[fusion-commits] r1952 - trunk/widgets/Redline
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Oct 26 11:48:19 EDT 2009
Author: chrisclaydon
Date: 2009-10-26 11:48:18 -0400 (Mon, 26 Oct 2009)
New Revision: 1952
   trunk/widgets/Redline/Redline.css
   trunk/widgets/Redline/Redline.php
Fixes #286 - Arrange draw elements vertically instead of horizontally
Modified: trunk/widgets/Redline/Redline.css
--- trunk/widgets/Redline/Redline.css	2009-10-26 05:21:43 UTC (rev 1951)
+++ trunk/widgets/Redline/Redline.css	2009-10-26 15:48:18 UTC (rev 1952)
@@ -16,6 +16,7 @@
 #RedlineWidget td,
 #RedlineWidget th {
   text-align: left;
+  vertical-align: text-top;
   font-size: 12px;
   padding: 2px 10px;
   margin-bottom: 30px;
@@ -24,6 +25,7 @@
 #RedlineWidget th {
   font-weight: bold;
 #RedlineWidgetFeatureList {
Modified: trunk/widgets/Redline/Redline.php
--- trunk/widgets/Redline/Redline.php	2009-10-26 05:21:43 UTC (rev 1951)
+++ trunk/widgets/Redline/Redline.php	2009-10-26 15:48:18 UTC (rev 1952)
@@ -41,8 +41,8 @@
         $fileUpload = true;
         $target_path = tempnam(sys_get_temp_dir(), preg_replace("/\.[^\.]+$/", "", basename( $_FILES['uploadedfile']['name'])).'_');
-        if (file_exists($target_path)) {
+        if (file_exists($target_path)) {
             unlink($target_path);
         $target_path = $target_path.'.gml';
@@ -77,13 +77,13 @@
             document.body.appendChild(div);
             <? if (isset($noFile)) {  echo "alert('Please select a file.');"; } ?>
       </script>
       <h1>Digitizing Options</h1>
       <table id="RedlineWidgetOptions" borders="1">
       <tr>
       <th>Select Layer: </th>
       <td>
@@ -102,11 +102,11 @@
         <th>Draw:</th>
         <td>
           <input id="RedlineWidgetPointRadio" type="radio" name="RedlineWidgetDrawRadio"/>
-          <label for="RedlineWidgetPointeRadio">Point</label>
+          <label for="RedlineWidgetPointeRadio">Point</label><br/>
           <input id="RedlineWidgetLineRadio" type="radio" name="RedlineWidgetDrawRadio"/>
-          <label for="RedlineWidgetLineRadio">Line</label>
+          <label for="RedlineWidgetLineRadio">Line</label><br/>
           <input id="RedlineWidgetRectangleRadio" type="radio" name="RedlineWidgetDrawRadio"/>
-          <label for="RedlineWidgetRectangleRadio">Rectangle</label>
+          <label for="RedlineWidgetRectangleRadio">Rectangle</label><br/>
           <input id="RedlineWidgetPolygonRadio" type="radio" name="RedlineWidgetDrawRadio"/>
           <label for="RedlineWidgetPolygonRadio">Polygon</label>
         </td>
@@ -149,13 +149,13 @@
         </td>
       </tr>
       </table>
     </body>
   </html>
 <?php
 function returnFile($filename) {
 header("Content-type: text/xml");
More information about the fusion-commits mailing list
