[fusion-commits] r1998 - in trunk: . layers/MapServer layers/MapServer/php lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Nov 30 17:28:16 EST 2009
Author: pdeschamps
Date: 2009-11-30 17:28:16 -0500 (Mon, 30 Nov 2009)
New Revision: 1998
Added:
   trunk/layers/MapServer/php/RestoreState.php
   trunk/config_dist.json
   trunk/layers/MapServer/MapServer.js
   trunk/lib/Map.js
implemented the restoreState= session loading functionality
Modified: trunk/config_dist.json
--- trunk/config_dist.json	2009-11-30 09:18:05 UTC (rev 1997)
+++ trunk/config_dist.json	2009-11-30 22:28:16 UTC (rev 1998)
@@ -41,6 +41,10 @@
 	        web-accessible temporary legend images. */
 	    "legendIconCacheDir":"/ms4w/tmp/ms_tmp",
             /* The file  system path to where the maps are stored. */
-            "mapFileRoot":"/ms4w/apps/"
+        "mapFileRoot":"/ms4w/apps/",
+        /*The file  system path where the saved map sessions are stored.*/
+         "mapRestoreState":"/opt/fgs/apps/savedSession/",
+        /*The file  system path where the php sessions are stored.*/
+         "mapRestoreStateSession":"/opt/fgs/tmp/"
Modified: trunk/layers/MapServer/MapServer.js
--- trunk/layers/MapServer/MapServer.js	2009-11-30 09:18:05 UTC (rev 1997)
+++ trunk/layers/MapServer/MapServer.js	2009-11-30 22:28:16 UTC (rev 1998)
@@ -42,6 +42,8 @@
     layerMetadataKeys: null,
     oMaptip:null,
     bMapTipFired: false,
+    bRestoreMapState: false,
+    oRestoredState: {},
     //the map file
     sMapFile: null,
@@ -63,6 +65,16 @@
           Fusion.queryParams['theme'] = null;
+        var restoreMapState = Fusion.getQueryParam('restoreState');
+        if (restoreMapState != '') {
+          //clear the query param after it has been used once
+          this.oRestoredState.id = restoreMapState;
+          Fusion.queryParams['restoreState'] = null;
+          // set flag to true so we can restore the map from a saved session.
+          this.bRestoreMapState = true;
         this.mapMetadataKeys = mapTag.extension.MapMetadata ? mapTag.extension.MapMetadata[0] : null;
         this.layerMetadataKeys = mapTag.extension.LayerMetadata ? mapTag.extension.LayerMetadata[0] : null;
@@ -118,12 +130,55 @@
               Fusion.initializeLocale(locale[0]);
               break;
-            this.triggerEvent(Fusion.Event.MAP_SESSION_CREATED);
+            /* Session is created, Check to see if we are going to restore a saved
+                map state and restore it if set to true.
+            if(this.bRestoreMapState == true){
+                var that = this;
+                var sl = Fusion.getScriptLanguage();
+                var scriptURL = 'layers/' + this.arch + '/' + sl + '/RestoreState.' + sl;
+                var params = {
+                    parameters: OpenLayers.Util.getParameterString({
+                        session: this.session[0] ,
+                        id: this.oRestoredState.id
+                    onComplete: function(xhr) {
+                        var o;
+                        eval('o='+xhr.responseText);
+                        that.restoreStateCB(o);
+                Fusion.ajaxRequest(scriptURL,params);
+            else
+                // done with session create, fire the event.
+                this.triggerEvent(Fusion.Event.MAP_SESSION_CREATED);
+    restoreStateCB: function(oResponse){
+        if(oResponse.error){
+            Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING, "Error Restoring Map State - "+oResponse.error));
+        else
+        this.oRestoredState = oResponse;
     mapSessionCreated: function() {
-        if (this.sMapFile != '') {
+        // restore the mapfile from a saved state.
