[fusion-commits] r1811 - in trunk: . layers/MapGuide lib
lib/OpenLayers
svn_fusion at osgeo.org
Thu Mar 5 12:50:39 EST 2009
Author: madair
Date: 2009-03-05 12:50:39 -0500 (Thu, 05 Mar 2009)
New Revision: 1811
trunk/config_dist.json
trunk/layers/MapGuide/MapGuide.js
trunk/lib/OpenLayers/OpenLayers.js
trunk/lib/fusion.js
closes #221: add useAsyncOverlay flag to determine if the MG site implements the asynchronous version of GETDYNAMICOVERLAY API.
Also updates OpenLayers with new version of MapGUide layer
Modified: trunk/config_dist.json
--- trunk/config_dist.json 2009-03-05 15:54:57 UTC (rev 1810)
+++ trunk/config_dist.json 2009-03-05 17:50:39 UTC (rev 1811)
@@ -18,7 +18,9 @@
with http and end with /mapguide. If you have installed
fusion inside the www directory of MapGuide, then you can
leave this empty as it will be automatically calculated. */
- "webTierUrl": ""
+ "webTierUrl": "",
+ /* for MapGuide OS version > 2.1 and MGE2010 and higher set this to true*/
+ "useAsyncOverlay": true
/* The MapServer section is required if you are installing fusion
for MapServer. */
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2009-03-05 15:54:57 UTC (rev 1810)
+++ trunk/layers/MapGuide/MapGuide.js 2009-03-05 17:50:39 UTC (rev 1811)
@@ -42,6 +42,7 @@
bSelectionOn: false,
oSelection: null,
selectionAsOverlay: true,
+ useAsyncOverlay: false,
defaultFormat: 'PNG',
initialize: function(map, mapTag, isMapWidgetLayer) {
@@ -531,15 +532,18 @@
* Returns an OpenLayers MapGuide layer object
createOLLayer: function(layerName, bIsBaseLayer, bSingleTile, behavior) {
- /* prevent the useOverlay flag based on site version */
- if (( this.siteVersion[0] == 2 && this.siteVersion[1] < 1 ) || this.siteVersion[0] < 2) { //v2.0.0 or previous
+ /* prevent the useOverlay flag based on MapGuide config element */
+ this.useAsyncOverlay = Fusion.getConfigurationItem('mapguide', 'useAsyncOverlay');
+ if (!this.useAsyncOverlay) { //v2.0.1 or earlier
this.selectionAsOverlay = false;
var layerOptions = {
units: this.units,
isBaseLayer: bIsBaseLayer,
maxResolution: 'auto',
useOverlay: this.selectionAsOverlay,
+ useAsyncOverlay: this.useAsyncOverlay,
ratio: this.ratio
if ((behavior & 1) == 0 && !/WebKit/.test(navigator.userAgent)) {
@@ -572,7 +576,6 @@
mapname: this._sMapname,
format: this.imageFormat,
behavior: behavior,
- version: "2.0.0",
clientagent: this.clientAgent
params.showLayers = this.aShowLayers.length > 0 ? this.aShowLayers.toString() : null;
@@ -594,6 +597,11 @@
+ //Fix for IE6 PNG transparency
+ if (params.format && params.format.toLowerCase().indexOf('png') >= 0) {
+ layerOptions.alpha = true;
Modified: trunk/lib/OpenLayers/OpenLayers.js
--- trunk/lib/OpenLayers/OpenLayers.js 2009-03-05 15:54:57 UTC (rev 1810)
+++ trunk/lib/OpenLayers/OpenLayers.js 2009-03-05 17:50:39 UTC (rev 1811)
@@ -224,6 +224,7 @@
"OpenLayers/Layer/Markers.js",
"OpenLayers/Layer/Text.js",
"OpenLayers/Layer/WorldWind.js",
+ "OpenLayers/Layer/ArcGIS93Rest.js",
"OpenLayers/Layer/WMS.js",
"OpenLayers/Layer/WMS/Untiled.js",
"OpenLayers/Layer/GeoRSS.js",
@@ -297,10 +298,15 @@
"OpenLayers/Strategy/Cluster.js",
"OpenLayers/Strategy/Paging.js",
"OpenLayers/Strategy/BBOX.js",
+ "OpenLayers/Strategy/Save.js",
"OpenLayers/Protocol.js",
"OpenLayers/Protocol/HTTP.js",
"OpenLayers/Protocol/SQL.js",
"OpenLayers/Protocol/SQL/Gears.js",
+ "OpenLayers/Protocol/WFS.js",
+ "OpenLayers/Protocol/WFS/v1.js",
+ "OpenLayers/Protocol/WFS/v1_0_0.js",
+ "OpenLayers/Protocol/WFS/v1_1_0.js",
"OpenLayers/Layer/PointTrack.js",
"OpenLayers/Layer/GML.js",
"OpenLayers/Style.js",
@@ -320,16 +326,22 @@
"OpenLayers/Format/KML.js",
"OpenLayers/Format/GeoRSS.js",
"OpenLayers/Format/WFS.js",
+ "OpenLayers/Format/WFSDescribeFeatureType.js",
"OpenLayers/Format/WKT.js",
"OpenLayers/Format/OSM.js",
"OpenLayers/Format/GPX.js",
+ "OpenLayers/Format/Filter.js",
+ "OpenLayers/Format/Filter/v1.js",
+ "OpenLayers/Format/Filter/v1_0_0.js",
+ "OpenLayers/Format/Filter/v1_1_0.js",
"OpenLayers/Format/SLD.js",
"OpenLayers/Format/SLD/v1.js",
"OpenLayers/Format/SLD/v1_0_0.js",
- "OpenLayers/Format/Filter.js",
- "OpenLayers/Format/Filter/v1.js",
- "OpenLayers/Format/Filter/v1_0_0.js",
+ "OpenLayers/Format/WFST.js",
+ "OpenLayers/Format/WFST/v1.js",
+ "OpenLayers/Format/WFST/v1_0_0.js",
+ "OpenLayers/Format/WFST/v1_1_0.js",
"OpenLayers/Format/Text.js",
"OpenLayers/Format/JSON.js",
"OpenLayers/Format/GeoJSON.js",
@@ -337,6 +349,7 @@
"OpenLayers/Format/WMC/v1.js",
"OpenLayers/Format/WMC/v1_0_0.js",
"OpenLayers/Format/WMC/v1_1_0.js",
+ "OpenLayers/Format/WMSGetFeatureInfo.js",
"OpenLayers/Layer/WFS.js",
"OpenLayers/Control/MouseToolbar.js",
"OpenLayers/Control/NavToolbar.js",
@@ -724,7 +737,7 @@
if (!this.viewRequestID ||
(this.map && this.viewRequestID == this.map.viewRequestID)) {
- this.style.backgroundColor = null;
+ this.style.backgroundColor ="transparent";
this.style.display = "";
@@ -1364,82 +1377,87 @@
OpenLayers.INCHES_PER_UNIT["degrees"] = OpenLayers.INCHES_PER_UNIT.dd;
OpenLayers.INCHES_PER_UNIT["nmi"] = 1852 * OpenLayers.INCHES_PER_UNIT.m;
-//CS-MAP units
+// Units from CS-Map
OpenLayers.METERS_PER_INCH = 0.02540005080010160020;
-OpenLayers.INCHES_PER_UNIT["Inch"] = OpenLayers.INCHES_PER_UNIT.inches;
-OpenLayers.INCHES_PER_UNIT["Meter"] = 1.0/OpenLayers.METERS_PER_INCH; //EPSG:9001
-OpenLayers.INCHES_PER_UNIT["Foot"] = 0.30480060960121920243/OpenLayers.METERS_PER_INCH; //EPSG:9003
-OpenLayers.INCHES_PER_UNIT["IFoot"] = 0.30480000000000000000/OpenLayers.METERS_PER_INCH; //EPSG:9002
-OpenLayers.INCHES_PER_UNIT["ClarkeFoot"] = 0.3047972651151/OpenLayers.METERS_PER_INCH; //EPSG:9005
-OpenLayers.INCHES_PER_UNIT["SearsFoot"] = 0.30479947153867624624/OpenLayers.METERS_PER_INCH; //EPSG:9041
-OpenLayers.INCHES_PER_UNIT["GoldCoastFoot"] = 0.30479971018150881758/OpenLayers.METERS_PER_INCH; //EPSG:9094
-OpenLayers.INCHES_PER_UNIT["IInch"] = 0.02540000000000000000/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["MicroInch"] = 0.00002540000000000000/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Mil"] = 0.00000002540000000000/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Centimeter"] = 0.01000000000000000000/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Kilometer"] = 1000.00000000000000000000/OpenLayers.METERS_PER_INCH; //EPSG:9036
-OpenLayers.INCHES_PER_UNIT["Yard"] = 0.91440182880365760731/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["SearsYard"] = 0.914398414616029/OpenLayers.METERS_PER_INCH; //EPSG:9040
-OpenLayers.INCHES_PER_UNIT["IndianYard"] = 0.91439853074444079983/OpenLayers.METERS_PER_INCH; //EPSG:9084
-OpenLayers.INCHES_PER_UNIT["IndianYd37"] = 0.91439523/OpenLayers.METERS_PER_INCH; //EPSG:9085
-OpenLayers.INCHES_PER_UNIT["IndianYd62"] = 0.9143988/OpenLayers.METERS_PER_INCH; //EPSG:9086
-OpenLayers.INCHES_PER_UNIT["IndianYd75"] = 0.9143985/OpenLayers.METERS_PER_INCH; //EPSG:9087
-OpenLayers.INCHES_PER_UNIT["IndianFoot"] = 0.30479951/OpenLayers.METERS_PER_INCH; //EPSG:9080
-OpenLayers.INCHES_PER_UNIT["IndianFt37"] = 0.30479841/OpenLayers.METERS_PER_INCH; //EPSG:9081
-OpenLayers.INCHES_PER_UNIT["IndianFt62"] = 0.3047996/OpenLayers.METERS_PER_INCH; //EPSG:9082
-OpenLayers.INCHES_PER_UNIT["IndianFt75"] = 0.3047995/OpenLayers.METERS_PER_INCH; //EPSG:9083
