[fusion-commits] r1965 - in sandbox/jxlib-3.0: lib lib/OpenLayers
templates/mapserver/standard/themes/crispin
templates/mapserver/standard/themes/delicious widgets
svn_fusion at osgeo.org
Fri Nov 6 11:05:29 EST 2009
Author: pagameba
Date: 2009-11-06 11:05:28 -0500 (Fri, 06 Nov 2009)
New Revision: 1965
Added:
sandbox/jxlib-3.0/lib/OLpatch.js
sandbox/jxlib-3.0/lib/OpenLayers/OpenLayers.js
sandbox/jxlib-3.0/lib/fusion.js
sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.css
sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.uncompressed.css
sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.css
sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.uncompressed.css
sandbox/jxlib-3.0/widgets/Legend.js
openlayers is interfering with mootools by providing some string functions, this patch removes OpenLayers string functions from the String prototype so mootools works again.
Added: sandbox/jxlib-3.0/lib/OLpatch.js
--- sandbox/jxlib-3.0/lib/OLpatch.js (rev 0)
+++ sandbox/jxlib-3.0/lib/OLpatch.js 2009-11-06 16:05:28 UTC (rev 1965)
@@ -0,0 +1,2 @@
+/** remove String.prototype.contains **/
+String.prototype.contains = null;
\ No newline at end of file
Modified: sandbox/jxlib-3.0/lib/OpenLayers/OpenLayers.js
--- sandbox/jxlib-3.0/lib/OpenLayers/OpenLayers.js 2009-11-05 21:59:29 UTC (rev 1964)
+++ sandbox/jxlib-3.0/lib/OpenLayers/OpenLayers.js 2009-11-06 16:05:28 UTC (rev 1965)
@@ -1,95 +1,95 @@
- OpenLayers.js -- OpenLayers Map Viewer Library
- Copyright 2005-2008 MetaCarta, Inc., released under the Clear BSD license.
- Please see http://svn.openlayers.org/trunk/openlayers/license.txt
- for the full text of the license.
- Includes compressed code under the following licenses:
- (For uncompressed versions of the code used please see the
- OpenLayers SVN repository: <http://openlayers.org/>)
-/* Contains portions of Prototype.js:
- * Prototype JavaScript framework, version 1.4.0
- * (c) 2005 Sam Stephenson <sam at conio.net>
- * Prototype is freely distributable under the terms of an MIT-style license.
- * For details, see the Prototype web site: http://prototype.conio.net/
-* Contains portions of Rico <http://openrico.org/>
-* Copyright 2005 Sabre Airline Solutions
-* Licensed under the Apache License, Version 2.0 (the "License"); you
-* may not use this file except in compliance with the License. You
-* may obtain a copy of the License at
-* http://www.apache.org/licenses/LICENSE-2.0
-* Unless required by applicable law or agreed to in writing, software
-* distributed under the License is distributed on an "AS IS" BASIS,
-* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
-* implied. See the License for the specific language governing
-* permissions and limitations under the License.
- * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
- * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Contains portions of Gears <http://code.google.com/apis/gears/>
- * Copyright 2007, Google Inc.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- * this list of conditions and the following disclaimer in the documentation
- * and/or other materials provided with the distribution.
- * 3. Neither the name of Google Inc. nor the names of its contributors may be
- * used to endorse or promote products derived from this software without
- * specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
- * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
- * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
- * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
- * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
- * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
- * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * Sets up google.gears.*, which is *the only* supported way to access Gears.
- * Circumvent this file at your own risk!
- * In the future, Gears may automatically define google.gears.* without this
- * file. Gears may use these objects to transparently fix bugs and compatibility
- * issues. Applications that use the code below will continue to work seamlessly
- * when that happens.
+ OpenLayers.js -- OpenLayers Map Viewer Library
+ Copyright 2005-2008 MetaCarta, Inc., released under the Clear BSD license.
+ Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+ for the full text of the license.
+ Includes compressed code under the following licenses:
+ (For uncompressed versions of the code used please see the
+ OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ * (c) 2005 Sam Stephenson <sam at conio.net>
+ * Prototype is freely distributable under the terms of an MIT-style license.
+ * For details, see the Prototype web site: http://prototype.conio.net/
+* Contains portions of Rico <http://openrico.org/>
+* Copyright 2005 Sabre Airline Solutions
+* Licensed under the Apache License, Version 2.0 (the "License"); you
+* may not use this file except in compliance with the License. You
+* may obtain a copy of the License at
+* http://www.apache.org/licenses/LICENSE-2.0
+* Unless required by applicable law or agreed to in writing, software
+* distributed under the License is distributed on an "AS IS" BASIS,
+* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+* implied. See the License for the specific language governing
+* permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * 3. Neither the name of Google Inc. nor the names of its contributors may be
+ * used to endorse or promote products derived from this software without
+ * specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
OpenLayers/SingleFile.js
@@ -21554,7 +21554,7 @@
* sz - {<OpenLayers.Size>}
* Returns:
- * {DOMElement} A new DOM Image with this marker´s icon set at the
+ * {DOMElement} A new DOM Image with this marker´s icon set at the
* location passed-in
draw: function(px, sz) {
Modified: sandbox/jxlib-3.0/lib/fusion.js
--- sandbox/jxlib-3.0/lib/fusion.js 2009-11-05 21:59:29 UTC (rev 1964)
+++ sandbox/jxlib-3.0/lib/fusion.js 2009-11-06 16:05:28 UTC (rev 1965)
@@ -1078,6 +1078,7 @@
if (!Fusion._singleFile) {
var coreScripts = ['lib/OpenLayers/OpenLayers.js',
+ 'lib/OLpatch.js',
'lib/jxlib.uncompressed.js',
'lib/proj4js-compressed.js',
'lib/EventMgr.js',
Modified: sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
--- sandbox/jxlib-3.0/lib/jxlib.uncompressed.js 2009-11-05 21:59:29 UTC (rev 1964)
+++ sandbox/jxlib-3.0/lib/jxlib.uncompressed.js 2009-11-06 16:05:28 UTC (rev 1965)
@@ -21784,7 +21784,7 @@
-// $Id: splitter.js 524 2009-09-18 05:40:16Z jonlb at comcast.net $
+// $Id: splitter.js 585 2009-11-05 20:19:59Z pagameba $
* Class: Jx.Splitter
@@ -27851,7 +27851,7 @@
e.stop();
-});// $Id: menu.separator.js 582 2009-10-30 22:03:58Z pagameba $
+});// $Id: menu.separator.js 586 2009-11-05 20:34:17Z pagameba $
* Class: Jx.Menu.Separator
@@ -27883,7 +27883,7 @@
owner: null,
options: {
- template: "<li class='jxMenuItem'><span class='jxMenuSeparator'></span></li>"
+ template: "<li class='jxMenuItemContainer jxMenuItem'><span class='jxMenuSeparator'> </span></li>"
classes: ['jxMenuItem'],
@@ -27894,6 +27894,7 @@
this.parent();
this.elements = this.processTemplate(this.options.template, this.classes);
this.domObj = this.elements.get('jxMenuItem');
+ this.domObj.store('jxMenuItem', this);
* Method: setOwner
@@ -28579,7 +28580,7 @@
this.domObj.appendChild(this.domSpan);
-// $Id: treeitem.js 581 2009-10-29 20:59:48Z pagameba $
+// $Id: treeitem.js 586 2009-11-05 20:34:17Z pagameba $
* Class: Jx.TreeItem
@@ -28840,7 +28841,7 @@
this.selection = selection;
-// $Id: treefolder.js 582 2009-10-30 22:03:58Z pagameba $
+// $Id: treefolder.js 586 2009-11-05 20:34:17Z pagameba $
* Class: Jx.TreeFolder
@@ -28877,9 +28878,9 @@
open: false,
/* folders will share a selection with the tree they are in */
select: false,
- template: '<li class="jxTreeContainer jxTreeBranch"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><a class="jxTreeItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel"></span></a><ul class="jxTreeFolder"></ul></li>'
+ template: '<li class="jxTreeContainer jxTreeBranch"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><a class="jxTreeItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel"></span></a><ul class="jxTree"></ul></li>'
- classes: ['jxTreeContainer','jxTreeImage','jxTreeItem','jxTreeIcon','jxTreeLabel','jxTreeFolder'],
+ classes: ['jxTreeContainer','jxTreeImage','jxTreeItem','jxTreeIcon','jxTreeLabel','jxTree'],
* APIMethod: render
* Create a new instance of Jx.TreeFolder
@@ -28912,7 +28913,7 @@
this.update();
this.fireEvent('remove', item);
}.bind(this)
- }, this.elements.get('jxTreeFolder'));
+ }, this.elements.get('jxTree'));
if (this.options.open) {
this.expand();
} else {
@@ -29017,7 +29018,7 @@
setSelection: function(selection) {
this.tree.setSelection(selection);
-});// $Id: tree.js 582 2009-10-30 22:03:58Z pagameba $
+});// $Id: tree.js 586 2009-11-05 20:34:17Z pagameba $
* Class: Jx.Tree
@@ -29364,6 +29365,399 @@
this.slider.set(this.options.startAt);
+Jx.Notification = new Class({
+ Extends: Jx.Widget,
+ Family: 'Jx.Notification',
+ options: {
+ * Option: parent
+ * The parent this notification is inside. If left undefined it is
+ * either document.body (for 'anchor' style) or window (for 'float'
+ * style).
+ parent: null,
+ * Option: items
+ * An initial list of notices to add. Pass them as an array of
+ * either strings, Elements, or Jx.Widget instances (anything that
+ * works with document.id() for grabbing gan element will work).
+ items: [],
+ * Option: style
+ * Determines if this is anchored to a side of a parent or
+ * floated in the viewport. Possible options are 'anchor' or
+ * 'float'
+ style: 'anchor',
+ * Option: position
+ * This option could have 2 different meanings. If style is set to
+ * "anchor" then this should be a string that indicates the side of
+ * the parent to anchor the notification container to. If style is
+ * "float" then position should be an object that defines the horizontal
+ * and vertical options for the widget's position method
+ position: 'top',
+ * Option: sizes
+ * An object with members to indicate the size of the notification
+ * container in different states. When 'anchor' is the style the valid
+ * options are 'open' and 'minimized'. When 'float' is the style the
+ * only valid option is 'width'.
+ sizes: {
+ open: 60,
+ minimized: 20
+ * Option: fx
+ * An instance of Fx.Tween (or an object containing options for it)
+ * to be used in animating the container when in an anchored state. If
+ * not set a default sliding animation will be used.
+ fx: null,
+ * Option: template
+ * This is the template for the notification container itself, not the
+ * actual notice. The actual notice is below in the class property
+ * noticeTemplate.
+ template: '<div class="jxNotificationContainer"><span class="jxNotificationMinimize"></span><span class="jxNoticeContainer"></span></div>',
+ * Option: listOptions
+ * An object holding custom options for the internal Jx.List instance.
+ listOptions: {
+ hover: true
+ * Option: floatChrome
+ * Determines whether a floated notification uses chrome. Defaults to
+ * true.