+        if(this.bRestoreMapState === true && this.oRestoredState.loadmap ){
+            this.loadMap(this.oRestoredState.loadmap);
+        else if (this.sMapFile != '') {
             this.loadMap(this.sMapFile);
         window.setInterval(OpenLayers.Function.bind(this.pingServer, this),
@@ -278,7 +333,6 @@
               this.mapWidget.addMap(this);
               this.mapWidget.oMapOL.units = this.oLayerOL.units;
             this.bMapLoaded = true;
         else
@@ -402,31 +456,35 @@
     mapLayersReset: function(aLayerIndex,r) {
-      if (r.status == 200) {
         var o;
         eval('o='+r.responseText);
-  			if (o.success) {
-  				var layerCopy = $A(this.aLayers);
-          var nLayers = layerCopy.length -1;
-          //Mapserver has list of layers reversed from MapGuide
-          aLayerIndex.reverse();
-  				this.aLayers = [];
-  				this.aVisibleLayers = [];
+        if (o.success) {
+            var layerCopy = $A(this.aLayers);
+            console.dir(layerCopy);
+            var nLayers = layerCopy.length -1;
+            console.log("nLayers:"+nLayers);
-          for (var i=0; i<aLayerIndex.length; ++i) {
-            this.aLayers.push( layerCopy[ nLayers - aLayerIndex[i] ] );
-            if (this.aLayers[i].visible) {
-                this.aVisibleLayers.push(this.aLayers[i].layerName);
+            //Mapserver has list of layers reversed from MapGuide
+            //aLayerIndex.reverse();
+            this.aLayers = [];
+            this.aVisibleLayers = [];
+            for (var i=0; i<aLayerIndex.length; ++i) {
+                this.aLayers.push( layerCopy[aLayerIndex[i] ] );
+                console.log("INDEX:"+(aLayerIndex[i]));
+                console.log(layerCopy[aLayerIndex[i]].layerName);
+                if (this.aLayers[i].visible) {
+                    this.aVisibleLayers.push(this.aLayers[i].layerName);
-  				//this.layerRoot.clear();
+            console.dir(this.aLayers);
+            //this.layerRoot.clear();
-  				this.drawMap();
-  				this.triggerEvent(Fusion.Event.MAP_LAYER_ORDER_CHANGED);
+            this.drawMap();
+            this.triggerEvent(Fusion.Event.MAP_LAYER_ORDER_CHANGED);
     parseMapLayersAndGroups: function(o) {
Added: trunk/layers/MapServer/php/RestoreState.php
--- trunk/layers/MapServer/php/RestoreState.php	                        (rev 0)
+++ trunk/layers/MapServer/php/RestoreState.php	2009-11-30 22:28:16 UTC (rev 1998)
@@ -0,0 +1,191 @@
+<?php
+ini_set("memory_limit","64M");
+dl('zip.so');
+ /* set up the session */
+include(dirname(__FILE__).'/Common.php');
+include('../../../common/php/Utilities.php');
+header('Content-type: application/json');
+header('X-JSON: true');
+isset($_REQUEST["session"])?$szSessionID = $_REQUEST["session"]:$szSessionID = NULL ;
+isset($_REQUEST["id"])?$loadSessionID = $_REQUEST["id"]:$loadSessionID = NULL ;
+$oReturn = NULL;
+if (isset($_SESSION['fusionConfig'])) {
+    $szStoreSessionPath = $_SESSION['fusionConfig']->mapserver->mapRestoreState;
+    $szFilePhpSession = $_SESSION['fusionConfig']->mapserver->mapRestoreStateSession;
+    $szDestination = $szFilePhpSession."/sess_".$szSessionID."/";
+    $szTmpFileName = $_FILES["sessionFile"]["tmp_name"];
+    $szZipFilename = $szStoreSessionPath."/ss_".$loadSessionID.".zip";
+    $szControlFile = $szStoreSessionPath."/".$loadSessionID.".dat";
+    if (file_exists($szZipFilename) && file_exists($szControlFile)){
+        $aData = readSessionSaveControlFile($szControlFile);
+        $bSuccessfull = unzip($szZipFilename, $szDestination, $create_zip_name_dir=true, $overwrite=true);
+            if($aData && $bSuccessfull === TRUE){
+                $oReturn->success = TRUE;
+                $oReturn->mapname = $aData["mapname"];
+                $oReturn->extents = $aData["_afCurrentExtents"];
+                $oReturn->vislayers = $aData["aVisibleLayers"];
+                $oReturn->sessionname = $aData["sessionName"];
+                $oReturn->loadmap = $szDestination."/".$oReturn->mapname.'.map';
+                $oMap = ms_newMapObj($oReturn->loadmap);
+                checkForGMLLayers($szDestination);
+                $oMap->save($oReturn->loadmap);
+                echo var2json($oReturn);
+            else
+                die("{'error':'Could not load session control file ".$loadSessionID. ".dat.'}");
+        else
+        die("{'error':'map state ".$loadSessionID. " does not exist.'}");
+    else
+    die("{'error':'PHP Session path is invalid.'}");
+function checkForGMLLayers($szDestination){
+    global $oMap;
+    @$oLayer = $oMap->getLayerByName("LWEGML-Point");
+    if($oLayer){
+    $oLayer->set("connection", $szDestination."/features.gml");
+    @$oLayer = $oMap->getLayerByName("LWEGML-Line");
+    if($oLayer){
+    @$oLayer = $oMap->getLayerByName("LWEGML-Polygon");
+    if($oLayer){
+    @$oLayer = $oMap->getLayerByName("LWEGML-Annotation");
+    if($oLayer){
+function readSessionSaveControlFile($szFileName){
+$handle = @fopen($szFileName, "r");
+if($handle)
+    $szData = fread($handle, filesize($szFileName));