-OpenLayers.INCHES_PER_UNIT["Mile"] = 1609.34721869443738887477/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["IYard"] = 0.91440000000000000000/OpenLayers.METERS_PER_INCH; //EPSG:9096
-OpenLayers.INCHES_PER_UNIT["IMile"] = 1609.34400000000000000000/OpenLayers.METERS_PER_INCH; //EPSG:9093
-OpenLayers.INCHES_PER_UNIT["NautM"] = 1852.00000000000000000000/OpenLayers.METERS_PER_INCH; //EPSG:9030
-OpenLayers.INCHES_PER_UNIT["Lat-66"] = 110943.316488932731/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Lat-83"] = 110946.25736872234125/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Decimeter"] = 0.10000000000000000000/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Millimeter"] = 0.00100000000000000000/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Dekameter"] = 10.00000000000000000000/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Decameter"] = 10.00000000000000000000/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Hectometer"] = 100.00000000000000000000/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["GermanMeter"] = 1.0000135965/OpenLayers.METERS_PER_INCH; //EPSG:9031
-OpenLayers.INCHES_PER_UNIT["CaGrid"] = 0.999738/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["ClarkeChain"] = 20.1166194976/OpenLayers.METERS_PER_INCH; //EPSG:9038 20.11669506"
-OpenLayers.INCHES_PER_UNIT["GunterChain"] = 20.11684023368047/OpenLayers.METERS_PER_INCH; //EPSG:9033
-OpenLayers.INCHES_PER_UNIT["BenoitChain"] = 20.116782494375872/OpenLayers.METERS_PER_INCH; //EPSG:9062
-OpenLayers.INCHES_PER_UNIT["SearsChain"] = 20.11676512155/OpenLayers.METERS_PER_INCH; //EPSG:9042
-OpenLayers.INCHES_PER_UNIT["ClarkeLink"] = 0.201166194976/OpenLayers.METERS_PER_INCH; //EPSG:9039
-OpenLayers.INCHES_PER_UNIT["GunterLink"] = 0.2011684023368047/OpenLayers.METERS_PER_INCH; //EPSG:9034
-OpenLayers.INCHES_PER_UNIT["BenoitLink"] = 0.20116782494375872/OpenLayers.METERS_PER_INCH; //EPSG:9063
-OpenLayers.INCHES_PER_UNIT["SearsLink"] = 0.2011676512155/OpenLayers.METERS_PER_INCH; //EPSG:9043
-OpenLayers.INCHES_PER_UNIT["Rod"] = 5.02921005842012/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["IntnlChain"] = 20.1168/OpenLayers.METERS_PER_INCH; //EPSG:9097
-OpenLayers.INCHES_PER_UNIT["IntnlLink"] = 0.201168/OpenLayers.METERS_PER_INCH; //EPSG:9098
-OpenLayers.INCHES_PER_UNIT["Perch"] = 5.02921005842012/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Pole"] = 5.02921005842012/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Furlong"] = 201.1684023368046/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Rood"] = 3.778266898/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["CapeFoot"] = 0.3047972615/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Brealey"] = 375.00000000000000000000/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["ModAmFt"] = 0.304812252984505969011938/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["Fathom"] = 1.8288/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["NautM-UK"] = 1853.184/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["50kilometers"] = 50000.0/OpenLayers.METERS_PER_INCH;
-OpenLayers.INCHES_PER_UNIT["150kilometers"] = 150000.0/OpenLayers.METERS_PER_INCH;
+OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT, {
+ "Inch": OpenLayers.INCHES_PER_UNIT.inches,
+ "Meter": 1.0 / OpenLayers.METERS_PER_INCH, //EPSG:9001
+ "Foot": 0.30480060960121920243 / OpenLayers.METERS_PER_INCH, //EPSG:9003
+ "IFoot": 0.30480000000000000000 / OpenLayers.METERS_PER_INCH, //EPSG:9002
+ "ClarkeFoot": 0.3047972651151 / OpenLayers.METERS_PER_INCH, //EPSG:9005
+ "SearsFoot": 0.30479947153867624624 / OpenLayers.METERS_PER_INCH, //EPSG:9041
+ "GoldCoastFoot": 0.30479971018150881758 / OpenLayers.METERS_PER_INCH, //EPSG:9094
+ "IInch": 0.02540000000000000000 / OpenLayers.METERS_PER_INCH,
+ "MicroInch": 0.00002540000000000000 / OpenLayers.METERS_PER_INCH,
+ "Mil": 0.00000002540000000000 / OpenLayers.METERS_PER_INCH,
+ "Centimeter": 0.01000000000000000000 / OpenLayers.METERS_PER_INCH,
+ "Kilometer": 1000.00000000000000000000 / OpenLayers.METERS_PER_INCH, //EPSG:9036
+ "Yard": 0.91440182880365760731 / OpenLayers.METERS_PER_INCH,
+ "SearsYard": 0.914398414616029 / OpenLayers.METERS_PER_INCH, //EPSG:9040
+ "IndianYard": 0.91439853074444079983 / OpenLayers.METERS_PER_INCH, //EPSG:9084
+ "IndianYd37": 0.91439523 / OpenLayers.METERS_PER_INCH, //EPSG:9085
+ "IndianYd62": 0.9143988 / OpenLayers.METERS_PER_INCH, //EPSG:9086
+ "IndianYd75": 0.9143985 / OpenLayers.METERS_PER_INCH, //EPSG:9087
+ "IndianFoot": 0.30479951 / OpenLayers.METERS_PER_INCH, //EPSG:9080
+ "IndianFt37": 0.30479841 / OpenLayers.METERS_PER_INCH, //EPSG:9081
+ "IndianFt62": 0.3047996 / OpenLayers.METERS_PER_INCH, //EPSG:9082
+ "IndianFt75": 0.3047995 / OpenLayers.METERS_PER_INCH, //EPSG:9083
+ "Mile": 1609.34721869443738887477 / OpenLayers.METERS_PER_INCH,
+ "IYard": 0.91440000000000000000 / OpenLayers.METERS_PER_INCH, //EPSG:9096
+ "IMile": 1609.34400000000000000000 / OpenLayers.METERS_PER_INCH, //EPSG:9093
+ "NautM": 1852.00000000000000000000 / OpenLayers.METERS_PER_INCH, //EPSG:9030
+ "Lat-66": 110943.316488932731 / OpenLayers.METERS_PER_INCH,
+ "Lat-83": 110946.25736872234125 / OpenLayers.METERS_PER_INCH,
+ "Decimeter": 0.10000000000000000000 / OpenLayers.METERS_PER_INCH,
+ "Millimeter": 0.00100000000000000000 / OpenLayers.METERS_PER_INCH,
+ "Dekameter": 10.00000000000000000000 / OpenLayers.METERS_PER_INCH,
+ "Decameter": 10.00000000000000000000 / OpenLayers.METERS_PER_INCH,
+ "Hectometer": 100.00000000000000000000 / OpenLayers.METERS_PER_INCH,
+ "GermanMeter": 1.0000135965 / OpenLayers.METERS_PER_INCH, //EPSG:9031
+ "CaGrid": 0.999738 / OpenLayers.METERS_PER_INCH,
+ "ClarkeChain": 20.1166194976 / OpenLayers.METERS_PER_INCH, //EPSG:9038
+ "GunterChain": 20.11684023368047 / OpenLayers.METERS_PER_INCH, //EPSG:9033
+ "BenoitChain": 20.116782494375872 / OpenLayers.METERS_PER_INCH, //EPSG:9062
+ "SearsChain": 20.11676512155 / OpenLayers.METERS_PER_INCH, //EPSG:9042
+ "ClarkeLink": 0.201166194976 / OpenLayers.METERS_PER_INCH, //EPSG:9039
+ "GunterLink": 0.2011684023368047 / OpenLayers.METERS_PER_INCH, //EPSG:9034
+ "BenoitLink": 0.20116782494375872 / OpenLayers.METERS_PER_INCH, //EPSG:9063
+ "SearsLink": 0.2011676512155 / OpenLayers.METERS_PER_INCH, //EPSG:9043
+ "Rod": 5.02921005842012 / OpenLayers.METERS_PER_INCH,
+ "IntnlChain": 20.1168 / OpenLayers.METERS_PER_INCH, //EPSG:9097
+ "IntnlLink": 0.201168 / OpenLayers.METERS_PER_INCH, //EPSG:9098
+ "Perch": 5.02921005842012 / OpenLayers.METERS_PER_INCH,
+ "Pole": 5.02921005842012 / OpenLayers.METERS_PER_INCH,
+ "Furlong": 201.1684023368046 / OpenLayers.METERS_PER_INCH,
+ "Rood": 3.778266898 / OpenLayers.METERS_PER_INCH,
+ "CapeFoot": 0.3047972615 / OpenLayers.METERS_PER_INCH,
+ "Brealey": 375.00000000000000000000 / OpenLayers.METERS_PER_INCH,
+ "ModAmFt": 0.304812252984505969011938 / OpenLayers.METERS_PER_INCH,
+ "Fathom": 1.8288 / OpenLayers.METERS_PER_INCH,
+ "NautM-UK": 1853.184 / OpenLayers.METERS_PER_INCH,
+ "50kilometers": 50000.0 / OpenLayers.METERS_PER_INCH,
+ "150kilometers": 150000.0 / OpenLayers.METERS_PER_INCH
//unit abbreviations supported by PROJ.4
-OpenLayers.INCHES_PER_UNIT["mm"] = OpenLayers.INCHES_PER_UNIT["Meter"] / 1000.0;