+ floatChrome: true
+ list: null,
+ containerFx: null,
+ noticeTemplate: '<span class="jxNotice"><span class="jxNoticeClose"></span></span>',
+ classes: ['jxNotificationContainer','jxNotificationMinimize', 'jxNoticeContainer'],
+ noticeClasses: ['jxNotice','jxNoticeClose'],
+ bound: {},
+ init: function () {
+ this.elements = this.processTemplate(this.options.template, this.classes);
+ this.bound.closeNotice = this.closeNotice.bind(this);
+ this.parent();
+ render: function () {
+ this.parent();
+ this.domObj = this.elements.get('jxNotificationContainer');
+ this.list = new Jx.List(this.elements.get('jxNoticeContainer'), this.options.listOptions);
+ this.containerFx = $defined(this.options.fx) ? this.options.fx : {};
+ if (!$defined(this.options.parent)) {
+ this.options.parent = document.body;
+ //add any initial notices
+ if (this.options.items.length > 0) {
+ this.options.items.each(function(item){
+ this.add(item);
+ },this);
+ if (this.options.style === 'anchor') {
+ this.setAnchors();
+ } else {
+ this.setFloat();
+ add: function (item, klass) {
+ var els = this.processTemplate(this.noticeTemplate,this.noticeClasses);
+ var notice = els.get('jxNotice');
+ if (Jx.type(item) === 'string') {
+ var n = new Element('span',{
+ html: item
+ n.inject(notice);
+ } else {
+ document.id(item).inject(notice);
+ if ($defined(klass)) {
+ notice.addClass('jxNotice'+klass);
+ this.list.add(notice);
+ els.get('jxNoticeClose').addEvent('click', this.closeNotice.bind(this, notice));
+ this.fireEvent('add', item);
+ return notice;
+ remove: function (notice) {
+ this.list.remove(notice);
+ this.fireEvent('remove',notice);
+ setAnchors: function () {
+ this.domObj.addClass('jxNotification'+this.options.postion.capitalize());
+ //first grab everything in the parent
+ var els = document.id(this.options.parent).getChildren();
+ //put those all into a div
+ this.originalDiv = new Element('div');
+ this.originalDiv.adopt(els);
+ //now, determine if there were initial notices added
+ //as that changes the initial layout
+ var opts;
+ if (this.list.count() > 0) {
+ opts = this.getOpenAnchorOpts('open');
+ } else {
+ opts = {
+ opts: {
+ height: 0
+ odOpts: {}
+ //inject children into parent
+ this.options.parent.adopt(this.domObj, this.originalDiv);
+ //check to see if parent already has layout
+ var pLayout = this.options.parent.get('jxLayout');
+ if (!$defined(pLayout)){
+ new Jx.Layout(this.options.parent);
+ //give the two siblings layout
+ new Jx.Layout(this.originalDiv, opts.odOpts);
+ new Jx.Layout(this.domObj, opts.opts);
+ //force the layout to resize
+ this.options.parent.resize();
+ //addEvents
+ this.bound = {
+ revealAnchor: this.revealAnchor.bind(this),
+ checkAnchor: this.checkAnchor.bind(this),
+ minimizeAnchor: this.minimizeAnchor.bind(this)
+ this.addEvent('add', this.bound.revealAnchor);
+ this.addEvent('remove', this.bound.checkAnchor);
+ this.elements.get('jxNotificationMinimize').addEvent('click', this.bound.minimizeAnchor);
+ this.revealAnchor();
+ getOpenAnchorOpts: function (state) {
+ var ret = {};
+ switch (this.options.position) {
+ case 'top':
+ ret.opts = {
+ height: this.options.sizes[state]
+ ret.odOpts = {
+ top : opts.height
+ break;
+ case 'bottom':
+ ret.opts = {
+ top: null,
+ ret.odOpts = {};
+ break;
+ case 'left':
+ ret.opts = {
+ width: this.options.sizes[state]
+ ret.odOpts = {
+ left : opts.width
+ break;
+ case 'right':
+ ret.opts = {
+ left: null,
+ ret.odOpts = {};
+ break;
+ return ret;
+ setFloat: function () {
+ this.domObj.setStyles({
+ visibility: 'hidden',
+ display: 'block',
+ opacity: 0,
+ width: this.options.sizes.width,
+ position: 'absolute'
+ this.positionOpts = {
+ element: this.domObj,
+ relative: this.options.parent
+ if (Jx.type(this.options.position) === "object") {
+ this.positionOpts.options = this.options.position;
+ } else {
+ this.positionOpts.options = {
+ horizontal: 'right right',
+ vertical: 'bottom bottom',
+ offsets: {
+ bottom: 10,
+ right: 10
+ this.elements.get('jxNotificationMinimize').addEvent('click', this.hideFloat.bind(this));
+ this.bound.revealFloat = this.revealFloat.bind(this);
+ this.bound.checkFloat = this.checkFloat.bind(this);
+ this.addEvent('add',this.bound.revealFloat);
+ this.addEvent('remove', this.bound.checkFloat);
+ this.revealFloat();
+ revealFloat: function () {
+ if (!this.showing) {
+ //inject domObj into parent
+ this.domObj.inject(this.options.parent);
+ if (this.options.floatChrome) {
+ this.showChrome(this.domObj);
+ this.position(this.positionOpts.element, this.positionOpts.relative, this.positionOpts.options);
+ this.domObj.fade('in');
+ this.showing = true;
+ hideFloat: function () {
+ if (this.showing) {
+ this.domObj.fade('out');
+ this.showing = false;
+ checkFloat: function () {
+ if (this.list.count() === 0) {
+ //list is empty so close the float
+ this.hideFloat();
+ revealAnchor: function () {
+ var prop;
+ if (['top','bottom'].contains(this.options.position)) {
+ prop = 'height';
+ } else {
+ prop = 'width';
+ //animate the panel opening
+ this.domObj.get('tween',{
+ property: prop,
+ onComplete: function () {
+ //then call resize with new options on both windows
+ var opts = this.getOpenAnchorOpts('open');
+ this.domObj.get('jxLayout').resize(opts.opts);
+ this.originalDiv.get('jxLayout').resize(opts.odOpts);
+ }.bind(this)
+ }).start(this.options.sizes.open);
+ checkAnchor: function () {
+ this.hideAnchor();
+ hideAnchor: function () {
+ var prop;
+ prop = 'height';
+ } else {
+ prop = 'width';
+ property: prop,
+ var opts = {
+ opts: {
+ height: 0
+ odOpts: {}
+ }.bind(this)
+ }).start(0);
+ minimizeAnchor: function () {
+ var prop;
+ prop = 'height';
+ } else {
+ prop = 'width';
+ property: prop,
+ var opts = this.getOpenAnchorOpts('minimized');
+ }.bind(this)
+ closeNotice: function (notice) {
+ notice.get('tween',{
+ property: 'opacity',
+ onComplete: this.remove.bind(this,notice)
+ }).start(0);
}); // $Id: $
* Class: Jx.Formatter
Modified: sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.css
--- sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.css 2009-11-05 21:59:29 UTC (rev 1964)
+++ sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.css 2009-11-06 16:05:28 UTC (rev 1965)
@@ -21,4 +21,4 @@
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
- */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:4px 4px 4px 0;border:none;background-image:url(images/button.png);background-position:right -24px;background-repeat:no-repeat;}ul.jxToolbar span.jxButtonContent{background-position:right top;}ul.jxToolbar .jxButtonActive,.jxButtonActive{background-position:left -72px;}ul.jxToolbar .jxButtonActive span.jxButtonContent,.jxButtonActive span.jxButtonContent{background-position:right -72px;}ul.jxToolbar .jxButton:focus,.jxButton:focus{background-position:left -96px;}ul.jxToolbar .jxButton:focus span.jxButtonContent,.jxButton:focus span.jxButtonContent{background-position:right -96px;}ul.jxToolbar .jxButtonActive:focus,.jxButtonActive:focus{background-position:left -144px;}ul.jxToolbar .jxButtonActive:focus span.jxButtonContent,.jxButtonActive:focus span.jxButtonContent{background-position:right -144px;}ul.jxToolbar .jxButton:hover,ul.jxToolbar .jxButtonActive:hover,.jxButton:hover,.jxButtonActive:hover{background-position:left -48px;}ul.jxToolbar .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxButtonActive:hover span.jxButtonContent,.jxButton:hover span.jxButtonContent,.jxButtonActive:hover span.jxButtonContent{background-position:right -48px;}ul.jxToolbar .jxButtonPressed,ul.jxToolbar .jxButtonPressed:focus,.jxButtonPressed,.jxButtonPressed:focus{background-position:left -120px;}ul.jxToolbar .jxButtonPressed span.jxButtonContent,ul.jxToolbar .jxButtonPressed:focus span.jxButtonContent,.jxButtonPressed span.jxButtonContent,.jxButtonPressed:focus span.jxButtonContent{background-position:right -120px;}.jxDisabled .jxButton,.jxDisabled span.jxButtonContent span{cursor:default;}ul.jxToolbar .jxDisabled .jxButton:focus,ul.jxToolbar .jxDisabled .jxButton:active,ul.jxToolbar .jxDisabled .jxButton:hover,ul.jxToolbar .jxDisabled .jxButtonPressed{background-position:left top;}.jxDisabled .jxButton:focus,.jxDisabled .jxButton:active,.jxDisabled .jxButton:hover,.jxDisabled .jxButtonPressed{background-position:left -24px;}ul.jxToolbar .jxDisabled .jxButton:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right top;}.jxDisabled .jxButton:focus span.jxButtonContent,.jxDisabled .jxButton:active span.jxButtonContent,.jxDisabled .jxButton:hover span.jxButtonContent,.jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right -24px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus,ul.jxToolbar .jxDisabled .jxButtonActive:active,ul.jxToolbar .jxDisabled .jxButtonActive:hover,.jxDisabled .jxButtonActive:focus,.jxDisabled .jxButtonActive:active,.jxDisabled .jxButtonActive:hover{background-position:left -72px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:hover span.jxButtonContent,.jxDisabled .jxButtonActive:focus span.jxButtonContent,.jxDisabled .jxButtonActive:active span.jxButtonContent,.jxDisabled .jxButtonActive:hover span.jxButtonContent{background-position:right -72px;}img.jxButtonIcon{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxButtonContent span{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;cursor:pointer;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;height:16px;white-space:nowrap;}span.jxButtonContent span.jxButtonLabel{margin:0;padding:0 4px 0 4px;color:#000;font-size:11px;}.jxButtonMenu span.jxButtonContent,.jxButtonMulti span.jxButtonContent,.jxButtonFlyout span.jxButtonContent,.jxButtonCombo span.jxButtonContent,.jxButtonEditCombo span.jxButtonContent{padding-right:0;}.jxButtonMenu span.jxButtonContent span,.jxButtonFlyout span.jxButtonContent span,.jxButtonMulti span.jxButtonContent span,.jxButtonCombo span.jxButtonContent span,.jxButtonEditCombo span.jxButtonContent span{padding-right:16px;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose{position:absolute;display:-moz-inline-box;display:inline-block;padding:4px 0;font-size:0;line-height:0;right:2px;top:2px;background-image:url(images/button_multi_disclose.png);background-position:right 0;background-repeat:no-repeat;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxButtonDisclose img{width:16px;height:16px;margin:0;padding:0;border:0;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose:focus,a.jxButtonDisclose:active{background-position:right -96px;}a.jxButtonDisclose:hover{background-position:right -48px;}a.jxButtonDisclosePressed{background-position:right -120px;}.jxDisabled a.jxButtonDisclose,.jxDisabled a.jxButtonDisclose:focus,.jxDisabled a.jxButtonDisclose:active,.jxDisabled a.jxButtonDisclose:hover,.jxDisabled a.jxButtonDisclosePressed{cursor:default;background-position:right 0;}ul.jxToolbar .jxButtonHover{background-position:left -24px!important;}ul.jxToolbar .jxButtonHover span.jxButtonContent{background-position:right -24px!important;}.jxFlyout .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxFlyout{position:absolute;display:block;z-index:100;margin:0;padding:0;}.jxFlyoutContent{position:relative;display:block;overflow:auto;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}.jxButtonMulti,.jxButtonMulti span.jxButtonContent{background-image:url(images/button_multi.png);}.jxButtonEditCombo,.jxButtonEditCombo span.jxButtonContent{background-image:url(images/button_combo.png);}.jxButtonMulti span.jxButtonContent span{padding-right:21px;}.jxButtonEditCombo span.jxButtonContent span{font-size:0;}.jxButtonComboDefault span.jxButtonContent span,.jxButtonComboDefault input{font-style:italic;color:#999;}.jxButtonEditCombo input{float:left;line-height:16px;height:16px;padding:0 4px;margin:0;border:none;font-size:11px;font-family:Arial,Helvetica,sans-serif;background-color:transparent;}.jxChrome{position:absolute;display:block;font-size:0;line-height:0;z-index:-1;width:100%;height:100%;top:0;left:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxChromeDrag{opacity:.5;-ms-filter:"Alpha(opacity=50)";}.jxChromeTL{position:absolute;overflow:hidden;left:0;top:0;width:50%;height:50%;}.jxChromeTR{position:absolute;overflow:hidden;left:50%;top:0;width:50%;height:50%;}.jxChromeBL{position:absolute;overflow:hidden;left:0;top:50%;width:50%;height:50%;}.jxChromeBR{position:absolute;overflow:hidden;left:50%;top:50%;width:50%;height:50%;}.jxChromeTL img{position:absolute;top:0;left:0;width:1000px;height:600px;}.jxChromeTR img{position:absolute;top:0;right:0;width:1000px;height:600px;}.jxChromeBL img{position:absolute;bottom:0;left:0;width:1000px;height:600px;}.jxChromeBR img{position:absolute;bottom:0;right:0;width:1000px;height:600px;}.jxColorBar{position:relative;overflow:hidden;}table.jxColorGrid{position:relative;border-collapse:collapse;empty-cells:show;clear:both;padding:0;margin:0;}.jxColorGrid tr{padding:0;margin:0;}.jxColorGrid td{border:1px solid #000;padding:0;margin:0;}.jxColorGrid td.emptyCell{border:0 solid #000;}.jxColorGrid td.emptyCell span{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;padding:1px;margin:0;}.jxColorGrid a.colorSwatch{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;margin:0;padding:1px;}.jxColorGrid a.borderWhite:hover{border:1px solid #fff;padding:0;}.jxColorGrid a.borderBlack:hover{border:1px solid #000;padding:0;}input.jxHexInput{width:55px;vertical-align:middle;}input.jxAlphaInput{width:30px;vertical-align:middle;}div.jxColorPreview{float:left;position:relative;width:20px;height:20px;border:1px solid #000;margin:2px;vertical-align:middle;background-image:url('images/grid.png');overflow:hidden;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch{display:block;float:left;width:14px;height:14px;border:1px solid #000;background-image:url('images/grid.png');background-position:0 0;background-repeat:repeat;padding-right:0!important;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch span{display:block;width:14px;height:14px;position:absolute;padding-right:0;background:none;}div.jxColorPreview img{position:absolute;z-index:0;}div.jxColorPreview div{width:20px;height:10px;position:absolute;display:block;left:0;z-index:1;font-size:10px;line-height:0;}div.jxColorPreview div.jxColorSelected{top:0;}div.jxColorPreview div.jxColorHover{bottom:0;}label.jxColorLabel,label.jxAlphaLabel{width:auto;font-family:Arial,sans-serif;font-size:11px;line-height:24px;padding:2px;vertical-align:middle;}a.jxColorClose{position:absolute;top:0;right:0;width:16px;height:16px;}a.jxColorClose img{width:16px;height:16px;}.