[fusion-commits] r1871 - trunk/layers/MapGuide/php
svn_fusion at osgeo.org
Tue Jul 21 14:39:18 EDT 2009
Author: pagameba
Date: 2009-07-21 14:39:16 -0400 (Tue, 21 Jul 2009)
New Revision: 1871
trunk/layers/MapGuide/php/Utilities.php
closes #1040 (mapguide) fix a problem in MGE 2010/MGOS 2.1 with Feature Info, the generate UTM WKT we were using is not valid any more, the new coord system is a world UTM.
Modified: trunk/layers/MapGuide/php/Utilities.php
--- trunk/layers/MapGuide/php/Utilities.php 2009-07-21 02:54:39 UTC (rev 1870)
+++ trunk/layers/MapGuide/php/Utilities.php 2009-07-21 18:39:16 UTC (rev 1871)
@@ -818,8 +818,10 @@
//conver the geometry to UTM auto so that local measurements
//are accruate in meters
if ($bNeedsTransform && $srsTarget == null && $srsXform == null) {
- $srsTarget = $srsFactory->Create(getUtmWkt($centroid->GetX(),
- $centroid->GetY()));
+ $wkt = getUtmWkt($centroid->GetX(),
+ $centroid->GetY());
+ $wkt = 'PROJCS["WORLD-MERCATOR",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Mercator_2SP"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["standard_parallel_1",0.00000000000000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]';
+ $srsTarget = $srsFactory->Create($wkt);
$verMajor = subStr(GetSiteVersion(), 0,1);
if ($verMajor == '1') {
$srsXform = new MgCoordinateSystemTransform($srsLayer, $srsTarget);
@@ -875,7 +877,7 @@
function getUtmWkt($lon, $lat) {
$siteVersion = explode(".",GetSiteVersion());
if ((integer)$siteVersion[0] > 2 || (integer)$siteVersion[0] == 2 && (integer)$siteVersion[1] > 0) { //v2.1.x or greater
- $epsg42003 = "PROJCS[\"WGS 84 / Auto Orthographic\",GEOGCS[\"WGS 84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137,298.257223563]],PRIMEM[\"Greenwich\",0],UNIT[\"Decimal_Degree\",0.0174532925199433]],PROJECTION[\"Orthographic\"],PARAMETER[\"central_meridian\",%.3e],PARAMETER[\"latitude_of_origin\",%.3e],UNIT[\"Meter\",1]]";
+ $epsg42003 = 'PROJCS["WORLD-MERCATOR",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Mercator_2SP"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["standard_parallel_1",0.00000000000000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]';
} else {
$epsg42003 = "PROJCS[\"WGS 84 / Auto Orthographic\",GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS_1984\",6378137,298.257223563]],PRIMEM[\"Greenwich\",0],UNIT[\"Decimal_Degree\",0.0174532925199433]],PROJECTION[\"Orthographic\"],PARAMETER[\"central_meridian\",%.3e],PARAMETER[\"latitude_of_origin\",%.3e],UNIT[\"Meter\",1]]";
More information about the fusion-commits