-OpenLayers.INCHES_PER_UNIT["cm"] = OpenLayers.INCHES_PER_UNIT["Meter"] / 100.0;
-OpenLayers.INCHES_PER_UNIT["dm"] = OpenLayers.INCHES_PER_UNIT["Meter"] * 100.0;
-OpenLayers.INCHES_PER_UNIT["km"] = OpenLayers.INCHES_PER_UNIT["Meter"] * 1000.0;
-OpenLayers.INCHES_PER_UNIT["kmi"] = OpenLayers.INCHES_PER_UNIT["nmi"]; //International Nautical Mile
-OpenLayers.INCHES_PER_UNIT["fath"] = OpenLayers.INCHES_PER_UNIT["Fathom"]; //International Fathom
-OpenLayers.INCHES_PER_UNIT["ch"] = OpenLayers.INCHES_PER_UNIT["IntnlChain"]; //International Chain
-OpenLayers.INCHES_PER_UNIT["link"] = OpenLayers.INCHES_PER_UNIT["IntnlLink"]; //International Link
-OpenLayers.INCHES_PER_UNIT["us-in"] = OpenLayers.INCHES_PER_UNIT["inches"]; //U.S. Surveyor's Inch
-OpenLayers.INCHES_PER_UNIT["us-ft"] = OpenLayers.INCHES_PER_UNIT["Foot"]; //U.S. Surveyor's Foot
-OpenLayers.INCHES_PER_UNIT["us-yd"] = OpenLayers.INCHES_PER_UNIT["Yard"]; //U.S. Surveyor's Yard
-OpenLayers.INCHES_PER_UNIT["us-ch"] = OpenLayers.INCHES_PER_UNIT["GunterChain"]; //U.S. Surveyor's Chain
-OpenLayers.INCHES_PER_UNIT["us-mi"] = OpenLayers.INCHES_PER_UNIT["Mile"]; //U.S. Surveyor's Statute Mile
-OpenLayers.INCHES_PER_UNIT["ind-yd"] = OpenLayers.INCHES_PER_UNIT["IndianYd37"]; //Indian Yard
-OpenLayers.INCHES_PER_UNIT["ind-ft"] = OpenLayers.INCHES_PER_UNIT["IndianFt37"]; //Indian Foot
-OpenLayers.INCHES_PER_UNIT["ind-ch"] = 20.11669506/OpenLayers.METERS_PER_INCH; //Indian Chain
+ "mm": OpenLayers.INCHES_PER_UNIT["Meter"] / 1000.0,
+ "cm": OpenLayers.INCHES_PER_UNIT["Meter"] / 100.0,
+ "dm": OpenLayers.INCHES_PER_UNIT["Meter"] * 100.0,
+ "km": OpenLayers.INCHES_PER_UNIT["Meter"] * 1000.0,
+ "kmi": OpenLayers.INCHES_PER_UNIT["nmi"], //International Nautical Mile
+ "fath": OpenLayers.INCHES_PER_UNIT["Fathom"], //International Fathom
+ "ch": OpenLayers.INCHES_PER_UNIT["IntnlChain"], //International Chain
+ "link": OpenLayers.INCHES_PER_UNIT["IntnlLink"], //International Link
+ "us-in": OpenLayers.INCHES_PER_UNIT["inches"], //U.S. Surveyor's Inch
+ "us-ft": OpenLayers.INCHES_PER_UNIT["Foot"], //U.S. Surveyor's Foot
+ "us-yd": OpenLayers.INCHES_PER_UNIT["Yard"], //U.S. Surveyor's Yard
+ "us-ch": OpenLayers.INCHES_PER_UNIT["GunterChain"], //U.S. Surveyor's Chain
+ "us-mi": OpenLayers.INCHES_PER_UNIT["Mile"], //U.S. Surveyor's Statute Mile
+ "ind-yd": OpenLayers.INCHES_PER_UNIT["IndianYd37"], //Indian Yard
+ "ind-ft": OpenLayers.INCHES_PER_UNIT["IndianFt37"], //Indian Foot
+ "ind-ch": 20.11669506 / OpenLayers.METERS_PER_INCH //Indian Chain
* Constant: DOTS_PER_INCH
@@ -1858,6 +1876,8 @@
* options - {Object}
* displayClass - {String} Optional parameter. A CSS class name(s) string
* to provide the CSS context of the rendered content.
+ * containerElement - {DOMElement} Optional parameter. Insert the HTML to
+ * this node instead of the body root when calculating dimensions.
* Returns:
* {OpenLayers.Size}
@@ -1872,6 +1892,9 @@
container.style.position = "absolute";
container.style.left = "-9999px";
+ var containerElement = (options && options.containerElement)
+ ? options.containerElement : document.body;
//fix a dimension, if specified.
if (size) {
if (size.w) {
@@ -1896,7 +1919,7 @@
container.appendChild(content);
// append container to body for rendering
- document.body.appendChild(container);
+ containerElement.appendChild(container);
// calculate scroll width of content and add corners and shadow width
if (!w) {
@@ -1912,7 +1935,7 @@
// remove elements
container.removeChild(content);
- document.body.removeChild(container);
+ containerElement.removeChild(container);
return new OpenLayers.Size(w, h);
@@ -2351,25 +2374,52 @@
if(!context) {
context = window;
- var tokens = template.split("${");
- var item, last, replacement;
- for(var i=1, len=tokens.length; i<len; i++) {
- item = tokens[i];
- last = item.indexOf("}");
- if(last > 0) {
- replacement = context[item.substring(0, last)];
- if(typeof replacement == "function") {
- replacement = args ?
- replacement.apply(null, args) :
- replacement();
+ // Example matching:
+ // str = ${foo.bar}
+ // match = foo.bar
+ var replacer = function(str, match) {
+ var replacement;
+ // Loop through all subs. Example: ${a.b.c}
+ // 0 -> replacement = context[a];
+ // 1 -> replacement = context[a][b];
+ // 2 -> replacement = context[a][b][c];
+ var subs = match.split(/\.+/);
+ for (var i=0; i< subs.length; i++) {
+ if (i == 0) {
+ replacement = context;
- tokens[i] = replacement + item.substring(++last);
+ replacement = replacement[subs[i]];
+ if(typeof replacement == "function") {
+ replacement = args ?
+ replacement.apply(null, args) :
+ replacement();
+ // If replacement is undefined, return the string 'undefined'.
+ // This is a workaround for a bugs in browsers not properly
+ // dealing with non-participating groups in regular expressions:
+ // http://blog.stevenlevithan.com/archives/npcg-javascript
+ if (typeof replacement == 'undefined') {
+ return 'undefined';
} else {
- tokens[i] = "${" + item;
+ return replacement;
- return tokens.join("");
+ return template.replace(OpenLayers.String.tokenRegEx, replacer);
+ * Property: OpenLayers.String.tokenRegEx
+ * Used to find tokens in a string.
+ * Examples: ${a}, ${a.b.c}, ${a-b}, ${5}
+ tokenRegEx: /\${([\w.]+?)}/g,
* Property: OpenLayers.String.numberRegEx
@@ -2394,6 +2444,18 @@
isNumeric: function(value) {
return OpenLayers.String.numberRegEx.test(value);
+ * APIFunction: numericIf
+ * Converts a string that appears to be a numeric value into a number.
+ * Returns
+ * {Number|String} a Number if the passed value is a number, a String
+ * otherwise.
+ numericIf: function(value) {
+ return OpenLayers.String.isNumeric(value) ? parseFloat(value) : value;
@@ -2745,6 +2807,8 @@
* To create a new OpenLayers-style class with multiple inheritance, use the
* following syntax:
* > var MyClass = OpenLayers.Class(Class1, Class2, prototype);
+ * Note that instanceof reflection will only reveil Class1 as superclass.
+ * Class2 ff are mixins.
OpenLayers.Class = function() {
@@ -2761,9 +2825,21 @@
var extended = {};
- var parent;
+ var parent, initialize;
for(var i=0, len=arguments.length; i<len; ++i) {
if(typeof arguments[i] == "function") {
+ // make the class passed as the first argument the superclass
+ if(i == 0 && len > 1) {
+ // replace the initialize method with an empty function,
+ // because we do not want to create a real instance here
+ initialize = arguments[i].prototype.initialize;
+ arguments[i].prototype.initialize = function() {};
+ // the line below makes sure that the new class has a
+ // superclass
+ extended = new arguments[i];
+ // restore the original initialize method
+ arguments[i].prototype.initialize = initialize;
// get the prototype of the superclass
parent = arguments[i].prototype;
} else {
@@ -5311,8 +5387,14 @@
var preparedHTML = "<div class='" + this.contentDisplayClass+ "'>" +
this.contentDiv.innerHTML +
"<div>";
+ var containerElement = (this.map) ? this.map.layerContainerDiv
+ : document.body;
var realSize = OpenLayers.Util.getRenderedDimensions(
- preparedHTML, null, { displayClass: this.displayClass }
+ preparedHTML, null, {
+ displayClass: this.displayClass,
+ containerElement: containerElement
// is the "real" size of the div is safe to display in our map?
