 2009-01-28 16:17:55 UTC (rev 1751)
@@ -2,11 +2,10 @@
<Type>ExtentHistory</Type>
<LocalizedType>Extent History</LocalizedType>
<Description>A widget to navigate forward or backward in the map view extent history</Description>
- <Label>Go To Extent</Label>
- <ImageUrl>images/icons.png</ImageUrl>
- <ImageClass>view-back</ImageClass>
- <Tooltip>Navigate to the previous extents</Tooltip>
- <Direction>Previous</Direction>
+ <Label></Label>
+ <ImageUrl></ImageUrl>
+ <ImageClass></ImageClass>
+ <Tooltip></Tooltip>
<StandardUi>true</StandardUi>
<ContainableBy>Any</ContainableBy>
<Parameter>
Modified: branches/fusion2-mg21/widgets/widgetinfo/invokescript.xml
--- branches/fusion2-mg21/widgets/widgetinfo/invokescript.xml 2009-01-27 18:08:15 UTC (rev 1750)
+++ branches/fusion2-mg21/widgets/widgetinfo/invokescript.xml 2009-01-28 16:17:55 UTC (rev 1751)
@@ -3,11 +3,11 @@
<LocalizedType>Invoke Script</LocalizedType>
<Description>A widget to execute arbitrary javascript</Description>
<Location></Location>
- <Label>Invoke script</Label>
- <Tooltip>Click to invoke a javascript method</Tooltip>
+ <Label></Label>
<StatusText></StatusText>
- <ImageClass>invoke-script</ImageClass>
<Parameter>
Modified: branches/fusion2-mg21/widgets/widgetinfo/invokeurl.xml
--- branches/fusion2-mg21/widgets/widgetinfo/invokeurl.xml 2009-01-27 18:08:15 UTC (rev 1750)
+++ branches/fusion2-mg21/widgets/widgetinfo/invokeurl.xml 2009-01-28 16:17:55 UTC (rev 1751)
@@ -3,11 +3,11 @@
<LocalizedType>Invoke URL</LocalizedType>
<Description>A widget to call up a URL into the TaskPane, a new window or HTML element. The map name and Session ID are automatically added to the URL, as well as any additional parameters specifed</Description>
- <Label>Invoke URL</Label>
- <Tooltip>Click to execute the URL</Tooltip>
+ <Label></Label>
- <ImageClass>invoke-url</ImageClass>
<Parameter>
Modified: branches/fusion2-mg21/widgets/widgetinfo/panonclick.xml
--- branches/fusion2-mg21/widgets/widgetinfo/panonclick.xml 2009-01-27 18:08:15 UTC (rev 1750)
+++ branches/fusion2-mg21/widgets/widgetinfo/panonclick.xml 2009-01-28 16:17:55 UTC (rev 1751)
@@ -1,13 +1,13 @@
<WidgetInfo>
<Type>PanOnClick</Type>
<LocalizedType>Pan on Click</LocalizedType>
- <Description>Pans the map in the specified diretion on a click</Description>
+ <Description>Pans the map in the specified direction on a click</Description>
- <Label>Pan on click</Label>
- <Tooltip>Pan the map</Tooltip>
+ <Label></Label>
- <ImageClass>pan</ImageClass>
<Parameter>
Modified: branches/fusion2-mg21/widgets/widgetinfo/zoomonclick.xml
--- branches/fusion2-mg21/widgets/widgetinfo/zoomonclick.xml 2009-01-27 18:08:15 UTC (rev 1750)
+++ branches/fusion2-mg21/widgets/widgetinfo/zoomonclick.xml 2009-01-28 16:17:55 UTC (rev 1751)
@@ -3,11 +3,11 @@
<LocalizedType>Zoom on Click</LocalizedType>
<Description>Zoom the map by a fixed amount when a button is clicked</Description>
- <Label>ZoomOnClick</Label>
- <Tooltip>Click to zoom in</Tooltip>
+ <Label></Label>
- <ImageClass>zoom-out-fixed</ImageClass>
<Parameter>
More information about the fusion-commits
