[fusion-commits] r1851 - trunk/widgets/widgetinfo
svn_fusion at osgeo.org
Sun May 17 16:10:22 EDT 2009
Author: pagameba
Date: 2009-05-17 16:10:22 -0400 (Sun, 17 May 2009)
New Revision: 1851
Added:
trunk/widgets/widgetinfo/redline.xml
re #251, adding widget info file.
Added: trunk/widgets/widgetinfo/redline.xml
--- trunk/widgets/widgetinfo/redline.xml (rev 0)
+++ trunk/widgets/widgetinfo/redline.xml 2009-05-17 20:10:22 UTC (rev 1851)
@@ -0,0 +1,52 @@
+<WidgetInfo>
+ <Type>Redline</Type>
+ <Location></Location>
+ <LocalizedType>Redline</LocalizedType>
+ <Description>This widget opens a panel in the TaskPane and allows the user to digitize features that can be downloaded as a GML file or uploaded to restore previously digitized features.</Description>
+ <Label>Redline</Label>
+ <Tooltip>Click to draw redline features</Tooltip>
+ <ImageUrl>images/icons.png</ImageUrl>
+ <ImageClass>redline</ImageClass>
+ <StandardUi>true</StandardUi>
+ <ContainableBy>Any</ContainableBy>
+ <Parameter>
+ <Name>Target</Name>
+ <Label>Target</Label>
+ <Type>target</Type>
+ <Description>The frame, window, or TaskPane in which to display any UI for the widget. If empty, a new window is used</Description>
+ <IsMandatory>true</IsMandatory>
+ <DefaultValue>TaskPane</DefaultValue>
+ </Parameter>
+ <Parameter>
+ <Name>FeatureStyle</Name>
+ <Label>Feature Style</Label>
+ <Type>string</Type>
+ <Description>A style map configuration string for features (format TBD).</Description>
+ <IsMandatory>false</IsMandatory>
+ <DefaultValue/
+ </Parameter>
+ <Parameter>
+ <Name>DefaultControl</Name>
+ <Label>Default Control</Label>
+ <Type>String</Type>
+ <Description>The drawing control that is selected by default.</Description>
+ <DefaultValue>point</DefaultValue>
+ <AllowedValue>
+ <Name>point</Name>
+ <Label>Point</Label>
+ </AllowedValue>
+ <AllowedValue>
+ <Name>line</Name>
+ <Label>Line</Label>
+ </AllowedValue>
+ <AllowedValue>
+ <Name>rectangle</Name>
+ <Label>Rectangle</Label>
+ </AllowedValue>
+ <AllowedValue>
+ <Name>polygon</Name>
+ <Label>Polygon</Label>
+ </AllowedValue>
+ </Parameter>
+</WidgetInfo>
Property changes on: trunk/widgets/widgetinfo/redline.xml
___________________________________________________________________
More information about the fusion-commits