@@ -5341,8 +5423,10 @@
//content is clipped in only one direction, so we need to
// run getRenderedDimensions() again with a fixed dimension
var clippedSize = OpenLayers.Util.getRenderedDimensions(
- preparedHTML, fixedSize,
- { displayClass: this.contentDisplayClass }
+ preparedHTML, fixedSize, {
+ displayClass: this.contentDisplayClass,
//if the clipped size is still the same as the safeSize,
@@ -6220,7 +6304,15 @@
// send request (optionally with data) and return
- request.send(config.data);
+ // call in a timeout for asynchronous requests so the return is
+ // available before readyState == 4 for cached docs
+ if(config.async === false) {
+ request.send(config.data);
+ } else {
+ window.setTimeout(function(){
+ }, 0);
return request;
@@ -6688,7 +6780,12 @@
* Class: OpenLayers.Control.ArgParser
+ * The ArgParser control adds location bar querystring parsing functionality
+ * to an OpenLayers Map.
+ * When added to a Map control, on a page load/refresh, the Map will
+ * automatically take the href string and parse it for lon, lat, zoom, and
+ * layers information.
* Inherits from:
* - <OpenLayers.Control>
@@ -6716,6 +6813,7 @@
* APIProperty: displayProjection
* {<OpenLayers.Projection>} Requires proj4js support.
* Projection used when reading the coordinates from the URL. This will
* reproject the map coordinates from the URL into the map's
* projection.
@@ -6851,7 +6949,10 @@
* Class: OpenLayers.Control.PanZoom
+ * The PanZoom is a visible control, composed of a
+ * <OpenLayers.Control.PanPanel> and a <OpenLayers.Control.ZoomPanel>. By
+ * default it is drawn in the upper left corner of the map.
* Inherits from:
@@ -7820,17 +7921,19 @@
if (!this.element.scrolls) {
- this.element.scrolls = [];
- this.element.scrolls[0] = (document.documentElement.scrollLeft
- || document.body.scrollLeft);
- this.element.scrolls[1] = (document.documentElement.scrollTop
- || document.body.scrollTop);
+ this.element.scrolls = [
+ (document.documentElement.scrollLeft
+ || document.body.scrollLeft),
+ (document.documentElement.scrollTop
+ || document.body.scrollTop)
if (!this.element.lefttop) {
- this.element.lefttop = [];
- this.element.lefttop[0] = (document.documentElement.clientLeft || 0);
- this.element.lefttop[1] = (document.documentElement.clientTop || 0);
+ this.element.lefttop = [
+ (document.documentElement.clientLeft || 0),
+ (document.documentElement.clientTop || 0)
if (!this.element.offsets) {
@@ -7902,6 +8005,20 @@
internalProjection: null,
+ * APIProperty: data
+ * {Object} When <keepData> is true, this is the parsed string sent to
+ * <read>.
+ data: null,
+ * APIProperty: keepData
+ * {Object} Maintain a reference (<data>) to the most recently read data.
+ * Default is false.
+ keepData: false,
* Constructor: OpenLayers.Format
* Instances of this class are not useful. See one of the subclasses.
@@ -7909,6 +8026,10 @@
* options - {Object} An optional object with properties to set on the
* format
+ * Valid options:
+ * keepData - {Boolean} If true, upon <read>, the data property will be
+ * set to the parsed object (e.g. the json or xml object).
* Returns:
* An instance of OpenLayers.Format
@@ -8307,8 +8428,10 @@
* pro4js projection object.
* Parameters:
- * options - {Object} An optional object with properties to set on the
- * format
+ * projCode - {String} A string identifying the Well Known Identifier for
+ * the projection.
+ * options - {Object} An optional object to set additional properties
+ * on the layer.
* Returns:
* {<OpenLayers.Projection>} A projection object.
@@ -9412,12 +9535,19 @@
// place it. Note that this operation is O(log(n)). If there's a
// performance problem (when dragging, for instance) this is
// likely where it would be.
- var insert = this.indexer ? this.indexer.insert(node) : null;
- if(insert) {
- this.root.insertBefore(node, insert);
+ if (this.indexer) {
+ var insert = this.indexer.insert(node);
+ if (insert) {
+ this.root.insertBefore(node, insert);
+ } else {
+ this.root.appendChild(node);
} else {
- this.root.appendChild(node);
+ // if there's no indexer, simply append the node to root,
+ // but only if the node is a new one
+ if (node.parentNode !== this.root){
this.postDraw(node);
@@ -11441,8 +11571,6 @@
* - *move* triggered after each drag, pan, or zoom
* - *moveend* triggered after a drag, pan, or zoom completes
* - *zoomend* triggered after a zoom completes
- * - *popupopen* triggered after a popup opens
- * - *popupclose* triggered after a popup opens
* - *addmarker* triggered after a marker has been added
* - *removemarker* triggered after a marker has been removed
* - *clearmarkers* triggered after markers have been cleared
@@ -11738,7 +11866,7 @@
eventListeners: null,
- * Property: panMethod
+ * APIProperty: panMethod
* {Function} The Easing function to be used for tweening. Default is
* OpenLayers.Easing.Expo.easeOut. Setting this to 'null' turns off
* animated panning.
@@ -14462,7 +14590,7 @@
* {DOMElement} The element to which we'll add the symbol definitions
createDefs: function() {
- var defs = this.nodeFactory("ol-renderer-defs", "defs");
+ var defs = this.nodeFactory(this.container.id + "_defs", "defs");
this.rendererRoot.appendChild(defs);
return defs;
@@ -15997,6 +16125,8 @@
this.backBufferTile.resolution = this.layer.getResolution();
this.backBufferTile.renderTile();
+ this.backBufferTile.hide();
@@ -16289,8 +16419,10 @@
* Class: OpenLayers.Control.OverviewMap
- * Create an overview map to display the extent of your main map and provide
- * additional navigation control. Create a new overview map with the
+ * The OverMap control creates a small overview map, useful to display the
+ * extent of a zoomed map and your main map and provide additional
+ * navigation options to the User. By default the overview map is drawn in
+ * the lower right corner of the main map. Create a new overview map with the
* <OpenLayers.Control.OverviewMap> constructor.
* Inerits from:
@@ -16357,24 +16489,33 @@
* APIProperty: minRatio
* {Float} The ratio of the overview map resolution to the main map
- * resolution at which to zoom farther out on the overview map.
+ * resolution at which to zoom farther out on the overview map.
minRatio: 8,
* APIProperty: maxRatio
- * resolution at which to zoom farther in on the overview map.
+ * resolution at which to zoom farther in on the overview map.
maxRatio: 32,
* APIProperty: mapOptions
* {Object} An object containing any non-default properties to be sent to
- * the overview map's map constructor. These should include any non-default
- * options that the main map was constructed with.
+ * the overview map's map constructor. These should include any
+ * non-default options that the main map was constructed with.
mapOptions: null,
+ * APIProperty: autoPan
+ * {Boolean} Always pan the overview map, so the extent marker remains in
+ * the center. Default is false. If true, when you drag the extent
+ * marker, the overview map will update itself so the marker returns
+ * to the center.
+ autoPan: false,
* Property: handlers
@@ -16666,7 +16807,7 @@
this.createMap();
- if(!this.isSuitableOverview()) {
+ if(this.autoPan || !this.isSuitableOverview()) {
this.updateOverview();
@@ -17975,7 +18116,7 @@
* Parameters:
* control - {<OpenLayers.Control>}
- * layers - {Array(<OpenLayers.Layer.Vector>)}
+ * layer - {<OpenLayers.Layer.Vector>}
* callbacks - {Object} An object with a 'over' property whos value is
* a function to be called when the mouse is over a feature. The
* callback should expect to recieve a single argument, the feature.
@@ -18088,18 +18229,32 @@
* {Boolean} The event occurred over a relevant feature.
handle: function(evt) {
+ if(this.feature && !this.feature.layer) {
+ // feature has been destroyed
+ this.feature = null;
var type = evt.type;
var handled = false;
var previouslyIn = !!(this.feature); // previously in a feature
var click = (type == "click" || type == "dblclick");
this.feature = this.layer.getFeatureFromEvent(evt);
- if(this.feature && this.feature.layer) {
+ if(this.lastFeature && !this.lastFeature.layer) {
+ // last feature has been destroyed
+ this.lastFeature = null;
+ if(this.feature) {
var inNew = (this.feature != this.lastFeature);
if(this.geometryTypeMatches(this.feature)) {
// in to a feature
if(previouslyIn && inNew) {
// out of last feature and in to another
- this.triggerCallback(type, 'out', [this.lastFeature]);
+ if(this.lastFeature) {
+ this.triggerCallback(type, 'out', [this.lastFeature]);
this.triggerCallback(type, 'in', [this.feature]);
} else if(!previouslyIn || click) {
// in feature for the first time
@@ -18109,7 +18264,7 @@
handled = true;
} else {
// not in to a feature
- if(previouslyIn && inNew || (click && this.lastFeature)) {
+ if(this.lastFeature && (previouslyIn && inNew || click)) {
// out of last feature for the first time
@@ -18121,8 +18276,7 @@
} else {
- if(this.lastFeature && this.lastFeature.layer &&
- (previouslyIn || click)) {
+ if(this.lastFeature && (previouslyIn || click)) {
@@ -18282,21 +18436,21 @@
* APIProperty: stopMove
- * {Boolean} Stop other listeners from being notified on mousemoves.
