[fusion-commits] r1990 - trunk/widgets
svn_fusion at osgeo.org
Tue Nov 24 22:28:03 EST 2009
Author: christinebao
Date: 2009-11-24 22:28:02 -0500 (Tue, 24 Nov 2009)
New Revision: 1990
trunk/widgets/Redline.js
Fix ticket http://trac.osgeo.org/fusion/ticket/320
Two Layers with the same name could be created in the Redline Panel
Modified: trunk/widgets/Redline.js
--- trunk/widgets/Redline.js 2009-11-24 20:55:16 UTC (rev 1989)
+++ trunk/widgets/Redline.js 2009-11-25 03:28:02 UTC (rev 1990)
@@ -280,6 +280,23 @@
this.vectorLayers[0].redLineLayer = true;
this.activateLayer(0);
+ getUniqueLayerName: function() {
+ var offset = this.vectorLayers.length;
+ var exist = true;
+ while (exist) {
+ exist = false;
+ var i = 0;
+ while (!exist && i < this.vectorLayers.length) {
+ if (("Digitizing layer " + offset) == this.vectorLayers[i].name)
+ exist = true;
+ i++;
+ if (exist)
+ offset++;
+ return "Digitizing layer " + offset;
@@ -363,8 +380,8 @@
doc.getElementById("RedlineWidgetRenameFeatureButton").onclick = OpenLayers.Function.bind(this.renameFeature, this);
- newLayer: function() {
- var name = prompt("Layer name:", "Digitizing layer "+this.widget.vectorLayers.length);
+ newLayer: function() {
+ var name = prompt("Layer name:", this.widget.getUniqueLayerName());
if (name!=null && name!="") {
this.widget.newLayer(name);
this.updateLayerList();
More information about the fusion-commits