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}.jxDisabled{opacity:.4;-ms-filter:"Alpha(opacity=40)";}.jxDisabled *{-ms-filter:"Alpha(opacity=40)";}iframe.jxIframeShim{position:absolute;top:0;left:0;width:100%;height:100%;opacity:0;-ms-filter:"Alpha(opacity=0)";z-index:-1;}.jxConfirmQuestion{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;}.jxDialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogModal{position:absolute;display:block;top:0;left:0;width:100%;height:100%;background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bottom:8px;}.jxDialogMoveable,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollapse img{background-position:0 -16px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls span.jxButtonContent,.jxDialogControls .jxButton:hover span.jxButtonContent,.jxDialogControls .jxButton:active span.jxButtonContent,.jxDialogControls .jxButtonActive span.jxButtonContent,.jxDialogControls .jxButtonActive:hover span.jxButtonContent,.jxDialogControls .jxButtonActive:active span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDialogControls .jxDisabled .jxButton,.jxDialogControls .jxDisabled .jxButton:hover,.jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent,.jxDialogControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent span,.jxDialogControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{width:150px;}div.jxFileFake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:2px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0;z-index:2;margin-top:-5px;height:35px;}.jxForm{display:block;position:relative;overflow:hidden;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;overflow:hidden;border:1px solid #ccc;border-radius:10px;-moz-border-radius:10px;-webkit-border-radius:10px;-khtml-border-radius:10px;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInputLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.jxInputText,.jxInputPassword,.jxInputTextarea{margin:0 4px;padding:4px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus{border:1px solid #000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldInvalid .jxInputText,.jxFieldInvalid .jxInputPassword,.jxFieldInvalid .jxInputTextarea,.jxFieldInvalid .jxInputSelect{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;}.jxFieldValidated .jxInputText,.jxFieldValidated .jxInputPassword,.jxFieldValidated .jxInputTextarea,.jxFieldValidated .jxInputSelect{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldInvalid .jxInputText:focus,.jxFieldInvalid .jxInputPassword:focus,.jxFieldInvalid .jxInputTextarea:focus,.jxFieldInvalid .jxInputSelect:focus{border-color:#8a1f11;}.jxFieldValidated .jxInputText:focus,.jxFieldValidated .jxInputPassword:focus,.jxFieldValidated .jxInputTextarea:focus,.jxFieldValidated .jxInputSelect:focus{border-color:#264409;}.jxFieldInvalid .jxInputLabel,.jxFieldInvalid .jxInputTag{color:#8a1f11;}.jxFieldValidated .jxInputLabel,.jxFieldValidated .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInline .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxInputTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}.jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jxInputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInputContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;width:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormInlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridHeader{width:100%;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridColHeadHide{height:0;line-height:0;font-size:0;background-color:#fff;white-space:normal;}.jxGridColHeadHide p,.jxGridRowHeadHide p{font-size:0;line-height:0;height:0;margin:0;padding:0;}.jxGridRowHeadHide{width:0;white-space:normal;}.jxGridCell{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding-left:3px;padding-right:3px;overflow:hidden;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;font-weight:bold;color:#333;cursor:default;padding-left:3px;padding-right:3px;white-space:nowrap;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-position:0 0;background-repeat:repeat-y;text-align:center;font-weight:bold;color:#333;cursor:default;overflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td{background-color:#f7f7f7;}td.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td{background-color:#e5f1ff;}td.jxGridCellPrelight{background-color:#cce3ff;}.jxColSortable{padding-right:20px;}.jxGridCell.jxColSortable{padding-right:0;}.jxColSortable span{background-image:url('images/emblems.png');padding-right:20px;background-repeat:no-repeat;background-position:right top;}.jxGridColumnSortedAsc span{background-position:right -160px;}.jxGridColumnSortedDesc span{background-position:right -16px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-position:left -24px;}.jxListItem:focus{margin:0;border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed,.jxListView .jxSelected{margin:0;border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxMenuItem{display:block;position:relative;overflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a.jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabled a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisabled a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButtonSubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jxMenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.jxMenuItemIcon,.jxMenuItemSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background-repeat:repeat-x;background-position:left center;}.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-align:center;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16px;}.jxPanelMaximize img{background-position:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls span.jxButtonContent,.jxPanelControls .jxButton:hover span.jxButtonContent,.jxPanelControls .jxButton:active span.jxButtonContent,.jxPanelControls .jxButtonActive span.jxButtonContent,.jxPanelControls .jxButtonActive:hover span.jxButtonContent,.jxPanelControls .jxButtonActive:active span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonActive:hover,.jxPanelControls .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled .jxButton:hover,.jxPanelControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent,.jxPanelControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent span,.jxPanelControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}.jxProgressBar-container{width:100%;display:block;clear:both;}.jxProgressBar-message{color:black;}.jxProgressBar-container .jxProgressBar{width:100%;clear:both;border-top:none;}.jxProgressBar-container .jxProgressBar .jxProgressBar-outline{border:1px solid #360;position:absolute;top:0;left:0;z-index:10;}.jxProgressBar-container .jxProgressBar .jxProgressBar-fill{background-color:#9c6;position:absolute;top:1px;left:1px;z-index:20;}.jxProgressBar-container .jxProgressBar .jxProgressBar-text{color:#360;margin:0;padding:2px;position:absolute;top:1px;left:1px;width:auto;z-index:30;border:none;}.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag{background-color:#eee;}.jxSnapHorizontalBefore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxToolbarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}div.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:block;position:relative;cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-repeat;}img.jxTabIcon{position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxTabClose img{width:16px;height:16px;background-image:url(images/tab_close.png);}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisabled a.jxTabClose{cursor:default;}.jxBarTop div.jxTabContainer,.jxBarBottom div.jxTabContainer{float:left;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent{background-image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:3px;right:3px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{float:left;padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{float:left;padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:focus span.jxTabContent{background-position:right -96px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabContent{background-position:right -120px;}.jxBarTop .jxDisabled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBottom .jxDisabled a.jxTabActive:focus,.jxBarBottom .jxDisabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{float:left;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{float:left;height:16px;padding:0 4px 0 4px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(images/tab_left.png);}.jxBarRight a.jxTab,.jxBarRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:3px;left:3px;}.jxBarLeft .jxTabClose span.jxTabContent,.jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBarLeft a.jxTabActive:focus span.jxTabContent,.jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRight a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLeft .jxDisabled a.jxTabPressed,.jxBarRight .jxDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBarLeft .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top;}.jxBarLeft .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:auto;height:100%;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repeat:repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{position:absolute;width:10000%;overflow:hidden;}.jxBarTop .jxBarScrollLeft,.jxBarBottom .jxBarScrollLeft{position:absolute;top:0;left:0;}.jxBarTop .jxBarScrollRight,.jxBarBottom .jxBarScrollRight{position:absolute;top:0;right:0;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollRight img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -96px;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;padding:0;margin:0;border:none;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolbar_separator_v.png);}.jxBarLeft ul.jxToolbar,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTreeFolder,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:left top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTreeFolder li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 17px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 16px;background-position:left -72px;}a.jxTreeItem:hover,li.jxTreeContainer a.jxHover{border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -24px;}li.jxTreeContainer a.jxSelected,li.jxTreeContainer a.jxSelected:hover,li.jxTreeContainer a.jxPressed,li.jxTreeContainer a.jxPressed:hover{border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -48px;}li.jxDisabled a.jxTreeItem{cursor:default;}li.jxDisabled a.jxTreeItem:focus,li.jxDisabled a.jxTreeItem:hover{background-position:left top;background-color:transparent;border:none;margin:0 1px 0 17px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:2px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTreeBranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .jxTreeImage{background-position:left -60px;}.jxTreeLeafLast .jxTreeImage{background-position:left -120px;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}.jxFileUploadPanel{padding:5px;}.jxFileUploadPanel .jxInputContainer{width:300px;}.jxUploadQueue{width:100%;margin-top:10px;}.jxUploadQueue div{position:relative;width:95%;clear:both;border-top:1px solid black;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue div span.jxUploadFileName{float:left;font-size:16px;}.jxUploadQueue div span.jxUploadFileDelete,.jxUploadQueue div span.jxUploadFileProgress,.jxUploadQueue div span.jxUploadFileComplete,.jxUploadQueue div span.jxUploadFileError{float:right;width:16px;height:16px;background-repeat:no-repeat;background-position:top left;cursor:pointer;}.jxUploadQueue div span.jxUploadFileDelete{background-image:url('images/delete.gif');}.jxUploadQueue div span.jxUploadFileProgress{background-image:url('images/loading.gif');}.jxUploadQueue div span.jxUploadFileComplete{background-image:url('images/green_tick.png');}.jxUploadQueue div span.jxUploadFileError{background-image:url('images/error.png');}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/error.png") no-repeat left top;color:black;width:100px;}