+ * {Boolean} - Stop other listeners from being notified on mousemoves.
* Default is false.
stopMove: false,
* Property: px
- * {<OpenLayers.Pixel>} The location of the last mousemove, expressed
+ * {<OpenLayers.Pixel>} - The location of the last mousemove, expressed
* in pixels.
px: null,
* Property: timerId
- * {Number} The id of the timer.
+ * {Number} - The id of the timer.
timerId: null,
@@ -18308,10 +18462,11 @@
* control - {<OpenLayers.Control>} The control that initialized this
* handler. The control is assumed to have a valid map property; that
* map is used in the handler's own setMap method.
- * callbacks - {Object} An object whose properties correspond to abstracted
- * events or sequences of browser events. The values for these
- * properties are functions defined by the control that get called by
- * the handler.
+ * callbacks - {Object} An object with keys corresponding to callbacks
+ * that will be called by the handler. The callbacks should
+ * expect to receive a single argument, the event. Callbacks for
+ * 'move', the mouse is moving, and 'pause', the mouse is pausing,
+ * are supported.
* options - {Object} An optional object whose properties will be set on
* the handler.
@@ -19631,7 +19786,7 @@
if(this.map.fractionalZoom) {
var low = Math.floor(zoom);
var high = Math.ceil(zoom);
- resolution = this.resolutions[high] +
+ resolution = this.resolutions[low] -
((zoom-low) * (this.resolutions[low]-this.resolutions[high]));
} else {
resolution = this.resolutions[Math.round(zoom)];
@@ -19679,7 +19834,7 @@
var dRes = highRes - lowRes;
if(dRes > 0) {
- zoom = lowZoom + ((resolution - lowRes) / dRes);
+ zoom = lowZoom + ((highRes - resolution) / dRes);
} else {
zoom = lowZoom;
@@ -19973,7 +20128,7 @@
* Class: OpenLayers.Control.DragPan
- * DragPan control.
+ * The DragPan control pans the map with a drag of the mouse.
* Inherits from:
@@ -20100,6 +20255,15 @@
attributes: null,
+ * Property: bounds
+ * {<OpenLayers.Bounds>} The box bounding that feature's geometry, that
+ * property can be set by an <OpenLayers.Format> object when
+ * deserializing the feature, so in most cases it represents an
+ * information set by the server.
+ bounds: null,
* Property: state
* {String}
@@ -20350,38 +20514,33 @@
* Constant: OpenLayers.Feature.Vector.style
* OpenLayers features can have a number of style attributes. The 'default'
- * style will typically be used if no other style is specified.
+ * style will typically be used if no other style is specified. These
+ * styles correspond for the most part, to the styling properties defined
+ * by the SVG standard.
+ * Information on fill properties: http://www.w3.org/TR/SVG/painting.html#FillProperties
+ * Information on stroke properties: http://www.w3.org/TR/SVG/painting.html#StrokeProperties
- * Default style properties:
- * - fillColor: "#ee9900",
- * - fillOpacity: 0.4,
- * - hoverFillColor: "white",
- * - hoverFillOpacity: 0.8,
- * - strokeColor: "#ee9900",
- * - strokeOpacity: 1,
- * - strokeWidth: 1,
- * - strokeLinecap: "round", [butt | round | square]
- * - strokeDashstyle: "solid", [dot | dash | dashdot | longdash | longdashdot | solid]
- * - hoverStrokeColor: "red",
- * - hoverStrokeOpacity: 1,
- * - hoverStrokeWidth: 0.2,
- * - pointRadius: 6,
- * - hoverPointRadius: 1,
- * - hoverPointUnit: "%",
- * - pointerEvents: "visiblePainted"
- * - cursor: ""
- * Other style properties that have no default values:
- * - externalGraphic,
- * - graphicWidth,
- * - graphicHeight,
- * - graphicOpacity,
- * - graphicXOffset,
- * - graphicYOffset,
- * - graphicName,
- * - display
+ * Symbolizer properties:
+ * fillColor - {String} Hex fill color. Default is "#ee9900".
+ * fillOpacity - {Number} Fill opacity (0-1). Default is 0.4
+ * strokeColor - {String} Hex stroke color. Default is "#ee9900".
+ * strokeOpacity - {Number} Stroke opacity (0-1). Default is 1.
+ * strokeWidth - {Number} Pixel stroke width. Default is 1.
+ * strokeLinecap - {String} Stroke cap type. Default is "round". [butt | round | square]
+ * strokeDashstyle - {String} Stroke dash style. Default is "solid". [dot | dash | dashdot | longdash | longdashdot | solid]
+ * pointRadius - {Number} Pixel point radius. Default is 6.
+ * pointerEvents - {String} Default is "visiblePainted".
+ * cursor - {String} Default is "".
+ * externalGraphic - {String} Url to an external graphic that will be used for rendering points.
+ * graphicWidth - {Number} Pixel width for sizing an external graphic.
+ * graphicHeight - {Number} Pixel height for sizing an external graphic.
+ * graphicOpacity - {Number} Opacity (0-1) for an external graphic.
+ * graphicXOffset - {Number} Pixel offset along the positive x axis for displacing an external graphic.
+ * graphicYOffset - {Number} Pixel offset along the positive y axis for displacing an external graphic.
+ * graphicZIndex - {Number} The integer z-index value to use in rendering.
+ * graphicName - {String} Named graphic to use when rendering points. Supported values include "circle" (default),
+ * "square", "star", "x", "cross", "triangle".
+ * display - {String} Symbolizers will have no effect if display is set to "none". All other values have no effect.
OpenLayers.Feature.Vector.style = {
'default': {
@@ -20550,7 +20709,7 @@
// depending on the box model, modify width and height to take borders
// of the box into account
- var box = this.getBoxCharacteristics(deltaX, deltaY);
+ var box = this.getBoxCharacteristics();
if (box.newBoxModel) {
if (xy.x > startX) {
this.zoomBox.style.width =
@@ -20621,7 +20780,17 @@
- getBoxCharacteristics: function(dx, dy) {
+ * Method: getCharacteristics
+ * Determines offset and box model for a box.
+ * Returns:
+ * {Object} a hash with the following properties:
+ * - xOffset - Corner offset in x-direction
+ * - yOffset - Corner offset in y-direction
+ * - newBoxModel - true for all browsers except IE in quirks mode
+ getBoxCharacteristics: function() {
if (!this.boxCharacteristics) {
var xOffset = parseInt(OpenLayers.Element.getStyle(this.zoomBox,
"border-left-width")) + parseInt(OpenLayers.Element.getStyle(
@@ -20923,6 +21092,12 @@
up: function(evt) {
this.finalize();
+ // the mouseup method of superclass doesn't call the
+ // "done" callback if there's been no move between
+ // down and up
+ if (this.start == this.last) {
+ this.callback("done", [evt.xy]);
@@ -22058,7 +22233,7 @@
isBaseLayer: false,
- * Property: markers
+ * APIProperty: markers
* {Array(<OpenLayers.Marker>)} internal marker list
markers: null,
@@ -22402,7 +22577,8 @@
* Class: OpenLayers.Control.DrawFeature
- * Draws features on a vector layer when active.
+ * The DrawFeature control draws point, line or polygon features on a vector
+ * layer when active.
* Inherits from:
@@ -22458,9 +22634,26 @@
OpenLayers.Control.prototype.initialize.apply(this, [options]);
- this.callbacks = OpenLayers.Util.extend({done: this.drawFeature},
- this.callbacks);
+ this.callbacks = OpenLayers.Util.extend(
+ done: this.drawFeature,
+ modify: function(vertex, feature) {
+ this.layer.events.triggerEvent(
+ "sketchmodified", {vertex: vertex, feature: feature}
+ this.callbacks
this.layer = layer;
+ var sketchStyle = this.layer.styleMap && this.layer.styleMap.styles.temporary;
+ if(sketchStyle) {
+ this.handlerOptions = this.handlerOptions || {};
+ this.handlerOptions.layerOptions = OpenLayers.Util.applyDefaults(
+ this.handlerOptions.layerOptions,
+ {styleMap: new OpenLayers.StyleMap({"default": sketchStyle})}
this.handler = new handler(this, this.callbacks, this.handlerOptions);
@@ -22469,10 +22662,15 @@
drawFeature: function(geometry) {
var feature = new OpenLayers.Feature.Vector(geometry);
- feature.state = OpenLayers.State.INSERT;
- this.layer.addFeatures([feature]);
- this.featureAdded(feature);
- this.events.triggerEvent("featureadded",{feature : feature});
+ var proceed = this.layer.events.triggerEvent(
+ "sketchcomplete", {feature: feature}
+ if(proceed !== false) {
+ feature.state = OpenLayers.State.INSERT;
+ this.layer.addFeatures([feature]);
+ this.featureAdded(feature);
+ this.events.triggerEvent("featureadded",{feature : feature});
CLASS_NAME: "OpenLayers.Control.DrawFeature"
@@ -22742,6 +22940,9 @@
* Class: OpenLayers.Control.ZoomBox
+ * The ZoomBox control enables zooming directly to a given extent, by drawing
+ * a box on the map. The box is drawn by holding down shift, whilst dragging
+ * the mouse.