+    fclose($handle);
+return unserialize($szData);
+function unzip($src_file, $dest_dir=false, $create_zip_name_dir=true, $overwrite=true)
+  if(function_exists("zip_open"))
+      if(!is_resource(zip_open($src_file)))
+          $src_file=dirname($_SERVER['SCRIPT_FILENAME'])."/".$src_file;
+      if (is_resource($zip = zip_open($src_file)))
+          $splitter = ($create_zip_name_dir === true) ? "." : "/";
+          if ($dest_dir === false) $dest_dir = substr($src_file, 0, strrpos($src_file, $splitter))."/";
+          // Create the directories to the destination dir if they don't already exist
+          create_dirs($dest_dir);
+          // For every file in the zip-packet
+          while ($zip_entry = zip_read($zip))
+            // Now we're going to create the directories in the destination directories
+            // If the file is not in the root dir
+            $pos_last_slash = strrpos(zip_entry_name($zip_entry), "/");
+            if ($pos_last_slash !== false)
+              // Create the directory where the zip-entry should be saved (with a "/" at the end)
+              create_dirs($dest_dir.substr(zip_entry_name($zip_entry), 0, $pos_last_slash+1));
+            // Open the entry
+            if (zip_entry_open($zip,$zip_entry,"r"))
+              // The name of the file to save on the disk
+              $file_name = $dest_dir.zip_entry_name($zip_entry);
+              // Check if the files should be overwritten or not
+              if ($overwrite === true || $overwrite === false && !is_file($file_name))
+                // Get the content of the zip entry
+                $fstream = zip_entry_read($zip_entry, zip_entry_filesize($zip_entry));
+                if(!is_dir($file_name))
+                file_put_contents($file_name, $fstream );
+                // Set the rights
+                if(file_exists($file_name))
+                    chmod($file_name, 0755);
+                    //echo "<span style=\"color:#1da319;\">file saved: </span>".$file_name."<br />";
+                else
+                    //echo "<span style=\"color:red;\">file not found: </span>".$file_name."<br />";
+              // Close the entry
+              zip_entry_close($zip_entry);
+          // Close the zip-file
+          zip_close($zip);
+      else
+        return false;
+      return true;
+  else
+      if(version_compare(phpversion(), "5.2.0", "<"))
+      $infoVersion="(use PHP 5.2.0 or later)";
+      die("error:'You need to install/enable the php_zip.dll extension $infoVersion'");
+function create_dirs($path)
+  if (!is_dir($path))
+    $directory_path = "";
+    $directories = explode("/",$path);
+    array_pop($directories);
+    foreach($directories as $directory)
+      $directory_path .= $directory."/";
+      if (!is_dir($directory_path))
+        mkdir($directory_path);
+        chmod($directory_path, 0777);
\ No newline at end of file
Property changes on: trunk/layers/MapServer/php/RestoreState.php
___________________________________________________________________
Added: svn:keywords
   + Id
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2009-11-30 09:18:05 UTC (rev 1997)
+++ trunk/lib/Map.js	2009-11-30 22:28:16 UTC (rev 1998)
@@ -41,7 +41,7 @@
 Fusion.Event.MAP_RELOADED = Fusion.Event.lastEventId++;
 Fusion.Event.MAP_SESSION_CREATED = Fusion.Event.lastEventId++;
 Fusion.Event.MAP_MAPTIP_REQ_FINISHED = Fusion.Event.lastEventId++;
-Fusion.Event.MAP_MAPGROUPLOADED = Fusion.Event.lastEventId++;
+Fusion.Event.MAP_MAP_GROUP_LOADED = Fusion.Event.lastEventId++;
 Fusion.Constant.LAYER_POINT_TYPE = 0;
@@ -169,7 +169,7 @@
         this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
         this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
         this.registerEventID(Fusion.Event.MAP_MAPTIP_REQ_FINISHED);
-		this.registerEventID(Fusion.Event.MAP_MapGroupLoaded);
+		this.registerEventID(Fusion.Event.MAP_MAP_GROUP_LOADED);
         this.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded,this));
@@ -232,7 +232,7 @@
           this.aMaps[i].registerForEvent(Fusion.Event.LAYER_LOADED, OpenLayers.Function.bind(this.layerLoaded,this));
-		this.triggerEvent(Fusion.Event.MAP_MapGroupLoaded);
+		this.triggerEvent(Fusion.Event.MAP_MAP_GROUP_LOADED);
     layerLoaded: function() {
@@ -245,8 +245,23 @@
       if (this.aMaps.length == 1) {
         this.oMapOL.setBaseLayer(this.aMaps[0].oLayerOL);
+        Are we restoring a saved map state?
+      if(this.aMaps[0].bRestoreMapState && this.aMaps[0].bRestoreMapState === true && typeof(this.aMaps[0].oRestoredState.extents) !=="undefined"){
+        var a = this.aMaps[0].oRestoredState.extents.split(',');
+        a[0] = parseFloat(a[0]);
+        a[1] = parseFloat(a[1]);
+        a[2] = parseFloat(a[2]);
+        a[3] = parseFloat(a[3]);
+        this.setExtents(new OpenLayers.Bounds(a[0], a[1], a[2],  a[3]));
+      else
       var initialExtent = this.setInitialExtents();
       this.setExtents(initialExtent);
       this.triggerEvent(Fusion.Event.MAP_LOADED);
More information about the fusion-commits mailing list
