[fusion-commits] r1878 - trunk/widgets/SelectWithin
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Jul 22 12:57:23 EDT 2009
Author: pagameba
Date: 2009-07-22 12:57:23 -0400 (Wed, 22 Jul 2009)
New Revision: 1878
   trunk/widgets/SelectWithin/SelectWithin.php
re #229, close the feature reader after using it.
Modified: trunk/widgets/SelectWithin/SelectWithin.php
--- trunk/widgets/SelectWithin/SelectWithin.php	2009-07-22 16:56:27 UTC (rev 1877)
+++ trunk/widgets/SelectWithin/SelectWithin.php	2009-07-22 16:57:23 UTC (rev 1878)
@@ -1,215 +1,215 @@
-<?php
- * SelectWithin
- * $Id$
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
-  $fusionMGpath = '../../layers/MapGuide/php/';
-  include $fusionMGpath . 'Common.php';
-  include $fusionMGpath . 'Utilities.php';
-  include('../../common/php/Utilities.php');
-  $mapName = "";
-  $sessionId = "";
-  $layers = null;
-  $queryInfo = false;   //seemed to be always set to true in MG version
-  GetRequestParameters();
-  try {
-    $featureSrvc = $siteConnection->CreateService(MgServiceType::FeatureService);
-    $renderingSrvc = $siteConnection->CreateService(MgServiceType::RenderingService);
-    //load the map runtime state
-    $map = new MgMap();
-    $map->Open($resourceService, $mapName);
-    //object to hold response
-    $result = NULL;
-    $result->hasSelection = false;
-    /*holds selection array*/
-    $properties = NULL;
-    $properties->layers = array();
-    $layers = explode(",", $layers);
-    if (count($layers) > 0) {
-      $layerNames = new MgStringCollection();
-      for ($i = 0; $i < count($layers); $i++) {
-        $layerNames->Add($layers[$i]);
-      // create a multi-polygon or a multi-geometry containing the input selected features
-      $inputGeom = MultiGeometryFromSelection($featureSrvc, $resourceService, $map, $mapName);
-      if ($inputGeom) {
-        // Query all the features belonging the the layer list that intersects with the input geometries
-        $fi = $renderingSrvc->QueryFeatures($map, $layerNames, $inputGeom, MgFeatureSpatialOperations::Intersects, -1);
-        if ($fi) {
-          $resultSel = $fi->GetSelection();
-          if( $resultSel) {
-            $resultSel->Save($resourceService, $mapName);
-            //this needs to be re-opened for some reason
-            $resultSel = new MgSelection($map);
-            $resultSel->Open($resourceService, $mapName);
-            $layers = $resultSel->GetLayers();
-            if ($layers && $layers->GetCount() >= 0) {
-              $result->hasSelection = true;
-              //set the extents for the selection object
-              $oExtents = $resultSel->GetExtents($featureSrvc);
-              if ($oExtents) {
-                $oMin = $oExtents->GetLowerLeftCoordinate();
-                $oMax = $oExtents->GetUpperRightCoordinate();
-                $result->extents = NULL;
-                $result->extents->minx = $oMin->GetX();
-                $result->extents->miny = $oMin->GetY();
-                $result->extents->maxx = $oMax->GetX();
-                $result->extents->maxy = $oMax->GetY();
-                /*keep the full extents of the selection when saving the selection in the session*/
-                $properties->extents = NULL;
-                $properties->extents->minx = $oMin->GetX();
-                $properties->extents->miny = $oMin->GetY();
-                $properties->extents->maxx = $oMax->GetX();
-                $properties->extents->maxy = $oMax->GetY();
-              //get properties for individual features
-              $result->layers = array();
-              for ($i=0; $i<$layers->GetCount(); $i++) {
-                $layer = $layers->GetItem($i);
-                $layerName = $layer->GetName();
-                $layerClassName = $layer->GetFeatureClassName();
-                $options = new MgFeatureQueryOptions();
-                $options->SetFilter($resultSel->GenerateFilter($layer, $layerClassName));
-                $resourceId = new MgResourceIdentifier($layer->GetFeatureSourceId());
-                $featureReader = $featureSrvc->SelectFeatures($resourceId, $layerClassName, $options);
-                $properties = BuildSelectionArray($featureReader, $layerName, $properties, false, NULL, false, $layer);
-                array_push($result->layers, $layerName);
-                array_push($properties->layers, $layerName);
-                $count = $resultSel->GetSelectedFeaturesCount($layer, $layerClassName);
-                $result->$layerName->featureCount = $count;
-              /*save selection in the session*/
-              $_SESSION['selection_array'] = $properties;
-    header('Content-type: application/json');
-    header('X-JSON: true');
-    echo var2json($result);
-  } catch(MgException $e) {
-    echo "\nException: " . $e->GetDetails();
-    return;
