[fusion-commits] r1805 - trunk/layers/MapServer/php
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Mar 4 15:27:32 EST 2009
Author: pdeschamps
Date: 2009-03-04 15:27:32 -0500 (Wed, 04 Mar 2009)
New Revision: 1805
   trunk/layers/MapServer/php/Maptip.php
removed Die() func on fail. instead used is_object on each layer so we
can specify layers that may not exist in the AppDef.
Modified: trunk/layers/MapServer/php/Maptip.php
--- trunk/layers/MapServer/php/Maptip.php	2009-03-04 20:22:05 UTC (rev 1804)
+++ trunk/layers/MapServer/php/Maptip.php	2009-03-04 20:27:32 UTC (rev 1805)
@@ -84,10 +84,6 @@
     foreach($aLayer as $key=>$layer){
         $oLayer = @$oMap->GetLayerByName($layer);
-        if(!is_object($oLayer)){
-            $szMessage = "{'maptips':'','url':'','label':'','error':' The layer [".$layer."] was not found'}";
-            die($szMessage);
         // make sure the layer exists in the map.
         if(is_object($oLayer)){
             $oLayer->set('tolerance', 0);
More information about the fusion-commits mailing list