\ No newline at end of file
+ */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:4px 4px 4px 0;border:none;background-image:url(images/button.png);background-position:right -24px;background-repeat:no-repeat;}ul.jxToolbar span.jxButtonContent{background-position:right top;}ul.jxToolbar .jxButtonActive,.jxButtonActive{background-position:left -72px;}ul.jxToolbar .jxButtonActive span.jxButtonContent,.jxButtonActive span.jxButtonContent{background-position:right -72px;}ul.jxToolbar .jxButton:focus,.jxButton:focus{background-position:left -96px;}ul.jxToolbar .jxButton:focus span.jxButtonContent,.jxButton:focus span.jxButtonContent{background-position:right -96px;}ul.jxToolbar .jxButtonActive:focus,.jxButtonActive:focus{background-position:left -144px;}ul.jxToolbar .jxButtonActive:focus span.jxButtonContent,.jxButtonActive:focus span.jxButtonContent{background-position:right -144px;}ul.jxToolbar .jxButton:hover,ul.jxToolbar .jxButtonActive:hover,.jxButton:hover,.jxButtonActive:hover{background-position:left -48px;}ul.jxToolbar .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxButtonActive:hover span.jxButtonContent,.jxButton:hover span.jxButtonContent,.jxButtonActive:hover span.jxButtonContent{background-position:right -48px;}ul.jxToolbar .jxButtonPressed,ul.jxToolbar .jxButtonPressed:focus,.jxButtonPressed,.jxButtonPressed:focus{background-position:left -120px;}ul.jxToolbar .jxButtonPressed span.jxButtonContent,ul.jxToolbar .jxButtonPressed:focus span.jxButtonContent,.jxButtonPressed span.jxButtonContent,.jxButtonPressed:focus span.jxButtonContent{background-position:right -120px;}.jxDisabled .jxButton,.jxDisabled span.jxButtonContent span{cursor:default;}ul.jxToolbar .jxDisabled .jxButton:focus,ul.jxToolbar .jxDisabled .jxButton:active,ul.jxToolbar .jxDisabled .jxButton:hover,ul.jxToolbar .jxDisabled .jxButtonPressed{background-position:left top;}.jxDisabled .jxButton:focus,.jxDisabled .jxButton:active,.jxDisabled .jxButton:hover,.jxDisabled .jxButtonPressed{background-position:left -24px;}ul.jxToolbar .jxDisabled .jxButton:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right top;}.jxDisabled .jxButton:focus span.jxButtonContent,.jxDisabled .jxButton:active span.jxButtonContent,.jxDisabled .jxButton:hover span.jxButtonContent,.jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right -24px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus,ul.jxToolbar .jxDisabled .jxButtonActive:active,ul.jxToolbar .jxDisabled .jxButtonActive:hover,.jxDisabled .jxButtonActive:focus,.jxDisabled .jxButtonActive:active,.jxDisabled .jxButtonActive:hover{background-position:left -72px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:hover span.jxButtonContent,.jxDisabled .jxButtonActive:focus span.jxButtonContent,.jxDisabled .jxButtonActive:active span.jxButtonContent,.jxDisabled .jxButtonActive:hover span.jxButtonContent{background-position:right -72px;}img.jxButtonIcon{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxButtonContent span{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;cursor:pointer;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;height:16px;white-space:nowrap;}span.jxButtonContent span.jxButtonLabel{margin:0;padding:0 4px 0 4px;color:#000;font-size:11px;}.jxButtonMenu span.jxButtonContent,.jxButtonMulti span.jxButtonContent,.jxButtonFlyout span.jxButtonContent,.jxButtonCombo span.jxButtonContent,.jxButtonEditCombo span.jxButtonContent{padding-right:0;}.jxButtonMenu span.jxButtonContent span,.jxButtonFlyout span.jxButtonContent span,.jxButtonMulti span.jxButtonContent span,.jxButtonCombo span.jxButtonContent span,.jxButtonEditCombo span.jxButtonContent span{padding-right:16px;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose{position:absolute;display:-moz-inline-box;display:inline-block;padding:4px 0;font-size:0;line-height:0;right:2px;top:2px;background-image:url(images/button_multi_disclose.png);background-position:right 0;background-repeat:no-repeat;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxButtonDisclose img{width:16px;height:16px;margin:0;padding:0;border:0;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose:focus,a.jxButtonDisclose:active{background-position:right -96px;}a.jxButtonDisclose:hover{background-position:right -48px;}a.jxButtonDisclosePressed{background-position:right -120px;}.jxDisabled a.jxButtonDisclose,.jxDisabled a.jxButtonDisclose:focus,.jxDisabled a.jxButtonDisclose:active,.jxDisabled a.jxButtonDisclose:hover,.jxDisabled a.jxButtonDisclosePressed{cursor:default;background-position:right 0;}ul.jxToolbar .jxButtonHover{background-position:left -24px!important;}ul.jxToolbar .jxButtonHover span.jxButtonContent{background-position:right -24px!important;}.jxFlyout .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxFlyout{position:absolute;display:block;z-index:100;margin:0;padding:0;}.jxFlyoutContent{position:relative;display:block;overflow:auto;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}.jxButtonMulti,.jxButtonMulti span.jxButtonContent{background-image:url(images/button_multi.png);}.jxButtonEditCombo,.jxButtonEditCombo span.jxButtonContent{background-image:url(images/button_combo.png);}.jxButtonMulti span.jxButtonContent span{padding-right:21px;}.jxButtonEditCombo span.jxButtonContent span{font-size:0;}.jxButtonComboDefault span.jxButtonContent span,.jxButtonComboDefault input{font-style:italic;color:#999;}.jxButtonEditCombo input{float:left;line-height:16px;height:16px;padding:0 4px;margin:0;border:none;font-size:11px;font-family:Arial,Helvetica,sans-serif;background-color:transparent;}.jxChrome{position:absolute;display:block;font-size:0;line-height:0;z-index:-1;width:100%;height:100%;top:0;left:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxChromeDrag{opacity:.5;-ms-filter:"Alpha(opacity=50)";}.jxChromeTL{position:absolute;overflow:hidden;left:0;top:0;width:50%;height:50%;}.jxChromeTR{position:absolute;overflow:hidden;left:50%;top:0;width:50%;height:50%;}.jxChromeBL{position:absolute;overflow:hidden;left:0;top:50%;width:50%;height:50%;}.jxChromeBR{position:absolute;overflow:hidden;left:50%;top:50%;width:50%;height:50%;}.jxChromeTL img{position:absolute;top:0;left:0;width:1000px;height:600px;}.jxChromeTR img{position:absolute;top:0;right:0;width:1000px;height:600px;}.jxChromeBL img{position:absolute;bottom:0;left:0;width:1000px;height:600px;}.jxChromeBR img{position:absolute;bottom:0;right:0;width:1000px;height:600px;}.jxColorBar{position:relative;overflow:hidden;}table.jxColorGrid{position:relative;border-collapse:collapse;empty-cells:show;clear:both;padding:0;margin:0;}.jxColorGrid tr{padding:0;margin:0;}.jxColorGrid td{border:1px solid #000;padding:0;margin:0;}.jxColorGrid td.emptyCell{border:0 solid #000;}.jxColorGrid td.emptyCell span{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;padding:1px;margin:0;}.jxColorGrid a.colorSwatch{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;margin:0;padding:1px;}.jxColorGrid a.borderWhite:hover{border:1px solid #fff;padding:0;}.jxColorGrid a.borderBlack:hover{border:1px solid #000;padding:0;}input.jxHexInput{width:55px;vertical-align:middle;}input.jxAlphaInput{width:30px;vertical-align:middle;}div.jxColorPreview{float:left;position:relative;width:20px;height:20px;border:1px solid #000;margin:2px;vertical-align:middle;background-image:url('images/grid.png');overflow:hidden;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch{display:block;float:left;width:14px;height:14px;border:1px solid #000;background-image:url('images/grid.png');background-position:0 0;background-repeat:repeat;padding-right:0!important;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch span{display:block;width:14px;height:14px;position:absolute;padding-right:0;background:none;}div.jxColorPreview img{position:absolute;z-index:0;}div.jxColorPreview div{width:20px;height:10px;position:absolute;display:block;left:0;z-index:1;font-size:10px;line-height:0;}div.jxColorPreview div.jxColorSelected{top:0;}div.jxColorPreview div.jxColorHover{bottom:0;}label.jxColorLabel,label.jxAlphaLabel{width:auto;font-family:Arial,sans-serif;font-size:11px;line-height:24px;padding:2px;vertical-align:middle;}a.jxColorClose{position:absolute;top:0;right:0;width:16px;height:16px;}a.jxColorClose img{width:16px;height:16px;}.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}.jxDisabled{opacity:.4;-ms-filter:"Alpha(opacity=40)";}.jxDisabled *{-ms-filter:"Alpha(opacity=40)";}iframe.jxIframeShim{position:absolute;top:0;left:0;width:100%;height:100%;opacity:0;-ms-filter:"Alpha(opacity=0)";z-index:-1;}.jxConfirmQuestion{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;}.jxDialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogModal{position:absolute;display:block;top:0;left:0;width:100%;height:100%;background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bottom:8px;}.jxDialogMoveable,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollapse img{background-position:0 -16px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls span.jxButtonContent,.jxDialogControls .jxButton:hover span.jxButtonContent,.jxDialogControls .jxButton:active span.jxButtonContent,.jxDialogControls .jxButtonActive span.jxButtonContent,.jxDialogControls .jxButtonActive:hover span.jxButtonContent,.jxDialogControls .jxButtonActive:active span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDialogControls .jxDisabled .jxButton,.jxDialogControls .jxDisabled .jxButton:hover,.jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent,.jxDialogControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent span,.jxDialogControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{width:150px;}div.jxFileFake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:2px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0;z-index:2;margin-top:-5px;height:35px;}.jxForm{display:block;position:relative;overflow:hidden;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;overflow:hidden;border:1px solid #ccc;border-radius:10px;-moz-border-radius:10px;-webkit-border-radius:10px;-khtml-border-radius:10px;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInputLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.jxInputText,.jxInputPassword,.jxInputTextarea{margin:0 4px;padding:4px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus{border:1px solid #000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldInvalid .jxInputText,.jxFieldInvalid .jxInputPassword,.jxFieldInvalid .jxInputTextarea,.jxFieldInvalid .jxInputSelect{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;}.jxFieldValidated .jxInputText,.jxFieldValidated .jxInputPassword,.jxFieldValidated .jxInputTextarea,.jxFieldValidated .jxInputSelect{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldInvalid .jxInputText:focus,.jxFieldInvalid .jxInputPassword:focus,.jxFieldInvalid .jxInputTextarea:focus,.jxFieldInvalid .jxInputSelect:focus{border-color:#8a1f11;}.jxFieldValidated .jxInputText:focus,.jxFieldValidated .jxInputPassword:focus,.jxFieldValidated .jxInputTextarea:focus,.jxFieldValidated .jxInputSelect:focus{border-color:#264409;}.jxFieldInvalid .jxInputLabel,.jxFieldInvalid .jxInputTag{color:#8a1f11;}.jxFieldValidated .jxInputLabel,.jxFieldValidated .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInline .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxInputTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}.jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jxInputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInputContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;width:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormInlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridHeader{width:100%;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridColHeadHide{height:0;line-height:0;font-size:0;background-color:#fff;white-space:normal;}.jxGridColHeadHide p,.jxGridRowHeadHide p{font-size:0;line-height:0;height:0;margin:0;padding:0;}.jxGridRowHeadHide{width:0;white-space:normal;}.jxGridCell{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding-left:3px;padding-right:3px;overflow:hidden;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;font-weight:bold;color:#333;cursor:default;padding-left:3px;padding-right:3px;white-space:nowrap;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-position:0 0;background-repeat:repeat-y;text-align:center;font-weight:bold;color:#333;cursor:default;overflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td{background-color:#f7f7f7;}td.