-  } catch(Exception $ne) {
-    return;
-function MultiGeometryFromSelection($featureSrvc, $resourceSrvc, $map, $mapName)
-    $sel = new MgSelection($map);
-    $sel->Open($resourceSrvc, $mapName);
-    $selLayers = $sel->GetLayers();
-    if ($selLayers == null) {
-        return null;
-    $geomColl = new MgGeometryCollection();
-    $agfRW = new MgAgfReaderWriter();
-    $polyOnly = true;
-    for($i = 0; $i < $selLayers->GetCount(); $i++)
-        $layer = $selLayers->GetItem($i);
-        $filter = $sel->GenerateFilter($layer, $layer->GetFeatureClassName());
-        $query = new MgFeatureQueryOptions();
-        $query->SetFilter($filter);
-        $featureSource = new MgResourceIdentifier($layer->GetFeatureSourceId());
-        $features = $featureSrvc->SelectFeatures($featureSource, $layer->GetFeatureClassName(), $query);
-        if($features)
-            $classDef = $features->GetClassDefinition();
-            $geomPropName = $classDef->GetDefaultGeometryPropertyName();
-            $j = 0;
-            $isPoly = true;
-            while($features->ReadNext())
-                $geomReader = $features->GetGeometry($geomPropName);
-                $geom = $agfRW->Read($geomReader);
-                if($j ++ == 0)
-                    $type = $geom->GetGeometryType();
-                    if($type == MgGeometryType::MultiPolygon || $type == MgGeometryType::CurvePolygon || $type == MgGeometryType::MultiCurvePolygon)
-                        $isPoly = false;
-                        $polyOnly = false;
-                    else if($type != MgGeometryType::Polygon)
-                        break;
-                $geomColl->Add($geom);
-            $features->Close();
-    if($geomColl->GetCount() == 0)
-        return null;
-    $gf = new MgGeometryFactory();
-    if($polyOnly)
-        $polyColl = new MgPolygonCollection();
-        for($i = 0; $i < $geomColl->GetCount(); $i++)
-            $polyColl->Add($geomColl->GetItem($i));
-        return $gf->CreateMultiPolygon($polyColl);
-    else
-        return $gf->CreateMultiGeometry($geomColl);
-function GetParameters($params)
-    global $layers, $mapName, $sessionId, $queryInfo;
-    $mapName = $params['mapname'];
-    $sessionId = $params['session'];
-    $layers = $params['layers'];
-    if(isset($params['queryinfo']))
-        $queryInfo = $params['queryinfo'] == "1";
-function GetRequestParameters()
-    if($_SERVER['REQUEST_METHOD'] == "POST")
-        GetParameters($_POST);
-    else
-        GetParameters($_GET);
+<?php
+ * SelectWithin
+ * $Id$
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+  $fusionMGpath = '../../layers/MapGuide/php/';
+  include $fusionMGpath . 'Common.php';
+  include $fusionMGpath . 'Utilities.php';
+  include('../../common/php/Utilities.php');
+  $mapName = "";
+  $sessionId = "";
+  $layers = null;
+  $queryInfo = false;   //seemed to be always set to true in MG version
+  GetRequestParameters();
+  try {
+    $featureSrvc = $siteConnection->CreateService(MgServiceType::FeatureService);
+    $renderingSrvc = $siteConnection->CreateService(MgServiceType::RenderingService);
+    //load the map runtime state
+    $map = new MgMap();
+    $map->Open($resourceService, $mapName);
+    //object to hold response
+    $result = NULL;
+    $result->hasSelection = false;
+    /*holds selection array*/
+    $properties = NULL;
+    $properties->layers = array();
+    $layers = explode(",", $layers);
+    if (count($layers) > 0) {
+      $layerNames = new MgStringCollection();
+      for ($i = 0; $i < count($layers); $i++) {
+        $layerNames->Add($layers[$i]);
+      // create a multi-polygon or a multi-geometry containing the input selected features
+      $inputGeom = MultiGeometryFromSelection($featureSrvc, $resourceService, $map, $mapName);
+      if ($inputGeom) {
+        // Query all the features belonging the the layer list that intersects with the input geometries
+        $fi = $renderingSrvc->QueryFeatures($map, $layerNames, $inputGeom, MgFeatureSpatialOperations::Intersects, -1);
+        if ($fi) {
+          $resultSel = $fi->GetSelection();
+          if( $resultSel) {
+            $resultSel->Save($resourceService, $mapName);
+            //this needs to be re-opened for some reason
+            $resultSel = new MgSelection($map);
+            $resultSel->Open($resourceService, $mapName);
+            $layers = $resultSel->GetLayers();
+            if ($layers && $layers->GetCount() >= 0) {
+              $result->hasSelection = true;
+              //set the extents for the selection object
+              $oExtents = $resultSel->GetExtents($featureSrvc);
+              if ($oExtents) {
+                $oMin = $oExtents->GetLowerLeftCoordinate();
+                $oMax = $oExtents->GetUpperRightCoordinate();
+                $result->extents = NULL;