* Inherits from:
@@ -23297,6 +23498,13 @@
// move the ToS and branding stuff up to the pane
// thanks a *mil* Erik for thinking of this
+ var termsOfUse = this.div.lastChild;
+ this.div.removeChild(termsOfUse);
+ this.pane.appendChild(termsOfUse);
+ termsOfUse.className = "olLayerGoogleCopyright";
+ termsOfUse.style.right = "";
+ termsOfUse.style.bottom = "";
var poweredBy = this.div.lastChild;
this.div.removeChild(poweredBy);
this.pane.appendChild(poweredBy);
@@ -23304,13 +23512,6 @@
poweredBy.style.left = "";
poweredBy.style.bottom = "";
- var termsOfUse = this.div.lastChild;
- this.div.removeChild(termsOfUse);
- this.pane.appendChild(termsOfUse);
- termsOfUse.className = "olLayerGoogleCopyright";
- termsOfUse.style.right = "";
- termsOfUse.style.bottom = "";
} catch (e) {
OpenLayers.Console.error(e);
@@ -24628,8 +24829,6 @@
// don't display if there were rules but none applied
if(rules.length > 0 && appliedRules == false) {
style.display = "none";
- } else {
- style.display = "";
return style;
@@ -25207,6 +25406,44 @@
+ * APIMethod: distanceTo
+ * Calculate the closest distance between two geometries.
+ * Parameters:
+ * geometry - {<OpenLayers.Geometry>} The target geometry.
+ * options - {Object} Optional properties for configuring the distance
+ * calculation.
+ * Valid options depend on the specific geometry type.
+ * Returns:
+ * {Number | Object} The distance between this geometry and the target.
+ * If details is true, the return will be an object with distance,
+ * x0, y0, x1, and x2 properties. The x0 and y0 properties represent
+ * the coordinates of the closest point on this geometry. The x1 and y1
+ * properties represent the coordinates of the closest point on the
+ * target geometry.
+ distanceTo: function(geometry, options) {
+ * APIMethod: getVertices
+ * Return a list of all points in this geometry.
+ * Parameters:
+ * nodes - {Boolean} For lines, only return vertices that are
+ * endpoints. If false, for lines, only vertices that are not
+ * endpoints will be returned. If not provided, all vertices will
+ * be returned.
+ * Returns:
+ * {Array} A list of all vertices in the geometry.
+ getVertices: function(nodes) {
* Method: atPoint
* Note - This is only an approximation based on the bounds of the
* geometry.
@@ -25281,6 +25518,36 @@
CLASS_NAME: "OpenLayers.Geometry"
+ * Function: OpenLayers.Geometry.fromWKT
+ * Generate a geometry given a Well-Known Text string.
+ * Parameters:
+ * wkt - {String} A string representing the geometry in Well-Known Text.
+ * Returns:
+ * {<OpenLayers.Geometry>} A geometry of the appropriate class.
+OpenLayers.Geometry.fromWKT = function(wkt) {
+ var format = arguments.callee.format;
+ if(!format) {
+ format = new OpenLayers.Format.WKT();
+ arguments.callee.format = format;
+ var geom;
+ var result = format.read(wkt);
+ if(result instanceof OpenLayers.Feature.Vector) {
+ geom = result.geometry;
+ } else if(result instanceof Array) {
+ var len = result.length;
+ var components = new Array(len);
+ for(var i=0; i<len; ++i) {
+ components[i] = result[i].geometry;
+ geom = new OpenLayers.Geometry.Collection(components);
+ return geom;
* Method: OpenLayers.Geometry.segmentsIntersect
@@ -25344,6 +25611,49 @@
return intersection;
+ * Function: OpenLayers.Geometry.distanceToSegment
+ * Parameters:
+ * point - {Object} An object with x and y properties representing the
+ * point coordinates.
+ * segment - {Object} An object with x1, y1, x2, and y2 properties
+ * representing endpoint coordinates.
+ * Returns:
+ * {Object} An object with distance, x, and y properties. The distance
+ * will be the shortest distance between the input point and segment.
+ * The x and y properties represent the coordinates along the segment
+ * where the shortest distance meets the segment.
+OpenLayers.Geometry.distanceToSegment = function(point, segment) {
+ var x0 = point.x;
+ var y0 = point.y;
+ var x1 = segment.x1;
+ var y1 = segment.y1;
+ var x2 = segment.x2;
+ var y2 = segment.y2;
+ var dx = x2 - x1;
+ var dy = y2 - y1;
+ var along = ((dx * (x0 - x1)) + (dy * (y0 - y1))) /
+ (Math.pow(dx, 2) + Math.pow(dy, 2));
+ var x, y;
+ if(along <= 0.0) {
+ x = x1;
+ y = y1;
+ } else if(along >= 1.0) {
+ x = x2;
+ y = y2;
+ } else {
+ x = x1 + along * dx;
+ y = y1 + along * dy;
+ return {
+ distance: Math.sqrt(Math.pow(x - x0, 2) + Math.pow(y - y0, 2)),
+ x: x, y: y
OpenLayers/Layer/MapGuide.js
@@ -25383,12 +25693,26 @@
* APIProperty: useOverlay
* {Boolean} flag to indicate if the layer should be retrieved using
* GETMAPIMAGE (default) or using GETDYNAMICOVERLAY requests.
- * Using an overlay image is only available in MapGuide Enterprise 2010
- * and MapGuide Open Source v2.0.3 or higher, but it allows selections
- * to be drawn separately from the map and offers styling options
useOverlay: false,
+ * APIProperty: useAsyncOverlay
+ * {Boolean} indicates if the MapGuide site supports the asynchronous
+ * GETDYNAMICOVERLAY requests which is available in MapGuide Enterprise 2010
+ * and MapGuide Open Source v2.0.3 or higher. The newer versions of MG
+ * is called asynchronously, allows selections to be drawn separately from
+ * the map and offers styling options.
+ * With older versions of MapGuide, set useAsyncOverlay=false. Note that in
+ * this case a synchronous AJAX call is issued and the mapname and session
+ * parameters must be used to initialize the layer, not the mapdefinition
+ * parameter. Also note that this will issue a synchronous AJAX request
+ * before the image request can be issued so the users browser may lock
+ * up if the MG Web tier does not respond in a timely fashion.
+ useAsyncOverlay: true,
* Constant: TILE_PARAMS
* {Object} Hashtable of default parameter key/value pairs for tiled layer
@@ -25419,7 +25743,7 @@
format: 'PNG',
locale: 'en',
clip: '1',
- version: '2.1.0'
+ version: '2.0.0'
@@ -25438,8 +25762,9 @@
* For untiled base layers, specify either combination of 'mapName' and
* 'session', or 'mapDefinition' and 'locale'.
- * For untiled overlay layers (useOverlay=true),
- * mapName and session are required parameters for the Layer constructor.
+ * For older versions of MapGuide and overlay layers, set useAsyncOverlay
+ * to false and in this case mapName and session are required parameters
+ * for the constructor.
* NOTE: MapGuide OS uses a DPI value and degrees to meters conversion
* factor that are different than the defaults used in OpenLayers,
@@ -25498,6 +25823,9 @@
this.params,
this.OVERLAY_PARAMS
+ this.params.version = "1.0.0";
} else {
this.params,
@@ -25578,8 +25906,21 @@
setviewcenterx: center.lon,
setviewcentery: center.lat,
setviewscale: this.map.getScale()
+ if (this.useOverlay && !this.useAsyncOverlay) {
+ //first we need to call GETVISIBLEMAPEXTENT to set the extent
+ var getVisParams = {};
+ getVisParams = OpenLayers.Util.extend(getVisParams, params);
+ getVisParams.operation = "GETVISIBLEMAPEXTENT";
+ getVisParams.version = "1.0.0";
+ getVisParams.session = this.params.session;
+ getVisParams.mapName = this.params.mapName;
+ getVisParams.format = 'text/xml';
+ url = this.getFullRequestString( getVisParams );
+ OpenLayers.Request.GET({url: url, async: false});
//construct the full URL
url = this.getFullRequestString( params );
} else {
@@ -26760,14 +27101,64 @@
* will have four times the area).
* origin - {<OpenLayers.Geometry.Point>} Point of origin for resizing
* ratio - {Float} Optional x:y ratio for resizing. Default ratio is 1.
+ * Returns:
+ * {OpenLayers.Geometry} - The current geometry.
resize: function(scale, origin, ratio) {
for(var i=0; i<this.components.length; ++i) {
this.components[i].resize(scale, origin, ratio);
+ return this;
+ * Parameters:
+ * calculation.
+ * Valid options:
+ * details - {Boolean} Return details from the distance calculation.
+ * edge - {Boolean} Calculate the distance from this geometry to the
+ * nearest edge of the target geometry. Default is true. If true,
+ * calling distanceTo from a geometry that is wholly contained within
+ * the target will result in a non-zero distance. If false, whenever
+ * geometries intersect, calling distanceTo will return 0. If false,
+ * details cannot be returned.
+ * Returns:
+ * x0, y0, x1, and y1 properties. The x0 and y0 properties represent
+ var edge = !(options && options.edge === false);
+ var details = edge && options && options.details;
+ var result, best;
+ var min = Number.POSITIVE_INFINITY;
+ for(var i=0, len=this.components.length; i<len; ++i) {
+ result = this.components[i].distanceTo(geometry, options);
+ distance = details ? result.distance : result;
+ if(distance < min) {
+ min = distance;
+ best = result;
+ if(min == 0) {
+ break;
+ return best;
* APIMethod: equals
* Tests for equivalent geometries
@@ -26839,6 +27230,30 @@
return intersect;
+ * Parameters:
+ * be returned.
