[fusion-commits] r1946 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Oct 15 16:34:06 EDT 2009
Author: pdeschamps
Date: 2009-10-15 16:34:05 -0400 (Thu, 15 Oct 2009)
New Revision: 1946
   trunk/widgets/LayerManager.js
   trunk/widgets/Legend.js
Modified LayerManager to listen for the event LAYER_PROPERTY_CHANGED to update itseld
Modified: trunk/widgets/LayerManager.js
--- trunk/widgets/LayerManager.js	2009-10-15 20:33:15 UTC (rev 1945)
+++ trunk/widgets/LayerManager.js	2009-10-15 20:34:05 UTC (rev 1946)
@@ -53,6 +53,8 @@
 Fusion.Widget.LayerManager = OpenLayers.Class(Fusion.Widget,  {
     currentNode: null,
     bIsDrawn: false,
+    map: null,
+    bLayerChanged:false,
     initializeWidget: function(widgetTag) {
         var json = widgetTag.extension;
         this.delIconSrc = json.DeleteIcon ? json.DeleteIcon[0] : 'images/icons/select-delete.png';
@@ -60,17 +62,27 @@
         Fusion.addWidgetStyleSheet(widgetTag.location + 'LayerManager/LayerManager.css');
         this.cursorNormal = ["url('images/grab.cur'),move", 'grab', '-moz-grab', 'move'];
         this.cursorDrag = ["url('images/grabbing.cur'),move", 'grabbing', '-moz-grabbing', 'move'];
-        this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded, this));
-        this.getMap().registerForEvent(Fusion.Event.MAP_RELOADED, OpenLayers.Function.bind(this.mapLoaded, this));
+        this.map = this.getMap();
+        this.map.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded, this));
+        this.map.registerForEvent(Fusion.Event.MAP_RELOADED, OpenLayers.Function.bind(this.mapReLoaded, this));
+        // update changes to the legend in this widget
+        this.map.aMaps[0].registerForEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, OpenLayers.Function.bind(this.layerChanged,this));
     mapLoaded: function() {
         this.draw();
+        this.bLayerChanged = true;
+    layerChanged: function() {
+        this.draw();
+        this.updateSessionMapFile();
+   mapReLoaded: function(){
+        this.bLayerChanged = false;
+        this.draw();
      * remove the dom objects representing the legend layers and groups
@@ -100,11 +112,13 @@
       //this processes the OL layers
       var map = this.getMap();
       for (var i=0; i<map.aMaps.length; ++i) {
         var mapBlock = document.createElement('li');
         mapBlock.className = 'jxLmanMap';
         mapBlock.id = 'mapBlock_'+i;
         //add a handle so the map blocks can be re-arranged
         var handle = document.createElement('a');
         handle.innerHTML = map.aMaps[i]._sMapTitle;
@@ -130,12 +144,14 @@
       mapBlockList.id = 'fusionLayerManager_'+map.getMapName();
       blockDom.appendChild(mapBlockList);
       map.layerPrefix = 'layer_';   //TODO make this unique for each block
+      mapBlockList.bLayerChanged = this.bLayerChanged;
       //this process all layers within an OL layer
       var processArray = map.aLayers;
-      if (map.bLayersReversed) {
+      if (map.bLayersReversed && this.bLayerChanged === false ) {
         processArray.reverse();
       for (var i=0; i<processArray.length; ++i) {
         var blockItem = document.createElement('li');
         blockItem.className = 'jxLmanLayer';
@@ -226,7 +242,7 @@
     for (var i=0; i<nLayers; ++i) {
       aIds[i] = this.childNodes[i].id.split('_');
       var index = parseInt(aIds[i].pop());
+      if (map.bLayersReversed && ul.bLayerChanged === false) {
         index = nLayers - (index+1);
       aLayerIndex.push(index);
@@ -240,7 +256,8 @@
       node.id = aIds[i].join('_');
       node.childNodes[1].checked = node.layer.isVisible()
       aLayerIndex.reverse();
     map.reorderLayers(aLayerIndex);
@@ -265,6 +282,33 @@
     } else {
       layer.hide();
+  updateSessionMapFile: function(){
+    // get map
+    var map = this.getMap();
+    var aMaps = map.getAllMaps();
+    var currentMap = aMaps[0];
+    var sessionId = aMaps[0].getSessionID();
+    // get all layers
+    var oLayers = currentMap.aLayers;
+    var aLayerNames = [];
+    var visibleLayers = [];
+    for(var i=0;i<oLayers.length;i++){
+        aLayerNames.push(oLayers[i].layerName);
+        if(oLayers[i].visible == true){
+            visibleLayers.push(oLayers[i].layerName);
+    // prepare ajax req
+    var params =  '&session='+sessionId+'&mapname='+ this.getMap().getMapName()+'&visLayers='+visibleLayers+'&layers='+aLayerNames;
+    var options = {parameters: params};
+    // fire the request no need to return
+    var m = this.getMap().aMaps[0];
+    var url = 'layers/' + m.arch + '/' + Fusion.getScriptLanguage() + "/updateSessionMapFile." + Fusion.getScriptLanguage()
+    Fusion.ajaxRequest(  url, options);
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js	2009-10-15 20:33:15 UTC (rev 1945)
+++ trunk/widgets/Legend.js	2009-10-15 20:34:05 UTC (rev 1946)
@@ -460,7 +460,7 @@
         layer.legend = {};
         layer.legend.parentItem = folder;
         layer.legend.currentRange = null;
-        layer.registerForEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, OpenLayers.Function.bind(this.layerPropertyChanged, this));
+        layer.oMap.registerForEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, OpenLayers.Function.bind(this.layerPropertyChanged, this));
     layerPropertyChanged: function(eventID, layer) {
More information about the fusion-commits mailing list
