[fusion-commits] r1888 - in trunk/widgets: . widgetinfo
svn_fusion at osgeo.org
Wed Jul 29 11:39:46 EDT 2009
Author: zjames
Date: 2009-07-29 11:39:45 -0400 (Wed, 29 Jul 2009)
New Revision: 1888
Added:
trunk/widgets/BasemapSwitcher.js
trunk/widgets/widgetinfo/basemapswitcher.xml
re #271: basemap switcher widget added on behalf of Arthur Liu (liuar)
Added: trunk/widgets/BasemapSwitcher.js
--- trunk/widgets/BasemapSwitcher.js (rev 0)
+++ trunk/widgets/BasemapSwitcher.js 2009-07-29 15:39:45 UTC (rev 1888)
@@ -0,0 +1,238 @@
+ * Fusion.Widget.BasemapSwitcher
+ * $Id: BasemapSwitcher.js
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Class: Fusion.Widget.BasemapSwitcher
+ * A widget to allow selection of the basemaps display under the overlay MapGuide layer
+ * Currently, Google Street, Google Satellite, Google Hybrid, Yahoo Street, Yahoo Satellite,
+ * Yahoo Hybrid, Bing Street, Bing Satellite and Bing Hybrid is supported.
+Fusion.Widget.BasemapSwitcher = OpenLayers.Class(Fusion.Widget, {
+ uiClass: Jx.Menu,
+ options: {
+ 'G_NORMAL_MAP': null,
+ 'G_SATELLITE_MAP': null,
+ 'G_HYBRID_MAP': null,
+ 'YAHOO_MAP_REG': null,
+ 'YAHOO_MAP_SAT': null,
+ 'YAHOO_MAP_HYB': null,
+ 'Road': null,
+ 'Aerial': null,
+ 'Hybrid': null,
+ 'None': null
+ baseMaps: {},
+ defaultBasemap: null,
+ menuItems: null,
+ initializeWidget: function(widgetTag) {
+ var maps = this.getMap().aMaps;
+ for (var i = 0, len = maps.length; i < len; i++) {
+ var map = maps[i];
+ switch (map.layerType) {
+ case 'MapGuide':
+ this.options['None'] = 'None';
+ this.baseMaps['None'] = map;
+ break;
+ case 'Google':
+ // if user didn't indicate basemap types, use the default Google Street
+ if (!map.mapTag.extension.Options || !map.mapTag.extension.Options[0].type) {
+ this.options['G_NORMAL_MAP'] = "Google Street";
+ this.baseMaps['G_NORMAL_MAP'] = map;
+ // The first non-MapGuide basemap will be the default basemap
+ if (!this.defaultBasemap) {
+ this.defaultBasemap = "G_NORMAL_MAP";
+ else {
+ switch (map.mapTag.extension.Options[0].type[0]) {
+ case 'G_NORMAL_MAP':
+ if (map.mapTag.extension.Options[0].name)
+ this.options['G_NORMAL_MAP'] = map.mapTag.extension.Options[0].name[0];
+ else
+ break;
+ case 'G_SATELLITE_MAP':
+ this.options['G_SATELLITE_MAP'] = map.mapTag.extension.Options[0].name[0];
+ else
+ this.options['G_SATELLITE_MAP'] = "Google Satellite";
+ this.baseMaps['G_SATELLITE_MAP'] = map;
+ break;
+ case 'G_HYBRID_MAP':
+ this.options['G_HYBRID_MAP'] = map.mapTag.extension.Options[0].name[0];
+ else
+ this.options['G_HYBRID_MAP'] = "Google Hybrid";
+ this.baseMaps['G_HYBRID_MAP'] = map;
+ break;
+ default:
+ //this.options['G_NORMAL_MAP'] = map.mapTag.extension.Options[0].name[0];
+ //this.baseMaps['G_NORMAL_MAP'] = map;
+ break;
+ this.defaultBasemap = map.mapTag.extension.Options[0].type[0];
+ break;
+ case 'Yahoo':
+ // if user didn't indicate basemap types, use the default Yahoo Street
+ this.options['YAHOO_MAP_REG'] = "Yahoo Street";
+ this.baseMaps['YAHOO_MAP_REG'] = map;
+ this.defaultBasemap = "YAHOO_MAP_REG";
+ else {
+ case 'YAHOO_MAP_REG':
+ this.options['YAHOO_MAP_REG'] = map.mapTag.extension.Options[0].name[0];
+ else
+ break;
+ case 'YAHOO_MAP_SAT':
+ this.options['YAHOO_MAP_SAT'] = map.mapTag.extension.Options[0].name[0];
+ else
+ this.options['YAHOO_MAP_SAT'] = "Yahoo Satellite";
