[fusion-commits] r1977 - trunk/layers/Generic
svn_fusion at osgeo.org
Mon Nov 16 22:05:48 EST 2009
Author: liuar
Date: 2009-11-16 22:05:46 -0500 (Mon, 16 Nov 2009)
New Revision: 1977
trunk/layers/Generic/Generic.js
Fixed ticket 317 at http://trac.osgeo.org/fusion/ticket/317
Map doesn't display as the selected base layers after selecting Map widget.
Modified: trunk/layers/Generic/Generic.js
--- trunk/layers/Generic/Generic.js 2009-11-16 20:09:34 UTC (rev 1976)
+++ trunk/layers/Generic/Generic.js 2009-11-17 03:05:46 UTC (rev 1977)
@@ -103,20 +103,32 @@
this.mapTag.layerOptions.type = G_SATELLITE_MAP;
break;
case 'G_NORMAL_MAP':
+ this.mapTag.layerOptions.type = G_NORMAL_MAP;
default:
- this.mapTag.layerOptions.type = G_NORMAL_MAP;
+ // For the re-loaded Google layers
+ if(this.mapTag.layerOptions.type == G_PHYSICAL_MAP)
+ this.mapTag.layerOptions.type = G_PHYSICAL_MAP;
+ else if(this.mapTag.layerOptions.type == G_HYBRID_MAP)
+ this.mapTag.layerOptions.type = G_HYBRID_MAP;
+ else if(this.mapTag.layerOptions.type == G_SATELLITE_MAP)
+ this.mapTag.layerOptions.type = G_SATELLITE_MAP;
+ else
break;
break;
case 'VirtualEarth':
switch (this.mapTag.layerOptions.type) { //VE layer types are enumerated values
case 'Aerial': //defined in VEMapStyle from the VE api
+ case 'a':
this.mapTag.layerOptions.type = VEMapStyle.Aerial;
break;
case 'Shaded':
+ case 's':
this.mapTag.layerOptions.type = VEMapStyle.Shaded;
break;
case 'Hybrid':
+ case 'h':
this.mapTag.layerOptions.type = VEMapStyle.Hybrid;
break;
default:
@@ -127,12 +139,15 @@
case 'Yahoo':
switch (this.mapTag.layerOptions.type) { //Yahoo is similar to google
case 'YAHOO_MAP_SAT': //defined by YMap, not a string
+ case 'YAHOO_SAT':
this.mapTag.layerOptions.type = YAHOO_MAP_SAT;
break;
case 'YAHOO_MAP_HYB':
+ case 'YAHOO_HYB':
this.mapTag.layerOptions.type = YAHOO_MAP_HYB;
break;
case 'YAHOO_MAP_REG':
+ case "YAHOO_REG":
default:
this.mapTag.layerOptions.type = YAHOO_MAP_REG;
break;
More information about the fusion-commits
