[fusion-commits] r1813 - trunk/widgets
svn_fusion at osgeo.org
Tue Mar 10 12:14:16 EDT 2009
Author: pdeschamps
Date: 2009-03-10 12:14:16 -0400 (Tue, 10 Mar 2009)
New Revision: 1813
trunk/widgets/Maptip.js
added init loop so that maptips does not get triggered until the map is
loaded.
Modified: trunk/widgets/Maptip.js
--- trunk/widgets/Maptip.js 2009-03-09 16:00:13 UTC (rev 1812)
+++ trunk/widgets/Maptip.js 2009-03-10 16:14:16 UTC (rev 1813)
@@ -62,6 +62,7 @@
szLabel:'',
aTextFields: null,
mapTipFired: false,
+ bStartMapTips:false,
initializeWidget: function(widgetTag) {
//var json = widgetTag.extension;
@@ -120,6 +121,7 @@
this.eventListener = false;
this.getMap().registerForEvent(Fusion.Event.MAP_MAPTIP_REQ_FINISHED,OpenLayers.Function.bind(this._display,this));
this.getMap().registerForEvent(Fusion.Event.MAP_BUSY_CHANGED, this.busyChanged.bind(this));
+ this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, this.startMapTips.bind(this));
mouseOut: function(e) {
@@ -132,32 +134,37 @@
+ startMapTips: function(){
+ this.bStartMapTips = true;
mouseMove: function(e) {
- if(!this.eventListener){
- this.eventListener = true;
- //console.log('map tip mouseMove');
- if (this.bOverTip || this.mouseIsDown) {
- return;
- var map = this.getMap();
- this.mapSize = map.getSize();
- this.mapOffset = map._oDomObj.offsets;
+ if( this.bStartMapTips == true){
+ if(!this.eventListener){
+ this.eventListener = true;
+ //console.log('map tip mouseMove');
+ if (this.bOverTip || this.mouseIsDown) {
+ return;
- var p = map.getEventPosition(e);
- this.oCurrentPosition = p;
- this.oMapTipPosition = p;
+ var map = this.getMap();
+ this.mapSize = map.getSize();
+ this.mapOffset = map._oDomObj.offsets;
- if(typeof( this.nTimer) == "number") {
- window.clearTimeout(this.nTimer);
- this.nTimer = null;
- this.nTimer = window.setTimeout(OpenLayers.Function.bind(this.showMaptip, this), this.delay);
- //Event.stop(e);
+ var p = map.getEventPosition(e);
+ this.oCurrentPosition = p;
+ this.oMapTipPosition = p;
+ if(typeof( this.nTimer) == "number") {
+ window.clearTimeout(this.nTimer);
+ this.nTimer = null;
+ this.nTimer = window.setTimeout(OpenLayers.Function.bind(this.showMaptip, this), this.delay);
+ //Event.stop(e);
+ } // bStartMapTips
mouseDown: function() {
More information about the fusion-commits