+ * Returns:
+ var vertices = [];
+ Array.prototype.push.apply(
+ vertices, this.components[i].getVertices(nodes)
+ return vertices;
CLASS_NAME: "OpenLayers.Geometry.Collection"
@@ -26918,20 +27333,55 @@
* Parameters:
- * point - {<OpenLayers.Geometry.Point>}
+ * calculation.
+ * Valid options:
+ * Returns:
- distanceTo: function(point) {
- var distance = 0.0;
- if ( (this.x != null) && (this.y != null) &&
- (point != null) && (point.x != null) && (point.y != null) ) {
- var dx2 = Math.pow(this.x - point.x, 2);
- var dy2 = Math.pow(this.y - point.y, 2);
- distance = Math.sqrt( dx2 + dy2 );
+ var distance, x0, y0, x1, y1, result;
+ if(geometry instanceof OpenLayers.Geometry.Point) {
+ x0 = this.x;
+ y0 = this.y;
+ x1 = geometry.x;
+ y1 = geometry.y;
+ distance = Math.sqrt(Math.pow(x0 - x1, 2) + Math.pow(y0 - y1, 2));
+ result = !details ?
+ distance : {x0: x0, y0: y0, x1: x1, y1: y1, distance: distance};
+ } else {
+ result = geometry.distanceTo(this, options);
+ if(details) {
+ // switch coord order since this geom is target
+ result = {
+ x0: result.x1, y0: result.y1,
+ x1: result.x0, y1: result.y0,
+ distance: result.distance
- return distance;
+ return result;
@@ -27010,12 +27460,16 @@
* distance between the point and origin.
+ * Returns:
ratio = (ratio == undefined) ? 1 : ratio;
this.x = origin.x + (scale * ratio * (this.x - origin.x));
this.y = origin.y + (scale * (this.y - origin.y));
this.clearBounds();
+ return this;
@@ -27058,6 +27512,23 @@
return this;
+ * Parameters:
+ * be returned.
+ * Returns:
+ return [this];
CLASS_NAME: "OpenLayers.Geometry.Point"
@@ -27140,6 +27611,19 @@
* - *afterfeaturemodified* Triggered when a feature is finished being modified.
* Listeners will receive an object with a *feature* property referencing
* the modified feature.
+ * - *vertexmodified* Triggered when a vertex within any feature geometry
+ * has been modified. Listeners will receive an object with a
+ * *feature* property referencing the modified feature, a *vertex*
+ * property referencing the vertex modified (always a point geometry),
+ * and a *pixel* property referencing the pixel location of the
+ * modification.
+ * - *sketchmodified* Triggered when a feature sketch bound for this layer
+ * is modified. Listeners will receive an object with a *vertex*
+ * property referencing the modified vertex.
+ * - *sketchcomplete* Triggered when a feature sketch bound for this layer
+ * is complete. Listeners will receive an object with a *feature*
+ * property referencing the sketch feature. By returning false, a
+ * listener can stop the sketch feature from being added to the layer.
* - *refresh* Triggered when something wants a strategy to ask the protocol
* for a new set of features.
@@ -27148,6 +27632,7 @@
"beforefeatureremoved", "featureremoved", "featuresremoved",
"beforefeatureselected", "featureselected", "featureunselected",
"beforefeaturemodified", "featuremodified", "afterfeaturemodified",
+ "vertexmodified", "sketchmodified", "sketchcomplete",
"refresh"],
@@ -27361,7 +27846,7 @@
* and assigns the first one whose "supported()" function returns true.
assignRenderer: function() {
- for (var i=0, len=this.renderers.length; i<this.renderers.length; i++) {
+ for (var i=0, len=this.renderers.length; i<len; i++) {
var rendererClass = OpenLayers.Renderer[this.renderers[i]];
if (rendererClass && rendererClass.prototype.supported()) {
this.renderer = new rendererClass(this.div,
@@ -27571,10 +28056,20 @@
* APIMethod: removeFeatures
+ * Remove features from the layer. This erases any drawn features and
+ * removes them from the layer's control. The beforefeatureremoved
+ * and featureremoved events will be triggered for each feature. The
+ * featuresremoved event will be triggered after all features have
+ * been removed. To supress event triggering, use the silent option.
* Parameters:
- * features - {Array(<OpenLayers.Feature.Vector>)}
+ * features - {Array(<OpenLayers.Feature.Vector>)} List of features to be
+ * removed.
+ * options - {Object} Optional properties for changing behavior of the
+ * removal.
+ * Valid options:
+ * silent - {Boolean} Supress event triggering. Default is false.
removeFeatures: function(features, options) {
if(!features || features.length === 0) {
@@ -27667,6 +28162,13 @@
* feature's style will be used. If the feature doesn't have a style,
* the layer's style will be used.
+ * This function is not designed to be used when adding features to
+ * the layer (use addFeatures instead). It is meant to be used when
+ * the style of a feature has changed, or in some other way needs to
+ * visually updated *after* it has already been added to a layer. You
+ * must add the feature to the layer for most layer-related events to
+ * happen.
* Parameters:
* feature - {<OpenLayers.Feature.Vector>}
* style - {Object} Symbolizer hash or {String} renderIntent
@@ -27901,9 +28403,11 @@
* Class: OpenLayers.Handler.Point
* Handler to draw a point on the map. Point is displayed on mouse down,
- * moves on mouse move, and is finished on mouse up. The handler triggers
- * callbacks for 'done' and 'cancel'. Create a new instance with the
- * <OpenLayers.Handler.Point> constructor.
+ * moves on mouse move, and is finished on mouse up. The handler triggers
+ * callbacks for 'done', 'cancel', and 'modify'. The modify callback is
+ * called with each change in the sketc and will receive the latest point
+ * drawn. Create a new instance with the <OpenLayers.Handler.Point>
+ * constructor.
* Inherits from:
* - <OpenLayers.Handler>
@@ -27974,19 +28478,23 @@
* Parameters:
* control - {<OpenLayers.Control>} The control that owns this handler
- * callbacks - {Object} An object with a 'done' property whose value is a
- * function to be called when the point drawing is finished.
- * The callback should expect to recieve a single argument,
- * the point geometry. If the callbacks object contains a
- * 'cancel' property, this function will be called when the
- * handler is deactivated while drawing. The cancel should
- * expect to receive a geometry.
+ * callbacks - {Object} An object with a properties whose values are
+ * functions. Various callbacks described below.
* options - {Object} An optional object with properties to be set on the
* handler
+ * Named callbacks:
+ * done - Called when the point drawing is finished. The callback will
+ * recieve a single argument, the point geometry.
+ * modify - Called with each move of a vertex with the vertex (point)
+ * geometry and the sketch feature.
+ * cancel - Called when the handler is deactivated while drawing. The
+ * cancel callback will receive a geometry.
initialize: function(control, callbacks, options) {
- // TBD: deal with style
- this.style = OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'], {});
+ if(!(options && options.layerOptions && options.layerOptions.styleMap)) {
+ this.style = OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'], {});
OpenLayers.Handler.prototype.initialize.apply(this, arguments);
@@ -28122,6 +28630,21 @@
+ * Method: modifyFeature
+ * Modify the existing geometry given a pixel location.
+ * Parameters:
+ * pixel - {<OpenLayers.Pixel>} A pixel location on the map.
+ modifyFeature: function(pixel) {
+ var lonlat = this.map.getLonLatFromPixel(pixel);
+ this.point.geometry.x = lonlat.lon;
+ this.point.geometry.y = lonlat.lat;
+ this.callback("modify", [this.point.geometry, this.point]);
+ this.point.geometry.clearBounds();
* Method: drawFeature
* Render features on the temporary layer.
@@ -28184,10 +28707,7 @@
this.lastDown = evt.xy;
this.drawing = true;
- var lonlat = this.map.getLonLatFromPixel(evt.xy);
- this.point.geometry.x = lonlat.lon;
- this.point.geometry.y = lonlat.lat;
- this.point.geometry.clearBounds();
+ this.modifyFeature(evt.xy);
this.drawFeature();
return false;
@@ -28205,10 +28725,7 @@
mousemove: function (evt) {
if(this.drawing) {
this.drawFeature();
return true;
@@ -28456,6 +28973,167 @@
return segments.sort(byX1);
+ * Parameters:
+ * be returned.
+ * Returns:
+ var vertices;
+ if(nodes === true) {
+ vertices = [
+ this.components[0],
+ this.components[this.components.length-1]
+ } else if (nodes === false) {
+ vertices = this.components.slice(1, this.components.length-1);
+ } else {
+ vertices = this.components.slice();
+ return vertices;
+ * Parameters:
+ * calculation.
+ * Valid options:
+ * Returns:
+ var result, best = {};
+ var segs = this.getSortedSegments();
+ var x = geometry.x;
+ var y = geometry.y;
+ var seg;
+ for(var i=0, len=segs.length; i<len; ++i) {
+ seg = segs[i];
+ result = OpenLayers.Geometry.distanceToSegment(geometry, seg);
+ if(result.distance < min) {
+ min = result.distance;
+ best = result;
+ if(min == 0) {
+ break;
+ } else {
+ // if distance increases and we cross y0 to the right of x0, no need to keep looking.