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td{background-color:#e5f1ff;}td.jxGridCellPrelight{background-color:#cce3ff;}.jxColSortable{padding-right:20px;}.jxGridCell.jxColSortable{padding-right:0;}.jxColSortable span{background-image:url('images/emblems.png');padding-right:20px;background-repeat:no-repeat;background-position:right top;}.jxGridColumnSortedAsc span{background-position:right -160px;}.jxGridColumnSortedDesc span{background-position:right -16px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-position:left -24px;}.jxListItem:focus{margin:0;border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed,.jxListView .jxSelected{margin:0;border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxMenuItem{display:block;position:relative;overflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a.jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabled a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisabled a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButtonSubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jxMenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.jxMenuItemIcon,.jxMenuItemSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background-repeat:repeat-x;background-position:left center;}.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxNotificationContainer{border:1px black solid;padding:2px;}.jxNotificationMinimize{width:100%;height:10px;margin:2px;background-color:blue;cursor:pointer;display:block;}.jxNotice{margin:5 auto;border:1px solid black;position:relative;display:block;}.jxNoticeClose{float:right;width:15px;height:15px;background-color:black;cursor:pointer;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-align:center;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16px;}.jxPanelMaximize img{background-position:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls span.jxButtonContent,.jxPanelControls .jxButton:hover span.jxButtonContent,.jxPanelControls .jxButton:active span.jxButtonContent,.jxPanelControls .jxButtonActive span.jxButtonContent,.jxPanelControls .jxButtonActive:hover span.jxButtonContent,.jxPanelControls .jxButtonActive:active span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonActive:hover,.jxPanelControls .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled .jxButton:hover,.jxPanelControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent,.jxPanelControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent span,.jxPanelControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}.jxProgressBar-container{width:100%;display:block;clear:both;}.jxProgressBar-message{color:black;}.jxProgressBar-container .jxProgressBar{width:100%;clear:both;border-top:none;}.jxProgressBar-container .jxProgressBar .jxProgressBar-outline{border:1px solid #360;position:absolute;top:0;left:0;z-index:10;}.jxProgressBar-container .jxProgressBar .jxProgressBar-fill{background-color:#9c6;position:absolute;top:1px;left:1px;z-index:20;}.jxProgressBar-container .jxProgressBar .jxProgressBar-text{color:#360;margin:0;padding:2px;position:absolute;top:1px;left:1px;width:auto;z-index:30;border:none;}.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag{background-color:#eee;}.jxSnapHorizontalBefore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxToolbarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}div.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:block;position:relative;cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-repeat;}img.jxTabIcon{position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxTabClose img{width:16px;height:16px;background-image:url(images/tab_close.png);}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisabled a.jxTabClose{cursor:default;}.jxBarTop div.jxTabContainer,.jxBarBottom div.jxTabContainer{float:left;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent{background-image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:3px;right:3px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{float:left;padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{float:left;padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:focus span.jxTabContent{background-position:right -96px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabContent{background-position:right -120px;}.jxBarTop .jxDisabled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBottom .jxDisabled a.jxTabActive:focus,.jxBarBottom .jxDisabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{float:left;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{float:left;height:16px;padding:0 4px 0 4px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(images/tab_left.png);}.jxBarRight a.jxTab,.jxBarRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:3px;left:3px;}.jxBarLeft .jxTabClose span.jxTabContent,.jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBarLeft a.jxTabActive:focus span.jxTabContent,.jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRight a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLeft .jxDisabled a.jxTabPressed,.jxBarRight .jxDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBarLeft .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top;}.jxBarLeft .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:auto;height:100%;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repeat:repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{position:absolute;width:10000%;overflow:hidden;}.jxBarTop .jxBarScrollLeft,.jxBarBottom .jxBarScrollLeft{position:absolute;top:0;left:0;}.jxBarTop .jxBarScrollRight,.jxBarBottom .jxBarScrollRight{position:absolute;top:0;right:0;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollRight img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -96px;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;padding:0;margin:0;border:none;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolbar_separator_v.png);}.jxBarLeft ul.jxToolbar,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTree,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:left top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTree li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 17px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 16px;background-position:left -72px;}a.jxTreeItem:hover,li.jxTreeContainer a.jxHover{border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -24px;}li.jxTreeContainer a.jxSelected,li.jxTreeContainer a.jxSelected:hover,li.jxTreeContainer a.jxPressed,li.jxTreeContainer a.jxPressed:hover{border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -48px;}li.jxDisabled a.jxTreeItem{cursor:default;}li.jxDisabled a.jxTreeItem:focus,li.jxDisabled a.jxTreeItem:hover{background-position:left top;background-color:transparent;border:none;margin:0 1px 0 17px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:2px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTreeBranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .jxTreeImage{background-position:left -60px;}.jxTreeLeafLast .jxTreeImage{background-position:left -120px;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}.jxFileUploadPanel{padding:5px;}.jxFileUploadPanel .jxInputContainer{width:300px;}.jxUploadQueue{width:100%;margin-top:10px;}.jxUploadQueue div{position:relative;width:95%;clear:both;border-top:1px solid black;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue div span.jxUploadFileName{float:left;font-size:16px;}.jxUploadQueue div span.jxUploadFileDelete,.jxUploadQueue div span.jxUploadFileProgress,.jxUploadQueue div span.jxUploadFileComplete,.jxUploadQueue div span.jxUploadFileError{float:right;width:16px;height:16px;background-repeat:no-repeat;background-position:top left;cursor:pointer;}.jxUploadQueue div span.jxUploadFileDelete{background-image:url('images/delete.gif');}.jxUploadQueue div span.jxUploadFileProgress{background-image:url('images/loading.gif');}.jxUploadQueue div span.jxUploadFileComplete{background-image:url('images/green_tick.png');}.jxUploadQueue div span.jxUploadFileError{background-image:url('images/error.png');}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/error.png") no-repeat left top;color:black;width:100px;}
Modified: sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.uncompressed.css
--- sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.uncompressed.css 2009-11-05 21:59:29 UTC (rev 1964)
+++ sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.uncompressed.css 2009-11-06 16:05:28 UTC (rev 1965)
@@ -1877,6 +1877,33 @@
text-align: center;
padding: 10px;
margin-top: 10px;
+}.jxNotificationContainer {
+ border: 1px black solid;
+ padding: 2px;
+.jxNotificationMinimize {
+ width: 100%;
+ height: 10px;
+ margin: 2px;
+ background-color: blue;
+ cursor: pointer;
+ display: block;
+.jxNotice {
+ margin: 5 auto;
+ border: 1px solid black;
+ position: relative;
+ display: block;
+.jxNoticeClose {
+ float: right;
+ width: 15px;
+ height: 15px;
+ background-color: black;
+ cursor: pointer;
* @project Jx
* @revision $Id: panel.css 302 2009-04-02 18:42:56Z fred.warnock $
@@ -2959,7 +2986,7 @@
* @project Jx
- * @revision $Id: tree.css 535 2009-09-28 18:47:18Z fred.warnock $
+ * @revision $Id: tree.css 586 2009-11-05 20:34:17Z pagameba $
* @author Fred Warnock (fwarnock at dmsolutions.ca)
* @copyright (c) 2006 DM Solutions Group Inc.
@@ -2974,7 +3001,7 @@
-.jxTreeFolder,
+.jxTree,
.jxTreeRoot {
/* relative positioning is required for IE to fix the peek-a-boo bug */
position:relative;
@@ -3011,7 +3038,7 @@
-khtml-user-select: none;
-.jxTreeFolder li.jxTreeContainer {
+.jxTree li.jxTreeContainer {
margin-left: 16px;
Modified: sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.css
--- sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.css 2009-11-05 21:59:29 UTC (rev 1964)
+++ sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.css 2009-11-06 16:05:28 UTC (rev 1965)
@@ -21,4 +21,4 @@
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
- */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:4px 4px 4px 0;border:none;background-image:url(images/button.png);background-position:right -24px;background-repeat:no-repeat;}ul.jxToolbar span.jxButtonContent{background-position:right top;}ul.jxToolbar .jxButtonActive,.jxButtonActive{background-position:left -72px;}ul.jxToolbar .jxButtonActive span.jxButtonContent,.jxButtonActive span.jxButtonContent{background-position:right -72px;}ul.jxToolbar .jxButton:focus,.jxButton:focus{background-position:left -96px;}ul.jxToolbar .jxButton:focus span.jxButtonContent,.jxButton:focus span.jxButtonContent{background-position:right -96px;}ul.jxToolbar .jxButtonActive:focus,.jxButtonActive:focus{background-position:left -144px;}ul.jxToolbar .jxButtonActive:focus span.jxButtonContent,.jxButtonActive:focus span.jxButtonContent{background-position:right -144px;}ul.jxToolbar .jxButton:hover,ul.jxToolbar .jxButtonActive:hover,.jxButton:hover,.jxButtonActive:hover{background-position:left -48px;}ul.jxToolbar .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxButtonActive:hover span.jxButtonContent,.jxButton:hover span.jxButtonContent,.jxButtonActive:hover span.jxButtonContent{background-position:right -48px;}ul.jxToolbar .jxButtonPressed,ul.jxToolbar .jxButtonPressed:focus,.jxButtonPressed,.jxButtonPressed:focus{background-position:left -120px;}ul.jxToolbar .jxButtonPressed span.jxButtonContent,ul.jxToolbar .jxButtonPressed:focus span.jxButtonContent,.jxButtonPressed span.jxButtonContent,.jxButtonPressed:focus span.jxButtonContent{background-position:right -120px;}.jxDisabled .jxButton,.jxDisabled span.jxButtonContent span{cursor:default;}ul.jxToolbar .jxDisabled .jxButton:focus,ul.jxToolbar .jxDisabled .jxButton:active,ul.jxToolbar .jxDisabled .jxButton:hover,ul.jxToolbar .jxDisabled .jxButtonPressed{background-position:left top;}.jxDisabled .jxButton:focus,.jxDisabled .jxButton:active,.jxDisabled .jxButton:hover,.jxDisabled .jxButtonPressed{background-position:left -24px;}ul.jxToolbar .jxDisabled .jxButton:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right top;}.jxDisabled .jxButton:focus span.jxButtonContent,.jxDisabled .jxButton:active span.jxButtonContent,.jxDisabled .jxButton:hover span.jxButtonContent,.jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right -24px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus,ul.jxToolbar .jxDisabled .jxButtonActive:active,ul.jxToolbar .jxDisabled .jxButtonActive:hover,.jxDisabled .jxButtonActive:focus,.jxDisabled .jxButtonActive:active,.jxDisabled .jxButtonActive:hover{background-position:left -72px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:hover span.jxButtonContent,.jxDisabled .jxButtonActive:focus span.jxButtonContent,.jxDisabled .jxButtonActive:active span.jxButtonContent,.jxDisabled .jxButtonActive:hover span.jxButtonContent{background-position:right -72px;}img.jxButtonIcon{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxButtonContent span{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;cursor:pointer;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;height:16px;white-space:nowrap;}span.jxButtonContent span.jxButtonLabel{margin:0;padding:0 4px 0 4px;color:#000;font-size:11px;}.jxButtonMenu span.jxButtonContent,.jxButtonMulti span.jxButtonContent,.jxButtonFlyout span.jxButtonContent,.jxButtonCombo span.jxButtonContent,.jxButtonEditCombo span.jxButtonContent{padding-right:0;}.jxButtonMenu span.jxButtonContent span,.jxButtonFlyout span.jxButtonContent span,.jxButtonMulti span.jxButtonContent span,.jxButtonCombo span.jxButtonContent span,.jxButtonEditCombo span.jxButtonContent span{padding-right:16px;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose{position:absolute;display:-moz-inline-box;display:inline-block;padding:4px 0;font-size:0;line-height:0;right:2px;top:2px;background-image:url(images/button_multi_disclose.png);background-position:right 0;background-repeat:no-repeat;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxButtonDisclose img{width:16px;height:16px;margin:0;padding:0;border:0;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose:focus,a.jxButtonDisclose:active{background-position:right -96px;}a.jxButtonDisclose:hover{background-position:right -48px;}a.jxButtonDisclosePressed{background-position:right -120px;}.jxDisabled a.jxButtonDisclose,.jxDisabled a.jxButtonDisclose:focus,.jxDisabled a.jxButtonDisclose:active,.jxDisabled a.jxButtonDisclose:hover,.jxDisabled a.jxButtonDisclosePressed{cursor:default;background-position:right 0;}ul.jxToolbar .jxButtonHover{background-position:left -24px!important;}ul.jxToolbar .jxButtonHover span.jxButtonContent{background-position:right -24px!important;}.jxFlyout .