+ this.baseMaps['YAHOO_MAP_SAT'] = map;
+ break;
+ case 'YAHOO_MAP_HYB':
+ this.options['YAHOO_MAP_HYB'] = map.mapTag.extension.Options[0].name[0];
+ else
+ this.options['YAHOO_MAP_HYB'] = "Yahoo Hybrid";
+ this.baseMaps['YAHOO_MAP_HYB'] = map;
+ break;
+ default:
+ //this.options['YAHOO_MAP_REG'] = map.mapTag.extension.Options[0].name[0];
+ //this.baseMaps['YAHOO_MAP_REG'] = map;
+ break;
+ break;
+ case 'VirtualEarth':
+ // if user didn't indicate basemap types, use the default Bing Street
+ this.options['Road'] = "Bing Street";
+ this.baseMaps['Road'] = map;
+ this.defaultBasemap = "Road";
+ else {
+ case 'Road':
+ this.options['Road'] = map.mapTag.extension.Options[0].name[0];
+ else
+ break;
+ case 'Aerial':
+ this.options['Aerial'] = map.mapTag.extension.Options[0].name[0];
+ else
+ this.options['Aerial'] = "Bing Satellite";
+ this.baseMaps['Aerial'] = map;
+ break;
+ case 'Hybrid':
+ this.options['Hybrid'] = map.mapTag.extension.Options[0].name[0];
+ else
+ this.options['Hybrid'] = "Bing Hybrid";
+ this.baseMaps['Hybrid'] = map;
+ break;
+ default:
+ //this.options['Road'] = map.mapTag.extension.Options[0].name[0];
+ //this.baseMaps['Road'] = map;
+ break;
+ break;
+ default:
+ break;
+ this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.setDefaultBasemap, this));
+ this.menuItems = {};
+ setUiObject: function(uiObj) {
+ Fusion.Widget.prototype.setUiObject.apply(this, [uiObj]);
+ var buttonSet = new Jx.ButtonSet();
+ //set up the root menu
+ for (var key in this.options) {
+ if (this.options[key]) {
+ var menuItem = new Jx.Menu.Item({
+ label: OpenLayers.i18n(this.options[key]),
+ toggle: true,
+ onDown: OpenLayers.Function.bind(this.setBasemap, this, key)
+ buttonSet.add(menuItem);
+ this.uiObj.add(menuItem);
+ this.menuItems[key] = menuItem;
+ setBasemap: function(baseMap) {
+ if ("None" != baseMap && this.getMap().oMapOL.baseLayer.CLASS_NAME == "OpenLayers.Layer.MapGuide") {
+ var visibility = this.baseMaps["None"].oLayerOL.visibility;
+ this.getMap().oMapOL.setBaseLayer(this.baseMaps[baseMap].oLayerOL, false);
+ // Keep the MapGuide layers visibility
+ this.baseMaps["None"].oLayerOL.visibility = visibility;
+ this.baseMaps["None"].oLayerOL.redraw();
+ else {
+ setDefaultBasemap: function() {
+ this.menuItems[this.defaultBasemap].setActive(true);
+ this.setBasemap(this.defaultBasemap);
Property changes on: trunk/widgets/BasemapSwitcher.js
___________________________________________________________________
Added: svn:executable
Added: svn:eol-style
+ native
Added: trunk/widgets/widgetinfo/basemapswitcher.xml
--- trunk/widgets/widgetinfo/basemapswitcher.xml (rev 0)
+++ trunk/widgets/widgetinfo/basemapswitcher.xml 2009-07-29 15:39:45 UTC (rev 1888)
@@ -0,0 +1,13 @@
+<WidgetInfo>
+ <Type>BasemapSwitcher</Type>
+ <LocalizedType>BasemapSwitcher</LocalizedType>
+ <Description>A widget to allow selection of the basemaps display under the overlay MapGuide layer</Description>
+ <Location></Location>
+ <Label>External Providers</Label>
+ <Tooltip>Click to change the basemap</Tooltip>
+ <StatusText></StatusText>
+ <ImageUrl>images/icons.png</ImageUrl>
+ <ImageClass>options</ImageClass>
+ <StandardUi>true</StandardUi>
+ <ContainableBy>Any</ContainableBy>
+</WidgetInfo>
Property changes on: trunk/widgets/widgetinfo/basemapswitcher.xml
+ native
More information about the fusion-commits
