[fusion-commits] r1985 - trunk/widgets/Theme/classes
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Nov 19 22:04:12 EST 2009
Author: christinebao
Date: 2009-11-19 22:04:10 -0500 (Thu, 19 Nov 2009)
New Revision: 1985
   trunk/widgets/Theme/classes/theme.php
Fix ticket http://trac.osgeo.org/fusion/ticket/323
Theme: Individual rule for Numeric property is disordered.
Modified: trunk/widgets/Theme/classes/theme.php
--- trunk/widgets/Theme/classes/theme.php	2009-11-20 02:42:27 UTC (rev 1984)
+++ trunk/widgets/Theme/classes/theme.php	2009-11-20 03:04:10 UTC (rev 1985)
@@ -257,22 +257,33 @@
         if ($this->args['DISTRO'] == 'INDIV_DIST')
+            $values = array();
             $aggregateOptions->AddFeatureProperty($this->args['PROPERTYNAME']);
             $aggregateOptions->SelectDistinct(true);
             $dataReader = $featureService->SelectAggregate($resId, $layer->GetFeatureClassName(), $aggregateOptions);
             while ($dataReader->ReadNext())
                 $value = $this->GetFeaturePropertyValue($dataReader, $this->args['PROPERTYNAME']);
+                array_push($values, $value);
+            $dataReader->Close();
+            if ($this->args['DATATYPE'] == MgPropertyType::String)
+                sort($values, SORT_STRING);
+            else
+                sort($values, SORT_NUMERIC);
+            for ($i = 0; $i < count($values); $i++)
                 $filterText = '&quot;' . $this->args['PROPERTYNAME'] . '&quot; = ';
-                    $filterText .= "'" . $value . "'";
+                    $filterText .= "'" . $values[$i] . "'";
                 else
-                    $filterText .= $value;
+                    $filterText .= $values[$i];
                 $areaRuleXML = sprintf($areaRuleTemplate,
-                    $this->args['PROPERTYNAME'] . ': ' . $value,
+                    $this->args['PROPERTYNAME'] . ': ' . $values[$i],
                     $filterText,
                     $this->InterpolateColor($portion, $this->args['FILLFROM'], $this->args['FILLTO'], $this->args['FILLTRANS']),
                     $this->InterpolateColor($portion, $this->args['LINEFROM'], $this->args['LINETO'], 0));
@@ -290,7 +301,6 @@
                 $portion += $increment;
-            $dataReader->Close();
         else
More information about the fusion-commits mailing list