+                $result->extents->minx = $oMin->GetX();
+                $result->extents->miny = $oMin->GetY();
+                $result->extents->maxx = $oMax->GetX();
+                $result->extents->maxy = $oMax->GetY();
+                /*keep the full extents of the selection when saving the selection in the session*/
+                $properties->extents = NULL;
+                $properties->extents->minx = $oMin->GetX();
+                $properties->extents->miny = $oMin->GetY();
+                $properties->extents->maxx = $oMax->GetX();
+                $properties->extents->maxy = $oMax->GetY();
+              } else { echo "/* no extents */"; }
+              //get properties for individual features
+              $result->layers = array();
+              for ($i=0; $i<$layers->GetCount(); $i++) {
+                $layer = $layers->GetItem($i);
+                $layerName = $layer->GetName();
+                $layerClassName = $layer->GetFeatureClassName();
+                $options = new MgFeatureQueryOptions();
+                $options->SetFilter($resultSel->GenerateFilter($layer, $layerClassName));
+                $resourceId = new MgResourceIdentifier($layer->GetFeatureSourceId());
+                $featureReader = $featureSrvc->SelectFeatures($resourceId, $layerClassName, $options);
+                $properties = BuildSelectionArray($featureReader, $layerName, $properties, false, NULL, false, $layer);
+                $featureReader->Close();
+                array_push($result->layers, $layerName);
+                array_push($properties->layers, $layerName);
+                $count = $resultSel->GetSelectedFeaturesCount($layer, $layerClassName);
+                $result->$layerName->featureCount = $count;
+              /*save selection in the session*/
+              $_SESSION['selection_array'] = $properties;
+            } else { echo "/* layers false or 0 */"; }
+          } else { echo "/* no resultsel */"; }
+        } else { echo "/* no fi */"; }
+      } else { echo "/*no multi geom*/"; }
+    } else { echo "/* no layers */"; }
+    header('Content-type: application/json');
+    header('X-JSON: true');
+    echo var2json($result);
+  } catch(MgException $e) {
+    echo "\nException: " . $e->GetDetails();
+    return;
+  } catch(Exception $ne) {
+    return;
+function MultiGeometryFromSelection($featureSrvc, $resourceSrvc, $map, $mapName)
+    $sel = new MgSelection($map);
+    $sel->Open($resourceSrvc, $mapName);
+    $selLayers = $sel->GetLayers();
+    if ($selLayers == null) {
+        return null;
+    $geomColl = new MgGeometryCollection();
+    $agfRW = new MgAgfReaderWriter();
+    $polyOnly = true;
+    for($i = 0; $i < $selLayers->GetCount(); $i++)
+        $layer = $selLayers->GetItem($i);
+        $filter = $sel->GenerateFilter($layer, $layer->GetFeatureClassName());
+        $query = new MgFeatureQueryOptions();
+        $query->SetFilter($filter);
+        $featureSource = new MgResourceIdentifier($layer->GetFeatureSourceId());
+        $features = $featureSrvc->SelectFeatures($featureSource, $layer->GetFeatureClassName(), $query);
+        if($features)
+            $classDef = $features->GetClassDefinition();
+            $geomPropName = $classDef->GetDefaultGeometryPropertyName();
+            $j = 0;
+            $isPoly = true;
+            while($features->ReadNext())
+                $geomReader = $features->GetGeometry($geomPropName);
+                $geom = $agfRW->Read($geomReader);
+                if($j ++ == 0)
+                    $type = $geom->GetGeometryType();
+                    if($type == MgGeometryType::MultiPolygon || $type == MgGeometryType::CurvePolygon || $type == MgGeometryType::MultiCurvePolygon)
+                        $isPoly = false;
+                        $polyOnly = false;
+                    else if($type != MgGeometryType::Polygon)
+                        break;
+                $geomColl->Add($geom);
+            $features->Close();
+    if($geomColl->GetCount() == 0)
+        return null;
+    $gf = new MgGeometryFactory();
+    if($polyOnly)
+        $polyColl = new MgPolygonCollection();
+        for($i = 0; $i < $geomColl->GetCount(); $i++)
+            $polyColl->Add($geomColl->GetItem($i));
+        return $gf->CreateMultiPolygon($polyColl);
+    else
+        return $gf->CreateMultiGeometry($geomColl);
+function GetParameters($params)
+    global $layers, $mapName, $sessionId, $queryInfo;
+    $mapName = $params['mapname'];
+    $sessionId = $params['session'];
+    $layers = $params['layers'];
+    if(isset($params['queryinfo']))
+        $queryInfo = $params['queryinfo'] == "1";
+function GetRequestParameters()
+    if($_SERVER['REQUEST_METHOD'] == "POST")
+        GetParameters($_POST);
+    else
+        GetParameters($_GET);
More information about the fusion-commits mailing list