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxFlyout{position:absolute;display:block;z-index:100;margin:0;padding:0;}.jxFlyoutContent{position:relative;display:block;overflow:auto;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}.jxButtonMulti,.jxButtonMulti span.jxButtonContent{background-image:url(images/button_multi.png);}.jxButtonEditCombo,.jxButtonEditCombo span.jxButtonContent{background-image:url(images/button_combo.png);}.jxButtonMulti span.jxButtonContent span{padding-right:21px;}.jxButtonEditCombo span.jxButtonContent span{font-size:0;}.jxButtonComboDefault span.jxButtonContent span,.jxButtonComboDefault input{font-style:italic;color:#999;}.jxButtonEditCombo input{float:left;line-height:16px;height:16px;padding:0 4px;margin:0;border:none;font-size:11px;font-family:Arial,Helvetica,sans-serif;background-color:transparent;}.jxChrome{position:absolute;display:block;font-size:0;line-height:0;z-index:-1;width:100%;height:100%;top:0;left:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxChromeDrag{opacity:.5;-ms-filter:"Alpha(opacity=50)";}.jxChromeTL{position:absolute;overflow:hidden;left:0;top:0;width:50%;height:50%;}.jxChromeTR{position:absolute;overflow:hidden;left:50%;top:0;width:50%;height:50%;}.jxChromeBL{position:absolute;overflow:hidden;left:0;top:50%;width:50%;height:50%;}.jxChromeBR{position:absolute;overflow:hidden;left:50%;top:50%;width:50%;height:50%;}.jxChromeTL img{position:absolute;top:0;left:0;width:1000px;height:600px;}.jxChromeTR img{position:absolute;top:0;right:0;width:1000px;height:600px;}.jxChromeBL img{position:absolute;bottom:0;left:0;width:1000px;height:600px;}.jxChromeBR img{position:absolute;bottom:0;right:0;width:1000px;height:600px;}.jxColorBar{position:relative;overflow:hidden;}table.jxColorGrid{position:relative;border-collapse:collapse;empty-cells:show;clear:both;padding:0;margin:0;}.jxColorGrid tr{padding:0;margin:0;}.jxColorGrid td{border:1px solid #000;padding:0;margin:0;}.jxColorGrid td.emptyCell{border:0 solid #000;}.jxColorGrid td.emptyCell span{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;padding:1px;margin:0;}.jxColorGrid a.colorSwatch{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;margin:0;padding:1px;}.jxColorGrid a.borderWhite:hover{border:1px solid #fff;padding:0;}.jxColorGrid a.borderBlack:hover{border:1px solid #000;padding:0;}input.jxHexInput{width:55px;vertical-align:middle;}input.jxAlphaInput{width:30px;vertical-align:middle;}div.jxColorPreview{float:left;position:relative;width:20px;height:20px;border:1px solid #000;margin:2px;vertical-align:middle;background-image:url('images/grid.png');overflow:hidden;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch{display:block;float:left;width:14px;height:14px;border:1px solid #000;background-image:url('images/grid.png');background-position:0 0;background-repeat:repeat;padding-right:0!important;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch span{display:block;width:14px;height:14px;position:absolute;padding-right:0;background:none;}div.jxColorPreview img{position:absolute;z-index:0;}div.jxColorPreview div{width:20px;height:10px;position:absolute;display:block;left:0;z-index:1;font-size:10px;line-height:0;}div.jxColorPreview div.jxColorSelected{top:0;}div.jxColorPreview div.jxColorHover{bottom:0;}label.jxColorLabel,label.jxAlphaLabel{width:auto;font-family:Arial,sans-serif;font-size:11px;line-height:24px;padding:2px;vertical-align:middle;}a.jxColorClose{position:absolute;top:0;right:0;width:16px;height:16px;}a.jxColorClose img{width:16px;height:16px;}.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}.jxDisabled{opacity:.4;-ms-filter:"Alpha(opacity=40)";}.jxDisabled *{-ms-filter:"Alpha(opacity=40)";}iframe.jxIframeShim{position:absolute;top:0;left:0;width:100%;height:100%;opacity:0;-ms-filter:"Alpha(opacity=0)";z-index:-1;}@CHARSET "ISO-8859-1";.jxConfirmQuestion{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;}.jxDialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogModal{position:absolute;display:block;top:0;left:0;width:100%;height:100%;background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bottom:8px;}.jxDialogMoveable,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollapse img{background-position:0 -16px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls span.jxButtonContent,.jxDialogControls .jxButton:hover span.jxButtonContent,.jxDialogControls .jxButton:active span.jxButtonContent,.jxDialogControls .jxButtonActive span.jxButtonContent,.jxDialogControls .jxButtonActive:hover span.jxButtonContent,.jxDialogControls .jxButtonActive:active span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDialogControls .jxDisabled .jxButton,.jxDialogControls .jxDisabled .jxButton:hover,.jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent,.jxDialogControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent span,.jxDialogControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{width:150px;}div.jxFileFake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:6px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0;z-index:2;margin-top:3px;height:35px;width:100%;}.jxForm{display:block;position:relative;overflow:hidden;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;overflow:hidden;border:1px solid #ccc;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInputLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.jxInputText,.jxInputPassword,.jxInputTextarea{margin:0 4px;padding:4px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus{border:1px solid #000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldInvalid .jxInputText,.jxFieldInvalid .jxInputPassword,.jxFieldInvalid .jxInputTextarea,.jxFieldInvalid .jxInputSelect{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;}.jxFieldValidated .jxInputText,.jxFieldValidated .jxInputPassword,.jxFieldValidated .jxInputTextarea,.jxFieldValidated .jxInputSelect{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldInvalid .jxInputText:focus,.jxFieldInvalid .jxInputPassword:focus,.jxFieldInvalid .jxInputTextarea:focus,.jxFieldInvalid .jxInputSelect:focus{border-color:#8a1f11;}.jxFieldValidated .jxInputText:focus,.jxFieldValidated .jxInputPassword:focus,.jxFieldValidated .jxInputTextarea:focus,.jxFieldValidated .jxInputSelect:focus{border-color:#264409;}.jxFieldInvalid .jxInputLabel,.jxFieldInvalid .jxInputTag{color:#8a1f11;}.jxFieldValidated .jxInputLabel,.jxFieldValidated .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInline .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxInputTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}.jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jxInputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInputContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;width:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormInlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridHeader{width:100%;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridColHeadHide{height:0;line-height:0;font-size:0;background-color:#fff;white-space:normal;}.jxGridColHeadHide p,.jxGridRowHeadHide p{font-size:0;line-height:0;height:0;margin:0;padding:0;}.jxGridRowHeadHide{width:0;white-space:normal;}.jxGridCell{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding-left:3px;padding-right:3px;overflow:hidden;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;font-weight:bold;color:#333;cursor:default;padding-left:3px;padding-right:3px;white-space:nowrap;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-position:0 0;background-repeat:repeat-y;text-align:center;font-weight:bold;color:#333;cursor:default;overflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td{background-color:#f7f7f7;}td.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td{background-color:#e5f1ff;}td.jxGridCellPrelight{background-color:#cce3ff;}.jxColSortable{padding-right:20px;}.jxGridCell.jxColSortable{padding-right:0;}.jxColSortable span{background-image:url('images/emblems.png');padding-right:20px;background-repeat:no-repeat;background-position:right top;}.jxGridColumnSortedAsc span{background-position:right -160px;}.jxGridColumnSortedDesc span{background-position:right -16px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-position:left -24px;}.jxListItem:focus{margin:0;border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed,.jxListView .jxSelected{margin:0;border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxMenuItem{display:block;position:relative;overflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a.jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabled a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisabled a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButtonSubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jxMenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.jxMenuItemIcon,.jxMenuItemSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background-repeat:repeat-x;background-position:left center;}@CHARSET "ISO-8859-1";.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-align:center;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16px;}.jxPanelMaximize img{background-position:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls span.jxButtonContent,.jxPanelControls .jxButton:hover span.jxButtonContent,.jxPanelControls .jxButton:active span.jxButtonContent,.jxPanelControls .jxButtonActive span.jxButtonContent,.jxPanelControls .jxButtonActive:hover span.jxButtonContent,.jxPanelControls .jxButtonActive:active span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonActive:hover,.jxPanelControls .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled .jxButton:hover,.jxPanelControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent,.jxPanelControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent span,.jxPanelControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}@CHARSET "ISO-8859-1";.jxProgressBar-container{width:100%;display:block;clear:both;}.jxProgressBar-message{color:black;}.jxProgressBar-container .jxProgressBar{width:100%;clear:both;border-top:none;}.jxProgressBar-container .jxProgressBar .jxProgressBar-outline{border:1px solid #360;position:absolute;top:0;left:0;z-index:10;}.jxProgressBar-container .jxProgressBar .jxProgressBar-fill{background-color:#9c6;position:absolute;top:1px;left:1px;z-index:20;}.jxProgressBar-container .jxProgressBar .jxProgressBar-text{color:#360;margin:0;padding:2px;position:absolute;top:1px;left:1px;width:auto;z-index:30;border:none;}@CHARSET "ISO-8859-1";.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag{background-color:#eee;}.jxSnapHorizontalBefore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxToolbarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}div.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:block;position:relative;cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-repeat;}img.jxTabIcon{position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxTabClose img{width:16px;height:16px;background-image:url(images/tab_close.png);}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisabled a.jxTabClose{cursor:default;}.jxBarTop div.jxTabContainer,.jxBarBottom div.jxTabContainer{float:left;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent{background-image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:3px;right:3px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{float:left;padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{float:left;padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:focus span.jxTabContent{background-position:right -96px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabContent{background-position:right -120px;}.jxBarTop .jxDisabled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBottom .jxDisabled a.jxTabActive:focus,.jxBarBottom .jxDisabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{float:left;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{float:left;height:16px;padding:0 4px 0 4px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(images/tab_left.png);}.jxBarRight a.jxTab,.jxBarRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:3px;left:3px;}.jxBarLeft .jxTabClose span.jxTabContent,.jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBarLeft a.jxTabActive:focus span.jxTabContent,.jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRight a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLeft .jxDisabled a.jxTabPressed,.jxBarRight .jxDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBarLeft .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top;}.jxBarLeft .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:auto;height:100%;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repeat:repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{position:absolute;width:10000%;overflow:hidden;}.jxBarTop .jxBarScrollLeft,.jxBarBottom .jxBarScrollLeft{position:absolute;top:0;left:0;}.jxBarTop .jxBarScrollRight,.jxBarBottom .jxBarScrollRight{position:absolute;top:0;right:0;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollRight img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -96px;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;padding:0;margin:0;border:none;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolbar_separator_v.png);}.jxBarLeft ul.jxToolbar,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTreeFolder,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:left top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTreeFolder li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 17px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 16px;background-position:left -72px;}a.jxTreeItem:hover,li.jxTreeContainer a.jxHover{border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -24px;}li.jxTreeContainer a.jxSelected,li.jxTreeContainer a.jxSelected:hover,li.jxTreeContainer a.jxPressed,li.jxTreeContainer a.jxPressed:hover{border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -48px;}li.jxDisabled a.jxTreeItem{cursor:default;}li.jxDisabled a.jxTreeItem:focus,li.jxDisabled a.jxTreeItem:hover{background-position:left top;background-color:transparent;border:none;margin:0 1px 0 17px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:2px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTreeBranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .jxTreeImage{background-position:left -60px;}.jxTreeLeafLast .jxTreeImage{background-position:left -120px;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}.jxFileUploadPanel{padding:5px;}.jxFileUploadPanel .jxInputContainer{width:300px;}.jxUploadQueue{width:100%;margin-top:10px;}.jxUploadQueue div{position:relative;width:95%;clear:both;border-top:1px solid black;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue div span.jxUploadFileName{float:left;font-size:16px;}.jxUploadQueue div span.jxUploadFileDelete,.jxUploadQueue div span.jxUploadFileProgress,.jxUploadQueue div span.jxUploadFileComplete,.jxUploadQueue div span.jxUploadFileError{float:right;width:16px;height:16px;background-repeat:no-repeat;background-position:top left;cursor:pointer;}.jxUploadQueue div span.jxUploadFileDelete{background-image:url('images/delete.gif');}.jxUploadQueue div span.jxUploadFileProgress{background-image:url('images/loading.gif');}.jxUploadQueue div span.jxUploadFileComplete{background-image:url('images/green_tick.png');}.jxUploadQueue div span.jxUploadFileError{background-image:url('images/error.png');}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/error.png") no-repeat left top;color:black;width:100px;}
\ No newline at end of file
+ */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:4px 4px 4px 0;border:none;background-image:url(images/button.png);background-position:right -24px;background-repeat:no-repeat;}ul.jxToolbar span.jxButtonContent{background-position:right top;}ul.jxToolbar .jxButtonActive,.jxButtonActive{background-position:left -72px;}ul.jxToolbar .jxButtonActive span.jxButtonContent,.jxButtonActive span.jxButtonContent{background-position:right -72px;}ul.jxToolbar .jxButton:focus,.jxButton:focus{background-position:left -96px;}ul.jxToolbar .jxButton:focus span.jxButtonContent,.jxButton:focus span.jxButtonContent{background-position:right -96px;}ul.jxToolbar .jxButtonActive:focus,.jxButtonActive:focus{background-position:left -144px;}ul.jxToolbar .jxButtonActive:focus span.jxButtonContent,.jxButtonActive:focus span.jxButtonContent{background-position:right -144px;}ul.jxToolbar .jxButton:hover,ul.jxToolbar .jxButtonActive:hover,.jxButton:hover,.jxButtonActive:hover{background-position:left -48px;}ul.jxToolbar .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxButtonActive:hover span.jxButtonContent,.jxButton:hover span.jxButtonContent,.jxButtonActive:hover span.jxButtonContent{background-position:right -48px;}ul.jxToolbar .jxButtonPressed,ul.jxToolbar .jxButtonPressed:focus,.jxButtonPressed,.jxButtonPressed:focus{background-position:left -120px;}ul.jxToolbar .jxButtonPressed span.jxButtonContent,ul.jxToolbar .jxButtonPressed:focus span.jxButtonContent,.jxButtonPressed span.jxButtonContent,.jxButtonPressed:focus span.jxButtonContent{background-position:right -120px;}.jxDisabled .jxButton,.jxDisabled span.jxButtonContent span{cursor:default;}ul.jxToolbar .jxDisabled .jxButton:focus,ul.jxToolbar .jxDisabled .jxButton:active,ul.jxToolbar .jxDisabled .jxButton:hover,ul.jxToolbar .jxDisabled .jxButtonPressed{background-position:left top;}.jxDisabled .jxButton:focus,.jxDisabled .jxButton:active,.jxDisabled .jxButton:hover,.jxDisabled .jxButtonPressed{background-position:left -24px;}ul.jxToolbar .jxDisabled .jxButton:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right top;}.jxDisabled .jxButton:focus span.jxButtonContent,.jxDisabled .jxButton:active span.jxButtonContent,.jxDisabled .jxButton:hover span.jxButtonContent,.jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right -24px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus,ul.jxToolbar .jxDisabled .jxButtonActive:active,ul.jxToolbar .jxDisabled .jxButtonActive:hover,.jxDisabled .jxButtonActive:focus,.jxDisabled .jxButtonActive:active,.jxDisabled .jxButtonActive:hover{background-position:left -72px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:hover span.jxButtonContent,.jxDisabled .jxButtonActive:focus span.jxButtonContent,.jxDisabled .jxButtonActive:active span.jxButtonContent,.jxDisabled .jxButtonActive:hover span.jxButtonContent{background-position:right -72px;}img.jxButtonIcon{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxButtonContent span{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;cursor:pointer;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;height:16px;white-space:nowrap;}span.jxButtonContent span.jxButtonLabel{margin:0;padding:0 4px 0 4px;color:#000;font-size:11px;}.jxButtonMenu span.jxButtonContent,.jxButtonMulti span.jxButtonContent,.jxButtonFlyout span.jxButtonContent,.jxButtonCombo span.jxButtonContent,.jxButtonEditCombo span.jxButtonContent{padding-right:0;}.jxButtonMenu span.jxButtonContent span,.jxButtonFlyout span.jxButtonContent span,.jxButtonMulti span.jxButtonContent span,.jxButtonCombo span.jxButtonContent span,.jxButtonEditCombo span.jxButtonContent span{padding-right:16px;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose{position:absolute;display:-moz-inline-box;display:inline-block;padding:4px 0;font-size:0;line-height:0;right:2px;top:2px;background-image:url(images/button_multi_disclose.png);background-position:right 0;background-repeat:no-repeat;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxButtonDisclose img{width:16px;height:16px;margin:0;padding:0;border:0;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose:focus,a.jxButtonDisclose:active{background-position:right -96px;}a.jxButtonDisclose:hover{background-position:right -48px;}a.jxButtonDisclosePressed{background-position:right -120px;}.jxDisabled a.jxButtonDisclose,.jxDisabled a.jxButtonDisclose:focus,.jxDisabled a.jxButtonDisclose:active,.jxDisabled a.jxButtonDisclose:hover,.jxDisabled a.jxButtonDisclosePressed{cursor:default;background-position:right 0;}ul.jxToolbar .jxButtonHover{background-position:left -24px!important;}ul.jxToolbar .jxButtonHover span.jxButtonContent{background-position:right -24px!important;}.jxFlyout .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxFlyout{position:absolute;display:block;z-index:100;margin:0;padding:0;}.jxFlyoutContent{position:relative;display:block;overflow:auto;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}.jxButtonMulti,.jxButtonMulti span.jxButtonContent{background-image:url(images/button_multi.png);}.jxButtonEditCombo,.jxButtonEditCombo span.jxButtonContent{background-image:url(images/button_combo.png);}.jxButtonMulti span.jxButtonContent span{padding-right:21px;}.jxButtonEditCombo span.jxButtonContent span{font-size:0;}.jxButtonComboDefault span.jxButtonContent span,.jxButtonComboDefault input{font-style:italic;color:#999;}.jxButtonEditCombo input{float:left;line-height:16px;height:16px;padding:0 4px;margin:0;border:none;font-size:11px;font-family:Arial,Helvetica,sans-serif;background-color:transparent;}.jxChrome{position:absolute;display:block;font-size:0;line-height:0;z-index:-1;width:100%;height:100%;top:0;left:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxChromeDrag{opacity:.5;-ms-filter:"Alpha(opacity=50)";}.jxChromeTL{position:absolute;overflow:hidden;left:0;top:0;width:50%;height:50%;}.jxChromeTR{position:absolute;overflow:hidden;left:50%;top:0;width:50%;height:50%;}.jxChromeBL{position:absolute;overflow:hidden;left:0;top:50%;width:50%;height:50%;}.jxChromeBR{position:absolute;overflow:hidden;left:50%;top:50%;width:50%;height:50%;}.jxChromeTL img{position:absolute;top:0;left:0;width:1000px;height:600px;}.jxChromeTR img{position:absolute;top:0;right:0;width:1000px;height:600px;}.jxChromeBL img{position:absolute;bottom:0;left:0;width:1000px;height:600px;}.jxChromeBR img{position:absolute;bottom:0;right:0;width:1000px;height:600px;}.jxColorBar{position:relative;overflow:hidden;}table.jxColorGrid{position:relative;border-collapse:collapse;empty-cells:show;clear:both;padding:0;margin:0;}.jxColorGrid tr{padding:0;margin:0;}.jxColorGrid td{border:1px solid #000;padding:0;margin:0;}.jxColorGrid td.emptyCell{border:0 solid #000;}.jxColorGrid td.emptyCell span{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;padding:1px;margin:0;}.jxColorGrid a.colorSwatch{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;margin:0;padding:1px;}.jxColorGrid a.borderWhite:hover{border:1px solid #fff;padding:0;}.jxColorGrid a.borderBlack:hover{border:1px solid #000;padding:0;}input.jxHexInput{width:55px;vertical-align:middle;}input.jxAlphaInput{width:30px;vertical-align:middle;}div.jxColorPreview{float:left;position:relative;width:20px;height:20px;border:1px solid #000;margin:2px;vertical-align:middle;background-image:url('images/grid.png');overflow:hidden;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch{display:block;float:left;width:14px;height:14px;border:1px solid #000;background-image:url('images/grid.png');background-position:0 0;background-repeat:repeat;padding-right:0!important;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch span{display:block;width:14px;height:14px;position:absolute;padding-right:0;background:none;}div.jxColorPreview img{position:absolute;z-index:0;}div.jxColorPreview div{width:20px;height:10px;position:absolute;display:block;left:0;z-index:1;font-size:10px;line-height:0;}div.jxColorPreview div.jxColorSelected{top:0;}div.jxColorPreview div.jxColorHover{bottom:0;}label.jxColorLabel,label.jxAlphaLabel{width:auto;font-family:Arial,sans-serif;font-size:11px;line-height:24px;padding:2px;vertical-align:middle;}a.jxColorClose{position:absolute;top:0;right:0;width:16px;height:16px;}a.jxColorClose img{width:16px;height:16px;}.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}.jxDisabled{opacity:.4;-ms-filter:"Alpha(opacity=40)";}.jxDisabled *{-ms-filter:"Alpha(opacity=40)";}iframe.jxIframeShim{position:absolute;top:0;left:0;width:100%;height:100%;opacity:0;-ms-filter:"Alpha(opacity=0)";z-index:-1;}@CHARSET "ISO-8859-1";.jxConfirmQuestion{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;}.jxDialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogModal{position:absolute;display:block;top:0;left:0;width:100%;height:100%;background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bottom:8px;}.jxDialogMoveable,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollapse img{background-position:0 -16px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls span.jxButtonContent,.jxDialogControls .jxButton:hover span.jxButtonContent,.jxDialogControls .jxButton:active span.jxButtonContent,.jxDialogControls .jxButtonActive span.jxButtonContent,.jxDialogControls .jxButtonActive:hover span.jxButtonContent,.jxDialogControls .jxButtonActive:active span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDialogControls .jxDisabled .jxButton,.jxDialogControls .jxDisabled .jxButton:hover,.jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent,.jxDialogControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent span,.jxDialogControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{width:150px;}div.jxFileFake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:6px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0;z-index:2;margin-top:3px;height:35px;width:100%;}.jxForm{display:block;position:relative;overflow:hidden;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;overflow:hidden;border:1px solid #ccc;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInputLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.jxInputText,.jxInputPassword,.jxInputTextarea{margin:0 4px;padding:4px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus{border:1px solid #000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldInvalid .jxInputText,.jxFieldInvalid .jxInputPassword,.jxFieldInvalid .jxInputTextarea,.jxFieldInvalid .jxInputSelect{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;}.jxFieldValidated .jxInputText,.jxFieldValidated .jxInputPassword,.jxFieldValidated .jxInputTextarea,.jxFieldValidated .jxInputSelect{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldInvalid .jxInputText:focus,.jxFieldInvalid .jxInputPassword:focus,.jxFieldInvalid .jxInputTextarea:focus,.jxFieldInvalid .jxInputSelect:focus{border-color:#8a1f11;}.jxFieldValidated .jxInputText:focus,.jxFieldValidated .jxInputPassword:focus,.jxFieldValidated .jxInputTextarea:focus,.jxFieldValidated .jxInputSelect:focus{border-color:#264409;}.jxFieldInvalid .jxInputLabel,.jxFieldInvalid .jxInputTag{color:#8a1f11;}.jxFieldValidated .jxInputLabel,.jxFieldValidated .