+ if(seg.x2 > x && ((y > seg.y1 && y < seg.y2) || (y < seg.y1 && y > seg.y2))) {
+ break;
+ if(details) {
+ best = {
+ distance: best.distance,
+ x0: best.x, y0: best.y,
+ x1: x, y1: y
+ } else {
+ best = best.distance;
+ } else if(geometry instanceof OpenLayers.Geometry.LineString) {
+ var segs0 = this.getSortedSegments();
+ var segs1 = geometry.getSortedSegments();
+ var seg0, seg1, intersection, x0, y0;
+ var len1 = segs1.length;
+ outer: for(var i=0, len=segs0.length; i<len; ++i) {
+ seg0 = segs0[i];
+ x0 = seg0.x1;
+ y0 = seg0.y1;
+ for(var j=0; j<len1; ++j) {
+ seg1 = segs1[j];
+ intersection = OpenLayers.Geometry.segmentsIntersect(seg0, seg1, true);
+ if(intersection) {
+ min = 0;
+ best = {
+ distance: 0,
+ x0: intersection.x, y0: intersection.y,
+ x1: intersection.x, y1: intersection.y
+ break outer;
+ } else {
+ result = OpenLayers.Geometry.distanceToSegment({x: x0, y: y0}, seg1);
+ best = {
+ distance: min,
+ x0: x0, y0: y0,
+ x1: result.x, y1: result.y
+ if(!details) {
+ if(min !== 0) {
+ // check the final vertex in this line's sorted segments
+ if(seg0) {
+ new OpenLayers.Geometry.Point(seg0.x2, seg0.y2),
+ options
+ var dist = details ? result.distance : result;
+ if(dist < min) {
+ if(details) {
+ best = {
+ distance: min,
+ } else {
+ best = dist;
+ } else {
+ best = geometry.distanceTo(this, options);
+ // swap since target comes from this line
+ if(details) {
+ best = {
+ x0: best.x1, y0: best.y1,
+ x1: best.x0, y1: best.y0
+ return best;
CLASS_NAME: "OpenLayers.Geometry.LineString"
@@ -28612,11 +29290,15 @@
+ * Returns:
for(var i=0, len=this.components.length; i<len - 1; ++i) {
+ return this;
@@ -28784,6 +29466,23 @@
return intersect;
+ * Parameters:
+ * be returned.
+ * Returns:
+ return (nodes === true) ? [] : this.components.slice(0, this.components.length-1);
CLASS_NAME: "OpenLayers.Geometry.LinearRing"
@@ -28840,17 +29539,20 @@
* Create a new path hander
* Parameters:
- * control - {<OpenLayers.Control>}
- * callbacks - {Object} An object with a 'done' property whos value is a
- * function to be called when the path drawing is finished. The
- * callback should expect to recieve a single argument, the line
- * string geometry. If the callbacks object contains a 'point'
- * property, this function will be sent each point as they are added.
- * If the callbacks object contains a 'cancel' property, this function
- * will be called when the handler is deactivated while drawing. The
- * cancel should expect to receive a geometry.
+ * control - {<OpenLayers.Control>} The control that owns this handler
* handler
+ * recieve a single argument, the linestring geometry.
+ * point - Called as each point is added. Receives the new point geometry.
OpenLayers.Handler.Point.prototype.initialize.apply(this, arguments);
@@ -28859,12 +29561,19 @@
* Method: createFeature
* Add temporary geometries
+ * Parameters:
+ * pixel - {<OpenLayers.Pixel>} The initial pixel location for the new
+ * feature.
- createFeature: function() {
+ createFeature: function(pixel) {
+ var lonlat = this.control.map.getLonLatFromPixel(pixel);
+ this.point = new OpenLayers.Feature.Vector(
+ new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat)
this.line = new OpenLayers.Feature.Vector(
- new OpenLayers.Geometry.LineString());
- this.point = new OpenLayers.Feature.Vector(
- new OpenLayers.Geometry.Point());
+ new OpenLayers.Geometry.LineString([this.point.geometry])
this.layer.addFeatures([this.line, this.point], {silent: true});
@@ -28878,12 +29587,12 @@
- * Method: destroyPoint
+ * Method: removePoint
* Destroy the temporary point.
- destroyPoint: function() {
+ removePoint: function() {
if(this.point) {
- this.layer.destroyFeatures([this.point]);
+ this.layer.removeFeatures([this.point]);
@@ -28891,11 +29600,22 @@
* Method: addPoint
* Add point to geometry. Send the point index to override
* the behavior of LinearRing that disregards adding duplicate points.
+ * Parameters:
+ * pixel - {<OpenLayers.Pixel>} The pixel location for the new point.
- addPoint: function() {
- this.line.geometry.addComponent(this.point.geometry.clone(),
- this.line.geometry.components.length);
+ addPoint: function(pixel) {
+ this.line.geometry.addComponent(
+ this.point.geometry, this.line.geometry.components.length
this.callback("point", [this.point.geometry, this.getGeometry()]);
+ this.callback("modify", [this.point.geometry, this.getSketch()]);
+ this.drawFeature();
@@ -28913,14 +29633,20 @@
* Modify the existing geometry given the new point
+ * Parameters:
+ * pixel - {<OpenLayers.Pixel>} The updated pixel location for the latest
+ * point.
- modifyFeature: function() {
- var index = this.line.geometry.components.length - 1;
- this.line.geometry.components[index].x = this.point.geometry.x;
- this.line.geometry.components[index].y = this.point.geometry.y;
- this.line.geometry.components[index].clearBounds();
* Render geometries on the temporary layer.
@@ -28931,6 +29657,17 @@
+ * Method: getSketch
+ * Return the sketch feature.
+ * Returns:
+ * {<OpenLayers.Feature.Vector>}
+ getSketch: function() {
+ return this.line;
* Method: getGeometry
* Return the sketch geometry. If <multi> is true, this will return
* a multi-part geometry.
@@ -28966,18 +29703,12 @@
if(this.persist) {
this.destroyFeature();
- this.createFeature();
+ this.createFeature(evt.xy);
+ } else if((this.lastUp == null) || !this.lastUp.equals(evt.xy)) {
+ this.addPoint(evt.xy);
this.mouseDown = true;
- var lonlat = this.control.map.getLonLatFromPixel(evt.xy);
- if((this.lastUp == null) || !this.lastUp.equals(evt.xy)) {
- this.addPoint();
- this.drawFeature();
return false;
@@ -28995,17 +29726,11 @@
if(this.drawing) {
if(this.mouseDown && this.freehandMode(evt)) {
- this.addPoint();
} else {
- this.modifyFeature();
- //this.callback("move", [evt.xy]);
return true;
@@ -29025,13 +29750,11 @@
this.mouseDown = false;
if(this.drawing) {
if(this.freehandMode(evt)) {
- if(this.persist) {
- this.destroyPoint();
+ this.removePoint();
this.finalize();
} else {
if(this.lastUp == null) {
- this.addPoint();
this.lastUp = evt.xy;
@@ -29055,9 +29778,7 @@
if(!this.freehandMode(evt)) {
this.line.geometry.removeComponent(this.line.geometry.components[index]);
this.finalize();
return false;
@@ -29227,6 +29948,47 @@
return intersect;
+ * Parameters:
+ * calculation.
+ * Valid options:
+ * Returns:
+ var result;
+ // this is the case where we might not be looking for distance to edge
+ if(!edge && this.intersects(geometry)) {
+ result = 0;
+ } else {
+ result = OpenLayers.Geometry.Collection.prototype.distanceTo.apply(
+ this, [geometry, options]
+ return result;
CLASS_NAME: "OpenLayers.Geometry.Polygon"
@@ -29293,18 +30055,20 @@
* Create a Polygon Handler.
* Parameters:
- * a function to be called when the path drawing is
- * finished. The callback should expect to recieve a
- * single argument, the polygon geometry.
- * If the callbacks object contains a 'point'
- * as they are added. If the callbacks object contains
- * a 'cancel' property, this function will be called when
- * the handler is deactivated while drawing. The cancel
- * should expect to receive a geometry.
+ * options - {Object} An optional object with properties to be set on the
+ * handler
+ * recieve a single argument, the polygon geometry.
OpenLayers.Handler.Path.prototype.initialize.apply(this, arguments);
@@ -29313,15 +30077,22 @@
+ * Parameters:
+ * feature.
+ this.line = new OpenLayers.Feature.Vector(
+ new OpenLayers.Geometry.LinearRing([this.point.geometry])
this.polygon = new OpenLayers.Feature.Vector(
- new OpenLayers.Geometry.Polygon());
- this.line = new OpenLayers.Feature.Vector(
- new OpenLayers.Geometry.LinearRing());
- this.polygon.geometry.addComponent(this.line.geometry);
+ new OpenLayers.Geometry.Polygon([this.line.geometry])
this.layer.addFeatures([this.polygon, this.point], {silent: true});
@@ -29335,18 +30106,6 @@
- * Method: modifyFeature
- * Modify the existing geometry given the new point
- var index = this.line.geometry.components.length - 2;
@@ -29356,6 +30115,17 @@
+ * Returns:
+ return this.polygon;
@@ -29384,9 +30154,7 @@
// remove the penultimate point
this.finalize();
return false;
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js 2009-03-05 15:54:57 UTC (rev 1810)
+++ trunk/lib/fusion.js 2009-03-05 17:50:39 UTC (rev 1811)
@@ -800,7 +800,7 @@
getFusionURL: function() {return this.fusionURL;},
getConfigurationItem: function(arch, key) {
- if (this.configuration[arch] && this.configuration[arch][key]) {
+ if (this.configuration[arch] && (this.configuration[arch][key]!='undefined')) {
return this.configuration[arch][key];
return null;
More information about the fusion-commits
