[fusion-commits] r1995 - in trunk: lib widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Nov 26 21:21:29 EST 2009
Author: liuar
Date: 2009-11-26 21:21:28 -0500 (Thu, 26 Nov 2009)
New Revision: 1995
   trunk/lib/Map.js
   trunk/widgets/BasemapSwitcher.js
Fixed ticket http://trac.osgeo.org/fusion/ticket/338
Map returned to the default commercial layer after theme operation
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2009-11-27 01:51:25 UTC (rev 1994)
+++ trunk/lib/Map.js	2009-11-27 02:21:28 UTC (rev 1995)
@@ -41,6 +41,7 @@
 Fusion.Event.MAP_RELOADED = Fusion.Event.lastEventId++;
 Fusion.Event.MAP_SESSION_CREATED = Fusion.Event.lastEventId++;
 Fusion.Event.MAP_MAPTIP_REQ_FINISHED = Fusion.Event.lastEventId++;
+Fusion.Event.MAP_MAPGROUPLOADED = Fusion.Event.lastEventId++;
 Fusion.Constant.LAYER_POINT_TYPE = 0;
@@ -168,6 +169,7 @@
         this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
         this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
         this.registerEventID(Fusion.Event.MAP_MAPTIP_REQ_FINISHED);
+		this.registerEventID(Fusion.Event.MAP_MapGroupLoaded);
         this.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded,this));
@@ -230,6 +232,7 @@
           this.aMaps[i].registerForEvent(Fusion.Event.LAYER_LOADED, OpenLayers.Function.bind(this.layerLoaded,this));
+		this.triggerEvent(Fusion.Event.MAP_MapGroupLoaded);
     layerLoaded: function() {
Modified: trunk/widgets/BasemapSwitcher.js
--- trunk/widgets/BasemapSwitcher.js	2009-11-27 01:51:25 UTC (rev 1994)
+++ trunk/widgets/BasemapSwitcher.js	2009-11-27 02:21:28 UTC (rev 1995)
@@ -22,34 +22,40 @@
 Fusion.Widget.BasemapSwitcher = OpenLayers.Class(Fusion.Widget, {
     uiClass: Jx.Menu,
-    options: {
-        'G_NORMAL_MAP': null,
-        'G_SATELLITE_MAP': null,
-        'G_HYBRID_MAP': null,
-        'YAHOO_MAP_REG': null,
-        'YAHOO_MAP_SAT': null,
-        'YAHOO_MAP_HYB': null,
-        'Road': null,
-        'Aerial': null,
-        'Hybrid': null,
-        'None': null
+    options: {},
     baseMaps: {},
     defaultBasemap: null,
     menuItems: {},
     initializeWidget: function(widgetTag) {
-        this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.setDefaultBasemap, this));
+        this.getMap().registerForEvent(Fusion.Event.MAP_MAPGROUPLOADED, OpenLayers.Function.bind(this.setDefaultBasemap, this));
-	generateOptions: function(){
-		// Clear previous settings
-		this.options = {};
+	refreshSettings: function(){
 		this.baseMaps = {};
 		this.defaultBasemap = null;
 		this.menuItems = {};
+		this.options = {
+			'G_NORMAL_MAP': null,
+			'G_SATELLITE_MAP': null,
+			'G_HYBRID_MAP': null,
+			'YAHOO_MAP_REG': null,
+			'YAHOO_MAP_SAT': null,
+			'YAHOO_MAP_HYB': null,
+			'Road': null,
+			'Aerial': null,
+			'Hybrid': null,
+			'None': null
+	generateOptions: function(){
+		// Clear previous settings
+		this.refreshSettings();
 		var maps = this.getMap().aMaps;
         for (var i = 0, len = maps.length; i < len; i++) {
@@ -94,8 +100,6 @@
                                 this.baseMaps['G_HYBRID_MAP'] = map;
                                 break;
                             default:
-                                //this.options['G_NORMAL_MAP'] = map.mapTag.extension.Options[0].name[0];
-                                //this.baseMaps['G_NORMAL_MAP'] = map;
                                 break;
@@ -141,8 +145,6 @@
                                 this.baseMaps['YAHOO_MAP_HYB'] = map;
                                 break;
                             default:
-                                //this.options['YAHOO_MAP_REG'] = map.mapTag.extension.Options[0].name[0];
-                                //this.baseMaps['YAHOO_MAP_REG'] = map;
                                 break;
                         // The first non-MapGuide basemap will be the default basemap
@@ -186,8 +188,6 @@
                                 this.baseMaps['Hybrid'] = map;
                                 break;
                             default:
-                                //this.options['Road'] = map.mapTag.extension.Options[0].name[0];
-                                //this.baseMaps['Road'] = map;
                                 break;
@@ -200,6 +200,9 @@
                     break;
+		if (!this.defaultBasemap) {
+			this.defaultBasemap = "NONE";
     setUiObject: function(uiObj) {
More information about the fusion-commits mailing list