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInline .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxInputTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}.jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jxInputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInputContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;width:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormInlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridHeader{width:100%;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridColHeadHide{height:0;line-height:0;font-size:0;background-color:#fff;white-space:normal;}.jxGridColHeadHide p,.jxGridRowHeadHide p{font-size:0;line-height:0;height:0;margin:0;padding:0;}.jxGridRowHeadHide{width:0;white-space:normal;}.jxGridCell{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding-left:3px;padding-right:3px;overflow:hidden;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;font-weight:bold;color:#333;cursor:default;padding-left:3px;padding-right:3px;white-space:nowrap;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-position:0 0;background-repeat:repeat-y;text-align:center;font-weight:bold;color:#333;cursor:default;overflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td{background-color:#f7f7f7;}td.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td{background-color:#e5f1ff;}td.jxGridCellPrelight{background-color:#cce3ff;}.jxColSortable{padding-right:20px;}.jxGridCell.jxColSortable{padding-right:0;}.jxColSortable span{background-image:url('images/emblems.png');padding-right:20px;background-repeat:no-repeat;background-position:right top;}.jxGridColumnSortedAsc span{background-position:right -160px;}.jxGridColumnSortedDesc span{background-position:right -16px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-position:left -24px;}.jxListItem:focus{margin:0;border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed,.jxListView .jxSelected{margin:0;border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxMenuItem{display:block;position:relative;overflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a.jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabled a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisabled a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButtonSubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jxMenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.jxMenuItemIcon,.jxMenuItemSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background-repeat:repeat-x;background-position:left center;}@CHARSET "ISO-8859-1";.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-align:center;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16px;}.jxPanelMaximize img{background-position:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls span.jxButtonContent,.jxPanelControls .jxButton:hover span.jxButtonContent,.jxPanelControls .jxButton:active span.jxButtonContent,.jxPanelControls .jxButtonActive span.jxButtonContent,.jxPanelControls .jxButtonActive:hover span.jxButtonContent,.jxPanelControls .jxButtonActive:active span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonActive:hover,.jxPanelControls .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled .jxButton:hover,.jxPanelControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent,.jxPanelControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent span,.jxPanelControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}@CHARSET "ISO-8859-1";.jxProgressBar-container{width:100%;display:block;clear:both;}.jxProgressBar-message{color:black;}.jxProgressBar-container .jxProgressBar{width:100%;clear:both;border-top:none;}.jxProgressBar-container .jxProgressBar .jxProgressBar-outline{border:1px solid #360;position:absolute;top:0;left:0;z-index:10;}.jxProgressBar-container .jxProgressBar .jxProgressBar-fill{background-color:#9c6;position:absolute;top:1px;left:1px;z-index:20;}.jxProgressBar-container .jxProgressBar .jxProgressBar-text{color:#360;margin:0;padding:2px;position:absolute;top:1px;left:1px;width:auto;z-index:30;border:none;}@CHARSET "ISO-8859-1";.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag{background-color:#eee;}.jxSnapHorizontalBefore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxToolbarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}div.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:block;position:relative;cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-repeat;}img.jxTabIcon{position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxTabClose img{width:16px;height:16px;background-image:url(images/tab_close.png);}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisabled a.jxTabClose{cursor:default;}.jxBarTop div.jxTabContainer,.jxBarBottom div.jxTabContainer{float:left;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent{background-image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:3px;right:3px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{float:left;padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{float:left;padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:focus span.jxTabContent{background-position:right -96px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabContent{background-position:right -120px;}.jxBarTop .jxDisabled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBottom .jxDisabled a.jxTabActive:focus,.jxBarBottom .jxDisabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{float:left;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{float:left;height:16px;padding:0 4px 0 4px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(images/tab_left.png);}.jxBarRight a.jxTab,.jxBarRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:3px;left:3px;}.jxBarLeft .jxTabClose span.jxTabContent,.jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBarLeft a.jxTabActive:focus span.jxTabContent,.jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRight a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLeft .jxDisabled a.jxTabPressed,.jxBarRight .jxDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBarLeft .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top;}.jxBarLeft .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:auto;height:100%;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repeat:repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{position:absolute;width:10000%;overflow:hidden;}.jxBarTop .jxBarScrollLeft,.jxBarBottom .jxBarScrollLeft{position:absolute;top:0;left:0;}.jxBarTop .jxBarScrollRight,.jxBarBottom .jxBarScrollRight{position:absolute;top:0;right:0;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollRight img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -96px;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;padding:0;margin:0;border:none;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolbar_separator_v.png);}.jxBarLeft ul.jxToolbar,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTree,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:left top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTree li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 17px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 16px;background-position:left -72px;}a.jxTreeItem:hover,li.jxTreeContainer a.jxHover{border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -24px;}li.jxTreeContainer a.jxSelected,li.jxTreeContainer a.jxSelected:hover,li.jxTreeContainer a.jxPressed,li.jxTreeContainer a.jxPressed:hover{border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -48px;}li.jxDisabled a.jxTreeItem{cursor:default;}li.jxDisabled a.jxTreeItem:focus,li.jxDisabled a.jxTreeItem:hover{background-position:left top;background-color:transparent;border:none;margin:0 1px 0 17px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:2px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTreeBranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .jxTreeImage{background-position:left -60px;}.jxTreeLeafLast .jxTreeImage{background-position:left -120px;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}.jxFileUploadPanel{padding:5px;}.jxFileUploadPanel .jxInputContainer{width:300px;}.jxUploadQueue{width:100%;margin-top:10px;}.jxUploadQueue div{position:relative;width:95%;clear:both;border-top:1px solid black;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue div span.jxUploadFileName{float:left;font-size:16px;}.jxUploadQueue div span.jxUploadFileDelete,.jxUploadQueue div span.jxUploadFileProgress,.jxUploadQueue div span.jxUploadFileComplete,.jxUploadQueue div span.jxUploadFileError{float:right;width:16px;height:16px;background-repeat:no-repeat;background-position:top left;cursor:pointer;}.jxUploadQueue div span.jxUploadFileDelete{background-image:url('images/delete.gif');}.jxUploadQueue div span.jxUploadFileProgress{background-image:url('images/loading.gif');}.jxUploadQueue div span.jxUploadFileComplete{background-image:url('images/green_tick.png');}.jxUploadQueue div span.jxUploadFileError{background-image:url('images/error.png');}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/error.png") no-repeat left top;color:black;width:100px;}
Modified: sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.uncompressed.css
--- sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.uncompressed.css 2009-11-05 21:59:29 UTC (rev 1964)
+++ sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.uncompressed.css 2009-11-06 16:05:28 UTC (rev 1965)
@@ -2967,7 +2967,7 @@
* @project Jx
- * @revision $Id: tree.css 535 2009-09-28 18:47:18Z fred.warnock $
+ * @revision $Id: tree.css 586 2009-11-05 20:34:17Z pagameba $
* @author Fred Warnock (fwarnock at dmsolutions.ca)
* @copyright (c) 2006 DM Solutions Group Inc.
@@ -2982,7 +2982,7 @@
-.jxTreeFolder,
+.jxTree,
.jxTreeRoot {
/* relative positioning is required for IE to fix the peek-a-boo bug */
position:relative;
@@ -3019,7 +3019,7 @@
-khtml-user-select: none;
-.jxTreeFolder li.jxTreeContainer {
+.jxTree li.jxTreeContainer {
margin-left: 16px;
Modified: sandbox/jxlib-3.0/widgets/Legend.js
--- sandbox/jxlib-3.0/widgets/Legend.js 2009-11-05 21:59:29 UTC (rev 1964)
+++ sandbox/jxlib-3.0/widgets/Legend.js 2009-11-06 16:05:28 UTC (rev 1965)
@@ -752,9 +752,9 @@
Fusion.Widget.Legend.TreeFolder = new Class({
Extends: Jx.TreeFolder,
options: {
- template: '<li class="jxTreeContainer jxTreeBranch"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><span class="fusionLegendCheckboxContainer"><input type="checkbox" class="fusionLegendCheckboxInput"></span><a class="jxTreeItem fusionCheckboxItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel"></span></a><a class="fusionGroupInfo"><img class="fusionGroupInfoIcon" src="'+Jx.aPixel.src+'"></a><a class="fusionLayerInfo"><img class="fusionLayerInfoIcon" src="'+Jx.aPixel.src+'"></a><ul class="jxTreeFolder"></ul></li>'
+ template: '<li class="jxTreeContainer jxTreeBranch"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><span class="fusionLegendCheckboxContainer"><input type="checkbox" class="fusionLegendCheckboxInput"></span><a class="jxTreeItem fusionCheckboxItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel"></span></a><a class="fusionGroupInfo"><img class="fusionGroupInfoIcon" src="'+Jx.aPixel.src+'"></a><a class="fusionLayerInfo"><img class="fusionLayerInfoIcon" src="'+Jx.aPixel.src+'"></a><ul class="jxTree"></ul></li>'
- classes: ['jxTreeContainer','jxTreeImage','jxTreeItem','jxTreeIcon','jxTreeLabel','jxTreeFolder','fusionLegendCheckboxInput','fusionGroupInfo','fusionGroupInfoIcon','fusionLayerInfo','fusionLayerInfoIcon'],
+ classes: ['jxTreeContainer','jxTreeImage','jxTreeItem','jxTreeIcon','jxTreeLabel','jxTree','fusionLegendCheckboxInput','fusionGroupInfo','fusionGroupInfoIcon','fusionLayerInfo','fusionLayerInfoIcon'],
render: function() {
this.parent();
More information about the fusion-commits
